Monday,29,June,2020,11:59:21:47653
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZGH070781 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 0D 15 17 18 19 22 25 56 5F 61 77 78 0B
VIN: WV2ZZZ7HZGH070781 Mileage: 39840km-24755miles
0D-Slide Door, Left -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0001
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KT HW: 04L 907 445 A
Component: R4 2.0l BTD H03 6176
Revision: 23101001
Coding: 0019401C432601080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KT 004008
ROD: EV_ECM20BTD03004L906056KT.rod
VCID: 094E66CC89B2E01F9EB-805C
15560 - EGR Sensor 1
P046C 00 [108] - Implausible Signal
Mileage: 39548 km
Date: 2020.06.18
Time: 12:41:04
Coolant temperature: 89 °C
Intake air temperature: 22 °C
Voltage terminal 30: 12.539 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: 2.78 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 13.16 %
Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.542 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.350 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.560 V
27277 - System Voltage
P0562 00 [032] - Too Low
Mileage: 39538 km
Date: 2020.06.18
Time: 11:43:33
Coolant temperature: 36 °C
Intake air temperature: 30 °C
Voltage terminal 30: 11.984 V
Unlearning counter according OBD: 23
Air mass at air mass meter 1: 0.0 kg/h
Standardised airflow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 3.21 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0.000 bar
Absolute intake pressure: 99 kPa abs
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 8
Index of next requested engine mode: 8
Index of engine target mode: 8
16295 - Oxygen (Lambda) Sensor B1 S1
P2238 00 [096] - Pump Current Short to Ground
Mileage: 39549 km
Date: 2020.06.18
Time: 15:51:30
Engine speed: 2248.25 /min
Normed load value: 88.6 %
Vehicle speed: 70 km/h
Coolant temperature: 94 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.820 V
Wraf state-Delphi Wraf State: WRAF_NORMAL_OPERATION
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 0.903 counts
O2 sensor 1 bank 1 dwnstrm cat.: raw value: 10.000 counts
Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.: 0.000 A
Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.056 Lambda / 0.000 V
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 43145000001250
Coding: 307E80986569847E0C7C017EA6832193790000
Shop #: WSC 02739 790 50316
VCID: 3FDAB81487F61EAFF0F-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 09111513471326
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40510C07CD7A7BB9-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 D HW: 7E0 907 040 D
Component: ClimatronicT5 H02 0508
Revision: 00001K03
Coding: 0004000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 241017780E505D778DD-8070
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0010611150015133
9480753 - Control/Display Unit for Rear Climatronic
B10AA 31 [008] - No Signal
Reset counter: 224
Mileage: 39676 km
Date: 2020.06.26
Time: 09:56:50
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 323150967
Coding: A0F6793A0A61349393288F446CEB8EF48DA4698960CC6960320403BF0840
Shop #: WSC 01362 002 1048576
VCID: 68884348B2787917615-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 231115 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU004111553087846
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU005111553090140
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 171
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 171
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29150002280080015464
Coding: B0FFFF
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02737 790 00000
VCID: 3038EB284628F1D7795-8064
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ000UN5J
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
VCID: 3828D308A2D82997315-806C
Serial number: 3495ZRB405T3FSTQJ082
Serial number: 3505ZRB40693FGI6I9FX
Part No SW: 7E0 920 980 L HW: 7E0 920 980 L
Component: KOMBI H05 1008
Coding: 170F010300
VCID: 3430E738BEB0CDF71DD-8060
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6A8C3940ACF44B07771-803E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
Mileage: 39538 km
Date: 2020.06.18
Time: 11:43:23
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00018.09.15
Coding: 0501
VCID: 54F087B81E70EDF73DD-8000
Component: IMMO H05 1008
Address 56: Radio
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 E HW: 1K8 035 150 E
Component: MU-E-D-ER 857 6495
Serial number: 29101500010338
Coding: 06570000FF00000041111101008000001F0000860000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
VCID: 270A00747F66B66FA8F-8072
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 62301H19431261914344
Address 77: Telephone
Address 78: Slide Door, Right Labels: Redir Fail!
End----(Elapsed Time: 02:01, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
