Security access codes
SVG
C?ID=246095
I was just out at my car (2014 Audi S4) re-coding some car settings that were reset during a recent service appointment.
I updated my Hex-Net unit to the latest software (20.4) then proceeded to update the coding. I got the usual security access code prompts for most categories but
I did have a few other categories that wouldn't get the security code prompt. They were 5F - Information Electr., & 52 Door Elect, Pass..
Are the codes available? Or do I even need them for those categories? I stopped working on the car due to the rising termperature.
Best,
SVG
Hi and welcome.
Many modules don't need security access to do most practical things. If you think you need a security access code for something, please tell us exactly what you're trying to do, and please post an Auto-Scan so people can see what control modules your car has.
SVG
C?ID=246095
Hi Uwe,
You wouldn't have a reason to remember me but we've exchanged PM's in the past. I've sort of been out of this loop for a while.
What I am trying to re-code is the following:
1) Disable NAV & Phone warning messages while entering data at speed (5F - Information Electr.)
2) Enable auxiliary ventilation (5F - Information Electr.)
3) Enable hidden menu in MMI (5F - Information Electr.)
4) Enable reverse mirror tilt (52 Door Electric, Pass.)
Here's my latest auto-scan from this morning.
Wednesday,24,June,2020,13:48:40:59463
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUBGAFL2EA028831   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
          5F 62 6C 72 A9
VIN: WAUBGAFL2EA028831   Mileage: 90520km-56246miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 F    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0001
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551F 001001
   ROD: EV_ECM30TFS0218K5907551F.rod
   VCID: 393AE4A5B8B1D54E0C-806C
6183 - Low Pressure Fuel regulation
          P310B 00 [096] - Fuel Pressure Outside Specification
                    Mileage: 87423 km
                    Date: 2020.03.13
                    Time: 14:41:17
                    Engine speed: 2016.00 /min
                    Normed load value: 27.1 %
                    Vehicle speed: 120 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 25 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 14.319 V
                    Unlearning counter according OBD: 31
                    Engine speed: actual: 2016 /min
                    MAF_ENVD: 217.88235 mg/stroke
                    Coolant temperature (unfiltered): 94.50 °C
                    T_AST_ENVD: 1696.20 s
                    FUP_EFP_ENVD: 6819.14 hPa
                    Battery voltage: 14.320313 V
11837 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
          P0219 00 [104] - -)
                    Fault Frequency: 6
                    Mileage: 87422 km
                    Date: 2020.03.13
                    Time: 14:40:58
                    Engine speed: 6971.00 /min
                    Normed load value: 98.4 %
                    Vehicle speed: 154 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 880 mbar
                    Voltage terminal 30: 13.812 V
                    Unlearning counter according OBD: 38
                    Engine speed: actual: 7168 /min
                    MAF_ENVD: 909.65880 mg/stroke
                    Coolant temperature (unfiltered): 93.00 °C
                    Engine: operating status: PL
                    Engine load: 99.609375 %
                    Vehicle speed: actual: 104 km/h
9662 - EVAP System
                    Mileage: 87953 km
                    Date: 2020.04.20
                    Time: 12:33:25
                    Engine speed: 1295.00 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 9 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.101 V
                    Unlearning counter according OBD: 29
                    CTR_NR_DIAG_SMALL_LEAK_NVLD: 1
                    CTR_NR_DIAG_TGT_NVLD: 5
                    CTR_NR_RESP_REP_COMC_NVLD_ENVD: 42
                    Ambient temperature: 15.75 °C
                    Coolant temperature: 14.25 °C
                    FTL_CAN: 52 l
   Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSINAR H01 0004
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ROD: EV_TCMDL501021.rod
   VCID: 3A38FBA9BDB7DE5605-806E
   Part No SW: 8K0 907 379 CF    HW: 8K0 907 379 CF
   Component: ESP8 quattro  H09 0050
   Coding: 291D1A01
   VCID: 7F4ECABDEE153B7E72-802A
02214 - Tire Pressure Warning
                    Reset counter: 167
                    Mileage: 87978 km
                    Date: 2020.04.21
                    Time: 11:19:17
                    Hex Value: 0x8700
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x1BB6
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Coding: 0D814040000000000000
   VCID: 014A4C4598E14D8E04-8054
   Serial number: 2313000120148013
   Revision: C1000000    Serial number: 01100720132013
   Coding: 6600228000
   Shop #: WSC 58664 003 1048576
   VCID: 393AE4A5B0B1D54E0C-806C
00711 - Left Footwell Flap Positioning Motor (V108)
                    Fault Status: 00100011
                    Reset counter: 159
                    Mileage: 87250 km
                    Date: 2020.03.05
                    Time: 10:11:55
                    Voltage: 13.70 V
                    Temperature: 1.0°C
                    Temperature: 5.0°C
                    Count: 13486
                    Count: 13613
                    Bin. Bits: 01000000
                    Bin. Bits: 10000001
                    Time: 64.00 s
   Revision: 08016001    Serial number: 00000645987102
   Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
   VCID: 78BC21A1CB3B0C4633-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA180613  H18 0461
   Serial number: 13061307040140
   Coding: 004577
   Serial number: 21505638
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000307131050
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R6SF302
   Serial number: 6B8809B6000000000001
   Serial number: 003KJDB07KT-
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 38619 001 1048576
   VCID: 4AD8AB69ED574ED695-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R130000BFUE
   Serial number: 6334MSME7C131A26F
   Serial number: 6344MSME7D252A10E
   Serial number: 6352QSME733433549
   Serial number: 6362QSME7134414CE
   Serial number: 63732SME7E4C3872D
   Serial number: 63832SME7E4C007EF
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130708000101
   Coding: 000036
   VCID: 51EABC0508017D0ED4-8004
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWH6AM87E
   Coding: 8BB709008301D705020000
   VCID: 72A81389AD4766160D-8026
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z13615022D
   Coding: 80C303FF00
   VCID: 4CD4AD71EF2350E6A7-8018
   Serial number: 8003840803
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 14
                    Reset counter: 178
                    Mileage: 86935 km
                    Date: 2020.02.07
                    Time: 16:54:01
                    Fault Frequency: 13
                    Reset counter: 178
                    Mileage: 86935 km
                    Date: 2020.02.07
                    Time: 19:53:27
                    Bin. Bits:    00000
                    Voltage: 12.60 V
                    Count: 7
   Component: 4 Wheel Drive H14 0100
   Serial number: 002706130001548
   VCID: 2F2EDAFD76F50BFEA2-807A
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000066291921
   Coding: 00581B00000000000000
   VCID: 3B36FEADBA8DE75E1E-806E
   Component: SWA Master    H04 0060
   Serial number: 0310393589
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FCE8ABDA695FB7E32-806A
   Component: SWA Slave  H04 0060
   Serial number: 0310690193
   Coding: 000102
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56E04F1921EF1A3601-8002
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H55 0702
   Revision: 00000001    Serial number: 0000947712
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   Revision: 00002001    Serial number: 0311348317
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000700463
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813017268403
   VCID: 2D12C0F574F979EE90-8078
   Component: TSG BF        H09 0305
   VCID: 55E248153CE9112E08-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000302881
   ROD: EV_ParkiBrake_AU48.rod
   Revision: AB001007    Serial number: 156G90D7826993
   Coding: 020007010000000001
   VCID: 240425D12733B8A64F-8070
   Part No SW: 8R1 035 746 D    HW: 8R1 035 746 D
   Component: H-BNT-NA      H40 0738
   Revision: --------    Serial number: 204G20D7589536
   Coding: 110200000206A3EF55028B4E00000403140000000000000000
   Shop #: WSC 06325 123 12345
   VCID: 383CE1A18BBBCC46F3-806C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130GX0D2777136
   Serial number: 00000001561661
   Component: CD-Database  5298
03389 - Data Set Implausible
                    Reset counter: 101
                    Mileage: 86710 km
                    Date: 2020.01.20
                    Time: 14:42:35
                    Voltage: 11.50 V
                    Bin. Bits:      010
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59FA442550F1354E2C-800C
   Revision: --H08---    Serial number: 525PA8-J3690CC
   Coding: 1000006
   VCID: 383CE1A14BBBCC46F3-806C
   Component: TSG HR        H07 0305
   Component: SAS-GEN 2     H06 0005
   Serial number: 130607200989
   VCID: 72A81389A54766160D-8026
End----------(Elapsed Time: 02:01, VBatt start/end: 12.0V/12.0V)-----------
Reverse Mirror Dipping is already coded in your 52-Pass. Door (Byte 4, Bit 2). I'm not sure why that isn't working.
I'm not that familiar with the MMI system in your car, but there should be other folks here who are.
The "Data Set Implausible" fault bothers me. Any idea how it got to be that way?
SVG
C?ID=246095
Thanks for reply Uwe. I honestly didn't check to see if the rear view mirror dip was active. I had lost my disable seat belt warning & disable DRL turn signal wink coding when I had my last service done and assumed everything else was reset as well.
I'm also not sure how the data set implausible fault occured.
This may all be for naught as I had a collision with a deer on Thursday night. The initial damage estimate was >$17K and almost surely to climb from there. Not sure what the threshold for my insurance company is for totaling a vehicle but I might be getting close. The car is at the body shop now and will either get repaired or sent to the bone yard. Which would be a shame as its been a great car.
SVG
C?ID=246095
Well the car was totaled by the insurance company. Not totally unexpected but disappointing nonetheless.
I won't be straying far as I'm going to pick up a 2019 Golf R in a few weeks.
Drew M
New Member
Montana, USA
Hello svg was wondering about your old audi can you PM me please.
