- Joined
- Jun 27, 2020
- Messages
- 8
- Reaction score
- 7
- Location
- United States
- VCDS Serial number
- C?ID=407817
Hi all,
First off, I want to say thank you to everyone who posts and helps on this site. Although I have not found a solution to my problem yet, I have come across mounds of useful information and have been able to identify the people I would consider are the main information group. Second, my apologies if this is not the right thread category for this. Please feel free to correct me on location if this needs to move. Third, I hope I have done all my due diligence, when it comes to searching a large chunk of forums. Apologies if I have somehow missed a very straight forward and obvious solution somewhere in a forum already established.
Anyways on to the problem. As the title suggests, I have a 2009 Jetta Sportwagen SEL LHD NAR. As one should already know, there is a recall for the ABS CM. Unfortunately I had my OS crap out several months before the RC. So I picked up a used ABS module off a 2009 Golf GTI 1K0 (same series as my wagen) from LKQ. Both OS and replacement modules are from the same plant in Mexico, and if my memory serves me right, my OS was an 1k0 907 379AP and the new one is AJ (labeled as supersession to AP on most databases). Here is the rub ( especially based off what I have read so far in my search) I do not have a copy of my original long code. I had a friend at the time do a scan to try and asses the issues in the first place. I had brought that to the dealer, to get an estimate and to trouble shoot. They lost my original code, so when I finally went in once the recall was issued, they could not code it, as they said, their server flash would not take and without the original code ( which the lost ), there was nothing they could do. That was almost two years ago. I went in and hard deleted my cluster alarm, for obvious reasons. I finally have gotten back into problem solving this issue and with my new copy of VCDS and HEX, I hope I can tackle this.
Alright, so here is where I am at. I am hoping that with the provided info below (Auto-Scan, P codes, and the almost solid memory that my original module was a 1K0 907 379AP) that someone can help me build a new long code.
( Yes I know I have a crap ton of 010 codes. most of them as you will see are somewhat minor.)
Please feel free to critique me if I have forgotten any steps or information you need. I greatly appreciate any help possible.
Friday,26,June,2020,16:19:59:51119
VIN: 3VWTJ81K19M276798 License Plate:
Mileage: 220320km-136900mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 4F 52 56 62 65
72
VIN: 3VWTJ81K19M276798 Mileage: 220320km-136900miles
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H724S0Q5
Coding: 0403010A18070160
Shop #: WSC 00066 123 12345
VCID: 698FB839357598B3E45-803C
Readiness: 0110 0101
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 7AADF7754CD3232B1DF-802E
03306 - Coding Not Valid
Reset counter: 12
Mileage: 220328 km
Count: 3
Count: 2
Count: 12288
Count: 4161
Count: 43008
Reset counter: 7
Mileage: 220303 km
Count: 3
Count: 2
Count: 12288
Count: 195
Count: 44800
Count: 256
Fault Status: 01100101
Reset counter: 7
Mileage: 220303 km
Count: 2
Count: 2
Count: 12288
Count: 291
Count: 44288
Count: 256
Reset counter: 7
Mileage: 220303 km
Count: 3
Count: 2
Count: 12800
Count: 279
Count: 49664
Count: 256
Reset counter: 7
Mileage: 220303 km
Count: 3
Count: 2
Count: 12800
Count: 270
Count: 49664
Count: 256
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6D87CC29019D849388D-8038
01809 - Actuating Motor for Temperature Flap; Left (V158)
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001045391
Coding: 048DCF234004153C063C00001C0000000008730600004120000000000000
VCID: 323D1F55D8231B6B95F-8066
Component: Wischer 040908 021 0501
Coding: 00038805
Shop #: WSC 00066
10 Faults Found:
Reset counter: 12
Mileage: 220321 km
Voltage: 11.85 V
Reset counter: 12
Mileage: 220321 km
Voltage: 11.85 V
01834 - Bulb for Side-Blinkers; Left (M18)
Fault Status: 01111100
Reset counter: 12
Mileage: 220303 km
Voltage: 12.15 V
01835 - Bulb for Side-Blinkers; Right (M19)
Reset counter: 12
Voltage: 12.30 V
Reset counter: 12
Mileage: 220327 km
Voltage: 13.95 V
Reset counter: 12
Mileage: 220327 km
Voltage: 11.75 V
Reset counter: 12
Mileage: 220303 km
Voltage: 12.00 V
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 12
Mileage: 220303 km
Voltage: 11.90 V
Reset counter: 12
Mileage: 220303 km
Voltage: 11.90 V
02404 - Vehicle Exterior Illumination
Reset counter: 12
Mileage: 220303 km
Voltage: 12.05 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0393831
Coding: 0000100
VCID: 33331A51273912639E9-8066
Reset counter: 7
Mileage: 220303 km
Time: 08:02:10
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 79 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06LWKZ
Coding: 0014137
VCID: 6C81C12D3A878D9B9F3-8038
Subsystem 2 - Serial number: 6332MSME38755830A
Subsystem 3 - Serial number: 6342MSME3E26344FN
Subsystem 4 - Serial number: 6351HSME18011B15
Subsystem 5 - Serial number: 6361HSME175D33415
Subsystem 6 - Serial number: 63727SME173C2706+
Subsystem 7 - Serial number: 63827SME174551790
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
010 - Open or Short to Plus - Intermittent - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Part No SW: 1K0 953 549 CB HW: 1K0 953 549 CB
Component: J0527 051 0101
Coding: 0002022
VCID: 74B1D94D62B7555B473-8020
Component: E0221 002 0010
Part No SW: 1K0 920 974 P HW: 1K0 920 974 P
Component: KOMBIINSTRUMENT 3HL 2416
Revision: V0003000 Serial number: VWX7Z0H724S0Q5
Coding: 0007203
VCID: 3B2332710F69DA23469-806E
Fault Frequency: 22
Reset counter: 12
Mileage: 220303 km
Time: 07:13:16
Part No SW: 1K0 907 530 R HW: 1K0 907 951
Component: J533 Gateway H06 0062
Revision: H06 01 Serial number: 230608F1002207
Coding: E980FF070013032002
VCID: 36352345344B074BB97-8062
Fault Frequency: 54
Reset counter: 12
Mileage: 220303 km
Time: 07:13:18
Reset counter: 7
Mileage: 220303 km
Time: 07:13:22
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T3FN403
VCID: 7DA7FC6951FD141338D-8028
Component: IMMO 3HL 2416
00003 - Control Module
014 - Defective
Fault Status: 01101110
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3B1621CB113683FA1-807A
02347 - Switch for Memory Position 3 (E220)
003 - Mechanical Failure
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1519
Revision: 71009005 Serial number: 00000766688817
Coding: 0001463
VCID: 71BFD0591DA56073AC5-8024
Fault Status: 00100101
Reset counter: 50
Fault Status: 00101100
Fault Frequency: 7
Reset counter: 48
Mileage: 220303 km
Fault Status: 00111000
Reset counter: 48
Mileage: 220303 km
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Fault Frequency: 24
Reset counter: 12
Mileage: 220303 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A0D0735F0F353AB2DF-807E
Fault Status: 11100101
Mileage: 220303 km
Time: 07:13:15
Battery Volts: 12.2 V
DD
Temperature: 45.0°C
Count: 8
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283083F2D020D8FB0880F0448FC00
VCID: 0451898D321765DB773-8050
Fault Status: 00110111
Reset counter: 51
Mileage: 220303 km
Time: 07:18:44
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 6695B305286BB7CBC97-8032
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1519
Revision: 71009005 Serial number: 00000764388811
Coding: 0001462
VCID: 72BDDF5518A35B6B55F-8026
Reset counter: 49
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2227605
Coding: 0010400
VCID: 290FF839F5F558B3245-807C
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003387245
Coding: 0001168
VCID: 76B5E34574CB474B797-8022
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003438468
Coding: 0001168
VCID: 77ABEE4173C13E43621-8022
End----(Elapsed Time: 01:43, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
