Possible CAN-BUS issues? Sporatic Communication Issues
Allen Vos
Canada
C?ID=384301
So Ive been having some issues with the car here for some time and have been unsuccessful at figuring it out.
My ABS module intermittency loses the steering angle sensor and sets the 01826 steering angle code.
I know it normally means the rack with the steering sensor needs to be changed, so Ive installed 2 used racks and have put 4 used ABS moudles in the car and the issue stiil exists.
Over the weekend I hooked up VCDS to do an auto scan and came up with numerous errors and codes as well as sporadic communication errors.
Now as soon as I started the car and redid the auto scan, all these error's disappeared.
I am starting to think my issues are due to CAN Bus issues but I'm not sure?
Does anyone have ideas on this one?
 Saturday,27,June,2020,13:14:07:33238
VIN: 3VWTL71K89M263079   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWTL71K89M263079   Mileage: 273980km-170243miles
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
1C-Position Sensing -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 N    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000SG  8680
   Revision: 12H01---    Serial number: VWX7Z0H524I095
   Coding: 0050072
   Shop #: WSC 84224 299 591528
   VCID: 3D273EB08179B38378D-8068
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 273957 km
                    Time: 06:42:38
                    RPM: 828 /min
                    Temperature: 43.2°C
                    Temperature: 92.7°C
                    Temperature: 27.0°C
                    Lambda: 63.1 %
                    Lambda: 0.0 %
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Revision: 00H45001
   Coding: 113B400D492700FE880C02E9921D00423000
   Shop #: WSC 41669 001 104857
   VCID: 7EA5F9BCC0FF689B217-802A
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70B9D78486AB0EEBA3B-8024
   Revision: 00H54000    Serial number: 00000009264211
   Coding: 10018E234004100007140000001400000008730B5C000120000000000000
   Shop #: WSC 53316 000 1048576
   VCID: 323D1D8C48277CFB95F-8066
   Component: Wischer 190309 021  0501
   Coding: 00038805
   Shop #: WSC 53316
8 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
                    Fault Status: 00111001
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
00834 - Signal for Activation of Heated Rear Window
                    Fault Status: 00101001
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
                    Reset counter: 89
                    Mileage: 273667 km
                    Voltage: 12.65 V
   Revision: 00000000    Serial number: AUZ4Z7I0532598
   Coding: 0000102
   VCID: 33331888B73D75F39E9-8066
00003 - Control Module
                    Fault Status: 00101110
                    Reset counter: 6
                    Mileage: 36521 km
                    Time: 14:55:18
                    Reset counter: 45
                    Mileage: 273357 km
                    Time: 14:35:11
01304 - Radio
                    Reset counter: 57
                    Mileage: 273869 km
                    Time: 22:06:04
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 2U AIRBAG VW8R  038 8600
   Revision: 07038000    Serial number: 003E7M08Y5PW
   Coding: 0012885
   VCID: 6D87CEF09199E30388D-8038
   Subsystem 1 - Serial number: 6332MSME43511211W
   Subsystem 2 - Serial number: 6342MSME4454272FF
   Subsystem 3 - Serial number: 6351HSME1C0C494FO
   Subsystem 4 - Serial number: 6361HSME1B790871C
   Subsystem 5 - Serial number: 63727SME1B74466BA
   Subsystem 6 - Serial number: 63827SME1B751E617
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0000331
   VCID: 76B5E19CE4CF20DB797-8022
   Part No SW: 1K0 920 874 D    HW: 1K0 920 874 D
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0005000    Serial number: VWX7Z0I224B0EN
   Coding: 0023303
   VCID: 2E0509FC5C1F581BF17-807A
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:08:13
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:05
   Revision:   H07 01    Serial number: 180209F2001694
   Coding: E9807F06001702001002
   VCID: 372B2C98A34599D3A21-8062
11 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:08:14
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:08:14
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:02
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:01
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:01
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:01
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:01
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:01
01304 - Radio
                    Reset counter: 45
                    Mileage: 273357 km
                    Time: 14:37:02
                    Reset counter: 45
                    Mileage: 273357 km
0                    Date: 2000.00.00
                    Time: 14:37:02
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 89
                    Mileage: 273667 km
                    Time: 00:00:05
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T413504
   Coding: 0000003
   VCID: 392F2AA095518FA3545-806C
   Component: IMMO            3HL 2418
   Revision: 72009005    Serial number: 00000805689208
   Coding: 0001205
   VCID: 6FBBD4F89B951113BA1-803A
                    Fault Status: 00100101
                    Reset counter: 91
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Frequency: 54
                    Reset counter: 61
                    Mileage: 273357 km
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A0D05EC60F7343B2DF-807E
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 13900F880106281B0904058FB0880F0488FC00
   Shop #: WSC 03285 999 14509
   VCID: 71BFD2808DA107E3AC5-8024
   Revision: 72009005    Serial number: 08120722582603
   Coding: 0001204
Address 56: Radio
   Revision: 12006001    Serial number: 00000003800031
   Coding: 0001168
   Revision: 12006001    Serial number: 00000003874453
   Coding: 0001168
   VCID: 77ABEC98E3C559D3621-8022
Address 77: Telephone
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
On an 11 year old car with 170,000 miles, it sure couldn't hurt to take pull apart the relevant electrical connectors at control modules, inspect them and the related wiring, and apply some contact conditioner such as DeoxIT or Stabilant 22.
You may also have harness rot somewhere.
Allen Vos
Canada
C?ID=384301
Thanks for your response Uwe, so I have no issue checking and applying contact cleaner to the modules.
I did get looking at some wiring diagrams, and specifically the CAN/Bus and computer data lines, as I'm assuming this is more than likely where the problem lies?
So looking at the CAN Bus module there are 3 separate sets of data lines running to it.
What I expected to see was my problem modules all on one set of wires, but that was not the case
So here is what I found.
First pair of data wires -
All 4 door modules
steering column module
climatronic control module
Comfort system central control module
Vehicle Elecrical system control module
Second set of data wires
PCM
Power steering control module
ABS
Air bag module
Transmission control module
Third set of Data wires
Vehicle position Recognition module
radio
telephone.
So looking at all this, my modules that are giving sporadic communication codes are power steering module, Central control module for convenience, all 4 door modules, Vehicle Position Recognition Control Module
It makes sense that I am seeing the sporadic communication issues with the power steering control module as I am losing steering angle to the ABS module intermittently.
What interesting is the instrument cluster codes only showed the Power steering module and the Central control module for convenience and nothing else?
Its still quite possible I have harness rot but it would seem unlikely that its showing sporadic communication with multiple modules running on separate data wires though?
I also thought about the electrical system control module not sending power the the CCMC and PS module or having bad contacts so to speak causing power to intermittently drop out
Whats the possibility of just having a bad CAN BUS module?
Does anyone on here have much experience with diagnosing this intermittent stuff?
Am I even going about this the right way?
Sorry for all the posts but these intermittent issues are so hard to track down sometimes
Comfort CAN bus.
Powertrain CAN bus
Infotainment CAN bus.
They all go to the CAN Gateway too, which acts as a router for traffic between these buses, and which has an additional Diagnostic CAN bus that only goes to the OBD-II connector.
I'm not sure what else to tell you. Intermittent problems like this are a huge pain to track down.
Allen Vos
Canada
C?ID=384301
Comfort CAN bus.
Powertrain CAN bus
That very interesting to know how they divy those modules up like that.
I know this is a huge PITA, Ive been trying to put my finger on this issue for over a year now. Ive spent a lot of time on this and do appreciate all the input Ive gotten so far.
Honestly, I don't have an issue doing whatever is suggested, but I'm really trying to avoid cutting open wiring harness's and stuff.
Would you agree with me that this is definitely a CAN BUS related issue such as can bus wiring, connectors or a faulty module as opposed to powers and grounds?
TFSI
Maryland, USA
C?ID=66650
Hi Allen,
I do understand such issue can be tough and time consuming to deal with, true. Uwe provided a good suggestion of checking and cleaning connectors. From the faults types recorded, I can tell most CAN bus systems have no signal/communication. Very likely bad connection between address 19 module. Look carefully at all the socket pins for bend/corrosion or damage on this module. Have you checked for Term 30, Term.15 for voltage/voltage drop and Term31 on this unit? Have you checked all the 4 door connectors (inside the rubber grommets?) I will unplug all for inspections clean them and do circuit checks/wiring check with good multimeter. This is Volkswagen we are talking about , one of the fine German engineering with nice but sensitive electrical system so do not leave any stone unturned if you want results, no short cuts. If fault is beyond me, I will seek help of an expert.
Allen Vos
Canada
C?ID=384301
Hi Allen,
Hi TFSI, thanks for your response.
I am definitely going to get some contact cleaner first of the week and check all those connections.
Since my primary issues are the power steering module and CAN BUS module, I will be focusing on those first, which will include following the can bus part of the power steering harness connector behind the drivers headlight.
I have access to some very cheap used parts at a local pic n save, but I don't just wanna keep guessing here as Ive done enough of that.
I will be checking powers and ground at the CAN BUS module for sure.
I was just looking for some input here as I would really like to understand what is going on here before I dive in balls deep :D
Allen Vos
Canada
C?ID=384301
Comfort CAN bus.
Powertrain CAN bus
The car hasn't acted up for quite some time until this past weekend, and it was brief at that.
Is there anything I should be looking for within VCDS while its acting up?
Something that could help me trouble shoot my issue?
I'm going out on a limb here, but im assuming because the steering angle reads perfectly from the steering angle module(44) while its acting up, that its not a steering angle sensor or module issue?
DV52
C?ID=194404
Allen: I'm not sure if my approach to fault-finding will be helpful, but my first port-of-call when diagnosing problems of the type in your scan report (i.e. where multiple DTC s have the same fault descriptor) is to look for commonality in the equipment wiring. I note that the "Sporadic communications" error in your auto-scan appears across a number of modules and it's tempting to blame one of the CAN buses in Uwe's list . However, if I look at the CAN Network topography below (which you can find in SSP 891403 and which I believe is applicable to a 2009 Jetta), I find that the modules are scattered over all 3 x CAN buses.
With the caveat that anything is possible, this observation kind-of confirms Uwe's suggestion that a good starting point for investigations might be the connector on the hex19 module (what Uwe calls the CAN "router"). Whilst it's possible that the twisted CAN pairs could share a faulty section of a common part of the car's wiring loom further downstream of the module connector - it's probably prudent to substantiate the termination at the rear of the module as a first step. This done - maybe trace the CAN wires downstream of the J533 module paying particular attention to shared parts of the loom. Of course, the other option is that the car genuinely has a series of CAN wiring faults that are independent of each other - less likely, but possible IMO.
Allen Vos
Canada
C?ID=384301
Thank you for the response Don.
So to start, I had looked at the CAN BUS wiring initially as well and had noticed the modules that had been flagging the sporadic communication issues are as you said, on different circuits so to speak, so the issue of being a wiring problem in the loom is unlikely but not impossible.
I have also checked the connectors at the can bus, the ABS and power steering modules and applied the contact cleaner to them. Nothing abnormal was found and all contacts appeared clean.
Having said that, the sporadic communications codes only ever came up once in the year and a half I have owned the car.
I think the bigger issue I am fighting with is that the steering angle value drops to "0" intermittently within the ABS module and not in the Steering(44) module, causing the traction control to activate when turning
corners.
I still believe this issue to be a communication issue on the ABS modules side of things as when it acts up , as I can read and graph the steering angle value from the steering(44) module flawlessly.
I'm assuming that since I can see the steering angle value from the steering module(44), that there are no issues within the steering rack or steering angle sensor itself?
Just to recap, I have tried 3 power steering racks and 4 abs modules in the car and it has not fixed the issue
Is there anything else I should be checking within VCDS while I catch it acting up?
I'm not against cutting wiring looms open to search for bad wiring but its an absolute last resort.
Cheers
Allen
