Results 1 to 10 of 11
Thread: P2099 still after changing everything
    Dec 2015
    Hi all I have a 2.0 tdi transporter 2011 which has fault code P2099. but I've changed everything N75 valve, all vac pipes, boost pressure sensor, map sensor , air flow sensor, EGR valve, turbo charger, turbo pipe seals , intercooler, eco, engine wiring loom exhaust system , DPF .... it goes into limp mode in third gear at 3500rpm. if I reset the fault code with vag-com and drive it you can get it to fault again easily but if you disconnect the battery you can drive it for about 100 miles before it faults again... I understand that they read the problem a few times before it will show as a fault but I thought a fault code delete would do the same ..( do I need to calibrate the electric turbo actuator and how do I record boost so I can see what's happening with actual over requested...... any ideas much appreciated
    Fully loaded vw eos exclusive ..
    Oct 2017
    Northwest UK
    Please post an autoscan.
    It sounds like a break in the engine bay wiring loom ‘somewhere’.
  3. Likes Uwe, Jack@European_Parts liked this post
    Is it a positive or negative deviation target failure?
    Please advise with scan as aforementioned.
    Could you do some or have you done logs of requested boost versus actual & after a DTC reset & log + drive it till it faulted, do you have that data?
    Are you saying you are experimenting with deleting codes in the flash diagnostic stack?
    Dec 2015
    Already changed it...
    Still no scan and log sigh...........
    Dec 2015
    Hi I don't know how to do a log.. I'm not experimenting just trying to sort it
    Well if you want help here you are going to have to conform or by all means keep changing parts, if you want help, post the data, okay?
    We are not experimenting we are testing,you are parts changing are you not?
    Are you making too much boost ( positive ) or too little boost ( negative ) ?
    Here is how......
    Here is how to log data...
    https://www.ross-tech.com/vcds/tour/logging.php
  9. #8
    Dec 2015
    The Vehicle in question is in my garage which isn't need my home so I can't post a full scan until Saturday but please don't stop giving your thoughts as im getting very close to sorting it with a match.. if somebody could tell me how to do a boost log it would be most appreciated .... thanks
  10. #9
    Dec 2015
    Thanks very much .. P2099 is low boost..
  11. #10
    Did you know that is a great big NOPE, not always, it means "control range not reached" and is that control range deviation "positive or negative" & before limp mode commences, that is what the scan will say, as will the log determine not just the P code?
    How to log is again as aforementioned here.... https://www.ross-tech.com/vcds/tour/logging.php
  12. Likes myounus liked this post
