Golf Mk7 manual ac tweak
vmmltu
Lithuania
C?ID=394547
Golf Mk7 manual ac tweak question. Possible?
Hello, all,
I had a ride in awful rain. Now i want that my manual ac OFF button worked as front window defoger (That function which climate control have. you push a window button and ac turn's on, the air starts blowing only to front window and with max speed). I almost crashed trying to find possition of flaps to blow air into window. Is that even possible??? Here's my autoscan (that falt is already gone :) ):
Wednesday,24,June,2020,10:16:44:12071
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZGW281735   License Plate: JFR405
Mileage: 64872km-40309mi   Repair Order: patikrinimas_2020_06_24
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW281735   Mileage: 64872km-40309miles
Address 01: Engine (J623-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 6336
   Revision: 22004001
   Coding: 01114012430411092000
   ASAM Dataset: EV_ECM16TDI03004L906056CL 004011
   ROD: EV_ECM16TDI03004L906056_004.rod
   VCID: 79AFEBA7495BA0B3145-802C
Readiness: N/A
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 90476000013399
   Coding: 01FA62A12428096D077E060341C82580462490E06082A4F300400078C002
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7EA5F8BB5075878B217-802A
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Revision: 00001K06
   Coding: 00020104202100001000000000000002
   ROD: EV_ACManueBHBVW37X_003.rod
   VCID: 3C2132B306E9559B4F3-8068
   Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
329220 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Reset counter: 184
                    Mileage: 63323 km
                    Date: 2020.06.12
                    Time: 08:45:46
                    Voltage terminal 30: 11.9 V
                    Outside air temperature: 19.5 °C
                    Air distribution flap: actual value: 223
                    Air distribution flap: actual value: 73.0 %
                    Air distribution flap: specified value: 78
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061606701128
   Coding: 00000842C20100530BA44080B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025D8C4B248DE36B45F-8056
   Component: WWS    160228  043 0551
   Serial number:         160305010014
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY113040EGL
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064966215
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1JNEG
   VCID: 41DF4347610B38731C5-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 803 16
   Serial number: 357670000008C328C91/
   Subsystem 2 - Part No SW: -----------    HW: 480 001 403 16
   Serial number: 3586700000092244A91R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 203 16
   Serial number: 3516502B9200CA04217.
   Subsystem 4 - Part No SW: -----------    HW: 480 401 203 16
   Serial number: 3526502C31F93A04A37E
   Subsystem 5 - Part No SW: -----------    HW: 480 401 103 16
   Serial number: 3556502B11F3539262B9
   Part No SW: 5Q0 953 507 GB    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 15031604220935
   Coding: 0600
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 7CA1F2B34669959B0F3-8028
   Part No SW: 5G1 920 741 A    HW: 5G1 920 741 A
   Component: KOMBI         202 6420
   Coding: 07A41A002380000801080A001400000000000000
   VCID: 2517F7D79563F45300D-8070
   Part No SW: 5Q0 907 530 AG    HW: 5Q0 907 530 D
   Component: GW MQB Low    126 1244
   Revision: --------    Serial number: 0004640316
   Coding: 030000041F087300FB000048080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 76B5E09B7845CFCB797-8022
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 4481909503
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 071115BK618589
   Coding: 003002208000040100001000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0103
   VCID: 44D14A537E192D5B373-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 021115BJV04229
   Coding: 003000208000040100801000
   VCID: 40D946436A01317B13B-8014
   Part No SW: 5G0 035 867 C    HW: 5G0 035 867 C
   Component: MU-E--ER      851 6490
   Serial number: 11031600010494
   Coding: 02730000FF0000004011000100010000000000040000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 2C0102F3F689C51BDF3-8078
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.2V)-----------
Thanks for replys.
Tom
TBAx
C?ID=287144
You can't, sorry.
vmmltu
Lithuania
C?ID=394547
I'am new to VCDS. Maybe you can explain how you know that it's not possible? So I can learn and next time try to find answer by myself. Thank you.
darkchina811
ITALY
C?ID=333184
because the firmware of the A/C panel doesn't allow buttons to be repurposed. period.
vmmltu
Lithuania
C?ID=394547
So manual AC is old design analog device? Like in old days car's?
The HVAC controller in you car is not an "analog" device, but VCDS can't re-write the software in it either.
VCDS can only change things that the software in a module has preexisting accommodations to be changed. Such accommodations have to be put there by VAG and/or the control module manufacturer, and if they're not there, then it can't be done.
myounus
Northwest UK
C?ID=321059
You can change the HVAC for a climatronic one but it will throw out errors unless you add the additional sensors in, you might also need to change other parts. I've not done the conversion but I suspect you'll need both vent sensors, sunlight sensor and maybe other parts. Maybe someone else can advise?
NZDubNurd
New Zealand
C?ID=230482
Surely, even on a manual system, the AC is automatically turned on when you select the "Windscreen" position???
Cars have been doing that since the 90's!
That fault code for the air distribution flap, probably isn't going to help get it blowing on the windscreen though.
