Results 1 to 6 of 6
Thread: Help with codes after audi a8 d4 headlight retrofit
    Dec 2016
    Bahrain
    Hello
    i have 2011 Audi A8 D4 4.2
    and I have done full facelift conversation
    everything is working fine low beam high beam DRL
    except I have DTC on dash
    can someone help me with getting rid of it
    here is a full scan done via VCDS and the fault codes
    Sunday,28,June,2020,00:53:28:64472
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAURVB4H0BN017775   License Plate: 111199
    Mileage: 77441km-48119mi   Repair Order:
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 34 36 3B 42 46
              52 53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAURVB4H0BN017775   Mileage: 77441km-48119miles
    Address 01: Engine (------CDRA)       Labels:* None
       Part No SW: 4H0 907 560 B    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0004
       Revision: N5H07---
       Coding: 01060003290F0168
       Shop #: WSC 99900 715 137177
       ASAM Dataset: EV_ECM42FSI0114H0907560B 001004
       ROD: EV_ECM42FSI0114H0907560B.rod
       VCID: 290FF817B9769FC3245-807C
    7144 - Please Check DTC Memory in CAN Gateway (J533)
              U1008 00 [044] - -
              [Diagnostic interface for databus -J533-please read DTC]
                        Fault Frequency: 15
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:30
                        Engine speed: 695.50 /min
                        Normed load value: 26.3 %
                        Coolant temperature: 97 °C
                        Intake air temperature: 54 °C
                        Voltage terminal 30: 13.169 V
                        AFS dm: 22.3 kg/h
                        Median injection timing: 1.080 ms
       Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
       Component: 0BK 42 FSIRdW H08 0001
       Revision: --H08---
       Coding: 001111
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_TCMALX51011 001013
       ROD: EV_TCMALX51011_001.rod
       VCID: 72BDDF7B54209C1B55F-8026
    Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H10 0273
       Coding: 44E6E20022674700E300
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 313F107791A6E703EC5-8064
       Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
       Coding: 05872F00000000000000
       Shop #: WSC 48154 001 1048576
       VCID: 6FBBD60F4792B1F3BA1-803A
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serial number: 2310000091594004
       Component: MEM-BFS       H08 0153
       Revision: AA000000    Serial number: 00001002289116
       Coding: 0018320000043201000001010101112131313333283333
       VCID: 343119636E34D22B873-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 C    HW: 4H0 820 043 C
       Component: Klima 4 Zonen H14 0061
       Coding: 4801227888
       ROD: EV_AirCondiFront_001_AU64.rod
       VCID: 2019E533CA4C5E8B73B-8074
    0291 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:13
    0314 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:13
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 GK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H20 0369
       Revision: 2502003S    Serial number: 00001757850202
       Coding: 52EBF2FD504581E19982D084A0005F00009EC30826084101800000166111170001000000090000
       VCID: 77ABEE6F3FC2F933621-8022
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110202  H32 0040
       Serial number:         110204023652
       Coding: 025523
       Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10046959
       Coding: 035523
       Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
       Component: E1 - LDS  H07 0044
       Serial number: 27 01 2011  00000328
       Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA102032000000169493
       Coding: 020300
    7 Faults Found:
                        Fault Status: 01101100
                        Reset counter: 91
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:36:53
                        Reset counter: 91
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:36:53
    03455 - Function Restriction due to Faults in Other Modules
                        Fault Frequency: 18
                        Reset counter: 91
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:36:54
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:37
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:37
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:38
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:43:38
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 2313EA3FDBDA45936E9-8076
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901102001744
       Coding: 300102
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 372B2E6F7FC23933A21-8062
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG001HBC-
       Coding: 30314246323430303034554A304C34483053
       VCID: 3635236B78C8C03BB97-8062
       Serial number: 3575HRB406506JDCA1AW
       Serial number: 3585HRB404T07OTS9GLW
       Serial number: 3515JRB405109U26P0UB
       Serial number: 3525JRB405109U26KORS
       Serial number: 3554VRB405T09GGSD8GF
       Serial number: 3564VRB405P09GGS215Q
       Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KB300051
       Coding: 000034
       VCID: 313F10779126E703EC5-8064
       Subsystem 1 - Part No SW: 4H0 951 528 G    HW: 4H0 951 528 G
       Component: E221 - MFL  H04 0009
       Serial number: 16 10 2010  33025330
       Part No SW: 4H0 920 900 C    HW: 4H0 920 900 E
       Component: TBenRDW------ H30 0297
       Revision: 26110011    Serial number: 658010211593036
       Coding: 53A708001B000008010000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU64.rod
       VCID: 2313EA3FDB5A45936E9-8076
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1110127000776
       Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
       Revision: --------    Serial number: 00000001106481
       Coding: 00E5074800
       Shop #: WSC 02729 823 28888
       VCID: 74B1D9632E34922B473-8020
       Voltage stabilizer:
    0272 - Local Databus
              U1030 00 [009] - Electrical Malfunction
                        Fault Frequency: 11
                        Reset counter: 91
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:33:21
                        Voltage terminal 30: 12.6 V
                        Voltage terminal 15: 12.6 V
                        Control Module temperature: 49 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 04018B6B74745D545420363E
       VCID: 33331A7F6B3AD5139E9-8066
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 C    HW: 4H0 919 158 C
       Component: Klima Fond    H14 0062
       Coding: 0000000000
       ROD: EV_AirCondiHeck.rod
       VCID: 303915739AACEE0BE3B-8064
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008000
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C010103B6848AEBDF3-8078
       Revision: AA000000    Serial number: 00001002289114
       Coding: 00183B0000053201000001010101112131313333203333
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA3100BU2+0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6C81C10376044AEB9F3-8038
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000112569279
       Coding: 011F1E205E0062C202080006
       VCID: 3B23325F436A1D53469-806E
       Revision: 00002001    Serial number: 0420708917
       Coding: 011A0E2000B93585B330C7C00A0100000000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H06 0006
       Serial number:     WOO1121203R
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
       Component: DACHELEKTRONI  H11 0080
       Serial number: H2011000000000005247
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO1000BH25
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000112597191
       Shop #: WSC 02312 785 00200
       VCID: 3A2D375B4C50245B5DF-806E
       Revision: --------    Serial number: 00000000038043
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D071BBC7094DB2DF-807E
       Coding: 02B602102A200200
       VCID: 343119636EB4D22B873-8060
       Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7530
       Coding: E00200
       Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7530
       Coding: E00200
    5334529 - Fan for Left Headlamp
              C1166 01 [137] - Electrical Failure
                        Fault Frequency: 18
                        Reset counter: 91
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:36:08
       Part No SW: 4H0 035 056 J    HW: 4H0 035 056
       Component: Radio U STD   H52 0133
       Revision: AB001007    Serial number: 439BZ0B7508038
       Coding: 070003020100000001
       VCID: 290FF817B9F69FC3245-807C
       Part No SW: 4H0 035 754 T    HW: 4H0 035 754 C
       Component: H-BN-RW       H41 0939
       Revision: --------    Serial number: 062BH0B7504121
       Coding: 020400000301F1EF47108F0E00000003FC0001000000000000
       VCID: 38292D53725C364BABB-806C
       Subsystem 1 - Part No: 8R0 060 884 BN
       Component: ROW 2014  0605
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDB1100CUJX
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000027927
       Subsystem 4 - Part No: 8R0 060 961 A
       Component: CD-Database  2712
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:35:28
                        Text: DU902A,Front,M,0,0,6
    03175 - Invalid Data Set
                        Reset counter: 85
                        Mileage: 77306 km
                        Date: 2020.06.20
                        Time: 02:35:27
                        Voltage: 12.60 V
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000112451161
       Coding: 010F1E20400062C202080006
       VCID: 392F285749562F43545-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H04---    Serial number: 525 PA8J0ZD0MF
       Coding: 1020003
       VCID: 6597B427996E7BA3C0D-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 020100307
       Coding: 0210044000
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B23325F43EA1D53469-806E
    0051 - Hall Sensors in Motor 1 for Rear Lid
              B1211 12 [008] - Short to Plus
                        Reset counter: 131
                        Mileage: 77440 km
                        Date: 2020.06.27
                        Time: 00:10:31
                        Voltage terminal 30: 13.88 V
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000022154
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6393AA3F9BDA05932E9-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000112451164
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H05 0081
       Revision: 0L0D5012    Serial number: SN101216  0524
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono_AU64.rod
       VCID: 2B03021FB38A8DD3D69-807E
    Address 88: Multicont. Seat Driver (J873)       Labels:* None
       Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
       Component: IVB           H07 0042
       Serial number: 00456606063301
       Coding: 660FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F3B160F8792F1F3FA1-807A
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Serial number: 00456606073702
       Coding: 260FF2
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F000000030801424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 6FBBD60F4712B1F3BA1-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
       VCID: 70B9D5735A2CAE0BA3B-8024
    End----------(Elapsed Time: 02:51, VBatt start/end: 12.3V/12.3V)-----------
    Quote Originally Posted by mohd606 View Post
    Moving to Retrofits.
    Dec 2016
    Bahrain
    Any help???.
    Any help???.
    Let me run right out to my D4 A8 and retrofit those same headlights; I'll be back in in hour and let you know what I find.'
    Oh, wait. I don't have a D4 A8.
    Dec 2016
    Bahrain
    Up up up up up
  6. #6
    Up up up up up
    If someone knows how to help I reckon they would have posted in the last 11 days
  7. Likes Uwe liked this post
