Results 1 to 9 of 9
Thread: Error related to ABS Module Replacement on Golf 7
    Sep 2015
    Australia
    Hi Folks,
    I have a 2015 Golf 7 GTI (Australian Delivered) that came in with a faulty ABS controller. I did not get to see teh car when it first came in, but the ABS module was non-responsive and couldn't read. A replacement unit was obtained, installed and coded online with ODIS, but was the wrong part number and so there were a few faults that couldn't be cleared. One of those was the indirect TPMS.
    I looked into it and obtained the correct module and coded the car based upon the coding suggested by ODIS, but it still had issues. I took a look at the fantastic spreadsheet for the Mk100 Conti ABS from one of the forum members and was able to adjust the coding to suit, but there are still 3 errors that I can't clear.
    I have posted a scan of the vehicle after having spent some time getting all visible faults cleared and there remain just these 3. They don't appear to affect the car and show no lights on the dash, but I would like to clear them nonetheless. I hate faults, even cosmetic ones. I don't know if someone has flashed or modified any of the modules in this vehicle to cause these errors to show.
    01 Engine - 17178 - Databus U1123 00 [039] - Received Error Message (Likely a result of the errors in Modules 03 and 17)
    03 ABS - 8314 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [009] - - [FCAN: Coding of ESP and TSK does not fit together]
    17 Instruments - 16776969 - Databus U1121 00 [009] - Missing Message [LDW_02 keine Kommunikation]
    This Vehicle does not have LDW and I'm not sure what TSK is (Traction Control ?)
    It's a fairly basic spec GTI. Anyway, scan below and hoping someone can shed some light on these issues.
    Regards
    Steve
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 42 44 52 5F A9
    VIN: WVWZZZAUZFW307500   Mileage: 85736km-53273miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0010
       Revision: --H13---
       Coding: 0A1D00324424050B2000
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ECM20TFS0215G0906259 001014
       ROD: EV_ECM20TFS0215G0906259.rod
       VCID: 6B83C14D130EA453969-803E
    17178 - Databus
                        Mileage: 85736 km
                        Date: 2020.06.30
                        Time: 21:32:40
                        Engine speed: 807.75 /min
                        Normed load value: 9.0 %
                        Coolant temperature: 100 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 13.242 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                        SEG_AD_MMV_ER_L[3]: 6.5308 ‰
    Readiness: 1010 0001
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4512
       Revision: 05853104    Serial number: TFK01503021878
       ROD: EV_TCMDQ250021.rod
       VCID: 290FFB45D9727643245-807C
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60795000000467
       Coding: 01FA93A134202973077C060041C3A980C92C94E0608295F7004200B8C209
       Shop #: WSC 01234 564 99999
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 48C95EC16238AF4BDBB-801C
              P1647 00 [009] - -
                        Reset counter: 11
                        Mileage: 85736 km
                        Date: 2020.06.30
                        Time: 21:32:40
       Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
       Revision: 00001K08
       Coding: 00120004200100001005004012101400
       VCID: 698FBB4519F2B643E45-803C
       Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
       Component: BCM MQBAB M   H18 0137
       Serial number: 01011507500355
       Coding: 03001842C24102FB0BA44080B10403281000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7DA7FF157D7A3AE338D-8028
       Component: WWS    150304  042 0551
       Serial number:         150312142626
       Component: RLHS  037 0059
       Serial number: S5Y15M03D24H19M41S45
       Coding: 90A8DD
       Serial number: 000000000ZY1504810GW
       Serial number: 00000000000061848033
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391507704779
       Coding: 0031151011
       VCID: 3D273F153DFAFAE378D-8068
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H16 0115
       Serial number: 14021541350200
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76B5E039584C69BB797-8022
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0HAASU
       Coding: 98CCC000000000005C00000000C800000065
       VCID: 41DF43E541029E031C5-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 803 15
       Serial number: 35767000000E9174731V
       Subsystem 2 - Part No SW: -----------    HW: 480 001 803 15
       Serial number: 358670000006F86DB316
       Subsystem 3 - Part No SW: -----------    HW: 480 401 903 15
       Serial number: 3516502C319EFD21026E
       Subsystem 4 - Part No SW: -----------    HW: 480 401 903 15
       Serial number: 3526502C519EFD20421F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 903 15
       Serial number: 3556502C719EFD23F35$
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150316400760
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDB451D37F6E8F36A1-806A
       Part No SW: 5G1 920 756     HW: 5G1 920 756
       Component: KOMBI         301 4310
       Coding: 27AD090873800008000F7A001400000000000000
       VCID: 6A8DC4491CF4BD5BEDF-803E
    16776969 - Databus
                        Reset counter: 11
                        Mileage: 85736 km
                        Date: 2020.06.30
                        Time: 21:32:36
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1204
       Revision: --------    Serial number: 0003284662
       Coding: 030100342F085900EF0002689C0F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 71BFD32531224E83AC5-8024
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150000592870025126
       Coding: 29FFFF
       Serial number: 6681136003
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 100315BC912028
       Coding: 003E02208001040000000000
       VCID: 42DD4CE94404851B05F-8016
       Serial number: 00000000000005555441
       Coding: 0D0000
       Coding: 8103
       VCID: 372B2D3D1FC6D0B3A21-8062
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 070315BC702482
       Coding: 003E02208E01040000800000
       Serial number: 00000000000005589007
       Coding: 150000
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
       Component: MU-S-N-ER     041 0430
       Serial number: V1F02203150415
       Coding: 02730008FF00000011510001000900001F0203960100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 270BFD7DCF664033321-8072
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9RS407BVG
       Subsystem 2 - Part No SW: 5G0 919 866 R    HW: -----------
       Component:  ROW 2015  --- 0031
       Serial number: 150307200488
    End----------(Elapsed Time: 01:38, VBatt start/end: 13.1V/13.1V)-----------
    Sep 2015
    Australia
    Vehicle Data Sticker is as follows:
    _______________________________
    WVWZZZAU Z FW307500
    5G1 9TY
    Golf 2.0 GTIBM
    162 KW TSI D6F
    CHHB QSJ
    LC9A-------- TW
    B0R CC1 G1A H7D J0T D60 Q4P
    - 1AZ 1G9 2FW 1NL 5RV 5SJ TP6
    0BG 3S0 3U1 QI4 I8D 8GU 8ZH
    1KV 1ZB - G06 7MM
    0Y2 4UH 4X3 4R4 4K3 N2T 5MR
    8RM 2JG E0A 0AE 0BG 2UJ 2G7
    UB1 L39 0YD
    Oct 2017
    Northwest UK
    If you go to adaptations in 17 and search for LDW you can deactivate the adaptation that may be active.
    I’m not sure what tsk is either. I’ll need to check my abs to see if it has it
  4. Likes Uwe liked this post
    Sep 2015
    Australia
    I looked at the adaptations on 01, 03 and 17 and on 03 had any LDW related coding. All off.
    Also 17 hasn't got any coding ticked for any LDW related functions.
    Adaptations for 17 - Instruments
    IDE00295-Oil temperature display	On 	1
    IDE00301-Distance	85736 km	3
    IDE00342-ESI: Resetting ESI	Warning active 	1
    IDE00343-Language version	English 	1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
    IDE00499-Display correction of consumptions and operating range	100%	1
    IDE00500-Hour	21 H	1
    IDE00501-Minute	51 min	1
    IDE00502-Year	2020 yr	2
    IDE00503-Month	6 mon	1
    IDE00504-Day	30 d	1
    IDE00510-ESI: distance driven from inspection	50666 km	3
    IDE00511-ESI: time from inspection	956 d	2
    IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
    IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
    IDE00514-ESI: maximum value of time between inspections	730 d	2
    IDE00515-ESI: oil quality	poor oil quality 	1
    IDE00517-ESI: soot entry	0 km	2
    IDE00518-ESI: thermal load	106600 km	2
    IDE00711-Trip recorder	not installed 	1
    IDE00819-Day counter	1910 d	2
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE00827-ESI: minimum value of time between inspections	365 d	2
    IDE01153-SIA: maximum value of distance to service	15000 km	2
    IDE01154-SIA: maximum value of time to service	365 d	2
    IDE02489-Display depiction	Version 2 	1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
    IDE03329-Driving profiled for range remaining	8.3 l/100km	2
    IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
    IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy 	3
    IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
    IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
    IDE03346-MAS02957-Units adjusted-Time	24h 	3
    IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
    IDE03346-MAS03034-Units adjusted-Pressure	psi 	3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
    IDE03348-MAS01456-Speed warning-Speed	120	2
    IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
    IDE03348-Speed warning-	not active 	2
    IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
    IDE03350-FIX: Maximum time until next time-dependent inspection	365 d	2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	67600 km	2
    IDE03352-FIX: Time since last time-dependent inspection	1165 d	2
    IDE03372-Source for synchronization of time	GPS 	1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
    IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
    IDE03867-Deactivate seat belt warning	Yes 	1
    IDE04169-Display correction of consumption and operating range: gas	100%	1
    IDE05930-Service notification in days	30 d	1
    IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
    IDE05932-FIX: Reset value for next time-dependent inspections	365 d	2
    IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06588-Ignition active message: actuator	Driver door 	1
    IDE06922-No-voltage display	Unknown (2)	1
    IDE07221-Cylinder shut-off	Display 	1
    IDE08140-Driving profiled for range remaining CNG	6.0 kg/100 km	2
    IDE08247-Driving profile for range remaining LPG	10.0 l/100km	2
    MAS03555-Lap counter	Display 	1
    MAS03685-Digital speedometer	Display 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
    ENG119875-defuel_threshold	45 l	1
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32	12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66	12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC 	12
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0	12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5	12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14	12
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17	12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32	12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46	12
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32	12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64	12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3	12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3	12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	8	12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	20	12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55	12
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96	12
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5	12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5	12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C 	12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17	12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32	12
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E 	20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41 	20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96	12
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1	12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1	12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7	12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12	12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E 	12
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
    ENG119874-Gas_functionality	not active 	1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
    ENG119882-init_fuel_algorithm	No 	1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
    ENG119825-Picture_Upload_Download	not active 	1
    ENG119876-Service_Key_Clear_All_Counter	Yes 	1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	30 s	18
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
    ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
    ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
    ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
    ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
    ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
    ENG112418-ENG99298-total_range_gas-State	not active 	4
    Adaptations for 03 ABS
    IDE00001-Production mode	not active 	3
    IDE00252-Brake system vacuum pump	5	1
    IDE00820-Activating and deactivating all development messages	0	1
    IDE01763-Dimming	activated 	1
    IDE02332-Deactivate production mode	Deactivating 	3
    IDE03493-Driver door status	activated 	1
    IDE03659-Roller test bench mode	Manual activation: possible 	1
    IDE04456-Brake disk drying	Medium 	1
    IDE04508-Hydraulic brake booster	8	1
    IDE04643-Overboost in brake system	activated 	1
    IDE04645-IDE05287-Electromechanical parking brake-Automatic application	activated 	2
    IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal	not activated 	2
    IDE04765-Counter steer support	Strong 	1
    IDE04774-Vehicle and trailer stabilization	not activated 	1
    IDE04871-Dynamic starting assist	normal 	1
    IDE04939-Tire pressure monitoring display	2	1
    IDE04944-Brake pedal evaluation	activated 	1
    IDE04949-Engine drag torque control	activated 	1
    IDE04951-Brake booster	4	1
    IDE04952-Braking torque boost for distance regulation	3	1
    IDE05055-Hydraulic brake assistant	normal 	1
    IDE05057-Brake prefill	activated 	1
    IDE05161-Straight ahead brake stabilization	activated 	1
    IDE05263-AUTO HOLD functionality	activated 	1
    IDE05264-AUTO HOLD increase threshold: reduced tensioning force	0%	1
    IDE05265-AUTO HOLD increase threshold: full tensioning force	10%	1
    IDE05286-Expanded electronic differential lock	Standard 	1
    IDE05337-Starting vibration reduction-	Strong 	1
    IDE05337-MAS02653-Starting vibration reduction-Torque limitation	Deactivated 	1
    IDE05711-Automatic application during engine stalling	activated 	1
    IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake	7	2
    IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button	7	2
    IDE06139-AUTO HOLD slippage recognition	activated 	1
    IDE06505-Electromechanical parking brake: delay level	6	1
    IDE07006-Tire pressure monitoring display: tire selection	2	1
    IDE07565-ABS in lower speed range	activated 	1
    IDE07848-Thresholds for brake performance	activated 	1
    MAS00122-Electronic Stability Program	activated 	1
    MAS00970-Running manufacturer number	activated 	1
    MAS01180-AUTO HOLD functional status	Last setting 	1
    MAS01299-Offroad	0	1
    MAS02080-XCP calibration protocol	not activated 	1
    MAS02138-Hill-start assistant	normal 	1
    MAS02666-Seat belt buckle scan	activated 	1
    MAS08145-Hill-start assistant: increase threshold	3%	1
    MAS09008-MAS00988-Plausibility check-Reverse gear	activated 	3
    MAS09008-MAS09009-Plausibility check-Neutral gear sensor	activated 	3
    MAS09008-MAS10668-Plausibility check-Clutch movement	activated 	3
    ENG118148-Developer_Function_1	0	1
    ENG130301-Developer_Function_121	not activated 	1
    ENG122844-ENG101574-dimming_characteristic_1-X1	0	12
    ENG122844-ENG99557-dimming_characteristic_1-X2	50	12
    ENG122844-ENG102140-dimming_characteristic_1-X3	220	12
    ENG122844-ENG102936-dimming_characteristic_1-X4	6	12
    ENG122844-ENG103548-dimming_characteristic_1-X5	8	12
    ENG122844-ENG113992-dimming_characteristic_1-X6	80	12
    ENG122844-ENG99777-dimming_characteristic_1-Y1	10	12
    ENG122844-ENG100480-dimming_characteristic_1-Y2	100	12
    ENG122844-ENG100773-dimming_characteristic_1-Y3	253	12
    ENG122844-ENG100631-dimming_characteristic_1-Y4	6	12
    ENG122844-ENG102174-dimming_characteristic_1-Y5	12	12
    ENG122844-ENG113993-dimming_characteristic_1-Y6	100	12
    ENG122845-ENG101574-dimming_characteristic_2-X1	0	12
    ENG122845-ENG99557-dimming_characteristic_2-X2	50	12
    ENG122845-ENG102140-dimming_characteristic_2-X3	220	12
    ENG122845-ENG102936-dimming_characteristic_2-X4	6	12
    ENG122845-ENG103548-dimming_characteristic_2-X5	8	12
    ENG122845-ENG113992-dimming_characteristic_2-X6	80	12
    ENG122845-ENG99777-dimming_characteristic_2-Y1	10	12
    ENG122845-ENG100480-dimming_characteristic_2-Y2	100	12
    ENG122845-ENG100773-dimming_characteristic_2-Y3	253	12
    ENG122845-ENG100631-dimming_characteristic_2-Y4	6	12
    ENG122845-ENG102174-dimming_characteristic_2-Y5	12	12
    ENG122845-ENG113993-dimming_characteristic_2-Y6	100	12
    May 2017
    Lane departure warning is coded in instruments. Uncheck that and the error is gone.
    For the ABS, now not 100% sure but the error might be due to incorrect engine type coding in ABS. Should be gasoline and is now diesel.
  7. Likes Uwe liked this post
    Oct 2017
    Northwest UK
    I think it’s complaining that traction control and esp and both coded, but not 100%. I think you might be right too, need to check ODIS for original coding
    Steve: G'day cobber - man you were up early this morning!!
    Here's how your long code string for the hex17 module looks in a more readable form:
    Byte	Hex	Binary
    0	27	00100111
    1	AD	10101101
    2	09	00001001
    3	08	00001000
    4	73	01110011
    5	80	10000000
    6	00	00000000
    7	08	00001000
    8	00	00000000
    9	0F	00001111
    10	7A	01111010
    11	00	00000000
    12	14	00010100
    13	00	00000000
    14	00	00000000
    15	00	00000000
    16	00	00000000
    17	00	00000000
    18	00	00000000
    19	00	00000000
    So in Byte 4, Bit 6 is set which enables Lane Assistance and Bit 4 is set which enables Wheel Dampening Electronics
    I suspect that your car has neither function
    EDIT: Ooops - and...... apropos of the TPMS matter, there aren't any related VAG codes in your 2nd post (i.e. the 7Kxx PR codes - 7K0 means "Without direct tire pressure monitoring system").
    Anyhow, Byte 27 on the ABS module on your auto-scan has the value hexB8 (or, binary 10111000). As you can see, Bit 4 and Bit 5 is set - according to my records, this aligns with PR 7K9 (Indirect tire pressure monitoring system). If the car doesn't have TPMS - try removing Byte 27, Bits 4 and 5
    And... again according to my records, Byte27, Bit 7 enables DCC - but the list in your 2nd post doesn't include the related PR code 2I0. - perhaps try removing Bit 7
  10. Likes Uwe liked this post
  11. #8
    Sep 2015
    Australia
    Hey Don, old habits staying up to ungodly hours doing research on corner case issues.
    I'll check the coding on the instruments as per your suggestions and report back. The car definitely has DCC or similar as per the initial scan with module 14 - suspension electronics. But no lane assist or lane departure warnings.
    I should definitely get into the habit of reading and displaying the coding as you have done and find the references for all of the esoteric bit functions. It would make life easier when troubleshooting things like Xenon retrofits across models and specifications.
    The car has indirect TPMS. I have a number of scans from other Golf's I have worked on, but none of them align exactly to this one.
    So for instruments - 17, I'll set Byte 4, bit 6 to 0 and check the subsequent behaviour.
    And for abs - 03 - I've tried a few variations on the higher bytes, but I don't know what TSK is nor where it is set in ABS. But it's definitely going to be the ABS coding.
    Thanks for the replies from everyone.
  12. #9
    Sep 2015
    Australia
    Ok, So I worked out I'm either blind or foolish or both. LDW was ticked (very obviously) in 17 - Instruments, but for whatever reason, I didn't see it that way.
    Oh well, even when you triple check something, it may be missed. The tip about Byte 4, Bit 6 was great and allowed me to zero in on the coding location. I'll just go bang my head against a wall somewhere to knock some sense into it.
    I also obtained the coding from another Mk7 GTI with the same spec and I just need to get back to the customer car to try the coding for 03 ABS.
    The coding differences are represented below using my quick method:
    Coding for 03 ABS
    Byte Ref
    Byte
    Current coding applied
    Factory original coding for a similar vehicle
    Differences
    15    16    17 ID 18 ID 19 ID 20 ID 21 ID 22 00 02 04 06 08 10 12 14
    00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
    01 FA 93 A1 34 20 29 73 07 7C 06 00 41 C3 A9 80 C9 2C 94 E0 60 82 95 F7 00 42 00 B8 C2 09
    01 FA 93 A1 34 28 29 6C 03 7D 06 08 C1 C9 A9 80 C9 2C 94 C0 60 83 95 F7 00 42 00 B8 C1 09
                             x          x                    x      x                    x
    And worked out using the bits
    Byte	Hex	Binary		Description			Binary	Hex		Note
    00	01	0000 0001	VW Golf (5G1)(AU1)(BQ1)		01	0000 0001	Same
    01	FA	1111 1010	VW Golf (Australia)		FA	1111 1010	Same
    02	93	1001 0011	2019 Golf R (RHD)		93	1001 0011	Same
    03	A1	1010 0001	VW Golf				A1	1010 0001	Same
    04	34	0011 0100	312mm Front Brakes		34	0011 0100	Same
    05	20	0010 0000	VIN 13th Digit + 20		28	0010 1000	VIN N/A
    06	29	0010 1001	Golf GTI Not Listed in SS	29	0010 1001	Same
    07	73	0111 0011	VIN 14th Digit + 6C		6C	0110 1100	VIN N/A
    08	07	0000 0111	EPB + Autohold + ??		03	0000 0011	Bit 2 Diff
    09	7C	0111 1100	VIN 15th Digit + 77		7D	0111 1101	VIN N/A
    10	06	0000 0110	FWD (RoW)			06	0000 0110	Same
    11	00	0000 0000	VIN 16th Digit + 0 		08	0000 1000	VIN N/A
    12	41	0100 0001	Golf GTI Not Listed in SS	C1	1100 0001	Bit 7 Diff
    13	C3	1100 0011	VIN 17th Digit + C3		C9	1100 1001	VIN N/A
    14	A9	1010 1001	Golf GTI Not Listed in SS	A9	1010 1001	Same
    15	80	1000 0000	Mirror Byte 00			80	1000 0000	Same
    16	C9	1100 1001	Mirror Byte 02			C9	1100 1001	Same
    17	2C	0010 1100	Mirror Byte 04			2C	0010 1100	Same
    18	94	1001 0100	Mirror Byte 06			94	1001 0100	Same
    19	E0	1110 0000	Mirror Byte 08			C0	1100 0000	Diff
    20	60	0110 0000	Mirror Byte 10			60	0110 0000	Same
    21	82	1000 0010	Mirror Byte 12			83	1000 0011	Diff
    22	95	1001 0101	Mirror Byte 14			95	1001 0101	Same
    23	F7	1111 0111	AH, XDS, MCB, EB, S/S, DSR	F7	1111 0111	Same
    24	00	0000 0000	No ACC/FrAss/AEB/PLA3/Trailer	00	0000 0000	Same
    25	42	0100 0010	HillStart/DQ/EPB + 2.L Gas	42	0100 0010	Same
    26	00	0000 0000	Wheel Speed Sensors		00	0000 0000	Same
    27	B8	1011 1000	TPMS Passive With Radio + DCC	B8	1011 1000	Same
    28	C2	1100 0010	Driver Out + BAP ESC/TPMS	C1	1100 0001	Bit 0/1 Diff
    29	09	0000 1001	ESC Conf			09	0000 1001	Same
  13. Likes Uwe liked this post
