- Joined
- Jun 20, 2020
- Messages
- 9
- Reaction score
- 0
- Location
- Mississippi, USA
- VCDS Serial number
- C?ID=404300
2006 Volkswagen Jetta TDI Manual/5-Speed
This is my first post and first time using VCDS. The engine has been completely rebuilt, bored over .25mm. I have gotten the car back together other than a few finish bits. My Initial attempt to start the car is a failure. Luckily I purchased VCDS before hand intending to dial in the timing on this car (wives commuter) and preform the adaptation on my 06 VW Jetta BRM TDI with a DSG that I recently replaced the DMF and Upgraded the frictions/steels within the K1 & K2 clutch pack.
First off with 12.3 volts on a battery maintainer, I turn the key in the ignition and the cooling fans come on. When attempting to start the engine, nothing happens. The lights do not dim like if the battery was low or a dead starter. I do hear a click under the steering column. I am including the auto scan from after I cleared the 14 year old codes. The car does have the EGR/Flap thing deleted, cooling fans are unplugged to avoid battery drain, downpipe is not installed so oxygen sensor fault. My wife is overly excited for the car to be running. Any help is well appreciated!
Tuesday,23,June,2020,14:14:44:64348
VIN: 3VWRT71K96M635616 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K96M635616 Mileage: 391620km-243341miles
42-Door Elect, Driver -- Status: Malfunction 1010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2458475
Coding: 0050071
VCID: 6393AAC5F75A0DD32E9-8036
001031 - EGR Sensor 2
P0407 - 000 - Signal too Low
Mileage: 391629 km
Time: 05:24:31
Lambda: 0.4 %
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000000
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Mileage: 391629 km
Time: 05:24:31
Voltage: 11.32 V
Duty Cycle: 95.1 %
Bin. Bits: 00000000
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Mileage: 391629 km
Time: 05:24:31
(no units): 0.20
(no units): 0.0
Bin. Bits: 11001001
005746 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground
Mileage: 391629 km
Time: 05:24:31
Voltage: 11.32 V
Bin. Bits: 11101000
Temperature: 23.4°C
Duty Cycle: 9.7 %
Readiness: 1 3 0 0 1
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 40D94549468C76CB13B-8014
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
VCID: 70B9D58936ACA64BA3B-8024
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000089558
Coding: 14010E234004180000140000001400000008730B5C
Shop #: WSC 25649 444 00462
VCID: 2A0D07E1D0F09C9B2DF-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 25649
10 Faults Found:
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
00906 - Horn (H1)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 117
Mileage: 391629 km
Voltage: 11.30 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.90 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.30 V
Reset counter: 117
Mileage: 391629 km
Voltage: 11.30 V
Reset counter: 157
Mileage: 391629 km
Voltage: 11.30 V
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD02JRAF
Coding: 0012627
VCID: 2E050BF1EC18F0BBF17-807A
Subsystem 1 - Component: BF-Gewichtsens.
Subsystem 2 - Serial number: 6332MSME096E314EM
Subsystem 3 - Serial number: 6342MSME096C6420B
Subsystem 4 - Serial number: 6351HSME072F12183
Subsystem 5 - Serial number: 6361HSME07391A514
Subsystem 6 - Serial number: 63727SME07104439V
Subsystem 7 - Serial number: 63827SME0710573E+
02511 - Control Module for Seat Occupied Recognition (J706)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78A9EDA95EDCFE0B6BB-802C
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1012
Coding: 0023203
VCID: 2B0302E5DF0A8593D69-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001054288393
Coding: 3D3F0B40071002
Fault Frequency: 14
Reset counter: 117
Mileage: 391629 km
Time: 05:24:32
Reset counter: 157
Mileage: 391629 km
Time: 05:26:00
Component: IMMO 3HL 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001269
VCID: 363523911448C87BB97-8062
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D1F81F820D45B95F-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09050F880F048051A0
VCID: 74B1D99942B49A6B473-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2E9513423173A21-8062
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E3040170
Coding: 0040400
VCID: 211FE0CDADC65FC37C5-8074
00856 - Radio Antenna
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 313F108DFD26EF43EC5-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070CFDE11E8BA3C8D-8078
End----(Elapsed Time: 01:05, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
