2010 Seat Ibiza 6j some help with led instalation
seonirc
Unverified
Portugal
Hello im new in vagcom world and i register in this forum to getr some help with coding my seat ibiza 6j.
I installed Led in fog lights and facelift tail lights (with leds) but i have the warning light of error bulb in the cluster, can anyone help me with this please??
thank you
PetrolDave
Westbury, UK
C?ID=1423
To help we need you to post a full unedited VCDS Auto-Scan so we can see how your Ibiza is equipped - see my sig for a link to a How-To.
seonirc
Unverified
Portugal
thank you for your help.
this is my today autoscan
Removed.   Data from a clone/pirate copy of VCDS is not acceptable here.
The faults from the radio era because i have a aftermarket android radio.
thanks for all
seonirc
Unverified
Portugal
Hello, Because is the version that comes with the cable. Thanks
seonirc
Unverified
Portugal
Hello, i think not, the cable and vcds is form my neighbor. This version isnt good? He have the latest version but is in portuguese. I dont use that because of the languange (not brcause of me, im portuguese).
PetrolDave
Westbury, UK
C?ID=1423
You can, and should, download the latest version in English (currently 20.4.1) from the Ross-Tech website which will work OK with any Ross-Tech cable - here's a link https://www.ross-tech.com/vcds/download/current.php.
Please install that and post an updated Auto-Scan made using it.
seonirc
Unverified
Portugal
As i said the cable is from my neighbor. I will check with him. I can buy a genuine cable for me but i would like to know if its possible for my car desactivate bulb warning light. Even if you dont tell how to do now without the cable. (Sorry my english)
seonirc
Unverified
Portugal
Just see, thank so just after i buy one for me i will know if its possible to do that changes with bcm.
Dont get me wrong but if doesnt possible to do that i will buy it for nothing.
Thank you for all i will think about it, if i want to take that "risk"
iichel
Netherlands, eastern part
C?ID=284912
you'll be able to disable the warning for LED fog light bulbs on your Ibiza 6J.
seonirc
Unverified
Portugal
Thank you for the reply. When i get a vcds cable i will ask to update my status. I hope with that i will fix this bulb error.
Note that iichel did not say anything about the tails, and I personally don't know because I'm not very familiar with those cars (we don't get them here).
seonirc
Unverified
Portugal
Thank you. Although i dont have any fault to rear light i pull the brake the bulb warning light pop up in the cluster (without leds in fog lights installed) and when i do output test in break light the result shows "not ok".
iichel
C?ID=284912
VCDS should also be able to disable the light diagnostics for the rear brake lights (assuming your light is still working but you have LEDs in there)
