Hello everyone i need help convert VW caddy from automatic to manual Gearbox
what is the sgo file number that can i use to flash ecu and how can i recoding the abs !
i attached full scan and advanced id for ecu
regards
regards
Monday,29,June,2020,18:48:18:06524
VIN: WV2ZZZ2KZBX227218 License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56
VIN: WV2ZZZ2KZBX227218 Mileage: 111170km-69077miles
02-Auto Trans -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FK HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9970
Revision: --H43--- Serial number: 00000000000000
Coding: 00254014032400080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023FK 003010
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 74B026578E3AB86B473-8020
6088 - No Communication with Transmission Control Module
U0101 00 [167] - -
Mileage: 111170 km
Date: 2020.06.29
Time: 04:56:03
Engine speed: 782.00 /min
Normed load value: 23.9 %
Coolant temperature: 95 °C
Intake air temperature: 42 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 13.779 V
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 60 °C
Readiness: 0110 1000
Address 02: Auto Trans
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 623C600D09240301460D06E59021C041300000
Shop #: WSC 35110 377 00159
VCID: 75B61B5385C0A16370D-8020
Reset counter: 217
Mileage: 111138 km
Date: 2014.11.20
Time: 02:28:23
Count: 3
Count: 14
Count: 29184
Count: 8195
Count: 49152
Count: 256
Count: 512
Part No SW: 7N0 907 426 HW: 7N0 907 426
Component: AC Manuell H15 0101
Revision: 00010001
Coding: 0000000002
ROD: EV_ClimaBasis_VW32.rod
VCID: 71BE2F43F1288D43AC5-8024
Part No SW: 2K5 937 086 B HW: 2K5 937 086 B
Component: BCM PQ35 M+ 011 1044
Revision: BD011001
Coding: 401A0A3A80251A6B088800829400816443517288526F8160648000000040
VCID: 3536DB53C540E163B0D-8060
Subsystem 1 - Part No: 1T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 08101 26 0512
Coding: 009795
Component: RLS 051010 05 54 0403
Coding: 0330ED
Reset counter: 217
Mileage: 111170 km
Date: 2014.11.20
Time: 04:56:02
Voltage: 13.90 V
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 L HW: 1K0 919 475 L
Component: PARKHILFE 005 1806
Revision: 00005000 Serial number: 0 263 004 450
Coding: 108101
VCID: 3B22CD6BE3643713469-806E
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag013 H06 0013
Revision: -------- Serial number: 003HN0019ZMO
Coding: 000000000000000000000000000000003133
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3332E54BCBB4FF539E9-8066
Serial number: 3495RRB405H00IUGJ9F4
Serial number: 3505RRB4065010DAEA0C
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JJD0002H
Coding: 1882160000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B41C5F9846AA7B797-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0026504
Coding: 820000
0516 - Databus
Reset counter: 217
Mileage: 111170 km
Date: 2020.06.29
Time: 04:56:02
Part No SW: 2K0 920 875 A HW: 2K0 920 875 A
Component: KOMBI H20 0420
Coding: 181A00
VCID: 2D06F3332D90A9A3C8D-8078
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Getriebe: keine Kommunikation]
Reset counter: 217
Mileage: 111170 km
Date: 2020.06.29
Time: 04:56:02
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 141010F1002559
Coding: EDA01F0600020200007400
VCID: 6D863333E19069A388D-8038
Reset counter: 217
Mileage: 111170 km
Date: 2014.11.20
Time: 04:56:03
Component: IMMO H20 0420
VCID: 6A8C382FDCFE7E9BEDF-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0000048
VCID: 48C8A2A7AEB26C8BDBB-801C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 140 3001
Revision: 00H17000
VCID: 313EEF433D28CD43EC5-8064
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000048
VCID: 47CAA19BA3AC63F3D21-8012
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: RCD310 EU H13 5042
Revision: -----05S Serial number: VWZ4Z2K1366256
Coding: 0500040002
VCID: 65964B13356051E3C0D-8030
Reset counter: 217
Mileage: 111170 km
Date: 2014.11.20
Time: 04:56:01
End----------(Elapsed Time: 00:58, VBatt start/end: 13.8V/13.8V)-----------
Monday,29,June,2020,19:05:40:06524
VCDS Version: Release 20.4.1 (x64)
Address 01: Engine
Control Module Part Number: 03L 906 023 FK
Component and/or Version: 1,6l R4 CR td H43 9970
Software Coding: 00254014032400080000
Work Shop Code: WSC 35110
Advanced Identification/FAZIT
Identification: SJ8-FST
Revision: --H43---
Date: 16.10.10
Manufacturer number: 0015
Test stand number: 0686
Flash Status
Programming Attempts(application): 2/3/2
Successful Attempts(application): 2/2/2
Programming Status: 00000000
Flash Date: 00.00.00
Misc.
Hardware number: 03L 907 425 C
Workshop System Name: J623
ASAM Dataset Revision: 003010
Car Info
Chassis Number: WV2ZZZ2KZBX227218
Engine code: CAYD
VCDS Info:
Labels: 03L-906-023-CAY.clb
Readiness: No script available
