I have a 2004 Touareg that all of the sudden is going into limp mode when driving / not shifting out of park. This happened very suddenly. Below are is the scan of the vehicle. I also checked Measuring block 125+ and saw that the transmission ECU and ABS ECU flickered from 1 to 0 a few times (not quick switches though, 1 for a few minutes, 0 for a few more.)
Any assistance in troubleshooting would be appreciated.
Sunday,21,June,2020,16:00:39:51346
VIN: License Plate:
Mileage: 196910km-122354mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: Mileage: 196910km-122354miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 0005
Coding: 0000133
Shop #: WSC 31414 000 00000
VCID: 50F972A6F6FFBAAB83B-5160
6 Faults Found:
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
18053 - Powertrain Data Bus
P1645 - 008 - Missing Message from AWD Controller - Intermittent
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 K
Component: AL 600 6Q 0361
Coding: 0004153
VCID: 3635243E745BF49BB97-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 C
Component: ESP ALLRAD MK25 0107
Coding: 0014337
Shop #: WSC 01220 444 58957
VCID: 392F2F0245451BE3545-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D070B52810DB743C8D-5160
Component: ELV XXXX
01177 - Engine Control Unit
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
00576 - Terminal 15
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L X 2714
Coding: 0001030
VCID: 313F17229D35D3A3EC5-5160
02100 - Footwell Flap Motor (V261)
01596 - Motor for Outside/Recirculated Air Flap (V154)
014 - Defective
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2702
Coding: 0101599
VCID: 44D14EF63287560B373-5160
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 D
Component: 02 Airbag 8.4E+ H07 0952
Coding: 0012338
VCID: 2411EE76D2C7760B173-5160
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 B
Component: Lenksäulenmodul 3201
Coding: 0000031
VCID: 3E253C1E5C6B3CDB617-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 D
Component: KOMBIINSTRUMENT RB4 1720
Coding: 0007231
VCID: 38292A067E4F02EBABB-5160
02053 - Control Module for Transfer Case (J646)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D22656BF9AABA3B-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1600
VCID: 04518EF67207960B773-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F5B011A1BE1F5D32A1-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
VCID: 6695B47E647B441BC97-51CE
00774 - Level Control System Sensor; Rear Left (G76)
Part No: 7L0 959 760
Component: Sitzverstellung 0202
VCID: 77ABE93A33D1CD93621-5160
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
VCID: 678BB97A63715D13F21-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: B2 HSG 0101
Coding: 0000085
VCID: 3C2136164A772ECB4F3-4B1E
Subsystem 1 - Part No: 7L0 959 701 A
Component: Tuersteuergeraet FS 0104
Subsystem 2 - Part No: 7L0 959 702 A
Component: Tuersteuergeraet BF 0104
Subsystem 3 - Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0104
Subsystem 4 - Part No: 7L0 959 704
Component: Tuersteuergeraet HR 0104
7 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00576 - Terminal 15
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 47: Sound System Labels:
VCID: 55F783B2CC0DDF8350D-5160
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180
Component: Radio DE2 0007
Coding: 0001035
VCID: 6A8DC04E7063607BEDF-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 372B293A73510D93A21-5160
Address 6E: Ctrl Head Roof Labels: 7L6-919-044-V1.clb
Part No: 7L6 919 044 C
Component: DACHDISPLAY 0529
Revision: 00000529 Serial number: 2009289.01
End----------(Elapsed Time: 08:39, VBatt start/end: 13.8V/13.8V)-----------
