Audi Q5 8R 2016 Bi Xexon Headlight dipping change
WBNa6
C?ID=119887
I've recently bought an Audi Q5 8R 2016 LHD, with Bi Xexon adaptive headlights. The lights are adaptive in that the headlight advance follows the bend in the road and also appear to auto dip and level.
From the information about these lights, it tends to suggests they may be auto adjustable to dip as RHD lights, based on the side of the road they are travelling. i.e. if travelling as a LHD they will dip right and as a RHD will dip left. There is also a suggestion that they may be changed via the MMI into TRAVEL Mode. I've had a look through the MMI menu, but cant see anything. Can anyone please enlighten me if these are auto changing, and if not how do I set them up on the MMI.
Thanks WBNa6
Please post an Auto-Scan for context. It's possible that feature needs to be enabled via an Adaptation channel or something like that.
Do you have sat nav? The GPS location data is used to enable the automatic changing of the headlights from RHD to LHD.
WBNa6
C?ID=119887
Thanks PD for your quick response. I'll try when dark and on a road with no oncoming traffic (bearing in mind the auto dip and me then driving on the wrong side of the road). With the auto bending function is there any other signs I should be looking for ?
WBNa6
C?ID=119887
Thanks Uwe. I did try at the time, but have now watched the link on how to upload, so will try again.
Just driving on the wrong side of the road won't change their behaviour - as I said the GPS location data is used to determine the county where the car is located, but if you don't have sat nav then the car won't have GPS!
So just to clarify - does your car have sat nav?
Not necessarily true. Andy had a 2015 GTI that didn't have Sat Nav, but the Telematics module had real-time GPS coordinates in the MVBs at all times. :eek:
However, I suspect that GPS data w/o navigation functionality is not sufficient to trigger an automatic change-over for the headlights.
DV52
C?ID=194404
^^^ hmm...... telematics modules fitted to UK model cars? Interesting!
I think it's required for the automatic transmission of crash data that the EU have been pushing for several years.
The car I mentioned (Andy's 2015 GTI) was a US model. But I suspect all modern telematics modules have a GPS receiver in them and know their location.
WBNa6
C?ID=119887
Hi PD and Uwe and thanks for the additional info.
The car is both automatic and has Sat Nav - From the software I think it's the original factory Fit of 2016. Have included the below the full scan.
Thanks and regards
WBN16
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 52 53 56 5F
          62 69 6D 72 AC
VIN: WAUZZZ8R7GA105978   Mileage: 150520km-93528miles
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 997 401 E    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0002
   Revision: 58H14---
   Coding: 2A254012057603030000
   Shop #: WSC 10831 002 1048576
   ASAM Dataset: EV_ECM30TDI0118K5997401E 001002
   ROD: EV_ECM30TDI011_AU48.rod
   VCID: 3B7FC5B5B284495E1E-806E
   Part No SW: 8R2 927 156 P    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0009
   Revision: --H03---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 4A919071ED5EE0D695-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Coding: 2F9DCC01
   Shop #: WSC 35106 001 1048576
   VCID: 050B634D8CC0CFAE38-8050
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 01A54000000000000000
   VCID: 7F07F1A5EE1C957E72-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0816000016988021
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01070220160915
   Coding: 3621028000
   VCID: 77F71985C62CAD3E3A-8022
   Revision: 08016001    Serial number: 00001273004701
   Coding: 2600C0108074AFC00081400300001D0D001C670826090201000008004401030100000024000000
   VCID: 78F51AB9CB32A24633-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160122  H13 0050
   Serial number: 90243014160113105024
   Coding: 01DD13
   Serial number: 61303977
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002801167141
   Serial number: E2980D08000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 007DA1
   VCID: 3777D98586AC6D3EFA-8062
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD1JBZA
   Coding: 30463531313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4895AA79F35212C683-801C
   Serial number: 6334MSME557B407BN
   Serial number: 6344MSME557C4F1F
   Serial number: 6352QSME24513B62B
   Serial number: 6362QSME2F511F64R
   Serial number: 63732SME5E503842/
   Serial number: 63832SME5E50346E8
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PB10002H
   Coding: 00001F
   VCID: 448DBE49C77A36A66F-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 932 B    HW: 8R0 920 932 B
   Component: KOMBIINSTR.   H36 0567
   Revision: 00200000    Serial number: 03C43GX1H
   Coding: 13A6220007010008010000
   VCID: 356BD38D9CA09F2EE8-8060
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z161190160
   Coding: 80CF07FF00
   VCID: 7EF90CA1E9169C7679-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 3363509003
   Serial number: 16029002128021200181
   Revision: AA001002
   Coding: 02012064747464545425363E00
   VCID: 7CFD06A9FF0A8E6657-8028
   Component: SWA Master    H07 0071
   Serial number: 0394090965
   Coding: 010321
   VCID: 3F87B1A5A69C557E32-806A
   Component: SWA Slave  H07 0071
   Serial number: 0392846938
   Coding: 010321
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000182473104
   Coding: 011003214000440004
   VCID: 50A582190302DA06DB-8004
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H53 0702
   Revision: 00000002    Serial number: 0000618454
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 4689A441F94604B671-8012
   Revision: 00002001    Serial number: 0394025146
   Coding: 0100063820B930008720053680040047
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000182475053
   VCID: 4FA781651E3CC5FEC2-801A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 20000000731706
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A71C0B1BDBE705605-806E
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227BO0G2506312
   Coding: 010003020100000001
   VCID: 264904C15106E4B651-8072
   Part No SW: 8R1 035 666 K    HW: 8R1 035 666 H
   Component: H-BN-EU       H49 0946
   Revision: --------    Serial number: 514A60GS008028
   Coding: 160100060005A9ED3180AB5E00000403E40000020000000000
   VCID: 4085B259D3622A864B-8014
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H42 0104
   Serial number: A130BT0G3524683
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002461904
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000185114592
   Coding: 010003204000240004
   VCID: 4689A441F14604B671-8012
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: Anhaenger     H12 0100
   Revision: 1G001001    Serial number: 00000371515832
   Coding: 0109080000000000
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7BCBADA490476E20-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000185114530
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160040409
   ROD: EV_RDCMA00100.rod
   VCID: 2F67E1E576FCA5FEA2-807A
End-------------------------(Elapsed Time: 03:59)--------------------------
WBNa6
C?ID=119887
Hi Uwe and thanks for the additional replies. Attached is the scan, which I've pasted below.
Refgards
WBNa6
          62 69 6D 72 AC
   Revision: 58H14---
   Revision: --H03---
   Coding: 2F9DCC01
   Coding: 3621028000
   Coding: 01DD13
   Coding: 02005C
   Coding: 007DA1
   Coding: 00001F
   Coding: 80CF07FF00
   Revision: AA001002
   Coding: 010321
   Coding: 010321
OK, so BCM 1 (at address 09) has a coding option (Byte 04, bit 6) for "Tourist Mode adjustable via MMI/Car Menu", which is not currently enabled. I would try enabling it and then see if you don't have a new menu item in your MMI.
WBNa6
C?ID=119887
Thank Uwe, I'll try that
Regards
