Hi all,
Looking at a 2008 Audi A4 B8 which has us scratching our heads, The owner started the car one morning, pulled out of his laneway and got about 50 metres down the road and the car died, just slowed to a stop on the road like the key was pulled out.
He got the car pulled back to his house now where it's being sitting a week and its refusing to start, I tried cranking it over with jump leads on to make sure its not a power problem and its definitely getting fuel since we pulled the fuel line going to the filter and its flowing plenty diesel.
He only has one key for the car and its the type that you slot into the dash. I'm thinking it could a immobilizer problem but I don't know if there would be a immobilizer fault light on the dash if its not working.
Other things I'm thinking of is something like air in the fuel system (Fuel Rail?) after the filter causing it to airlock but I'd think it should throw some kind of code if it was.
I've a auto scan attached and another after I cleared codes to see what's new but the fault codes showing up I don't think are related with the problem. Perhaps they are but I'm not sure.
1st Scan
The second scan where I had codes cleared and had jump leads on.
I know the 2 previous owners who had the car going back 5 years or more, they are very particular about cars and would be on the button with the service schedule and looked after the car very well.
Any suggestions on what to check first or advice would be helpful.
All the best.
1st Scan
VIN: WAUZZZ8K68A037984 License Plate: 08DL11452AUDIB8
Mileage: 280220km-174120mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72
VIN: WAUZZZ8K68A037984 Mileage: 280220km-174120miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 B HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3210
Revision: --H01---
Coding: 0104002C18072018
ASAM Dataset: EV_ECM20TDI03L906022B A01014
ROD: EV_ECM20TDI03L906022.rod
VCID: 2411113E7E5961AB173-8070
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [039] - Electrical Fault
Mileage: 280220 km
Date: 2020.06.22
Time: 08:04:36
Coolant temperature: 11 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.440 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11440 mV
Coolant temperature: 11.7 °C
Glow status-Bits 0-7: 0
Preheat time: 2000 ms
Fuel temperature: 10.9 °C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [039] - Electrical Fault
Mileage: 280220 km
Date: 2020.06.22
Time: 08:04:36
Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
Component: ESP8 front H03 0210
Coding: 160500
Shop #: WSC 06325 000 00000
VCID: 0849658EE231A5CB1BB-805C
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Coding: 031100
VCID: 3039ED6E3A21CD0BE3B-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0608000005294005
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0208000006585011
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
Component: KLIMA 3 ZONEN H05 0120
Revision: D0000000 Serial number: 0113.03.080335
Coding: 34040000
VCID: 3C21C95EE669396B4F3-8068
Reset counter: 38
Mileage: 280220 km
Date: 2020.06.22
Time: 07:53:21
Temperature: 12.0°C
Part No SW: 8K0 907 063 HW: 8K0 907 063
Component: BCM1 1.0 H21 0253
Revision: 01021001 Serial number: 00000000015024
Coding: 690040B10014A7000001000000005F5F001D020800000141000000
VCID: 6C81391ED68969EB9F3-8038
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200308 H05 0060
Serial number: SWFBIE 0000520
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10086319
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000002103080489
Reset counter: 38
Mileage: 280220 km
Date: 2020.06.22
Time: 07:53:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330808906488
Coding: 000003
VCID: 3829D54ED251154BABB-806C
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD143MSF
Coding: 30363434363030303030554A3052384B3053
VCID: 3C21C95EE6E9396B4F3-8068
Serial number: 6334MSME480063723
Serial number: 6344MSME3853230CA
Serial number: 6352QSME5B0C355BT
Serial number: 6362QSME5A571903I
Serial number: 63732SME5470301DW
Serial number: 63832SME5D4B107FD
Component: Lenks.Modul H11 0012
Revision: -------- Serial number: 90304HCR0001E
Coding: 000012
VCID: 3D27C45AFD73306378D-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7BY19CW38
Coding: 2F04080002002600010000
VCID: 313FE86A312BC403EC5-8064
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G08307805D
Coding: 000303
VCID: 46D5ABB6A8A573BB297-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 1800DA59110308
Reset counter: 78
Mileage: 280220 km
Date: 2020.06.22
Time: 07:50:00
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000006947945
Coding: 011002204001410001
VCID: 40D9BDAE8A815D8B13B-8014
Revision: 00002001 Serial number: 0110340950
Coding: 011B062200390440002001
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 S HW: 8T0 035 223 B
Component: DSP Prem H13 0210
Revision: 00013001 Serial number: 34833000803204
Coding: 0203010301
VCID: 3E25C356F0752B7B617-806A
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000006863703
VCID: 3FDBBE52F77F22736A1-806A
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000097431
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 B HW: 8T2 035 186 B
Component: Concert3 H11 0150
Revision: 00000512 Serial number: AUZ5Z6H1038960
Coding: 0003008001010D00035B070000
VCID: 372BD672DF4F1A33A21-8062
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000006957261
Coding: 010002204001210001
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HR H10 0251
Revision: Serial number: 0000101025093
VCID: 44D1B1BE9E9941AB373-8010
End----(Elapsed Time: 01:25, VBatt start/end: 11.5V/11.6V. VIgn 11.5V)-----
Revision: --H01---
Coding: 160500
Coding: 031100
Coding: 34040000
Reset counter: 38
Mileage: 280220 km
Date: 2020.06.22
Time: 08:28:16
Temperature: 12.0°C
Coding: 00FD11
Coding: 025028
Reset counter: 38
Mileage: 280220 km
Date: 2020.06.22
Time: 08:28:00
Coding: 000003
Coding: 000012
Coding: 000303
Coding: 0203010301
Component: Display
End----------(Elapsed Time: 01:23, VBatt start/end: 13.3V/13.3V)-----------
All the best.
