Not long ago I learned about the cam follower issue the hard way.I ended up replacing the intake cam, hpfp, cam follower,
cam position sensor & while I was in there I did the timing chain, tensioner & coolant flange. I got it back together
ran great sounded good & about 2 days later got P000A code so I parked the car and did some research and found out I
should have replaced the 3 ring seals inside the timing cover so I pulled the timing cover found the old rings laying
in there broken re-checked my timing marks installed new ring seals fired it up code gone ran great.The next morning
misfire code #2 cyl I switched coils between cyls plugs were new and switched them around misfire stays with #2 cyl did
compress check all cyls @ 200 psi. I bought VCDS I have not driven the car looking for advice and direction and help with VCDS
Wednesday,24,June,2020,17:18:57:31022
VIN: WAUAF78E57A101662 License Plate:
Mileage: 243960km-151589mi Repair Order:
67 69 75 76 77
VIN: WAUAF78E57A101662 Mileage: 243960km-151589miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH14--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 22122 444 92498
VCID: 2E050BD4EC10D79BF17-807A
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 243966 km
RPM: 1110 /min
Load: 33.7 %
Temperature: 45.0°C
Temperature: 39.0°C
Absolute Pres.: 900.0 mbar
Voltage: 13.589 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
Mileage: 243966 km
RPM: 993 /min
Load: 37.6 %
Temperature: 45.0°C
Temperature: 39.0°C
Voltage: 13.589 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0020
Revision: 00000012 Serial number: 00000002101143
Shop #: WSC 02073 002 1048576
VCID: 323D1FA4F828F37B95F-8066
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Coding: 0004525
Shop #: WSC 06325 000 00000
VCID: 2C0101DCDA0CA58BDF3-8078
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x019A
Hex Value: 0x0000
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 6C81C1DC1F9C658B9F3-50D0
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D273C9834663C0378D-4AA4
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0CK71
Coding: 0032607
VCID: 3C21319C2A6C350B4F3-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3ARMA
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB403C91113Dÿ†63
Subsystem 5 - Serial number: 91113Dÿ†6342DRB403DC8928$ÿ†63
Subsystem 6 - Serial number: C8928$ÿ†6352ARB400E7935BVÿ†63
Subsystem 7 - Serial number: 7935BVÿ†6362ARB400E5351EPÿ†63
Subsystem 8 - Serial number: 5351EPÿ†63729RB4018B75A2Rÿ†63
Subsystem 9 - Serial number: B75A2Rÿ†63829RB40189BADC5ÿ
Subsystem 10 - Serial number: 9BADC5ÿ
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
Fault Status: 00100011
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04041
Shop #: WSC 06325
VCID: 41DF4068489E58E31C5-4AA4
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H14 0120
Revision: 0120 Serial number: 00000000000000
Coding: 0022261
Shop #: WSC 33467 512 00000
VCID: 2E050BD4EC00D79BF17-50F4
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0022261
01304 - Radio
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11820
Shop #: WSC 06325
VCID: 78A9ED8C5BC4D92B6BB-4AA4
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
00955 - Key 1
35-00 - -
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290FF8C8D5FEB0A3245-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH03 0020
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H25 0290
Revision: 00000000 Serial number: 00000005005351
Coding: 0001677
VCID: 3D273C9831663C0378D-50D0
01304 - Radio
Reset counter: 177
Time Indication: 15
End----------(Elapsed Time: 05:16, VBatt start/end: 12.3V/12.3V)-----------
Wednesday,24,June,2020,19:38:31:31022
Mileage: 243960km-151589mi Repair Order: 13
Address 01: Engine (8E0 910 115 P)
19:38:25 Group 002: General
720 /min Engine Speed (G28)
33.1 % Engine Load
1.53 ms Injection Timing
5.28 g/s Mass Air Flow Sensor (G70)
19:38:39 Group 003: General
680 /min Engine Speed (G28)
5.11 g/s Mass Air Flow Sensor (G70)
5.5 % Throttle Valve Angle
1.5 °BTDC Ignition Timing Angle
19:38:43 Group 004: General
13.442 V Battery Voltage (Terminal 30)
65.0°C Coolant Temperature (G62)
43.0°C Intake Air Temperature (G42)
19:38:49 Group 006: General
31.6 % Engine Load
42.0°C Intake Air Temperature (G42)
-11.7 % Altitude Correction Factor
19:38:58 Group 009: Service Interval Extension
74.0 mm Oil Level
48.5 mm Oil Warning Threshold
24042 Fuel Consumption Signal
170 Fuel Consumption Equivalent
19:39:01 Group 010: Ignition
30.8 % Engine Load
5.3 °ATDC Ignition Timing Angle
19:39:12 Group 014: Ignition (Misfire Recognition - Total)
30.8 % Engine Load
323 Misfire Counter
Enabled Misfire Recognition
19:39:15 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
0 Misfire Counter Cylinder 1
339 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
19:39:18 Group 016: Ignition (Misfire Recognition - Cylinder 4)
0 Misfire Counter Cylinder 4
19:39:23 Group 018: Ignition (Misfire Recognition - RPM/Load Barriers)
720 /min Lower RPM Barrier
1480 /min Upper RPM Barrier
47.8 % Lower Load Barrier
87.8 % Upper Load Barrier
19:39:27 Group 020: Ignition (Timing Retardation Cylinder 1-4)
0.0°KW Timing Retardation Cylinder 1
0.0°KW Timing Retardation Cylinder 2
0.0°KW Timing Retardation Cylinder 3
-0.8°KW Timing Retardation Cylinder 4
19:39:31 Group 022: Ignition (Timing Retardation Cylinder 1 && 2)
30.1 % Engine Load
19:39:34 Group 023: Ignition (Timing Retardation Cylinder 3 && 4)
30.1 % Engine Load
19:39:39 Group 026
0.000 V Voltage
0.000 V Voltage
0.000 V Voltage
0.000 V Voltage
19:39:43 Group 028: Ignition (Knock Sensor Test)
760 /min Engine Speed (G28)
25.6 % Engine Load
69.0°C Coolant Temperature (G62)
Test OFF Knock Sensor Test Result
19:39:48 Group 030: Lambda Control (Sensor Status)
00110 Bank 1 Sensor 1
0000 Bank 1 Sensor 2
19:39:51 Group 031: Lambda Control (Lambda Sensor Voltages)
1.52 Lambda Control Bank 1 (actual)
1.00 Lambda Control Bank 1 (specified)
19:39:54 Group 032: Lambda Control (Mixture Adaptation)
0.0 % Adaptation (Idle) Bank 1 Sensor 1
0.0 % Adaptation (Partial) Bank 1 Sensor 1
19:39:57 Group 033: Lambda Control
0.0 % Lambda Control Bank 1 Sensor 1
1.84 V Sensor Voltage Bank 1 Sensor 1
19:40:00 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1)
372.0°C Catalytic Converter Bank 1 Temp.
0.69 Dynamic Factor Bank 1 Sensor 1
Test OFF Result Lambda Aging
19:40:04 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
0.45 V Sensor Voltage Bank 1 Sensor 2
Test OFF Result Lambda Availability
19:40:07 Group 037: Lambda Control (Delta Lambda Bank 1)
28.6 % Engine Load
0.000 Delta Lambda Bank 1 Sensor 2
Test OFF Result Delta Lambda B1
19:40:16 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
300 ohms Resistance Bank 1 Sensor 1
45.3 % Heater Condition Bank 1 Sensor 1
Resistance Bank 1 Sensor 2
Htg. S2 OFF Heater Condition Bank 1 Sensor 2
19:40:19 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
378.0°C Catalytic Converter Bank 1 Temp.
0.45 V Lambda Voltage Bank 1 Sensor 1
Test OFF Lambda Sensor Aging Test B1S2
19:40:24 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
384.0°C Catalytic Converter Bank 1 Temp.
1.09 Catalytic Conversion Bank 1
Test OFF Cat. Conversion Test Bank 1
19:40:34 Group 051: Idle Speed Stabilization (Gear shifts)
720 /min Engine Speed (actual)
750 /min Engine Speed (specified)
0 Selected Gear
19:40:39 Group 053: Idle Speed Stabilization (Generator Load)
730 /min Engine Speed (actual)
13.348 V Battery Voltage (Terminal 30)
49.8 % Generator Load
19:40:42 Group 054: Idle Speed Stabilization
770 /min Engine Speed (G28)
Idle Load Status
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
4.7 % Throttle Valve Angle
19:40:44 Group 055: Idle Speed Stabilization
4.1 % Idle Regulator
1.6 % Idle Stabilization Self-Adaptation
000000 Operating Condition
19:40:47 Group 056: Idle Speed Stabilization
760 /min Engine Speed (actual)
19:40:49 Group 057: Idle Speed Stabilization (Air Condition)
750 /min Engine Speed (actual)
Compr.OFF A/C Compressor
0.7 Nm A/C Compressor Load
19:40:52 Group 058
730 /min RPM
28.6 % Load
19:40:56 Group 060: Electronic Throttle (Throttle Body Alignment)
14.5 % Throttle Valve Sensor 1 (G187)
85.5 % Throttle Valve Sensor 2 (G188)
4 Throttle Valve Steps Counter
ADP. O.K. Throttle Body Alignment Status
19:40:58 Group 061: Electronic Throttle
13.536 V Battery Voltage (Terminal 30)
19:41:01 Group 062: Electronic Throttle (Sensor Values)
14.8 % Accel. Pedal Pos. Sensor 1 (G79)
7.4 % Accel. Pedal Pos. Sensor 2 (G185)
19:41:03 Group 063: Electronic Throttle (Kick-Down Alignment)
89.8 % Kick-Down Alignment Value
Not Oper. Kick-Down Switch
ADP. O.K. Kick-Down Alignment Status
19:41:06 Group 064: Electronic Throttle (Sensor Adaption Values)
0.520 V Lower Adaptation Sensor 1 (G187)
4.580 V Lower Adaptation Sensor 2 (G188)
0.840 V Emergency Air Gap Sensor 1 (G187)
4.280 V Emergency Air Gap Sensor 2 (G188)
19:41:11 Group 066: Electronic Throttle (Cruise Control System)
0.0 km/h Vehicle Speed (current)
00001000 Switch Positions I
0.0 km/h Vehicle Speed (specified)
10000001 Switch Positions II
19:41:15 Group 067: Electronic Throttle (Cruise Control System)
19:41:18 Group 068: Transmission Status
27.8 % Engine Load
0 Selected Gear
TC Open Torque Converter/Clutch
19:41:22 Group 070: Emission Reduction (EVAP Valve Test)
0.0 % Evap. Emissions Sol. Valve (Open)
Evap. Emissions Sol. Valve (Flow)
Test OFF EVAP Valve Test
19:41:25 Group 071: Emission Reduction (Leak Diagnostic System)
Reed Closed Reed Contact Status
Abort Leak Diagnostic Status Message
Leak Diagnostic Test Status
Test OFF Leak Diagnostic Test Result
19:41:34 Group 079: Emission Reduction (Exhaust Flap)
27.1 % Engine Load
Exhaust Flap Status
19:41:39 Group 080: Advanced Control Module Identification I
BPG-810 22.09.06 5EH14--- 1479 0154 Identification
19:41:41 Group 081: Advanced Control Module Identification II
WAUAF78E57A101662 < > Vehicle Ident. Number (VIN)
19:41:44 Group 082: Advanced Control Module Identification III
2212244492498 < > < > <> Flash-Tool Code (FTC)
19:41:49 Group 085: In-Use Monitor Performance Ratios (IUMPR)
243960 km Vehicle Mileage
26 IUMPR Record Counter
6280 General Denominator
24208 Ignition Cycle Counter
19:41:52 Group 086: Readiness Code I
01100101 Readiness Bits
00101101 Cycle Flags I
00011111 Cycle Flags II (Part 1)
Cycle Flags II (Part 2)
19:41:54 Group 087: Readiness and Error Bits
00000000 Error Flags I
00000000 Error Flags II (Part 1)
Error Flags II (Part 2)
19:41:57 Group 088: Cycle Flags
11001000 Cycle Flags I
01101001 Cycle Flags II
10011000 Cycle Flags III
19:42:00 Group 089: On-Board-Diagnostics (OBD)
0 km Distance Driven with MIL on
OK Tank Condition
19:42:04 Group 091: Camshaft Adjustment (Bank 1 Intake)
6.3 % Cam. Adjustment Intake Bank 1
28.0°KW Cam. Adjustment Intake B1 (spec.)
27.0°KW Cam. Adjustment Intake B1 (act.)
19:42:08 Group 093: Camshaft Adjustment Adaptation
25.6 % Engine Load
3.0°KW Phase Position Bank 1 Intake
19:42:11 Group 094: Camshaft Adjustment (Intake)
27.5°KW Cam. Adjustment Intake B1 (act.)
Test OFF Cam. Adj. Test Bank 1 Intake
19:42:18 Group 099: Lambda Control Shut-Off
78.0°C Coolant Temperature (G62)
O2-Reg.OFF Lambda Control Status
19:42:22 Group 100: Readiness Code
230.4 s Time since Engine Start
11010000 OBD-Status
19:42:24 Group 101: Fuel Injection
25.6 % Engine Load
0.00 ms Injection Timing
4.17 g/s Mass Air Flow Sensor (G70)
19:42:27 Group 102: Fuel Injection
39.0°C Intake Air Temperature (G42)
1.28 ms Injection Timing
19:42:30 Group 103: Fuel Injection (Fuel Pump Adaptation)
4.57 bar Current Fuel Pressure
-54 Fuel Pressure Regulator
380 Adaptation Value elect. Fuel Pump
ADP. O.K. Fuel Pump Adapt. Status
19:42:33 Group 104: Fuel Injection (Start Adaption Values)
63.0°C Engine Start Temperature
0.0 % Temperature Adaptation Factor 1
0.0 % Temperature Adaptation Factor 2
0.0 % Temperature Adaptation Factor 3
19:42:38 Group 106: Fuel Injection (Fuel Supply System)
50.52 bar Fuel Rail Pressure (actual)
57.3 % Electric Fuel Pump 1/2
Electric Fuel Pump 3/4
655.35 s Fuel Pump Shut-Off Time
19:42:41 Group 107: Fuel Injection (Fuel Supply System)
Test OFF Result Lambda Control
19:42:45 Group 110: Load Registration (Load/Full Throttle Enrichment)
79.0°C Coolant Temperature (G62)
4.3 % Throttle Valve Angle
19:42:49 Group 111: Charge Pressure Control
0.0 % Adaptation RPM Range 1
0.0 % Adaptation RPM Range 2
0.0 % Adaptation RPM Range 3
0.0 % Adaptation RPM Range 4
19:42:52 Group 112: Exhaust Gas Temperature
Exhaust Gas Temperature Bank 1
0.0 % Enrichment Factor Sensor Bank 1
438.0°C Exhaust Gas Temp. Projection
438.0°C Median Exhaust Gas Temperature
19:42:55 Group 113: Load Registration (Load/Full Throttle Enrichment)
24.8 % Engine Load
3.9 % Throttle Valve Angle
900.0 mbar Athmospheric Pressure
19:42:57 Group 114: Charge Pressure Control
88.7 % Engine Load (specified)
88.7 % Engine Load (spec. corrected)
21.8 % Engine Load (actual Value)
0.0 % Boost Pressure Control (N75)
19:43:00 Group 115: Charge Pressure Control
23.3 % Engine Load
410.0 mbar Boost Pressure (specified)
900.0 mbar Boost Pressure (actual)
19:43:03 Group 116: Charge Pressure Control
0.0 % Correction Factor Fuel
0.0 % Correction Factor Coolant Temp.
0.0 % Intake Air Temp. Correction Factor
19:43:06 Group 117: Charge Pressure Control
3.5 % Throttle Valve Sensor 1 (G187)
400.0 mbar Boost Pressure (specified)
19:43:08 Group 118: Charge Pressure Control
19:43:11 Group 119: Charge Pressure Control
0.0 % Boost Pressure Control Adapt.
19:43:14 Group 120: Traction Control (ASR)
399.8 Nm Torque specified by ASR
5.9 Nm Engine Torque (actual)
ASR OFF Traction Control Status
19:43:19 Group 122: Transmission
3.9 Nm Engine Torque (actual)
No Torq Red Transmission Status
19:43:23 Group 125: CAN-Databus Communication (Powertrain)
Transm. 1 Transmission Electronics (J217)
ABS 1 Brake Electronics (J104)
Instruments 1 Instrument Cluster (J285)
HVAC 1 Heating/Air Condition (J255)
19:43:26 Group 126: CAN-Databus Communication (Powertrain)
Steer. ang. 1 Steering Angle Sensor (G85)
Airbag 1 Airbag (J234)
Central Electronics (J519)
19:43:29 Group 127: CAN-Databus Communication (Powertrain)
All-Wheel-Drive
St. Wheel 1 Steering Wheel Electronics (J527)
Brake Booster
19:43:32 Group 128: CAN-Databus Communication (Powertrain)
Electronic Ignition Lock
NOx Sensor Bank 1
19:43:36 Group 129: CAN-Databus Communication (Powertrain)
Oil Level 1 Oil Temp./Level Sensor (G266)
CAN-Gateway (J533)
19:43:39 Group 130: Engine Cooling (Map Cooling)
81.0°C Engine Outlet Temperature
Radiator Outlet Temperature
Thermostat Duty Cycle
Map Cooling System Test
19:43:41 Group 131: Engine Cooling (Map Cooling)
81.0°C Engine Outlet Temperature (act.)
Engine Outlet Temperature (spec.)
19:43:44 Group 132: Engine Cooling (Map Cooling)
90.0°C Radiator Outlet Temperature
Temp. Difference Radiator/Engine
Heater Supply Potentiometer
00001001 Cooling Status
19:43:48 Group 134: Engine Cooling (Temperatures)
68.0°C Oil Temperature
28.0°C Ambient Temperature
19:43:51 Group 135: Engine Cooling (Fan Activation)
8.6 % Fan 1 Activation Duty Cycle
19:43:54 Group 136: Engine Cooling (Fan Activation)
Cooling Fan Relay 1
Cooling Fan Relay 2
Auxiliary Water Pump
OFF Fan After Run
19:43:57 Group 137: Engine Cooling (Air Condition Requirements)
A/C-Low A/C Readiness
8.2 bar A/C Refrigerant Pressure
0.0 % Fan Request from A/C-System
19:44:00 Group 138: Thermostat Diagnosis
0.00 g/s Mean Engine Air Mass
0.0 km/h Median Vehicle Speed
Test OFF Thermostat Test Result
19:44:03 Group 139: Thermostat Diagnosis
-48.0°C Engine Coolant Temperature Diag.
0.0 kg Actual Integral Mass Air Flow
0.0 kg Specified Integral Mass Air Flow
19:44:05 Group 140: Fuel Supply System (Quantity Control Valve)
46.4° Quantity Valve closing Angle
-28.8° Quantity Valve opening Angle
49.64 bar Fuel Rail Pressure (actual)
01 Quantity Control Valve Status
19:44:09 Group 141: Fuel Supply System (Quantity Control Valve)
0.00 bar High Pressure System Adaptation
-3155 Controller Portion
4497 Total Compression Volume
50.16 bar Fuel Rail Pressure (actual)
19:44:11 Group 142: Fuel Supply System (Intake Runner Flap Adaptation: Bank 1)
0.000 V Runner Flap B1 Position (act.)
1.540 V Runner Flap B1 Position (spec.)
0 Runner Flap B1 Position Offset
ADP. O.K. Runner Flap B1 Adaptation
19:44:14 Group 143: Fuel Supply System (Intake Runner Flap Adaptation: Bank 1)
22.6 % Engine Load
99.6 % Runner Flap Position (act.)
00000001 Operating Mode
19:44:30 Group 166: Lambda Control (Lambda Sensor Plausibility)
1.71 Lambda Control Bank 1 (actual)
0.00 V Sensor Voltage Bank 1 Sensor 1
3.89 g/s Integral Mass Air Flow
Test OFF Plausibility Test B1-S1
19:44:34 Group 167: Lambda Control (Lambda Sensor Overrun Compensation)
Oxygen Content
Diagnosis Overrun Counter
Lambda Sensor Correction Value
Overrun Compensation Test Status
19:44:58 Group 203
11 Count
1.05 (no units)
11.3 °BTDC Ign. Timing
00000010 Bin. Bits
19:45:02 Group 204
0.0 % Lambda
1.02 ms Time
0.00 ms Time
0.00 V Voltage
19:45:05 Group 205
99.6 % Load
99.6 % Load
27.0°KW Idle Stabilization
49.84 bar Pressure
19:45:08 Group 206
3.56 g/s Mass Flow
3.64 g/s Mass Flow
0.92 (no units)
900.0 mbar Pressure
19:45:11 Group 207
720 /min RPM
22.6 % Load
19:45:14 Group 208
22.6 % Load
21.8 % Load
0 Count
HL
19:45:17 Group 209
2.0 % Lambda
0.0 % Lambda
0.0 % Lambda
0.0 % Lambda
19:45:19 Group 210
0 Count
19:45:23 Group 211
720 /min RPM
0.0 % Load
3.5 % Load
900.0 mbar Pressure
19:45:26 Group 212
0.0°KW Idle Stabilization
100.0 % Duty Cycle
100.0 % Load
19:45:29 Group 213
720 /min RPM
22.6 % Load
1.05 (no units)
1.00 (no units)
19:45:32 Group 214
1.05 (no units)
1.00 (no units)
1.00 (no units)
414.0°C Temperature
19:45:35 Group 215
760 /min RPM
22.6 % Load
900.0 mbar Pressure
19:45:38 Group 216
-1.5°KW Idle Stabilization
19:45:41 Group 217
-11.7 % Lambda
88.7 % Load
First Map
19:45:43 Group 218
0.0 % Duty Cycle
0.0 % Lambda
0.0 % Lambda
0.0 % Load
19:45:46 Group 219
22.4 % Load
100000 Bin. Bits
0.56 g/s Mass Flow
500°C CAT Temp.
19:45:49 Group 220
3.69 g/s Mass Flow
0.98 (no units)
0.92 (no units)
0.56 g/s Mass Flow
19:45:53 Group 221
00000000 Bin. Bits
00000000 Bin. Bits
00000000 Bin. Bits
00000000 Bin. Bits
19:45:56 Group 222
0.00 s Time
0.00 s Time
0.00 s Time
Test OFF
19:45:58 Group 223
6 Count
17515 Count
0 Count
0 Count
19:46:02 Group 224
00000000 Bin. Bits
00000000 Bin. Bits
00000000 Bin. Bits
255 Count
19:46:07 Group 226
1.38 (no units)
0 Count
1.95 V Voltage
10101000 Bin. Bits
19:46:11 Group 227
2.84 kOhm Resistance
500°C CAT Temp.
19:46:14 Group 228
85.0°C Temperature
39.0°C Temperature
73.0°C Temperature
28.0°C Temperature
19:46:17 Group 229
0 Count
2 Count
1 Count
6280 Count
19:46:20 Group 230: Fuel Injection (Fuel Rail Pressure)
50.00 bar Rail Pressure (specified)
50.30 bar Rail Pressure (actual)
-0.30 bar Rail Pressure Difference
19:46:23 Group 231
4.81 bar Pressure
4.89 bar Pressure
59.6 % Load
19:46:26 Group 232
24208 Count
6280 Count
1190 Count
19:46:29 Group 233
7541 Count
8668 Count
5685 Count
7769 Count
19:46:32 Group 234
2195 Count
14308 Count
0 Count
2333 Count
19:46:35 Group 235
1.69 (no units)
0.000 Difference
0.000 Difference
11010001 Bin. Bits
19:46:39 Group 236
37.0°C Temperature
51.0°C Temperature
3 Count
19:46:42 Group 237
0.00 (no units)
1.09 (no units)
0.0 (no units)
19:46:45 Group 238
86.0°C Temperature
0.0 kg Mass/Weight
4.2 kg Mass/Weight
0 Count
19:46:47 Group 239
0.00 g/s Mass Flow
0.0 km/h Speed
0.00 s Time
39.0°C Temperature
19:46:52 Group 241
897 Count
20711 Count
20711 Count
16216 Count
19:46:54 Group 242
20713 Count
16518 Count
17742 Count
15903 Count
19:46:58 Group 243
23964 Count
7620 Count
22791 Count
22802 Count
19:47:00 Group 244
1037 Count
1099 Count
1758 Count
0 Count
19:47:03 Group 245
99.6 % Load
0 Count
86.0°C Temperature
22.7 % Lambda
19:47:06 Group 246
4.81 bar Pressure
4.81 bar Pressure
59.6 % Load
393 (no units)
19:47:08 Group 247
82.0°C Temperature
19:47:14 Group 250
22432 Count
7698 Count
19:47:17 Group 251
0.00 bar Pressure
0.00 bar Pressure
0.00 s Time
0.00 V Voltage
19:47:20 Group 252
3.96 bar Pressure
3.96 bar Pressure
0.0 s Time
83.0°C Temperature
