Hex Net: Toggle between Infrastructure and AP Mode
haimik
C?ID=79561
My HexNet does not switch from AP to Infrastructure Mode by pushing the button anymore.
The switch from IS to AP works fine.
When attempting to switch back to IS, the WiFi LED keeps showing orange, the AP Mode stays on and the CPU flashes red/orange.
To get out of this status I found a workaround: I use VCDS Mobile, connect to AP, Network Options and activate one of the IS profiles.
Is there any way to reactivate the toggle again?
Thanks,
Alfred
DV52
C?ID=194404
Alfred:Hi.
Have you tried the long-press button process (holding down the button for at least 45 seconds) - then start again? This resets the device to factory settings including the passwords
Shaun
It sounds like maybe it accidentally has two profiles for your infrastructure network and one of them isn't configured right. I would do as DV52 suggests and re-setup your desired network from scratch.
