Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 52 53 56 5F
62 69 6D 72 AC
VIN: WAUZZZ8R7GA105978 Mileage: 150520km-93528miles
Address 01: Engine (J623-CTBA) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 997 401 E HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0002
Revision: 58H14---
Coding: 2A254012057603030000
Shop #: WSC 10831 002 1048576
ASAM Dataset: EV_ECM30TDI0118K5997401E 001002
ROD: EV_ECM30TDI011_AU48.rod
VCID: 3B7FC5B5B284495E1E-806E
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8R2 927 156 P HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0009
Revision: --H03---
Coding: 000001
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 4A919071ED5EE0D695-801E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BF HW: 8R0 907 379 BF
Component: ESP8 quattro H09 0020
Coding: 2F9DCC01
Shop #: WSC 35106 001 1048576
VCID: 050B634D8CC0CFAE38-8050
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Coding: 01A54000000000000000
VCID: 7F07F1A5EE1C957E72-802A
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0816000016988021
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Component: KLIMA 3 ZONEN H04 0122
Revision: C1000000 Serial number: 01070220160915
Coding: 3621028000
VCID: 77F71985C62CAD3E3A-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001273004701
Coding: 2600C0108074AFC00081400300001D0D001C670826090201000008004401030100000024000000
VCID: 78F51AB9CB32A24633-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 160122 H13 0050
Serial number: 90243014160113105024
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 61303977
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002801167141
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E2980D08000000000001
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0110
Coding: 007DA1
VCID: 3777D98586AC6D3EFA-8062
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H49 0610
Serial number: 003JPDD1JBZA
Coding: 30463531313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4895AA79F35212C683-801C
Serial number: 6334MSME557B407BN
Serial number: 6344MSME557C4F1F
Serial number: 6352QSME24513B62B
Serial number: 6362QSME2F511F64R
Serial number: 63732SME5E503842/
Serial number: 63832SME5E50346E8
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372PB10002H
Coding: 00001F
VCID: 448DBE49C77A36A66F-8010
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 932 B HW: 8R0 920 932 B
Component: KOMBIINSTR. H36 0567
Revision: 00200000 Serial number: 03C43GX1H
Coding: 13A6220007010008010000
VCID: 356BD38D9CA09F2EE8-8060
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z161190160
Coding: 80CF07FF00
VCID: 7EF90CA1E9169C7679-802A
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 3363509003
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 16029002128021200181
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02012064747464545425363E00
VCID: 7CFD06A9FF0A8E6657-8028
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H07 0071
Serial number: 0394090965
Coding: 010321
VCID: 3F87B1A5A69C557E32-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H07 0071
Serial number: 0392846938
Coding: 010321
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0511
Revision: Serial number: 0000182473104
Coding: 011003214000440004
VCID: 50A582190302DA06DB-8004
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H53 0702
Revision: 00000002 Serial number: 0000618454
Coding: 100000000001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
VCID: 4689A441F94604B671-8012
Revision: 00002001 Serial number: 0394025146
Coding: 0100063820B930008720053680040047
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0511
Revision: Serial number: 0000182475053
VCID: 4FA781651E3CC5FEC2-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H03 0005
Revision: -------- Serial number: 20000000731706
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A71C0B1BDBE705605-806E
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227BO0G2506312
Coding: 010003020100000001
VCID: 264904C15106E4B651-8072
Part No SW: 8R1 035 666 K HW: 8R1 035 666 H
Component: H-BN-EU H49 0946
Revision: -------- Serial number: 514A60GS008028
Coding: 160100060005A9ED3180AB5E00000403E40000020000000000
VCID: 4085B259D3622A864B-8014
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130BT0G3524683
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000002461904
Component: CD-Database 6890
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H02 0510
Revision: Serial number: 0000185114592
Coding: 010003204000240004
VCID: 4689A441F14604B671-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H12 0100
Revision: 1G001001 Serial number: 00000371515832
Coding: 0109080000000000
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D7BCBADA490476E20-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H02 0510
Revision: Serial number: 0000185114530
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 160040409
ROD: EV_RDCMA00100.rod
VCID: 2F67E1E576FCA5FEA2-807A
End-------------------------(Elapsed Time: 03:59)--------------------------
