Audi A6 C7 Air suspension lowering
omagnetun
New Member
Norway
C?ID=271919 (NRRT)
Hi!
I've been trying to lower the air suspension at my car by following this youtube video:
https://www.youtube.com/watch?v=v0PEK9G-wkE
The security code 20103 is the same on my care, and air system control is similar to my car.
When I'm going to put the new values in Adaptation/IDE02001-Body height left front wheel house edge , system cannot find the right workshop code and coding rejected.
Can anyone help me find the right code, so I can store new values?
Now I have air suspension fault, and cannot adjust suspension, and stored value is 0.00mm (should be original 375.44 at left front wheel)
Thank's
PetrolDave
Westbury, UK
C?ID=1423
We'll need to see a full unedited Auto-Scan of your A6 ...
omagnetun
New Member
Norway
C?ID=271919 (NRRT)
Here*s my full Auto-Scan:
Tuesday,30,June,2020,17:55:23:00895
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Bilkomponenter.no
VIN: WAUZZZ4G0GN112669   License Plate: KJ19920
Mileage: 24032km-14932mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 28 34 36 3B 3C 42 44 46
          52 53 55 5F 62 65 69 6C 6D 72 82 84 85 8B 8E 8F 90 AC C0
VIN: WAUZZZ4G0GN112669   Mileage: 24032km-14932miles
17-Instruments -- Status: Cannot be reached 0100
65-Tire Pressure -- Status: Cannot be reached 0100
84-Night Vision -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZVC)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 B    HW: 4G2 907 311 A
   Component: 3.0TDI MD1    H22 0002
   Revision: C4H22---
   Coding: 1225401A057601030000
   ASAM Dataset: EV_ECM30TDI0114G2907311B 001006
   ROD: EV_ECM30TDI0114G2907311B.rod
   VCID: 244781C22FD880A64F-8070
   Part No SW: 4G0 927 166 K    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0005
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 35614C869442092EE8-8060
   Coding: 17A6DF49E865FB92BB00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41892856D08AB58E44-8014
14080 - Function Restricted due to Missing Message(s)
          U1111 00 [040] - -
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:14
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 9B
181760 - Function Restriction due to Implausible Message(s)
          U1112 00 [032] - -
200448 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 9B
200192 - Function Restriction due to Implausible Message(s)
          U1112 00 [035] - -
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05896F0E000000000000
   VCID: 7DF194A6E4F2116E60-8028
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 09111500041368
   Coding: 369211783D0000
   VCID: 63C5C2DE6A56C79E76-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001208743302
   Coding: 0105C01440349FE2C9014040A0001800CF9CE7082E08020100000894E10117020040002D0B0000
   VCID: 71E9B896A8AA650EF4-8024
   Component: WWS57X 150926  H38 0080
   Serial number:         151017085907
   Coding: 0045F7
   Serial number: 60903638
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BH    HW: 4G0 941 531 BH
   Component: E1 - LDS  H07 0044
   Serial number: 09 11 2015  00000595
   Serial number: 509809D7000000000001
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Fault Status: 01101101
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:21
            013 - Check DTC Memory
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:21
                    Reset counter: 30
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:14
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:26
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7F04010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 295990F648FA5DCE7C-807C
145152 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 238
                    Mileage: 23434 km
                    Date: 2020.06.18
                    Time: 23:48:38
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 11.666 V
                    Velocity_vehicle_reference: -0.01 m/s
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Fault Frequency: 11
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:23
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 12.101 V
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007944A
   Coding: 30333130313730323630554A304C34473053
   VCID: 3B755ABEB266DF5E1E-806E
   Serial number: 3575HRB401I551R0C24P
   Serial number: 3585HRB40693LHKE51HL
   Serial number: 3515JRB405H3KDM62HBJ
   Serial number: 3525JRB405H3KDM621D6
   Serial number: 3554VRB401E52SHKK990
   Serial number: 3564VRB401C52SHKK9UK
   Revision: --------    Serial number: 90372OK6000HY
   Coding: 0004FD
   VCID: 387F45B28B50F446F3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 19 08 2015  D0049298
   Part No SW: 4G8 920 934 J    HW: 4G8 920 934 J
   Component: TDieRdwAccNv  H11 0106
   Revision: 08001098    Serial number: 658051115596032
   Coding: 538712001F550008010000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 387F45B28350F446F3-806C
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H26 0270
   Revision: 77007007    Serial number: 20151024120057
   Coding: 5D3F01
   VCID: 295990F640FA5DCE7C-807C
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002045911
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 7736028303
   Voltage stabilizer:
   Serial number: 1507310000000000040F
5707 - Tire Pressure Monitoring Module
          U0127 00 [009] - No Communications
                    Reset counter: 238
                    Mileage: 23434 km
                    Date: 2020.06.18
                    Time: 23:51:08
                    Voltage terminal 30: 11.6 V
                    Voltage terminal 15: 11.5 V
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 23
                    Mileage: 23434 km
                    Date: 2020.06.19
                    Time: 00:16:16
                    Voltage terminal 30: 11.4 V
                    Voltage terminal 15: 11.4 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 16
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 10111500041453
   Coding: 21
   VCID: 3D7154A6AC72D16E20-8068
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6D7EEE761E33FEA2-807A
367877 - Ride Height Not Learned
          C1044 00 [009] - -
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:42:21
266752 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:42:21
38144 - No End-of-Line Programming
          B2013 00 [009] - -
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:42:21
   Revision: AA000000    Serial number: 00000171843789
   VCID: 77FD868EC6CE3B3E3A-8022
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820AHEUW
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36634B8A89440236E1-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0385620445
   Coding: 040321
   VCID: 397940B6B85AED4E0C-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0385497368
   Coding: 040321
4192014 - Control Module 2 for Lane Change Assistance
          C1115 04 [009] - Internal System Fault
                    Reset counter: 238
                    Mileage: 23434 km
                    Date: 2020.06.19
                    Time: 11:42:27
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F1E015E00628002080013
   VCID: 45813C46CCA299AE78-8010
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000343156
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7B5FBABD5CE65605-806E
   Revision: 00002001    Serial number: 0382768603
   Coding: 013A0E20A0B93095C32009842E030F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST000MZLU000000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00016042673
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST000MZLSY00000
   Coding: 801F00
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93669723
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0511
   Coding: 011F1E015E00628002080002
   VCID: 44872142C798A0A66F-8010
   Revision: --------    Serial number: 00000001653868
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5164E67C1241EE90-8078
   Coding: 04FA02202A1F0200
   VCID: 346771829F381026DF-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
13705999 - Databus
          U1123 00 [137] - Received Error Message
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:22
   Part No SW: 4G1 035 020 D    HW: 4G1 035 020 D
   Component: MU-H-ND-EU    051 0389
   Serial number: A735J0FB000838
   Coding: 017502010000000013111102000A00002F0006E5F17001009F
   VCID: 1A3BBF3A1D9CC656E5-804E
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9FY803F6L
   Multimedia Operating Unit:
   Serial number: 90349OJU000LW
   Component: Gracenote2  --- 1012
6663 - No Communications with Control Head for Multimedia
          U10E4 00 [008] - -
                    Reset counter: 23
                    Mileage: 23434 km
                    Date: 2020.06.19
                    Time: 11:13:56
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Coding: 010F1C004000628002080002
   VCID: 479D364EF6AE8BBE8A-8012
Address 65: Tire Pressure
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001002    Serial number: 0386436424
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW37.rod
   VCID: 3365729E9A36171EC6-8066
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0125829
   Coding: 0213000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 297500706
   Coding: 093205C031
   ROD: EV_HDSGAu571.rod
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H08 0306
   Coding: D70000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201541
   Coding: 300100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C5769E2470848E687-8078
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1530300241
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
0706 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 30
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:14
                    Outside air temperature: -40.5 °C
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 42.0 °C
0793 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:21
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   ROD: EV_AdaptCruisContr2AU57X_002.rod
   VCID: 275D96CE5EEE6BBE6A-8072
          U1113 00 [009] - -
                    Reset counter: 238
                    Mileage: 23434 km
                    Date: 2020.06.18
                    Time: 23:55:12
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.660 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621211157
   Coding: 04C0BB1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0063 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 238
                    Mileage: 23434 km
                    Date: 2020.06.18
                    Time: 23:54:51
                    Outside air temperature: 16.5 °C
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 33.0 °C
0091 - Function Limitation due to Missing Video Data
          C1108 00 [009] - -
                    Fault Frequency: 10
                    Reset counter: 245
                    Mileage: 24032 km
                    Date: 2020.06.26
                    Time: 00:30:23
                    Outside air temperature: 19.5 °C
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 30.0 °C
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 31697896602A250EB4-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 326B779A652C1E16CD-8066
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152860451
   ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0007
   Serial number: 151209200750
End-------------------------(Elapsed Time: 07:39)--------------------------
You have a fault for "38144 - No End-of-Line Programming" in your suspension module.
I would guess that you did the Basic Setting "IDE01475 -- Resetting of all adaptations" and ignored the warning in VCDS that tells you you'll probably have to go to the dealer if you do that.
Now you have get the module re-parameterized. :eek:
