Thursday,18,June,2020,12:01:48:14741
VCDS Version: 20.4.1.0 (x64) HEX-NET2 CB: 0.4523.4
VIN: 3VV3B7AX1LM125622 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 52 5F 6C 6D 75 A5
BB BC CA
VIN: 3VV3B7AX1LM125622 Mileage: 57km-35miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 B HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0004
Revision: 1DH31000
Coding: 012A00122464012FB4000000000000000000000000000000
Shop #: WSC 00066 790 00453
ASAM Dataset: EV_ECM20TFS01183A907115B 001005
ROD: EV_ECM20TFS01183A907115B.rod
VCID: A51C1ADE75621F7380D-80F0
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DS HW: 09G 927 158
Component: AISIN AQ8 206 3699
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00440
ROD: EV_TCMAQ450031_VW37.rod
VCID: 87407056EFAE2D63921-80D2
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 50250000000417
Coding: 0BFA6BA450221B71C57D0202A2C549D0D60AD8A34045927038415058D2A24A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: FEAE15B2B0746CABA17-80AA
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0538432395
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: C5DCBA5E9522FF73A0D-8090
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 AG HW: 5NN 907 044 AG
Component: AC Automat H36 4901
Revision: 20K04000 Serial number: 00000D00535344
Coding: 0002002420011C001104010C12115406
ASAM Dataset: EV_ACClimaPrehVW37X 002030
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 91745E0E91EA63D34C5-80C4
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 087 BG HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: C864190220061T
Shop #: WSC 00066 790 00238
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 81546E4EC18A1353DC5-80D4
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 200115 034 0373
Serial number: 20011321006630
Subsystem 2 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 051 0207
Serial number: S6Y19M12D19H08M17S41
Coding: 0008DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 R HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300220220200C200661
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000259540420044
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: D0F29B0A5A602ADB03B-8084
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200075258FF8728749C810530409700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: C3D8A4469B16C1438E9-8096
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 008 0403
Serial number: 003FGM083M9C
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 8C4A4F7AF6C84E3BBF3-80D8
Occupant Detection:
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000CR0G2H
Coding: 303451
Subsystem 2 - Part No SW: ----------- HW: 480 001 212 19
Serial number: 3570000000035861F34H
Subsystem 3 - Part No SW: ----------- HW: 480 001 001 20
Serial number: 358000000003244D344A
Subsystem 4 - Part No SW: ----------- HW: 480 400 701 20
Component: SideSensor_Dr 003 6149
Serial number: 3510001A332812D2665S
Subsystem 5 - Part No SW: ----------- HW: 480 400 701 20
Component: SideSensor_Pr 003 6149
Serial number: 3520001A932812D1C6A2
Subsystem 6 - Part No SW: ----------- HW: 480 402 001 20
Component: FrontSensor_D 003 6149
Serial number: 3550001BF32C33C514FE
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 001 20
Component: FrontSensor_P 003 6149
Serial number: 3560001BF32C33C65618
Part No SW: 3G0 920 890 E HW: 3G0 920 890 E
Component: KOMBI 503 4193
Coding: 08A420086788CF050288624B10010000A0000D07
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: AB08ECE613862903569-80FE
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 26022000840333
Coding: 030100347F085900FA000258180F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: F0B23B8AFA200ADB23B-80A4
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B
Component: E221__MFL-TAT H06 0025
Serial number: 0202010492800897FG2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 4133957100
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230021680496
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: B924C6AEE9DA8B93D45-80EC
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0485
Serial number: 14058005700013
Coding: 00301B200000048000000000
Shop #: WSC 01383 790 50316
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: CBC88C66B3460903769-809E
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000005316666
Coding: 011000
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Coding: 111F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D1F49E0E516A23D30C5-8084
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0485
Serial number: 15058004800973
Coding: 003013200000048000000000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: CAC68962BC3C100B4DF-809E
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000005316766
Coding: 091000
Part No SW: 2GM 035 876 B HW: 2GM 035 876 B
Component: MU-S-NS-US 854 0520
Coding: 02730602BE00000051220001001808211F0500E401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 261 8214
Serial number: VWZ6ZMX0485291
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Coding: 0123060122002017300040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C758-8680-4
Coding: 0A08
VCID: C8C2B36AA230E21B5BB-809C
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0295
Serial number: 0000000912NVUQ8
Coding: 0232602019682C208005461160100607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW37.rod
VCID: 82566142C48C084BC5F-80D6
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 08012015P14023
Coding: 0003070601020201002213468140490084000E00010000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: C0D2AB4A8A00DA5B93B-8094
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address CA: Sunroof
End----------(Elapsed Time: 01:24, VBatt start/end: 14.4V/14.6V)-----------
01 @ idle <80C
;SW:83A-907-115-B HW:06L-907-309-B --- Engine
;Component:R4 2.0l TFSI H31 0004, Coding:012A00122464012FB4000000000000000000000000000000
;EV_ECM20TFS01183A907115B,001005,EV_ECM20TFS01183A907115B.rod
;Thursday,18,June,2020,11:51:49:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: A51C1ADE75621F7380D-80F0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV3B7AX1LM125622,
IDE00019,Voltage terminal 30,14.500, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,848, /min
IDE00025,Coolant temperature,56, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,92, s
IDE00083,Throttle valve position (absolute),11.8, %
IDE00084,Absolute load value,24, %
IDE00085,Normed load value,23.5, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,42.8, Nm
IDE00102,Control Module temperature,26.3, °C
IDE00148,Median injection timing,1.1364, ms
IDE00150,Pressure in brake booster,12.97, hPa
IDE00151,Oil fill level,70.508, mm
IDE00152,Oil warning threshold,58.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,619.3, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.45, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.28, °
IDE00178,Camshaft adjustment intake bank 1: specified value,-4.89, °
IDE00179,Camshaft adjustment intake bank 1: actual value,-4.28, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,21.1, °C
IDE00188,Fuel high pressure: actual value,6.9320, MPa
IDE00190,Charge air pressure specified value,430.47, hPa
IDE00191,Charge air pressure: actual value,984.84, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,23.0, °C
IDE00194,Coolant temperature at radiator output: specified value,90.0, °C
IDE00196,Engine oil temperature,26.9, °C
IDE00201,High fuel pressure: specified value,7.0860, MPa
IDE00202,Low fuel pressure: specified value,461.5, kPa
IDE00304,Fuel level,57.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,4.05, g/s
IDE00348,Intake air temperature,26, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,14.5, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,26.3, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,985.63, hPa
IDE00371,Fuel consumption,1.31, l/h
IDE00375,Generator: load signal,41.87, %
IDE00380,Coolant fan 1: activation,30.85, %
IDE00392,Accelerator pedal: sensor voltage 1,730.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,377.0, mV
IDE00405,Crankshaft speed (RPM),802.0, /min
IDE00406,Camshaft speed (RPM),400.3, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,22.2, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,143,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,23, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.000 Lambda / -0.012 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.820, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,3, %
IDE00584,Distance driven since erasing DTC memory,40, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,100.0, %
IDE00589,Fuel pressure,6830, kPa rel
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-4.0, Degrees
IDE00594,Absolute intake pressure,40, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,2,
IDE00604,Short term adaptation of mixture formation bank 1,-2.3, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.4, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,-0.00104,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,23.0, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,1093.27, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.97290,
IDE01378,High fuel pressure: control deviation,0.0220, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,193,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.829, V
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14460, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.61, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,3.0, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,33.609, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,52.048, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,100.01, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,-0.2, Nm
IDE01902,Lost torque adaptation A/C compressor,3.0, Nm
IDE01903,Lost torque adaptation driving mode,-0.1, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,7.9, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.01282,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.06708,
IDE01911,Leakage air,2.6, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,168,
IDE01916,Leakage recognition from oxygen sensor control,0.9578,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,212,
IDE01922,Vehicle distance driven,57, km
IDE01923,Control module distance driven,57106, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.750, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,35.9, °
IDE01929,Open cam shaft angle at quantity control valve,-1.0, °
IDE01930,High pressure regulation: adaptation value,-0.096, MPa
IDE01932,High pressure pump injection volume,-7.43, mm³
IDE01975,Numb.of misfir.: cylinder 1,30,
IDE01976,Numb.of misfir.: cylinder 2,23,
IDE01977,Numb.of misfir.: cylinder 3,15,
IDE01978,Numb.of misfir.: cylinder 4,8,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,222,
IDE02117,Relative load value,23.60, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,2.52, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,76,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,2,
IDE03010-MAS01627,Number of prevented stop processes-Steering,23,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,32,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,6,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,41,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,23,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,1,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,4,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,18,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.483, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.507, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.907, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.770, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3443.0, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.000, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,227,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,0.38, °
IDE03711,Mass flow through throttle valve,14.2, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,29.840, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,10,
IDE03813,Test of secondary air system: result,Syst. OK,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,228,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,332.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,298.8, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,24.817, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3452.6, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,642.6, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.96118,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge press. ctrl.,BP_A act:98, kPa
IDE04010,Engine torque: normalized,14, %
IDE04011,Nominal torque,320, Nm
IDE04083,Coolant temperatures,ECT 1:62 °C / ECT 2:23 °C,
IDE04110,Additional inputs and outputs,,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1810.6, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.72, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-2.75, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,2.75, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.46, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3416.4, mV
IDE04409,Intake manifold pressure: corrected,426.17, hPa
IDE04410,Intake manifold pressure: target value,438.13, hPa
IDE04414,Cat conv temp: modeled,430, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,0,
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,8.9, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,45.4, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,972.50, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,1.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,22.7, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,26.3, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,81427, s
IDE05140,Intake manifold pressure raw value,424.45, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,22.5, °C
IDE05438,Rear cat conv temp main cat conv model value,434.5, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,24.19, %
IDE05445,Pressure before throttle valve of pressure sensor,984.69, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00159,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,784.12, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.20313,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,9.090, %
IDE05482,Tank venting adaptation factor,4.131,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,22.9, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,984.10, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,2.992, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,19.955, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,2.8125, hPa
IDE05951,Charge pressure control adaptation value 2,2.8125, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,26.9, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,800.0, /min
IDE06040,High fuel pressure: regulator output value,-0.1420, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,63.9, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,13, hPa
IDE06098,Sensor control factor: output value,0.98260,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0065964, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0040367, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0037552, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0041946, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,32,
IDE06255,Vehicle lateral acceleration,0.02, g
IDE06256,Vehicle lateral acceleration: raw value,0.02, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,6,
IDE06307-MAS00108,Stop prevention history data-Day,13,
IDE06307-MAS00109,Stop prevention history data-Hours,11,
IDE06307-MAS00110,Stop prevention history data-Minutes,57,
IDE06307-MAS00111,Stop prevention history data-Seconds,3,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Steering,
IDE06307,Stop prevention history data,Sporadic function restriction,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Restriction in the start system,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,14.332, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,2,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06552,Time since terminal 15 ON,154110, ms
IDE06567,Start-stop function deactivation frequency counter,15,
IDE06568,Stop prevention by driver frequency counter,38,
IDE06569,Vehicle stopped frequency counter,100,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,21.2, °C
IDE06610,Vehicle standstill with stop frequency counter,0,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,8,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,5,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.32, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,1.87, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,0.9696, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,792.0, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,4732,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,53.26, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,53.38, %
IDE07550,Engine temp. management actuator: raw value,2172.6, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3953.0, mV
IDE07554,Engine temperature management actuator: stop open,130.2, mV
IDE07573,Throttle valve adapter: actual value,2.938, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-44.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,64.8, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,27.60, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,1,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,64,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,0.02, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,2.55, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-2.11, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.13, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,0.61, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.96118,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,77.7, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,8,
IDE10041,Intake camshaft bank1 active operating mode,8,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,2, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,1, km
IDE10302,Time since engine start,138.1, s
IDE10303,Integrated air masse at first engine start,1.0027, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,30.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,7.039, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00104,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000078,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,8.455, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2181040128,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14534,Knock control: error status,2147483648,
IDE14818,Reduce ignition advance with global knock control adaptation,0.0, °
IDE15614,Time since first start of combustion engine,141420, ms
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 31 00 00 00 00 00 00 00 E3 00 2F 00 09 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,57.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,436.3, °C
MAS16074,Temperature in pre-cat bank 1: model value,551.5, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.180,
MAS16098,Tank ventilation relative mixture proportion: actual value,4.69, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,433.84, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,1.06,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,7.280, V
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,332, Ohm
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17191,Characteristics cooling module: target position,53.26, %
MAS17192,Characteristics cooling module: upper mechanical stop,130.2, mV
MAS17193,Characteristics cooling module: lower mechanical stop,3953.0, mV
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.76, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,6.82, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,1,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,83A115B 0004DXBA,
ENG99697,Calibration Verification Number,0C F6 63 23,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,0,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,89,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,108,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,173,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,5,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,7.450, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG115973,Engine Exhaust Flow Rate,15.8, kg/h
ENG20102,Engine Friction - Percent Torque,6.0, %
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,45.8, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,57.000, l
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.28, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.28, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.10, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,41.87, %
ENG112931,Generator_load_from_CAN,1046.15, W
ENG112929,Generator_torque_request,12.7, Nm
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,15.0, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 02 00 4A 00 00 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 01 00 02 00 11 00 00 00 02 00 00 00 00 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,5,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,1,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,8,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,53,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,27,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG111606,Load value: unrestricted commanded value,24.94, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-44.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,984.84, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,30.5, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,31.3, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
ENG08688,Thr Vlv u Sens1 B1,0.596, V
ENG08689,Thr Vlv u Sens2 B1,4.396, V
ENG01775,Top_speed_limitation,201.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,45.6, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,3.0, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG111604,Turbocharger_inlet_pressure_corrected_value,435.86, hPa
ENG119911,UEGO r Lam S1 B1,1.0029,
ENG115976,Vehicle Odometer,57.4, km
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,81401, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8618599, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,20356, s
Elapsed Time: 01:02
01 @ idle >80C
;SW:83A-907-115-B HW:06L-907-309-B --- Engine
;Component:R4 2.0l TFSI H31 0004, Coding:012A00122464012FB4000000000000000000000000000000
;EV_ECM20TFS01183A907115B,001005,EV_ECM20TFS01183A907115B.rod
;Thursday,18,June,2020,12:02:38:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: A51C1ADE75621F7380D-80F0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV3B7AX1LM125622,
IDE00019,Voltage terminal 30,14.420, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,786, /min
IDE00025,Coolant temperature,88, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,742, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,20, %
IDE00085,Normed load value,19.6, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,31.9, Nm
IDE00102,Control Module temperature,35.4, °C
IDE00148,Median injection timing,0.7552, ms
IDE00150,Pressure in brake booster,25.00, hPa
IDE00151,Oil fill level,78.868, mm
IDE00152,Oil warning threshold,62.184, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,384.9, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.45, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.16, °
IDE00178,Camshaft adjustment intake bank 1: specified value,-1.39, °
IDE00179,Camshaft adjustment intake bank 1: actual value,-1.61, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,21.1, °C
IDE00188,Fuel high pressure: actual value,6.4700, MPa
IDE00190,Charge air pressure specified value,378.98, hPa
IDE00191,Charge air pressure: actual value,985.39, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,30.4, °C
IDE00194,Coolant temperature at radiator output: specified value,90.0, °C
IDE00196,Engine oil temperature,87.0, °C
IDE00201,High fuel pressure: specified value,6.6400, MPa
IDE00202,Low fuel pressure: specified value,500.0, kPa
IDE00304,Fuel level,57.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,2.94, g/s
IDE00348,Intake air temperature,36, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,11.0, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,69.0, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,985.43, hPa
IDE00371,Fuel consumption,1.02, l/h
IDE00375,Generator: load signal,41.87, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,731.2, mV
IDE00393,Accelerator pedal: sensor voltage 2,377.0, mV
IDE00405,Crankshaft speed (RPM),799.5, /min
IDE00406,Camshaft speed (RPM),397.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,10.1, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,1,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,165,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,24, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.990 Lambda / -0.031 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.810, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,40, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,100.0, %
IDE00589,Fuel pressure,6650, kPa rel
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-2.5, Degrees
IDE00594,Absolute intake pressure,33, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,2,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,4.7, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,-0.00104,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,24.0, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,848.23, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.97284,
IDE01378,High fuel pressure: control deviation,-0.2380, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,193,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.813, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test on,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,234,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,3,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,3,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14420, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.84, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,-0.4, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,37.061, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,53.891, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,100.01, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,-0.4, Nm
IDE01902,Lost torque adaptation A/C compressor,-1.2, Nm
IDE01903,Lost torque adaptation driving mode,-0.1, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,7.9, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.99738,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.06708,
IDE01911,Leakage air,2.6, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,168,
IDE01916,Leakage recognition from oxygen sensor control,1.0046,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,212,
IDE01922,Vehicle distance driven,57, km
IDE01923,Control module distance driven,57106, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.750, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,29.9, °
IDE01929,Open cam shaft angle at quantity control valve,-1.7, °
IDE01930,High pressure regulation: adaptation value,-0.096, MPa
IDE01932,High pressure pump injection volume,-5.83, mm³
IDE01975,Numb.of misfir.: cylinder 1,30,
IDE01976,Numb.of misfir.: cylinder 2,41,
IDE01977,Numb.of misfir.: cylinder 3,15,
IDE01978,Numb.of misfir.: cylinder 4,8,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,191,
IDE02117,Relative load value,18.28, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,3.81, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,76,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,2,
IDE03010-MAS01627,Number of prevented stop processes-Steering,23,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,32,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,6,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,41,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,23,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,1,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,4,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,18,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.483, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.507, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.907, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.765, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3130.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.000, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,227,
IDE03700,Status adaptation dew point end,ADP is OK,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03709,Angle difference actual-specified camshaft adjuster,0.00, °
IDE03711,Mass flow through throttle valve,10.6, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,27.322, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,10,
IDE03813,Test of secondary air system: result,Syst. OK,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,228,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,330.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,300.1, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,28.210, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3452.6, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,642.6, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.96118,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04010,Engine torque: normalized,9, %
IDE04011,Nominal torque,320, Nm
IDE04083,Coolant temperatures,ECT 1:89 °C / ECT 2:30 °C,
IDE04110,Additional inputs and outputs,,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1012.0, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.44, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-2.75, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,2.75, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.58, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3410.0, mV
IDE04409,Intake manifold pressure: corrected,336.56, hPa
IDE04410,Intake manifold pressure: target value,343.67, hPa
IDE04414,Cat conv temp: modeled,330, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,0,
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04638,Transmission coolant valve,Correct result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,1,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,31.8, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,Correct result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,1,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,960.39, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,3.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,12.6, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,36.8, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,81427, s
IDE05140,Intake manifold pressure raw value,336.25, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,21.8, °C
IDE05438,Rear cat conv temp main cat conv model value,333.8, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,18.33, %
IDE05445,Pressure before throttle valve of pressure sensor,985.39, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00159,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,784.96, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.20313,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,6.293, %
IDE05482,Tank venting adaptation factor,6.504,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,28.7, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,985.35, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,2.219, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,20.456, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,2.8125, hPa
IDE05951,Charge pressure control adaptation value 2,2.8125, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,37.1, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,800.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0800, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,37,
IDE06043,Cylinder head temperature: actual value,89.6, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,25, hPa
IDE06098,Sensor control factor: output value,1.01083,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0064003, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0057831, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0053947, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0061676, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,32,
IDE06255,Vehicle lateral acceleration,0.01, g
IDE06256,Vehicle lateral acceleration: raw value,0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,6,
IDE06307-MAS00108,Stop prevention history data-Day,13,
IDE06307-MAS00109,Stop prevention history data-Hours,11,
IDE06307-MAS00110,Stop prevention history data-Minutes,57,
IDE06307-MAS00111,Stop prevention history data-Seconds,3,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Steering,
IDE06307,Stop prevention history data,Sporadic function restriction,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Restriction in the start system,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,14.332, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,3,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06552,Time since terminal 15 ON,803620, ms
IDE06567,Start-stop function deactivation frequency counter,15,
IDE06568,Stop prevention by driver frequency counter,38,
IDE06569,Vehicle stopped frequency counter,100,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,68.3, °C
IDE06610,Vehicle standstill with stop frequency counter,0,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,8,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,5,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.32, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,1.87, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,3.1456, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,803.0, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,21967,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,33.00, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,33.11, %
IDE07550,Engine temp. management actuator: raw value,1397.8, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3953.0, mV
IDE07554,Engine temperature management actuator: stop open,130.2, mV
IDE07573,Throttle valve adapter: actual value,2.156, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-28.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,89.9, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,1,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,64,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,0.02, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,2.55, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-2.11, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.13, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,0.84, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.96118,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,77.7, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,8,
IDE10041,Intake camshaft bank1 active operating mode,8,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,2, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,1, km
IDE10302,Time since engine start,787.7, s
IDE10303,Integrated air masse at first engine start,3.1708, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,30.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,7.238, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00104,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000024,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,9.215, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2181040128,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14534,Knock control: error status,2147483648,
IDE14818,Reduce ignition advance with global knock control adaptation,0.0, °
IDE15614,Time since first start of combustion engine,790950, ms
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 31 00 00 00 00 00 00 00 E3 00 2F 00 09 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,57.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,378.3, °C
MAS16074,Temperature in pre-cat bank 1: model value,385.9, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.242,
MAS16098,Tank ventilation relative mixture proportion: actual value,4.69, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,334.05, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,1.05,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,7.510, V
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,332, Ohm
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17191,Characteristics cooling module: target position,33.00, %
MAS17192,Characteristics cooling module: upper mechanical stop,130.2, mV
MAS17193,Characteristics cooling module: lower mechanical stop,3953.0, mV
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,2.90, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,6.82, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,1,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,83A115B 0004DXBA,
ENG99697,Calibration Verification Number,0C F6 63 23,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,0,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,89,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,115,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,166,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,5,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,5.804, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG115973,Engine Exhaust Flow Rate,12.0, kg/h
ENG20102,Engine Friction - Percent Torque,5.0, %
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,86.3, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,57.000, l
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.22, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.22, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.30, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,41.87, %
ENG112931,Generator_load_from_CAN,848.23, W
ENG112929,Generator_torque_request,10.1, Nm
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,11.3, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 02 00 4A 00 00 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 01 00 02 00 11 00 00 00 02 00 00 00 00 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,5,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,1,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,8,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,53,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,27,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG111606,Load value: unrestricted commanded value,18.59, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-28.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,985.63, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,30.5, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,31.3, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
ENG08688,Thr Vlv u Sens1 B1,0.570, V
ENG08689,Thr Vlv u Sens2 B1,4.424, V
ENG01775,Top_speed_limitation,201.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,31.2, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,4.0, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG111604,Turbocharger_inlet_pressure_corrected_value,353.59, hPa
ENG119911,UEGO r Lam S1 B1,1.0034,
ENG115976,Vehicle Odometer,57.4, km
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,81401, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8618599, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,20356, s
Elapsed Time: 01:02
02:
;SW:09G-927-158-DS HW:09G-927-158 --- Auto Trans
;Component:AISIN AQ8 206 3699, Coding:0002000100000000000000000000000000000000
;EV_TCMAQ450031,001001,EV_TCMAQ450031_VW37.rod
;Thursday,18,June,2020,11:52:53:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: 87407056EFAE2D63921-80D2
Group,Description,Actual
IDE00008-ENG103646,Softwareversion-VW Application Software Version Number,3699,
IDE00018,Voltage terminal 15,14.5, V
IDE00019,Voltage terminal 30,14.5, V
IDE00021,Engine speed,198, /min
IDE00022,Transmission input speed,178.25, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024,Transmission fluid temperature,24, °C
IDE00025-ENG101037,Coolant temperature-Engine coolant temperature,69.75, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00031-ENG101217,Torque transmitting function-Transmission function,0.0,
IDE00037-MAS02112,Programmability status-Programmability,programmable,
IDE00037-MAS02113,Programmability status-Program consistency,Program present,
IDE00072,ASAM/ODX file identification,EV_TCMAQ450031,
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0, km/h
IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00089,Driving position,P,
IDE00090,selected gear,PN range,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,not active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00098,Transmission position,P,
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00358-ENG101555,Limitation: torque-Engine torque limitation,182, Nm
IDE00544,Factor torque,Factor 0.5,
IDE00548-ENG101198,Converter clutch slip-Slip Speed LU,73, /min
IDE00609-ENG110904,Communication status of data bus 1-ACC ECU support/not support,Not supported,
IDE00609-ENG110905,Communication status of data bus 1-ACC Status active/not active,not active,
IDE00609-ENG110906,Communication status of data bus 1-Airbag ECU support/not support,Not supported,
IDE00609-ENG110907,Communication status of data bus 1-Airbag Status active/not active,not active,
IDE00609-ENG110902,Communication status of data bus 1-Aircon ECU support/not support,Not supported,
IDE00609-ENG110903,Communication status of data bus 1-Aircon Status active/not active,not active,
IDE00609-ENG30405,Communication status of data bus 1-BCM ECU support/not support,supported,
IDE00609-ENG30406,Communication status of data bus 1-BCM Status active/not active,active,
IDE00609-ENG110900,Communication status of data bus 1-Brake ECU support/not support,supported,
IDE00609-ENG110901,Communication status of data bus 1-Brake Status active/not active,active,
IDE00609-ENG130510,Communication status of data bus 1-Column Lock ECU support/not support,supported,
IDE00609-ENG130511,Communication status of data bus 1-Column Lock Status active/not active,active,
IDE00609-ENG110898,Communication status of data bus 1-Engine ECU support/not support,supported,
IDE00609-ENG110899,Communication status of data bus 1-Engine Status active/not active,active,
IDE00609-ENG110916,Communication status of data bus 1-EPB ECU support/not support,supported,
IDE00609-ENG110917,Communication status of data bus 1-EPB Status active/not active,active,
IDE00609-ENG110912,Communication status of data bus 1-Gateway ECU support/not support,supported,
IDE00609-ENG110913,Communication status of data bus 1-Gateway Status active/not active,active,
IDE00609-ENG130512,Communication status of data bus 1-Hybrid Charge Battery Manager ECU support/not support,Not supported,
IDE00609-ENG130513,Communication status of data bus 1-Hybrid Charge Battery Manager Status active/not active,not active,
IDE00609-ENG110910,Communication status of data bus 1-Kombi ECU support/not support,supported,
IDE00609-ENG110911,Communication status of data bus 1-Kombi Status active/not active,active,
IDE00609-ENG110918,Communication status of data bus 1-Shifter ECU support/not support,Not supported,
IDE00609-ENG110919,Communication status of data bus 1-Shifter Status active/not active,not active,
IDE00609-ENG110908,Communication status of data bus 1-Steering Wheel ECU support/not support,Not supported,
IDE00609-ENG110909,Communication status of data bus 1-Steering Wheel Status active/not active,not active,
IDE00609-ENG110914,Communication status of data bus 1-Transfercase ECU support/not support,Not supported,
IDE00609-ENG110915,Communication status of data bus 1-Transfercase Status active/not active,not active,
IDE00798-ENG28485,Number of possible access authorizations-Number of Logins,01,
IDE00820-ENG114742,Activating and deactivating all development messages-Activation of Development Messages,00,
IDE00972,Idle speed increase,OFF,
IDE02211,Brake pressure,25.80, bar
IDE02220-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,valid value,
IDE02713,Brake Light Switch,On,
IDE02714,Brake test switch,On,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,wire,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,1,
IDE02820,Transmission mileage,57.0, km
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Transmission fluid temperature too high,not active,
IDE03008-MAS03913,Stop process prevented-Adaptation procedure active,not active,
IDE03008-MAS03914,Stop process prevented-Pressure accumulator filling not completed,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not selected,not active,
IDE03008-MAS03918,Stop process prevented-Brake acceleration too great,not active,
IDE03008-MAS03960,Stop process prevented-Shifting process active,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,0,
IDE03010-MAS03912,Number of prevented stop processes-Transmission fluid temperature too high,0,
IDE03010-MAS03913,Number of prevented stop processes-Adaptation procedure active,0,
IDE03010-MAS03914,Number of prevented stop processes-Pressure accumulator filling not completed,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not selected,5,
IDE03010-MAS03918,Number of prevented stop processes-Brake acceleration too great,0,
IDE03010-MAS03960,Number of prevented stop processes-Shifting process active,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Unknown (0),
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2050,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,10,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,25,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,32,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03152-ENG100761,Neutral due to driver registr. proced. cond.: cause-cause: when it happened last time,N after R,
IDE03152-ENG102840,Neutral due to driver registr. proced. cond.: cause-distance [ s ] = km: last time it occurred,0, km
IDE03152-ENG100645,Neutral due to driver registr. proced. cond.: cause-how often over life time,0, counts
IDE03171-ENG103012,Driving strategy transmission mileage-Total Driving Time2,N/A---,
IDE03172-ENG103276,Driving strategy driving portions in D or S w/ CCS-Driving Time Ecological,0, %
IDE03173-ENG103020,Driving strategy driving portions in S w/o CCS-Driving Time Sporty,0, %
IDE03174-ENG100072,Driving strategy driving portions in Tiptronic-Driving Time Manual,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,3,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,77,
IDE03212,Start-stop conditions,Stop release,
IDE03361-ENG130487,Driver request torque-Driver Requested Torque,3, Nm
IDE03404-ENG130574,AUTOSAR Standard application software identification-software ID,20 00,
IDE03404-ENG104191,AUTOSAR Standard application software identification-Vendor ID,00 01,
IDE03404-ENG99019,AUTOSAR Standard application software identification-Version number,01 01 00,
IDE05398-ENG130490,Transmission output speed: uncond voltage-Automatic transmission output speed raw voltage,1.3, V
IDE05400-ENG102986,Hill factor driving strategy-DSP Mountain Index,0.0, %
IDE05401-ENG130491,Transmission input speed: uncond voltage-Automatic transmission input speed raw voltage,1.0, V
IDE05403-ENG130492,Accelerator pedal idling-Accelerator Idle signal,Not operated,
IDE05668-ENG101751,Transmission control module torque request-TCM Requested Torque,initialized,
IDE06323-ENG102229,Status: switch valve S1/S2-S1,closed,
IDE06323-ENG102841,Status: switch valve S1/S2-S2,Open,
IDE06658-ENG99605,Pressure control valve 2: act. current-Actual current SLB1,0.10, A
IDE06659-ENG101258,Pressure control valve 3: act. current-Actual current SLC1,0.10, A
IDE06660-ENG101181,Pressure control valve 3: spec. current-Order current SLC1,0.10, A
IDE06661-ENG100294,Pressure control valve 2: spec. current-Order current SLB1,0.10, A
IDE06662-ENG100356,Pressure control valve 4: spec. current-Order current SLC2,0.10, A
IDE06663-ENG99880,Pressure control valve 4: act. current-Actual current SLC2,0.10, A
IDE06664-ENG99347,Pressure control valve 5: act. current-Actual current SLC3,0.34, A
IDE06665-ENG101266,Pressure control valve 5: spec. current-Order current SLC3,0.34, A
IDE06666-ENG101252,Pressure control valve 6: act. current-Actual current SLC4,0.10, A
IDE06667-ENG103324,Pressure control valve 6: spec. current-Order current SLC4,0.10, A
IDE06668-ENG103285,Pressure control valve 1: act. current-Actual current SLT,0.99, A
IDE06669-ENG103245,Pressure control valve 1: spec. current-Order current SLT,1.00, A
IDE06670-ENG102978,Pressure control valve 7: act. current-Actual current SLU,0.10, A
IDE06671-ENG101564,Pressure control valve 7: spec. current-Order current SLU,0.10, A
IDE06672-ENG130501,Current gear/clutch status-Actual Gear And LU Mode,0 ,
IDE06674-ENG102023,Driving strategy: rolling resistance-DSP Road Resistance,-0.3, %
IDE06675-ENG100839,Driving strategy: Sport Index-DSP Sport Index,0, %
IDE06676-ENG130488,Driving strategy: driving mode-DSP Driving Mode,DS,
IDE06677-ENG100939,Driving strategy: Sport Index Hybrid-DSP Sport Index Hybrid,Not supported,
IDE06875-ENG101762,Height-Altitude,0.97625, mbar
IDE06879-ENG103976,Software level supplier-ATCU software level,3,
IDE06880-ENG06100,Calc. transmission fluid temp.-Temp TC Lifetime Max Value,83, °C
IDE06881-ENG130493,Max. transmission fluid temperature over lifetime-ATF Temperature Lifetime Max Value,83, °C
IDE06882-ENG102253,Trans. fluid temp. model value-Transmission fluid temperature (Model),25, °C
IDE06883-ENG130500,Max. transmission fluid temp. model value over lifetime-ATF Temperature Model Lifetime Max Value,100, °C
IDE06884-ENG99385,Trans. fluid temp. sensor: voltage-ATF-Temperature Voltage,2.8, V
IDE06885-ENG102696,Torque converter: torque loss-Converter Loss Torque,0, Nm
IDE06887-ENG130498,Driver for electric oil pump: max. temperature-DrivingRecorder - highest temperature of the choke coil estimate temperature,-55, °C
IDE06888-ENG130499,battery voltage: distribution-DrivingRecorder - distribution of Battery voltage,N/A---,
IDE06889-ENG130497,Driver for electric oil pump: temperature distribution-DrivingRecorder - distribution of choke coil estimate temperature,N/A---,
IDE06893-ENG130489,Trans. thermal management request-DSP Fan control,heating,
IDE06894-ENG130495,Hot running progr. status-DSP Hotmode Status,normal,
IDE06895-ENG130502,Level/hill recognition-DSP Plain/Mountains,Ebene (Plain),
IDE06896-ENG103489,Driving strategy: software version-DSP software level,3,
IDE06897-ENG99419,Engine torque loss-Engine Loss Torque,Not supported,
IDE06898-ENG101044,Engine torque with external intervention-Engine Torque With External Engagement,3, Nm
IDE06899-ENG99632,Engine torque without external intervention-Engine Torque Without External Engagement,2, Nm
IDE06912-ENG125777,DTC for primary and secondary processor-Error Code Sub And Main CPU,N/A---,
IDE06913-ENG102247,Trans. pilot control torque-Idle Speed Loss Torque,4, Nm
IDE06914-ENG99114,Unfiltered transmission input speed-Turbine Speed Signal Current Value,690, /min
IDE06915-ENG98331,Trans. position switch: raw signal-a,closed,
IDE06915-ENG98436,Trans. position switch: raw signal-B,Open,
IDE06915-ENG98435,Trans. position switch: raw signal-C,Open,
IDE06915-ENG98824,Trans. position switch: raw signal-Pa,closed,
IDE06916-ENG101593,Software_ID-Mot-File,H7003G43.MOT ,
IDE06917-ENG100970,Software enable status-Software Level,3,
IDE06918-ENG99734,Software enable status 2-Software Version of Sub-CPU,02 00,
IDE06919-ENG102285,Torque converter clutch: status-Lock Up Clutch Status,Open,
IDE06920-MAS00115,Tiptronic: raw signal-Tiptronic gate,OFF,
IDE06920-MAS00116,Tiptronic: raw signal-Tiptronic +,OFF,
IDE06920-MAS00117,Tiptronic: raw signal-Tiptronic -,OFF,
IDE06920-MAS00118,Tiptronic: raw signal-Tiptronic steering wheel +,OFF,
IDE06920-MAS00119,Tiptronic: raw signal-Tiptronic steering wheel -,OFF,
IDE06921-ENG100848,Calculated vehicle speed-Vehicle Speed Sensor (Dev),0.0, km/h
IDE07159-ENG28759,Control module switch-off: counter-Knockout_counter,0,
IDE80020,Analysis 20,0,
IDE80021,Analysis 21,0,
IDE80022,Analysis 22,100,
IDE80023,Analysis 23,100,
IDE80024,Analysis 24,100,
IDE80025,Analysis 25,100,
IDE80026,Analysis 26,100,
IDE80027,Analysis 27,100,
IDE80028,Analysis 28,100,
IDE80029,Analysis 29,100,
IDE80030,Analysis 30,100,
IDE80031,Analysis 31,100,
IDE80032,Analysis 32,100,
IDE80033,Analysis 33,100,
IDE80034,Analysis 34,100,
IDE80035,Analysis 35,335,
IDE80036,Analysis 36,158,
IDE80039,Analysis 39,23009,
IDE80040,Analysis 40,N/A---,
IDE80041,Analysis 41,N/A---,
IDE80042,Analysis 42,N/A---,
IDE80043,Analysis 43,N/A---,
IDE80046,Analysis 46,N/A---,
ENG114439-ENG98401,Analysis 48-Block 1,44,
ENG114439-ENG98452,Analysis 48-Block 2,0.0,
ENG114439-ENG98408,Analysis 48-Block 3,0,
ENG114440,Analysis 49,100,
ENG125778,EMOP Demand Duty %,0, %
ENG125927-ENG125781,EMOP_Feedback_ON OFF-EMOP Feedback ON/OFF,OFF,
ENG02239,The counter and interval timer for Race up shifting,Not supported,
Elapsed Time: 00:15
03:
;SW:5Q0-614-517-DL HW:5Q0-614-517-BP --- ABS Brakes
;Component:ESC H35 0113, Coding:0BFA6BA450221B71C57D0202A2C549D0D60AD8A34045927038415058D2A24A0B00002E64121A03102F35351919323200
;EV_Brake1UDSContiMK100IPB,049012,EV_Brake1UDSContiMK100IPB_049_VW27.rod
;Thursday,18,June,2020,11:53:11:14741
;VCID: FEAE15B2B0746CABA17-80AA
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,ERROR,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,AX25622,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.00000, m/s²
IDE02486,Data logger triggering,not active,
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE04446,Stop process prevented-Hill descent control,not active,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-IDE06139,Stop process prevented-AUTO HOLD slippage recognition,not active,
IDE03008-MAS04485,Stop process prevented-ESP function deactivation,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS07931,Stop process prevented-Retaining function unavailable,not active,
IDE03008-MAS07932,Stop process prevented-Inclination limit,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,13,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,8,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,15,
IDE03011-IDE04446,Number of requested start processes-Hill descent control,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04485,Number of requested start processes-ESP function deactivation,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,17,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.011, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.741, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-972, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,26.40, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,Condition not met,
IDE04425-IDE04440,Left front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04425-IDE04441,Left front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,Condition not met,
IDE04426-IDE04440,Right front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04426-IDE04441,Right front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04428-IDE04440,Right rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 42 2019,
IDE04442-IDE00010,Vacuum sensor-Serial number,06 B0 08 55 B1,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-97, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,0.31392, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,0.08829, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,0.19620, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,0.109, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,-3.062, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,-3.062, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE02955,Hill descent control-System status,Not available due to specific system,
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,not activated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04456-MAS01282,Brake disk drying-Wiper,not active,
IDE04456-MAS03095,Brake disk drying-Function status,not active,
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXDRAD00029,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-IDE03659,Internal measured values-Roller test bench mode,not active,
IDE04461-MAS01481,Internal measured values-Temperature in control module,26, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00012,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-972, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,26.40, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,558, mbar
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04644-MAS03095,Roll-over protection-Function status,not active,
IDE04645-IDE00003,Electromechanical parking brake-Coding,performed,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,Enabled,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,Enabled,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver door status,Enabled,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,Enabled,
IDE04645-IDE04941,Electromechanical parking brake-Clearance calibration,calibrated,
IDE04645-IDE04942,Electromechanical parking brake-Main examination mode,not active,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,Enabled,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,Enabled,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,Enabled,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,22.5, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,22.5, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,35,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,35,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE03735,Counter steer support-Steering torque,0, Nm
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,48, km
IDE04765-MAS03095,Counter steer support-Function status,not active,
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04774-MAS03095,Vehicle and trailer stabilization-Function status,not active,
IDE04871-IDE01599,Dynamic starting assist-Slope,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),2, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,255,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,255,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,255,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,255,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,0, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,252,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,252,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,252,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,252,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,6231,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,68102,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,579,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,88,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 33 32 35 32 30 33 30 30 30 30 35 32 30 31 32 35 30 30 31 41 31 2F 02 FE 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,99.9936, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,99.9936, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,97.65, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,9,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.9936, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,3,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,98.0406, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,7,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,99.9936, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,8,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,22.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,22.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,22.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,22.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00121-MAS03095,Electronic Differential Lock-Function status,not active,
MAS00210-IDE80007,Parking Brake-Analysis 7,6, km
MAS00210-IDE80008,Parking Brake-Analysis 8,56, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,57, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS01464,All Wheel Drive (AWD)-Emergency running mode,not active,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS00988,Hill-start assistant-Reverse gear,not selected,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
05:
;SW:3Q0-959-435-N HW:3Q0-959-435-N --- Acc/Start Auth.
;Component:VWKESSYMQB 037 1307, Coding:132C0C0723
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB.rod
;Thursday,18,June,2020,11:53:28:14741
;VCID: C5DCBA5E9522FF73A0D-8090
IDE00019,Voltage terminal 30,14.655, V
IDE00021,Engine speed,792.5, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Current,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 1,
IDE02407,Status of vehicle locking,Vehicle unlocked at single door,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,183,
IDE02419,Proximity sensor frt.pass. door: number of triggers,64,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,22,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,23,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,C7,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,22,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,23,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,C7,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,00,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,00,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,Yes,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,No,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02495,Service key: number of activations,14,
IDE02496,Service key: number of timeouts,0,
IDE02497,Service key: number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,On,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,On,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,1,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,2,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2011,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2020,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,4,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,12,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,2,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,56,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,17,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,47,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,ID sensor not found,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Missing message from Engine Control Module,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,ID sensor not found,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,62,
IDE05204,Manufacturing dates for driver door handle,0F 13 12 B7 51,
IDE05205,Manufacturing dates for frt.pass. door handle,0F 13 12 B7 51,
IDE05206,Manufacturing dates for left rear door handle,00 00 00 00 00,
IDE05207,Manufacturing dates for right rear door handle,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,89,
IDE08440,Recommendation energy management,no restriction,
IDE80258,Immobilizer status,Electronic steering locking device not installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,1,
IDE80258-MAS00110,Immobilizer status-Minutes,31,
IDE80258-MAS00111,Immobilizer status-Seconds,38,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,52,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,20,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,57, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop in start-stop mode active,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition not met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG29819,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG29818,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG29817,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG29816,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,14.667, V
ENG08690,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_Entriegelt,
ENG114479,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,0, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,0, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,0, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG118078-MAS00111,History_low_voltage-Seconds,0, s
ENG118078-ENG118397,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG118078-ENG118381,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG118078-ENG118223,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG118078-ENG118309,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG118078-ENG118280,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG118078-ENG118389,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG118078-ENG118329,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG118078-ENG118282,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG118078-ENG118267,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG118078-ENG118278,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,ECUEXT_RR_HPM_EOL,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Default,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG26926-MAS00106,lf_shutdowns-Year,2000,
ENG26926-MAS00107,lf_shutdowns-Month,0,
ENG26926-MAS00108,lf_shutdowns-Day,0,
ENG26926-MAS00109,lf_shutdowns-Hours,0,
ENG26926-MAS00110,lf_shutdowns-Minutes,0,
ENG26926-MAS00111,lf_shutdowns-Seconds,0,
ENG26926-ENG32070,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG26926-ENG32071,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG26926-ENG32072,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG26926-ENG32073,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,9,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,1,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,57, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,57, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,0, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,0, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,0, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,0, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,0, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,0, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,0, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,0, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,0, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,0, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,57, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,57, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,57, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,0, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,0, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,0, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,0, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,0, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,9,
ENG26348-ENG30077,Scan_cycle_data-Retry_count_n -6,1,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,10,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,0,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,0,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,0,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,0,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,0,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,0,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,0,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,0,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,0,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,0,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,9,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,10,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,9,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,12,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,0,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,0,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,0,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,driver_window,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Initial,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Initial,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Initial,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Initial,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Initial,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Initial,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Initial,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Initial,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Initial,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Initial,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Passenger_door,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,rear_right_door,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Initial,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Initial,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Initial,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Reset_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Reset_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Reset_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2020,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,5,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,27,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00109,service_key_internal_status-Hours,14,
ENG129035-MAS00110,service_key_internal_status-Minutes,50,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,12,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG08630-ENG09181,WFS_key_signature-clap_15_activateing_signature,01,
ENG08630-ENG09176,WFS_key_signature-signature_key_1,06 70,
ENG08630-ENG09177,WFS_key_signature-signature_key_2,02 54,
ENG08630-ENG09178,WFS_key_signature-signature_key_3,00 00,
ENG08630-ENG09179,WFS_key_signature-signature_key_4,00 00,
ENG08630-ENG09180,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:19
08:
;SW:5NN-907-044-AG HW:5NN-907-044-AG --- Auto HVAC
;Component:AC Automat H36 4901, Coding:0002002420011C001104010C12115406
;EV_ACClimaPrehVW37X,002030,EV_ACClimaPrehVW37X_002_VW37.rod
;Thursday,18,June,2020,11:53:49:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: 91745E0E91EA63D34C5-80C4
Group,Description,Actual
IDE00019,Voltage terminal 30,14.5, V
IDE00021,Engine speed,800, /min
IDE00025,Coolant temperature,78, °C
IDE00075,Vehicle speed,0, km/h
IDE00198,Refrigerant pressure,10.0, bar
IDE00322,Status of basic setting,was not yet started,
IDE00767,No. of unscheduled ECU resets,2,
IDE00965,Compressor shut-off requirement,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.485, A
IDE00967,Compressor current: specified value,0.485, A
IDE00968,Compressor speed,900, /min
IDE00969,Compressor load,9.4, Nm
IDE00970,Coolant fan activation: actual value,0.0, %
IDE00971,Coolant fan activation: specified value,27.6, %
IDE00973,Outside air temperature,23.0, °C
IDE00974,Outside air temperature internally calculated,23.0, °C
IDE00976,Left front vent temperature,9, °C
IDE00977,Right front vent temperature,23, °C
IDE00981,Footwell vent temperature,26.3333, °C
IDE00982,Temperature after evaporator,1.3, °C
IDE00983,Interior temperature,31.1, °C
IDE00984,Sun intensity left,160, W/m²
IDE00985,Sun intensity right,150, W/m²
IDE00987,Blower voltage: specified value,3.4, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,0.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,356,
IDE00995,Specified value for fresh air/recirc air flow flap,354,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,363,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,695,
IDE00998,Left temperature flap - actual value,106,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00999,Left temperature flap - specified value,90,
IDE01040,Left temperature flap: cold stop,107,
IDE01041,Left temperature flap: warm stop,922,
IDE01042,Right temperature flap: actual value,98,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01043,Right temperature flap: specified value,86,
IDE01044,Right temperature flap: cold stop,103,
IDE01045,Right temperature flap: warm stop,913,
IDE01050,Front air distribution flap: actual value,100.0, %
IDE01050,Front air distribution flap: actual value,98,
IDE01051,Front air distribution flap: specified value,96,
IDE01052,Front air distribution flap: air outlet stop,105,
IDE01053,Front air distribution flap: footwell air outlet stop,933,
IDE01054,Defroster flap: actual value,99,
IDE01054,Defroster flap: actual value,0.0, %
IDE01055,Defroster flap: specified value,87,
IDE01056,Defroster flap: stop open,930,
IDE01057,Defroster flap: stop closed,104,
IDE01063,Status of recirculation air,Automatic recirc. active,
IDE01066,Convertible top status,closed,
IDE01076,Time since ignition off,254, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,3.4, V
IDE01227,Blower current,0.75, A
IDE01232,Supply voltage for external components,4.9, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,0,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,2,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS01577,Pressing a button-Parking heater,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02192,Pressing a button-SYNC,not activated,
IDE01442-MAS03196,Pressing a button-Menu,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04605,Pressing a button-AC MAX,not activated,
IDE01442-MAS17527,Pressing a button-Air Care,not activated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE02270-IDE00002,CAN input signal(s) status-Transport mode,OFF,
IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,OFF,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01269,CAN input signal(s) status-Wipe wash,OFF,
IDE02270-MAS01277,CAN input signal(s) status-Rear window heater actual value,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-MAS01517,Stop process prevented-Defrost active,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS04353,Stop process prevented-Fogging hazard (humidity sensor),not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to setting,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127,Prevented stop processes (ring memory),Measured value not available,
IDE03128,Requested start processes (ring memory),Measured value not available,
IDE03212,Start-stop conditions,Stop release,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,222, s
IDE04312-MAS00084,System run time-Terminal 15 on,248, s
IDE04797,Center push-and-rotary knob counter,12,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,253,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,34.6, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,34.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,26.0, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,11.8, °C
IDE06163-MAS04628,External humidity sensor-Air temperature,not installed,
IDE06163-MAS04629,External humidity sensor-Sensor temperature,not installed,
IDE06163-MAS04630,External humidity sensor-Relative humidity,not installed,
IDE06163-MAS04647,External humidity sensor-Dew point,not installed,
IDE06201,Blower reduction,No switch-off: no reduction,
IDE07159-MAS01155,Control module switch-off: counter-Control module,00,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,00,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE11791,Particulate matter content in air,0, µg/m³
IDE12141-MAS00106,History memory: parking heater-Year,2000,
IDE12141-MAS00107,History memory: parking heater-Month,0,
IDE12141-MAS00108,History memory: parking heater-Day,0,
IDE12141-MAS00109,History memory: parking heater-Hours,0,
IDE12141-MAS00110,History memory: parking heater-Minutes,0,
IDE12141-MAS00111,History memory: parking heater-Seconds,0,
IDE12141-MAS02526,History memory: parking heater-Activation,Measured value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measured value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load mgmnt.,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load mgmnt.,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
Elapsed Time: 00:10
09:
;SW:5Q0-937-087-BG HW:5Q0-937-087-BA --- Cent. Elect.
;Component:BCM PQ37BOSCH 038 0303, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,020001,EV_BCMBOSCH_020.rod
;Thursday,18,June,2020,11:54:03:14741
;VCID: 81546E4EC18A1353DC5-80D4
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside air temperature,23.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01285,Counter of component protection malfunctions,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,not active,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,36,
IDE01943-MAS04352,Turn signal-Connector number,Plug B,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,not enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02486,Data logger triggering,not active,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,normal,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,39,
IDE02743-MAS04352,High Beam-Connector number,Plug B,
IDE02744-MAS01632,Steering wheel heater-Status,switched off,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,82,
IDE02857-IDE03111,Activation current-Interior light,30, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,65532, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,NOT-DEFINED,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Not available,
IDE03111-MAS01737,Interior light-Diagnosis,normal,
IDE03111-MAS02248,Interior light-Signal state,active,
IDE03111-MAS03873,Interior light-Duty cycle,88.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,12,
IDE03111-MAS04352,Interior light-Connector number,Plug C,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,active,
IDE03310-MAS03873,Brake light-Duty cycle,88.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,71,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,29.00, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,29.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,OFF,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,not active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,not active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,Unlock. indiv. doors,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,not active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,5, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,5, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,normal,
IDE03638-MAS02248,static AFS light-Signal state,not active,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,45,
IDE03638-MAS04352,static AFS light-Connector number,Plug B,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,18.50, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,400,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,normal,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,10,
IDE05323-MAS04352,Fog light-Connector number,Plug B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,Measured value not available,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,not coded/not installed,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: engaged,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: engaged,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,Measured value not available,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,not coded/not installed,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,active,
IDE05739-MAS03873,Footwell light-Duty cycle,55.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not coded/not installed,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,0,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,Unknown (65534),
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
IDE05836-MAS04807,Rain recognition sensor-park position,active,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,24000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,4716, lx
IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,not active,
IDE05839-MAS03873,Parking light-Duty cycle,0.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,10,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Remote control,
IDE05841-MAS07519,Central locking history data-Command,Unlock. indiv. doors,
IDE05841-MAS07942,Central locking history data-Additional information,Rem. ctrl. no. 1,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,keine Bedienstelle,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Search lights-Diagnosis,normal,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,62,
IDE06012-MAS04352,Search lights-Connector number,Plug C,
IDE06012-MAS15156,Search lights-terminal,Variant A,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-38.5, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,35.0, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,26.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-38.8, °C
IDE06096-IDE03111,Interior lighting-Interior light,100, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.0, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,100.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,88.0, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,Measured value not available,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06649-MAS05016,Radio-frequency transmitter-Receiver status,not installed,
IDE06649-MAS05048,Radio-frequency transmitter-Number of transmitters adapted,0,
IDE06649-ENG116085,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG116115,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,normal,
IDE06864-MAS02248,Daytime running lights-Signal state,not active,
IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,10,
IDE06864-MAS04352,Daytime running lights-Connector number,Plug B,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,65.535, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,Unknown (254),
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,Unknown (254),
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,Unknown (254),
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Vehicle unlocked at single door,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,0,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,7,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,78 26 51 B5,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,20, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,20, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,10, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,0, mA
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,0, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,6850, mA
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,6850, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,620, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,610, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,270, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,40, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,0, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,0, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,0, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,160, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,155, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,Measured value not available,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,not coded/not installed,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not activated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not activated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not activated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not activated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not activated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not activated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not activated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not activated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not activated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not activated,
IDE12940,Lever functions of the steering column electronics,not activated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,14.50, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,14.45, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,14.50, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,14.55, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,14.45, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,14.55, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00043-ENG119641,Supply voltage: Terminal 30-Messauswertung Pruefspannung Wischerablagenheizung,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,On,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,On,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,53,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,12,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,57, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,not activated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-68,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,5, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,7,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,not active,
MAS03835-MAS03873,Parking light-Duty cycle,0.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,10,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog light-Signal state,Measured value not available,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,0,
MAS03836-MAS04352,Rear fog light-Connector number,not coded/not installed,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,Selector lever is not in P,
MAS07959-MAS00107,Remote start history data-Month,6,
MAS07959-MAS00108,Remote start history data-Day,8,
MAS07959-MAS00109,Remote start history data-Hours,17,
MAS07959-MAS00110,Remote start history data-Minutes,16,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843-MAS00106,SE references from last used digital key devices-Year,0,
MAS18843-MAS00107,SE references from last used digital key devices-Month,0,
MAS18843-MAS00108,SE references from last used digital key devices-Day,0,
MAS18843-MAS00109,SE references from last used digital key devices-Hours,0,
MAS18843-MAS00110,SE references from last used digital key devices-Minutes,0,
MAS18843-ENG119380,SE references from last used digital key devices-km_Stand,1048574,
MAS18843-ENG118445,SE references from last used digital key devices-Secure_element_reference,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS18843-ENG118320,SE references from last used digital key devices-Secure_element_reference_state,invalid,
ENG116910,Control unit internal measured value (supplier),31 39 30 30 30 30 31 39 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116008-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG116008-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 08 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 78 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,0,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,0,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,0,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,0,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,0,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,10,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,1,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,1,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,1,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,2,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,1,
ENG116790-MAS00711,Supply voltage history-Odometer reading,11, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.7, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.5, V
ENG116791,Temperatures,22.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,Radio telegram: valid,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,22.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,not activated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.5, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,On,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,On,
Elapsed Time: 00:44
10:
;SW:5QA-919-294-G HW:5QA-919-294 --- Park/Steer Assist
;Component:PDC 8 Kanal H08 0061, Coding:0471155811
;EV_EPHVA18AU3700000,009046,EV_EPHVA18AU3700000_009_VW37.rod
;Thursday,18,June,2020,11:54:50:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: D0F29B0A5A602ADB03B-8084
Group,Description,Actual
IDE00018,Voltage terminal 15,14.0, V
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,not active,
IDE00325,Diagnostic mode,VW - diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00973,Outside air temperature,22.50, °
IDE00974,Outside air temperature internally calculated,22.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,ERROR,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,ERROR,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,ERROR,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,ERROR,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,ERROR,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,ERROR,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,ERROR,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,ERROR,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 1,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 7,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Park assist button,not activated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,14.0, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio reduction request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01943,Turn signal,not activated,
IDE02486,Data logger triggering,not active,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,08 BC,
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,08 BD,
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,08 C4,
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,08 C4,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator position,255, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator position,1, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator position,50, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,255, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,20, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,50, bar
IDE12038-IDE16238,Brake requirements (ring buffer)-Fluchtwunsch: Ereignisliste,1,
IDE12038-IDE16238,Brake requirements (ring buffer)-Fluchtwunsch: Ereignisliste,0,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2127,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2064,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,15,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,31,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,31,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,63,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,60,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,20,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,63,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,0,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,43.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,30.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-19.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,0.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-4.9, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,7.7, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,7.7, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-4.9, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
MAS00464-MAS00111,Standard - ambient data 1-Seconds,46,
MAS01426,Speaker volume for rear park assist,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 1,
MAS01428,Speaker volume for front park assist,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 7,
MAS10122,ARA operating condition,Initializing,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
MAS16451-IDE11215,Personalization 5-Automatic Activation,activated,
MAS16451-IDE11217,Personalization 5-Show parking space,not activated,
MAS16451-MAS01426,Personalization 5-Speaker volume for rear park assist,Stage 4,
MAS16451-MAS01427,Personalization 5-Speaker frequency for rear park assist,Stage 1,
MAS16451-MAS01428,Personalization 5-Speaker volume for front park assist,Stage 4,
MAS16451-MAS01429,Personalization 5-Speaker frequency for front park assist,Stage 7,
MAS16451-MAS06197,Personalization 5-Profile 5,not active,
MAS16451-MAS12843,Personalization 5-Maneuvering brake function,activated,
MAS16452-IDE11215,Personalization 6-Automatic Activation,activated,
MAS16452-IDE11217,Personalization 6-Show parking space,not activated,
MAS16452-MAS01426,Personalization 6-Speaker volume for rear park assist,Stage 4,
MAS16452-MAS01427,Personalization 6-Speaker frequency for rear park assist,Stage 1,
MAS16452-MAS01428,Personalization 6-Speaker volume for front park assist,Stage 4,
MAS16452-MAS01429,Personalization 6-Speaker frequency for front park assist,Stage 7,
MAS16452-MAS06198,Personalization 6-Profile 6,not active,
MAS16452-MAS12843,Personalization 6-Maneuvering brake function,activated,
MAS16453-IDE11215,Personalization 7-Automatic Activation,activated,
MAS16453-IDE11217,Personalization 7-Show parking space,not activated,
MAS16453-MAS01426,Personalization 7-Speaker volume for rear park assist,Stage 4,
MAS16453-MAS01427,Personalization 7-Speaker frequency for rear park assist,Stage 1,
MAS16453-MAS01428,Personalization 7-Speaker volume for front park assist,Stage 4,
MAS16453-MAS01429,Personalization 7-Speaker frequency for front park assist,Stage 7,
MAS16453-MAS06199,Personalization 7-Profile 7,not active,
MAS16453-MAS12843,Personalization 7-Maneuvering brake function,activated,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,100, %
Elapsed Time: 00:14
13:
;SW:2Q0-907-572-R HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H03 0372, Coding:3200075258FF8728749C810530409700000000000000000004
;EV_ACCMRRCONTIVW376,003016,EV_ACCMRRCONTIVW376_003_VW37.rod
;Thursday,18,June,2020,11:55:07:14741
;VCID: C3D8A4469B16C1438E9-8096
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.6, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,41, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00391,Adaptive distance regulation: status,ACC_Off_MainSwitch_Off,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01794-ENG29960,ACC operating lever signal-ACC_main_switch,not activated,
IDE01794-ENG98480,ACC operating lever signal-Cancel,not activated,
IDE01794-ENG29971,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG29972,ACC operating lever signal-Control_lever_error,no error,
IDE01794-ENG29984,ACC operating lever signal-distance_control_minus,not activated,
IDE01794-ENG29985,ACC operating lever signal-distance_control_plus,not activated,
IDE01794-ENG30060,ACC operating lever signal-part_control_lever,VW_MFL_Gen2,
IDE01794-ENG28543,ACC operating lever signal-Resume,not activated,
IDE01794-ENG98911,ACC operating lever signal-Set,not activated,
IDE01794-ENG30162,ACC operating lever signal-tip_down_in_step_1,not activated,
IDE01794-ENG30163,ACC operating lever signal-tip_down_in_step_2,not activated,
IDE01794-ENG30164,ACC operating lever signal-tip_up_in_step_1,not activated,
IDE01794-ENG30165,ACC operating lever signal-tip_up_in_step_2,not activated,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,BA 94 15 C6,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 90 03,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,83 D8 A9 C6 A2 5F 95 2F 9A C7 07 19 CE 81 32 39 60 7F 0F D0 B2 94 86 3E 82 8C 6E 19 B5 2D 10 04 55 7F E1 1D 37 CC AA 45 46 81 1C 27 FC 2B F2 07 70 6D DB 7B B4 F2 A4 92 00 FF C0 96 82 48 8D E2 81 FD 83 D6 B5 E3 F7 E4 67 2E D3 F9 9D 81 9C E5 C9 71 C8 76 21 BE 13 C4 26 06 D9 15 EE 1A 8D A0 DF 31 66 C3 AA 82 99 AD 2B 38 92 4F BD C5 D6 3C C2 2A 6C 5C AB 63 ED 39 D2 0E B5 FA 98 58 37 EF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE05228,Operating hour counter,170, min
IDE05814,Individualization characteristic,06 F7 19 D6 DF,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06307,Stop prevention history data,Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,
IDE06307,Stop prevention history data,Driving ahead Vehicles start moving: ACC passive,
IDE06307,Stop prevention history data,Driving ahead Vehicles are starting: ACC off,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06308,Start request history data,Driving ahead Veh start mov.: ACC act.:autom. Starting possible,
IDE06308,Start request history data,Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,
IDE06308,Start request history data,Driving ahead Vehicles start moving: ACC passive,
IDE06308,Start request history data,Driving ahead Vehicles are starting: ACC off,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,-0.117, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,-0.63, °
IDE09380-MAS00106,Performed adjustment-Year,14,
IDE09380-MAS00107,Performed adjustment-Month,03,
IDE09380-MAS00108,Performed adjustment-Day,04,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.12, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,-0.33, °
IDE09906,Vertical deadjustment,-0.956, °
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,1.500, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.001, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,not activated,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,-0.626, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,-0.254, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2020,
IDE10903-MAS00107,Expanded ambient data 2-Month,3,
IDE10903-MAS00108,Expanded ambient data 2-Day,4,
IDE10903-MAS00109,Expanded ambient data 2-Hours,2,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,34,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,35,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,0, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,-0.630, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,-0.250, °
IDE10903,Expanded ambient data 2,0,
IDE10903,Expanded ambient data 2,65, %
IDE10903,Expanded ambient data 2,100, %
IDE10903,Expanded ambient data 2,90, %
IDE10903,Expanded ambient data 2,79, %
IDE10903,Expanded ambient data 2,95, %
IDE10903,Expanded ambient data 2,14, %
IDE10903,Expanded ambient data 2,99, %
IDE10903,Expanded ambient data 2,0, %
IDE10903-ENG124556,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG125239,Expanded ambient data 2-Sensor_FRKL,10,
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,2,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,2,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,-0.120, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-0.960, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.120, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,-0.330, °
IDE12062,Counter for terminal 15 reset,107,
ENG123595,Freeze_Frame_Dataset_Sensor_01,FF FA 67 71 FF FD BB 58 FF C1 FF E7 00 00 0F 00 01 0A 00 00 00 00 A1 90 51 46 4F 41 00 63 64 5A 0E 5F 00 00,
ENG123596,Freeze_Frame_Dataset_Sensor_02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123597,Freeze_Frame_Dataset_Sensor_03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123598,Freeze_Frame_Dataset_Sensor_04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123599,Freeze_Frame_Dataset_Sensor_05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123600,Freeze_Frame_Dataset_Sensor_06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123601,Freeze_Frame_Dataset_Sensor_07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123602,Freeze_Frame_Dataset_Sensor_08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123603,Freeze_Frame_Dataset_Sensor_09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123604,Freeze_Frame_Dataset_Sensor_10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123605,Freeze_Frame_Dataset_Sensor_11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123606,Freeze_Frame_Dataset_Sensor_12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,0, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,0, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,0, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,0, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
Elapsed Time: 00:15
15:
;SW:5Q0-959-655-BM HW:5Q0-959-655-BM --- Airbags
;Component:AirbagVW21 008 0403, Coding:8CCCFC00000000005000001AC24800000065
;EV_AirbaVW20SMEVW37X,002164,EV_AirbaVW20SMEVW37X_VW37.rod
;Thursday,18,June,2020,11:55:24:14741
;VCID: 8C4A4F7AF6C84E3BBF3-80D8
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.8, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.2, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.2, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.3, Ohm
IDE01115,side belt force limiter igniter ohm value,2.2, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,too Low,
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01285,Counter of component protection malfunctions,0,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE02246,Number of activations of pedestrian protection,0,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE06959,Seat occupant detection: diagnosis signal,34.0, %
IDE06960,Seat occupant detection: msmt. signal,2.0, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
IDE13284-MAS01632,Seat occupancy detection 3. row driver side-Status,not installed,
IDE13284-MAS05030,Seat occupancy detection 3. row driver side-Resistance,0.0, Ohm
IDE13586-MAS01632,Seat occupancy detection 3. row passenger side-Status,not installed,
IDE13586-MAS05030,Seat occupancy detection 3. row passenger side-Resistance,0.0, Ohm
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear safety belt tension igniter,cannot be measured currently,
MAS00022,Igniter for battery interrupt,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition: driver side: rear,not installed,
MAS00039,Seat occupied recognition: passenger side: rear,not installed,
MAS00040,Seat occupied recognition: center: rear,not installed,
MAS00044,Supply voltage: Terminal 15,14.6, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:12
17:
;SW:3G0-920-890-E HW:3G0-920-890-E --- Instruments
;Component:KOMBI 503 4193, Coding:08A420086788CF050288624B10010000A0000D07
;EV_DashBoardVDDMQBA0,001042,EV_DashBoardVDDMQBA0_VW37.rod
;Thursday,18,June,2020,11:50:24:14741
;VCID: AB08ECE613862903569-80FE
IDE00019,Voltage terminal 30,11.4, V
IDE00021,Engine speed,1188.00, /min
IDE00025,Coolant temperature,20.25, °C
IDE00075,Vehicle speed,0, km/h
IDE00191,Charge air pressure: actual value,20.40, %
IDE00196,Engine oil temperature,20, °C
IDE00301,Distance,57, km
IDE00310,Outside air temperature,23.0, °C
IDE00316-IDE00500,Time-Hour,11, H
IDE00316-IDE00501,Time-Minute,49, min
IDE00316-MAS00111,Time-Seconds,9, s
IDE00317-IDE00502,Date-Year,2020, yr
IDE00317-IDE00503,Date-Month,6, mon
IDE00317-IDE00504,Date-Day,18, d
IDE00510,ESI: distance driven from inspection,57, km
IDE00511,ESI: time from inspection,106, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,300, km
IDE00520,Phototransistor,253,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,16050, km
IDE00698,ESI: remaining running time,259, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,106, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2205, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2205, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,80967, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,not activated,
IDE02642,Outside temp.: displayed value,23.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,236,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,106, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,8.9, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,57.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,60.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,8.4, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,3.8, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,10.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,9.7, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,3.5, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,2.8, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,8.7, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,8.7, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,2.8, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,0,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,75, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,-2, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,1141,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,2366,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,57.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,73, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,56.3, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-56.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,56.3, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,56.3, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,56.3, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.01,
IDE03474-ENG101623,Calculated volume-reference_volume,57.7, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,133,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0024996,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,16, H
IDE03477-IDE00501,GPS time-Minute,50, min
IDE03477-IDE00501,GPS time-Minute,49, min
IDE03477-IDE00502,GPS time-Year,2020, yr
IDE03477-IDE00503,GPS time-Month,6, mon
IDE03477-IDE00504,GPS time-Day,18, d
IDE03477-MAS00111,GPS time-Seconds,24, s
IDE03477-MAS00111,GPS time-Seconds,45, s
IDE03477-MAS03493,GPS time-last synchronization year,2020, yr
IDE03506,Distance: high resolution,00 00 E0 41,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,FF FF FF FF,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,FF FF FF FF,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,FF FF FF FF,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,FF FF FF FF,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,730, d
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,00,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,00,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,85 CE F5 E0,
IDE08240,Transponder ID Key 2,A5 0A F1 E0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Softwareversion,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,FA 34 CC C8,
IDE08343,Immobilizer Challenge,91 72 C7 31,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,91 77 03 E0 1A 57 B5 85 58 71 3C A5 78 A4 F0 44,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,A0 B4 25 D9,
IDE14186-MAS17993,Communication transponder-Phase value,16,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
MAS00077-ENG99298,Immobilizer-State,02 01 03 76 02 00 00 00 15 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG119259-ENG119523,Condition_check_1-State_info_1,4,
ENG119259-ENG119409,Condition_check_1-State_info_2,1,
ENG119259-ENG119615,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG119260-ENG119523,Condition_check_2-State_info_1,4,
ENG119260-ENG119409,Condition_check_2-State_info_2,1,
ENG119260-ENG119615,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,100, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,97, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG99439,Instrument_recorder,06 41 93 00 46 50 4B 45 56 57 07 39 53 31 08 41 43 35 44 0B 65 33 63 30 37 31 5F 06 00 01 00 B0 00 1F 00 00 01 E8 00 00 00 00 80 00 00 00 00 05 A4 96 AA C8 52 90 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 1F 00 B0 00 E8 01 00 00 00 00 00 00 96 A4 05 00 90 52 C8 AA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 26 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 41 93 00 46 50 4B 45 56 57 07 39 53 31 09 47 43 5F 56 57 0B 00 00 00 F9 00 0F 00 00 04 A0 00 00 00 00 00 03 00 05 A8 5A 5E BC 97 C3 00 00 04 5F 00 84 00 8B 00 5E 00 00 00 00 00 00 00 05 9F FE EF 6D A3 C0 00 00 01 DE 00 46 00 00 00 E8 00 00 00 00 00 03 00 05 A1 10 A7 04 41 20 00 00 04 82 00 86 00 1C 00 80 00 00 00 00 00 00 00 05 A1 93 C2 6D 85 24 00 00 04 82 00 86 00 1C 00 AC 00 00 00 00 00 00 00 05 A1 93 C2 72 0F FC 00 00 03 6A 00 6C 00 00 00 22 00 00 00 00 00 00 00 05 A8 5A 61 1A 83 EC 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107920-ENG98868,onboard_computer-Range,592, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,9.1, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,9.1, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,9.8, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,592, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,146,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,14,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Start_Delay,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG30183,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG30184,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG30185,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:26
19:
;SW:3Q0-907-530-AC HW:3Q0-907-530-C --- CAN Gateway
;Component:GW MQB High 521 5388, Coding:030100347F085900FA000258180F00010001070000000000000000000000
;EV_GatewNF,013026,EV_GatewNF_VW37.rod
;Thursday,18,June,2020,11:50:55:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: F0B23B8AFA200ADB23B-80A4
Group,Description,Actual
IDE00019,Voltage terminal 30,14.5, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00030,Status of actuator test,not active,
IDE00056-ENG20489,History data 1-Life Cycle Data String,2020-06-18-11:47*17.3*01*00829***
2020-06-17-13:10*01.2*01**
2020-06-16-12:20*24.0*01**
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String,2020-05-01-08:54*T*0*077*070*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-05-01-07:16*T*0*080*073*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-29-14:45*T*0*080*079*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-28-08:01*T*0*077*074*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-28-06:47*T*0*081*081*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-27-11:44*T*0*080*079*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-27-08:51*T*0*082*081*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-27-08:18*T*0*084*084*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-27-05:25*T*0*084*085*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-24-12:35*T*0*084*085*0-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String, 0000000km*01*070*JCB*1111111111*09974*00073*000.0*000.0*000.0**
IDE00060-ENG20489,History data 5-Life Cycle Data String,-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489,History data 6-Life Cycle Data String,2020-06-17-13:12*057*+23*+001.1*00.10*0.00*000**
2020-06-13-11:56*052*+28*-000.3*00.00*0.00*000**
2020-06-13-08:48*060*+24*-000.2*00.00*0.00*000**
2020-06-08-17:16*066*+36*+000.1*00.00*0.00*000**
2020-06-06-15:12*059*+33*+000.8*00.00*0.00*000**
2020-06-06-13:33*060*+30*+000.4*00.00*0.00*000**
2020-05-27-14:49*064*+30*+004.1*00.10*0.00*000**
2020-05-22-15:46*061*+20*-000.2*00.00*0.00*000**
2020-05-20-18:07*061*+23*+000.8*00.00*0.00*000**
2020-05-20-16:24*065*+21*+000.4*00.00*0.00*000**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,2020-06-17-13:19*060*+000.4*022.6*00.0*00.0**
2020-06-13-11:57*057*+001.2*073.6*00.0*00.0**
2020-06-13-08:48*060*+000.2*003.1*00.0*00.0**
2020-06-08-17:19*062*+001.3*063.7*00.0*00.0**
2020-06-06-15:15*062*+000.7*050.1*00.0*00.0**
2020-06-06-13:35*058*+000.2*001.5*00.0*00.0**
2020-05-27-15:00*059*+002.5*191.3*00.0*00.0**
2020-05-27-13:59*060*+000.4*000.8*00.0*00.0**
2020-05-22-15:46*060*+001.6*094.5*00.0*00.0**
2020-05-20-18:12*065*+000.6*045.7*00.0*00.0**,
IDE00063-ENG20489,History data 8-Life Cycle Data String,2020-05-01-11:16*4*03*00*00*02*2020-05-01-09:14*01**
2020-03-04-03:30*1*03*00*00*01*-------------:--*01**
2020-03-04-02:26*1*02*00*00*01*-------------:--*01**,
IDE00064-ENG20489,History data 9-Life Cycle Data String, 0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
IDE00065-ENG20489,History data 10-Life Cycle Data String,2020-06-08-17:10*1*000.0*0000.0*0*000.0*0000.0*00.00*0000000**
IDE00066-ENG20489,History data 11-Life Cycle Data String,2020-06-08-17:16*000*000*000*002*0000*003*00.0*00.3*074*066*074*066*01*00001*00002*00000*00010*00021**
2020-06-08-17:10*000*000*000*000*0000*006*00.0*00.0*071*059*074*065*01**
2020-05-22-15:46*000*000*000*000*0000*000*00.0*00.1*071*060*070*061*01**
2020-05-20-16:24*000*000*000*002*0000*003*00.0*00.6*070*061*070*065*01**
2020-05-19-15:49*000*000*000*000*0000*000*00.0*00.0*070*061*070*058*01**,
IDE00067-ENG20489,History data 12-Life Cycle Data String,-------------:--*---------------**
IDE00068-ENG20489,History data 13-Life Cycle Data String,-------------:--*---------*---.-*-----**
IDE00069-ENG20489,History data 14-Life Cycle Data String,2020-06-18-11:48*3*00000*0020*0010*00.00*000014*+22*0000.6*0000.0*0000.0**
2020-06-17-13:12*3*00000*0019*0011*00.10*000014*+23**
2020-06-13-11:56*3*00000*0003*0012*00.00*000014*+28**
2020-06-13-08:48*3*00000*0000*0010*00.00*000014*+24**
2020-06-08-17:16*3*00000*0018*0012*00.00*000014*+36**
00055*00070*00014*00000*00000**
IDE00071-ENG20489,History data 16-Life Cycle Data String, 0000057km**
00011*00044*00045*00000*00000**
00055*00015*00002*00001**
00463*00004*00001*00000**
00057*00014*00001*00002**
00065*00009*00000**
00000*00000*00000*00000**
00013*00000*00000**
00000*00000*00000**
00004*00000*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,1,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,244,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE00773,Terminal 15 status via CAN,On,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Databus extended,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.2, H
IDE01810-MAS00106,History data 24-Year,2020,
IDE01810-MAS00107,History data 24-Month,5,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,8, H
IDE01810-MAS00110,History data 24-Minutes,30, min
IDE01810-MAS14375,History data 24-Cycle counter,75,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,24,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,12 DD 54 71,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,1,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Comfort data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,1B 00 00 0E,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 00 00,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,0,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Unknown,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,105,
IDE01812-MAS03173,History data 26-Databus drivetrain,2,
IDE01812-MAS03174,History data 26-Comfort data bus,383,
IDE01812-MAS03175,History data 26-Databus extended,0,
IDE01812-MAS03177,History data 26-Databus Infotainment,0,
IDE01812-MAS03178,History data 26-Suspension data bus,3,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,388,
IDE01813-MAS03173,History data 27-Databus drivetrain,64,
IDE01813-MAS03174,History data 27-Comfort data bus,456,
IDE01813-MAS03175,History data 27-Databus extended,0,
IDE01813-MAS03177,History data 27-Databus Infotainment,41,
IDE01813-MAS03178,History data 27-Suspension data bus,50,
IDE01813-MAS14374,History data 27-Totals,611,
IDE01814-MAS03173,History data 28-Databus drivetrain,0,
IDE01814-MAS03174,History data 28-Comfort data bus,675,
IDE01814-MAS03175,History data 28-Databus extended,0,
IDE01814-MAS03177,History data 28-Databus Infotainment,0,
IDE01814-MAS03178,History data 28-Suspension data bus,3,
IDE01814-MAS14374,History data 28-Totals,679,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,49.9, H
IDE01816-MAS00106,History data 30-Year,2020,
IDE01816-MAS00107,History data 30-Month,6,
IDE01816-MAS00108,History data 30-Day,8,
IDE01816-MAS00109,History data 30-Hours,17, H
IDE01816-MAS00110,History data 30-Minutes,16, min
IDE01816-MAS14375,History data 30-Cycle counter,101,
IDE01816-ENG20570,History data 30-Bus_1,Suspension data bus,
IDE01816-ENG20572,History data 30-Bus_2,Databus drivetrain,
IDE01816-ENG20574,History data 30-Bus_3,Comfort data bus,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.1, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.1, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.1, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.2, H
IDE01819-MAS00106,History data 33-Year,2020,
IDE01819-MAS00107,History data 33-Month,5,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,8, H
IDE01819-MAS00110,History data 33-Minutes,30, min
IDE01819-MAS14375,History data 33-Cycle counter,75,
IDE01819-MAS14393,History data 33-ID of the alerting message,12 DD 54 71,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,22.4, H
IDE01820-MAS00106,History data 34-Year,2020,
IDE01820-MAS00107,History data 34-Month,6,
IDE01820-MAS00108,History data 34-Day,18,
IDE01820-MAS00109,History data 34-Hours,11, H
IDE01820-MAS00110,History data 34-Minutes,48, min
IDE01820-MAS14375,History data 34-Cycle counter,105,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,4, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,106,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Generator specified voltage value,14.7, V
IDE01828,Generator DF Signal,29.050, %
IDE01829,Generator exciter current,2.250, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82 - 140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.684, V
IDE01836,Battery current,16.568, A
IDE01837,Temperature of battery sensor,23, °C
IDE01838,Battery temperature,22, °C
IDE01839,Battery charge condition,69, %
IDE01841,Battery internal resistance,4.4, mOhm
IDE01842,Usable battery charge,59, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,0.1, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initializing,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,52.2, A
IDE01948,Battery internal resistance not normed,4.4, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,DD DC 85 16,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,0,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,70, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB+,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,invalid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,not activated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,not activated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,not activated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,not activated,
IDE05583-IDE02766,Pause recommendation-Malfunction status,not installed,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,not active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,not engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,not engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,64 4B C8 44 68,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,no function,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,0,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,0,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop - operation,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.6, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,blocked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,blocked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,blocked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
IDE07637,Current charge contingent for feedback,360.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.05,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.05, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.05, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,864, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,848, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,48.0, Ah
IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,73.5, Ah
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Not Used,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,Not Used,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Not Used,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,Not Used,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,9F DB 97 9C,
IDE08346-MAS06117,Generator Analysis-Rated voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.7, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.1, V
IDE08346-MAS06866,Generator Analysis-Generator speed,2880, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,24, °C
IDE08347,adapted battery capacity,118, Ah
IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,01 3E,
IDE08685-SFT09757,Status LIN user-Alternator,not active,
IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT09833,Status LIN user-Power Converter DC AC,not active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,not active,
IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Closed-circuit current of last LIN sleep phase,-2.056, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084,Status of component protection slaves,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 21 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,256,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.60, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.65, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,10.6, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14),
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initializing,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*0000-01-01-00-00-00*0**,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,50,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,16,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,57, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,14,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT09757,Alternator,-,
SFT09757-ENG119789,Alternator-alternator_family,35,
SFT09757-ENG114913,Alternator-asic_manufacturer,30 30,
SFT09757-ENG119379,Alternator-asic_variant,30 34,
SFT09757-ENG40398,Alternator-Manufacturer,30 30,
SFT09757-ENG99001,Alternator-Variant,31 34,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,1,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
ENG118766,eASS_operation_status,active,
ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG20108,EM_electrical_system_current,33.333, A
ENG118437,EM_IAlternatorReserve,117.4, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,900, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,92, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,86, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,101F,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,6710,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9112,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,0503,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7210,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initializing,
ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initializing,
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initializing,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,-204.0, A
ENG20120,MV-EM_dc_power_desired,-6325, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,-511, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG119298-ENG119462,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:47
3C:
;SW:2Q0-907-686-B HW:2Q0-907-686-B --- Lane Change
;Component:HRE3_Kl15_Mst H06 0148, Coding:52954640
;EV_HREntryHellaGen3Kl15,002001,EV_HREntryHellaGen3Kl15.rod
;Thursday,18,June,2020,11:55:39:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: B924C6AEE9DA8B93D45-80EC
Group,Description,Actual
IDE00018,Voltage terminal 15,14.40, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00102,Control Module temperature,42.0, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00925,Yaw rate,0.04, °/s
IDE01441,Back-up light,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not recognized,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,12.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,3.20,
IDE02486,Data logger triggering,not initialize,
IDE03619,System status,On,
IDE05064,lane change assist. 2: supply voltage,14.40, V
IDE05065,lane change assist. 2: temperature,40.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,OFF,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,passive,
IDE05067-SFT00060,Functional status of lane change assist.-Lane Change Assistant,passive,
IDE05070,Curve radius,19456, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,7,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,823,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,25.25, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,15.88, m
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,90.25, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,25.25, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,15.88, m
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,90.25, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,25.25, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,15.88, m
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,90.25, m/s
IDE05084,Closest object left lane,No_Object,
IDE05085,Closest object right lane,No_Object,
IDE05086,Closest object lane used,No_Object,
IDE05087,Dynamic angle offset lane change assist. 1,-4.30, °
IDE05088,Dynamic angle offset lane change assist. 2,3.20, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,-20.48, °
IDE05093,Measured angle lane change assist. 2,-20.48, °
IDE05094,Static angle offset lane change assist. 1,10.24, °
IDE05095,Static angle offset lane change assist. 2,10.24, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG39349,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG39349,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG39349,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane holding warn. syst.-LED,yellow,
IDE10236-MAS10041,Lane holding warn. syst.-Distance to lane,1.25, m
IDE10236-MAS10042,Lane holding warn. syst.-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane holding warn. syst.-Vehicle side,Right,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG39349,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
IDE13096,Rear cross traffic assistant: left warning level,RCTA_hat_links_nichts_erkannt,
IDE13107,Rear cross traffic assistant: right warning level,RCTA_hat_rechts_nichts_erkannt,
IDE80001,Analysis 1,No display,
IDE80002,Analysis 2,keine_Anzeige,
IDE80004,Analysis 4,keine_Anzeige,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System status,System off,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,25.25, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,15.88, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,25.25, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,15.88, m
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,90.25, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,90.25, m/s
MAS12659-IDE00007,VW/Audi part numbers of sub-bus users-VW/Audi part number,2Q0907685B ,
MAS12659-MAS01170,VW/Audi part numbers of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12659-ENG39145,VW/Audi part numbers of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12659-ENG39146,VW/Audi part numbers of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12659-ENG39149,VW/Audi part numbers of sub-bus users-SubSystem Node Address,00 3B,
MAS12660-IDE00016,Hardware version number of sub-bus users-Hardwareversion,H06,
MAS12660-MAS01170,Hardware version number of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12660-ENG39145,Hardware version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12660-ENG39146,Hardware version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12660-ENG39149,Hardware version number of sub-bus users-SubSystem Node Address,00 3B,
MAS12661-IDE00008,Software version number of sub-bus users-Softwareversion,0148,
MAS12661-MAS01170,Software version number of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12661-ENG39145,Software version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12661-ENG39146,Software version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12661-ENG39149,Software version number of sub-bus users-SubSystem Node Address,00 3B,
MAS12662-IDE00012,Hardware part number of sub-bus users-Hardware part number,2Q0907685B ,
MAS12662-MAS01170,Hardware part number of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12662-ENG39145,Hardware part number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12662-ENG39146,Hardware part number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12662-ENG39149,Hardware part number of sub-bus users-SubSystem Node Address,00 3B,
MAS12663-IDE00010,Series number of sub-bus users-Serial number,11230021516678 ,
MAS12663-MAS01170,Series number of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12663-ENG39145,Series number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12663-ENG39146,Series number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12663-ENG39149,Series number of sub-bus users-SubSystem Node Address,00 3B,
MAS12665-MAS00966,FAZIT identifications of sub-bus users-Manufacture location index,YRK-HEC,
MAS12665-MAS00968,FAZIT identifications of sub-bus users-Day of manufacture,15.01.20,
MAS12665-MAS00969,FAZIT identifications of sub-bus users-Manufacturer- test stand number,6CC1,
MAS12665-MAS00970,FAZIT identifications of sub-bus users-Running manufacturer number,4921,
MAS12665-MAS01170,FAZIT identifications of sub-bus users-Subsystem designation,Lane Change Assistant 2,
MAS12665-ENG39145,FAZIT identifications of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12665-ENG39146,FAZIT identifications of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12665-ENG39149,FAZIT identifications of sub-bus users-SubSystem Node Address,00 3B,
MAS12666-MAS01170,SubSystemNodeAddress of sub bus participant-Subsystem designation,Lane Change Assistant 2,
MAS12666-ENG39149,SubSystemNodeAddress of sub bus participant-SubSystem Node Address,00 3B,
MAS12667-ENG39148,Specified installation of sub-bus users-SubSystem coded Bit 0,Yes,
MAS12667-ENG45626,Specified installation of sub-bus users-SubSystem coded Bit 1,No,
MAS12667-ENG45625,Specified installation of sub-bus users-SubSystem coded Bit 2,No,
MAS12667-ENG45624,Specified installation of sub-bus users-SubSystem coded Bit 3,No,
MAS12667-ENG45623,Specified installation of sub-bus users-SubSystem coded Bit 4,No,
MAS12667-ENG45622,Specified installation of sub-bus users-SubSystem coded Bit 5,No,
MAS12667-ENG45621,Specified installation of sub-bus users-SubSystem coded Bit 6,No,
MAS12667-ENG45620,Specified installation of sub-bus users-SubSystem coded Bit 7,No,
MAS12668-ENG39150,Actual installation of sub-bus users-SubSystem present Bit 0,can be reached,
MAS12668-ENG45633,Actual installation of sub-bus users-SubSystem present Bit 1,cannot be reached,
MAS12668-ENG45632,Actual installation of sub-bus users-SubSystem present Bit 2,cannot be reached,
MAS12668-ENG45631,Actual installation of sub-bus users-SubSystem present Bit 3,cannot be reached,
MAS12668-ENG45630,Actual installation of sub-bus users-SubSystem present Bit 4,cannot be reached,
MAS12668-ENG45629,Actual installation of sub-bus users-SubSystem present Bit 5,cannot be reached,
MAS12668-ENG45628,Actual installation of sub-bus users-SubSystem present Bit 6,cannot be reached,
MAS12668-ENG45627,Actual installation of sub-bus users-SubSystem present Bit 7,cannot be reached,
MAS12669-ENG39147,Bus identification of sub-bus users-Bus ID,1,
MAS13422-IDE00013,System description of sub bus participant-System description,HRE3_Kl15_Slv,
MAS13422-MAS01170,System description of sub bus participant-Subsystem designation,Lane Change Assistant 2,
MAS13422-ENG39145,System description of sub bus participant-Number Of Expected SubSystem Identification,1,
MAS13422-ENG39146,System description of sub bus participant-Number Of Retrieved SubSystem Identification,1,
MAS13422-ENG39149,System description of sub bus participant-SubSystem Node Address,00 3B,
MAS18838,Auto-calibration: adaptive angle correction characteristic curve (slave),0, %
MAS18839,Auto-calibration: adaptive angle correction characteristic curve,0, %
MAS18840-MAS04108,Distance of object 6-Distance in X-direction,25.25, m
MAS18840-MAS04109,Distance of object 6-Distance in Y-direction,15.88, m
MAS18841-MAS02469,Relative speed of object 6-Speed in x-direction,90.25, m/s
Elapsed Time: 00:09
42:
;SW:5Q4-959-393-K HW:5Q4-959-393-K --- Door Elect, Driver
;Component:TSG FS 007 0485, Coding:00301B200000048000000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHKLO.rod
;Thursday,18,June,2020,11:55:50:14741
;VCID: CBC88C66B3460903769-809E
IDE00310,Outside air temperature,22.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.20, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.50, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE02668,Central window regulator switch,not installed,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-install,not installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,100, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,not activated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,3K02,
IDE06933,Front window regulator relay: driver side,Open,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,14.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07222,Window regulator child lock: driver side,Not available,
IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,32, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,42, °C
IDE07413,Comfort function for front window regulator: driver side,not active,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not installed,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote release button,not activated,
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,Not available,
ENG117315-ENG32834,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
44:
;SW:5QM-909-144-C HW:5QM-909-144-B --- Steering Assist
;Component:EPS_MQB_ZFLS 173 1082, Coding:111F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Thursday,18,June,2020,11:56:01:14741
;VCID: D1F49E0E516A23D30C5-8084
IDE00018,Voltage terminal 15,14.55, V
IDE00019,Voltage terminal 30,14.46, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,804, /min
IDE00102,Control Module temperature,32.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,06,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,A6,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,04,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,operational,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assistant-Function status,activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,25.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02486,Data logger triggering,not active,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,0, /min
IDE03682-MAS02961,Sensor for motor position-Engine angle,-42.8, °
IDE03682-MAS03083,Sensor for motor position-Cosine signal,2.009, V
IDE03682-MAS03211,Sensor for motor position-Sine signal,2.692, V
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,Dynamic,
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-6.0, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,-0.194, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,-0.194, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-2.3, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-2.3, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,2, N
IDE04183,Steering assistance: target engine torque,-0.023, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,14.51, V
IDE04186,Battery terminal recognition,connected,
IDE04187,Steering torque: raw value 1,-55.078, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-63.379, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,-55.078, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-63.379, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.38, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.42, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.37, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,-0.3, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.8, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,-0.5, A
IDE04194,Steering assistance: electromotor power,0.00, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-4.8, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.1, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,156.47, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.09, mm
IDE04460,Steering angle sensor: offset straight line running,2.1, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,Initializing,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05155,Power steering current consumption,0.00, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,78.32, mm
IDE05162-MAS01850,Software end stop-Right,-78.15, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,928,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,1031,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,341,
IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,341,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,27728,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,7,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,9,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,532,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,54,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,51,
MAS00976-IDE80003,Counter-Analysis 3,579040471,
MAS00976-IDE80004,Counter-Analysis 4,93242,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,33.0, °C
ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,93242,
ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,0,
ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,579049440,
ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG37819-ENG102605,Strain_detection-outside_temperature,22.5, °C
ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,3, /min
ENG37819-ENG26208,Strain_detection-Steering_angle,-4.8, °
ENG37819-ENG37919,Strain_detection-steering_moment,-0.194, Nm
ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,-0.027, Nm
ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000007003, %
Elapsed Time: 00:07
52:
;SW:5Q4-959-392-K HW:5Q4-959-392-K --- Door Elect, Pass.
;Component:TSG BFS 007 0485, Coding:003013200000048000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHKLO.rod
;Thursday,18,June,2020,11:56:11:14741
;VCID: CAC68962BC3C100B4DF-809E
IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear passenger side door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.20, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.60, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,3K02,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,32, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,42, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,14.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
ENG117316-ENG32834,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:07
5F:
;SW:2GM-035-876-B HW:2GM-035-876-B --- Information Electr.
;Component:MU-S-NS-US 854 0520, Coding:02730602BE00000051220001001808211F0500E401200405C6
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Thursday,18,June,2020,11:56:21:14741
;VCID: C5DCBA5E9522FF73A0D-8090
IDE00019,Voltage terminal 30,14.6, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,808.00, /min
IDE00668-MAS03231,Microphone current consumption-Microphone 1,6.00, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Condition not met,
IDE00916-IDE02128,Speaker status-Right front speaker,Condition not met,
IDE00916-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE00916-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,084°06'41.44"W,
IDE01712-MAS01780,GPS Position-Width,035°54'19.75"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,26,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,28,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,62, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,50, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,52, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,52, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,not installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,1,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,50, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth partially visible: connection possible,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,Sleep mode,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03151-ENG20551,TP CAN identifier-ECU TP-CAN-Identifier-Request Bit 0,1907,
IDE03151-ENG20550,TP CAN identifier-ECU TP-CAN-Identifier-Response Bit 0,2013,
IDE03477-MAS00106,GPS time-Year,2020,
IDE03477-MAS00107,GPS time-Month,6,
IDE03477-MAS00108,GPS time-Day,18,
IDE03477-MAS00109,GPS time-Hours,15,
IDE03477-MAS00110,GPS time-Minutes,56,
IDE03477-MAS00111,GPS time-Seconds,23,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,6, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,7, H
IDE04317-MAS00110,Total system run time-Minutes,28, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04344-ENG20451,Control module assignment-ECU ID,5F,
IDE04344-ENG20480,Control module assignment-ECU Name,Information Control Unit 1,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.510, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,Position finding possible even without GPS,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,084°06'41.58"W,
IDE04605-MAS01780,Navigation: Corrected position-Width,035°54'20.04"N,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.2, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.3, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 2,
IDE04649-MAS06857,Activation for housing fan-Speed,4980, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,58 16 D7 48 FA 77,
IDE05040-MAS01632,Video input status-Status,valid,
IDE05040-MAS04390,Video input status-Active source,Rearview camera,
IDE05536-MAS01632,GPS almanac-Status,invalid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,00 00 00 00 00 00,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,--
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),00 00,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),00 00,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,--
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,--
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,00 00,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,00 00,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,00 00,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,00 00,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,00 00,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,00 00,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,00 00,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,00 00,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,00 00,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,00 00,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,00 00,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,00 00,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,00 00,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,00 00,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,00 00,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,00 00,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,00 00,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05726,Terminal 58xd dimmer,99.94, %
IDE05814,Individualization characteristic,08 A8 77 00 23,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-1,
IDE06028-MAS04414,Control head button operation-Volume control,1,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,103,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,01-00-01---,
IDE11034-MAS11961,Satellite radio: module information-Serial number,QX87XA0Z,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 08 00 51 58 38 37 58 41 30 5A 00 02 98 07 8A 38 64 68 F5 31 71 89 46 FF 18 07 8C 8C 1F 25 5C B6 31 38 40 B0 00 08 00 66 03 41 00 09 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,0b-26-00---,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,02-04-04---,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,03-05-00---,
IDE11034-MAS11966,Satellite radio: module information-Database Version,02-04-04--A,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,55,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,25,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,57, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,5, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,40, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,14.5, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,71, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,51, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,98.7, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,51, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,52, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,51, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,20, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,6, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,18, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,10, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,47, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,23, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,134, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2034,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,31,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,63,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,63,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,0,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG127487-IDE02451,SDARS_tuner_status_2-Satellite radio antenna status,Electrical OK,
ENG127487-IDE02453,SDARS_tuner_status_2-Channel selection for satellite radio,1,
ENG127487-MAS01765,SDARS_tuner_status_2-Audio Signal,Available,
ENG127487-MAS01808,SDARS_tuner_status_2-Antenna current,96, mA
ENG127487-MAS02573,SDARS_tuner_status_2-Reception quality,optimum_signal,
ENG127487-MAS13343,SDARS_tuner_status_2-Satellite radio tuner: pre-activation status,07,
ENG127487-MAS13344,SDARS_tuner_status_2-Satellite radio tuner: pre-activation value,07,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not available,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,65535,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,65535,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,60, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,0, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,44, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,53, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,0, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,33, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,58, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,0, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,42, °C
Elapsed Time: 00:24
6C:
;SW:5Q0-980-556-B HW:5Q0-980-556-B --- Back-up Cam.
;Component:RVC Compact H18 0231, Coding:0123060122002017300040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB.rod
;Thursday,18,June,2020,11:56:48:14741
;VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
;VCID: B924C6AEE9DA8B93D45-80EC
Group,Description,Actual
IDE00019,Voltage terminal 30,14.45, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00303-MAS00222,Status of doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status of doors/lids 1-Hood,Measured value not available,
IDE00303-MAS01374,Status of doors/lids 1-Trailer,detected,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00773,Terminal 15 status via CAN,On,
IDE00924-IDE08941,Steering angle-Rack position,0.000, mm
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.800, °
IDE00924,Steering angle,0.300, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.000, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01714,Status reverse gear,not selected,
IDE03619,System status,passive,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07402,External activation,Not available,
MAS00037-MAS05746,Calibration status-Rearview camera calibration status,Calibration ended,
MAS00037-MAS05748,Calibration status-Rearview camera calibration progress,100, %
MAS00037-MAS05750,Calibration status-Rearview camera calibration repeat attempts,0,
MAS00037-MAS05753,Calibration status-Cause of rearview camera calibration error,no error,
MAS00037-MAS05803,Calibration status-Rearview camera calibration resumption,No resumption,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,33,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2, counts
ENG119197-ENG128717,camera_calibration_parameters-Cam0 Calibration binary threshold,00,
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 20 41,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,0, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,1,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,0,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,1145928909, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,1101004800, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,half size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,3220386611, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,3220386611, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,1166536704, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,1067953684, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,3216192307, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,1043878380, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,1045891645, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,0, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,0, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,1091515264, mm
Elapsed Time: 00:02
6D:
;SW:5Q0-959-107-S HW:5Q0-959-107-J --- Trunk Elect.
;Component:HDSG-Modul H13 0271, Coding:0A08
;EV_DeckLidCONTIAU736,001017,EV_DeckLidCONTIAU736_VW37.rod
;Thursday,18,June,2020,11:56:53:14741
;VCID: C8C2B36AA230E21B5BB-809C
IDE00019,Voltage terminal 30,14.55, V
IDE00542,Excessive temperature protection,not active,
IDE02010,Motor 1 for rear lid: activation,0, %
IDE02011,Motor 1 for tailgate: current,0.00, A
IDE02013,Motor 2 for rear lid: activation,0, %
IDE02014,Motor 2 for tailgate: current,0.00, A
IDE02017,Rear lid position: relative,0, %
IDE02018,Rear lid position: absolute,0,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,99, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,1533,
IDE02049,Trailer detected,Not available,
IDE02093-MAS09014,Status of rear lid lock-Safety catch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main catch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,not activated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,not activated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,not activated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,not activated,
IDE02171-MAS01913,Terminals for closing assist-Pull-shut asst.,not locked,
IDE02171-MAS01943,Terminals for closing assist-Terminal 1,Open,
IDE02171-MAS01944,Terminals for closing assist-Terminal 2,Open,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,1543,
IDE03615-MAS02672,Version-Start-stop,2,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,OFF,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
IDE05584,Rear lid basic setting status,Unknown (7),
IDE09491-IDE03434,Lock-in area-Detection area lower,70,
IDE09491-IDE03435,Lock-in area-Detection area upper,20,
IDE09492-MAS06165,Temperatures-Processor,35.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,22.00, °C
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,29.00, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,37.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,23.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,23.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,37.00, °C
IDE09492-MAS09053,Temperatures-Output stage for pull-shut assist.: calc.,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,31.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,37.00, °C
IDE09493,Status of basic tailgate setting,Basic setting not active,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Cancel,
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Cancel,
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Cancel,
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Cancel,
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,was cancelled due to safety reasons,
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Reset,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Position overrun,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Position overrun,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Position overrun,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,not activated,
IDE09498-MAS01872,Status of control points-Rear lid remote release button,not activated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,not activated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,not activated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,not activated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,ERROR,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,ERROR,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,OFF,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.57, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,29,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,33,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,6,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,1,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,24,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,29,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,7,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,3,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,5,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,0,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,2,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,4,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,13,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,265,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,0,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,1,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,5,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09506,Tailgate play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000000 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000000 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000000 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000000 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,0,
IDE10697-MAS02282,Luggage compartment cover: position-Position,0,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initializing,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,not active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,6,
Elapsed Time: 00:06
75:
;SW:5WA-035-283 HW:5WA-035-283 --- Telematics
;Component:OCUGen3Low H10 0295, Coding:0232602019682C208005461160100607
;EV_OCUGen3Low,002036,EV_OCUGen3Low_002_VW37.rod
;Thursday,18,June,2020,11:57:02:14741
;VCID: 82566142C48C084BC5F-80D6
IDE00019,Voltage terminal 30,14.4, V
IDE00102,Control Module temperature,37, °C
IDE00608,Type of fuel,Petrol,
IDE00667-MAS03231,Microphone status-Microphone 1,Electrical OK,
IDE00667-MAS03232,Microphone status-Microphone 2,Not available,
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.7, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,0.0, mA
IDE00672,Roadside Assistance Button,not activated,
IDE00673,Information Service Button,not activated,
IDE00767,No. of unscheduled ECU resets,2,
IDE01215,Terminal 58d dimmer,Measured value not available,
IDE01216,Terminal 58s dimmer,100, %
IDE01588,Driving direction,128, °
IDE01588-MAS01632,Driving direction-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Button lighting in control unit for phone-Actuation time,0 s,
IDE01630-ENG39349,Button lighting in control unit for phone-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG39349,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,84°6'41.6"W,
IDE01712-MAS01780,GPS Position-Width,35°54'19.9"N,
IDE01712-MAS02230,GPS Position-Height,288, m
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01971,Lowest recorded control module temperature,3, °C
IDE01972,Highest recorded control module temperature,57, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,64, %
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,3,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,6,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,7,
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,46, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,44, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,50, dBµV
IDE03477-MAS00111,GPS time-Seconds,58,
IDE04293,Operating state for emer call module,registerstate_registered,
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03878,SIM cards-SIM IMSI,311480947938595,
IDE04750-MAS04226,SIM cards-Telephone number, ,
IDE04750-MAS08401,SIM cards-SIM intern,operational,
IDE04750-MAS08402,SIM cards-SIM extern,Unknown,
IDE04750-MAS11003,SIM cards-ICCID,89148000005845852581,
IDE04750-MAS11004,SIM cards-UICCID,89033023312150000000000768075207,
IDE04790,Call for help button,not activated,
IDE05430,Telephone serial number,015278001287296,
IDE05431-MAS01167,Locking for H-V charge plug-Actuation time,0 s,
IDE05431-ENG39349,Locking for H-V charge plug-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,A/C heater function via remote control-Actuation time,0 s,
IDE07007-ENG39349,A/C heater function via remote control-IoReached Status,Output diagnostic test not active,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2020,
IDE07589-MAS00107,Update programming: status-Month,3,
IDE07589-MAS00108,Update programming: status-Day,4,
IDE07589-MAS00109,Update programming: status-Hours,6,
IDE07589-MAS00110,Update programming: status-Minutes,13,
IDE07589-MAS00111,Update programming: status-Seconds,42,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG39349,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charge function of H-V battery-Actuation time,0 s,
IDE07975-ENG39349,Remote control for charge function of H-V battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG39349,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 76 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,62 13 89 5F,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,64, %
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge condition,96, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG39349,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VV3B7AX1LM125622,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2020, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,5, mon
IDE13957-MAS00108,Mobile Online Service: connection status-Day,1, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,9, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,14, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,2, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2020, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),5, mon
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),1, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),15, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),15, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),10, s
IDE13957-ENG20907,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, mon
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,Not available,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, mon
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, mon
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG115012,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG115183,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG115048,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG115207,Mobile Online Service: service status-status_second_last_ok,65535,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,76,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,56,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,996, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,122,
MAS03615-MAS01167,Establishing a connection-Actuation time,0 s,
MAS03615-ENG39349,Establishing a connection-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country code for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,64, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,41728790,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,Electrical OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG39349,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,54 s,
MAS16678-ENG39349,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG39349,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,0230,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest# ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
ENG123206,Antenna_Switch,LTE antenna 1,
ENG123492-ENG124418,Backup_Battery_SoH-BUB_ci,1115804387,
ENG123492-ENG124985,Backup_Battery_SoH-mcharge_time,3179, s
ENG123492-ENG125013,Backup_Battery_SoH-mSoH,85,
ENG123492-ENG125230,Backup_Battery_SoH-rSoH,85,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.70.205.86,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,8224,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,8224,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4294967295, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,8224,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,no error,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,8224,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,13824,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,65535,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,65535,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,65535,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,65535,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,8224,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,11832,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,8447,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,35,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,8224,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,65535, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,ERROR,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,775041077, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,65535,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808335152, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,no error,
ENG114618,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG116737,Position_Confidence,37, m
ENG26349-MAS04460,Scan_Network_List-Validity,valid,
ENG26349-MAS08406,Scan_Network_List-Network type,LTE,
ENG26349-MAS08406,Scan_Network_List-Network type,UMTS,
ENG26349-MAS08406,Scan_Network_List-Network type,GSM,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,310,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,313,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,311,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,580,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,100,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,260,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,480,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,490,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,410,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,589,
ENG116740-ENG28257,Second_Last_Position-Latitude,--------------,
ENG116740-ENG28256,Second_Last_Position-Longitude,--------------,
ENG116750-ENG28257,Third_Last_Position-Latitude,--------------,
ENG116750-ENG28256,Third_Last_Position-Longitude,--------------,
ENG123779-MAS01779,VTT_First_GPS_fix-Length,--- ,
ENG123779-MAS01780,VTT_First_GPS_fix-Width,--- ,
ENG123779-MAS02230,VTT_First_GPS_fix-Height,3466, m
ENG123780,VTT_Last_SMS_Content,2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 00:46
A5:
;SW:3Q0-980-654-L HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H12 0610, Coding:0003070601020201002213468140490084000E00010000
;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002.rod
;Thursday,18,June,2020,11:57:51:14741
;VCID: C0D2AB4A8A00DA5B93B-8094
IDE00018,Voltage terminal 15,14.4, V
IDE00102,Control Module temperature,45, °C
IDE00322,Status of basic setting,not active,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,4.8, °
IDE00767,No. of unscheduled ECU resets,0,
IDE00925-MAS02471,Yaw rate-Sign,Positive,
IDE00925,Yaw rate,0.05, °/s
IDE00973,Outside air temperature,22.5, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.184, °
IDE01969,Dynamic calibration: pitch angle offset,-0.292, °
IDE01970,Dynamic calibration: roll angle offset,-0.425, °
IDE01971,Lowest recorded control module temperature,16, °C
IDE01972,Highest recorded control module temperature,76, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not active,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,1, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,19,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,Deactivated,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,Unknown (960),
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,Unknown (960),
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,Unknown (960),
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,Unknown (960),
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,Unknown (960),
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,Unknown (960),
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,Unknown (960),
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,Unknown (960),
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,Not available,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,Not available,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,Unknown (126),
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,Unknown (126),
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,Unknown (126),
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,Unknown (126),
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,Unknown (126),
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,Unknown (126),
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Restricted view,
IDE09436,Recognized street illumination,Not available,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.300, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,2.131, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.251, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1498, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2020,
IDE10664-MAS00107,Current initial calibration: details-Month,3,
IDE10664-MAS00108,Current initial calibration: details-Day,4,
IDE10664-MAS00109,Current initial calibration: details-Hours,3,
IDE10664-MAS00110,Current initial calibration: details-Minutes,31,
IDE10664-MAS00111,Current initial calibration: details-Seconds,54,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,2,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00100001 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,3VV3B7AX1LM125622,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1382,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,635,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,363,
IDE10664,Current initial calibration: details,00110011 ,
IDE10664,Current initial calibration: details,00111101 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,56,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,40,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:37
CA:
;SW:4K0-907-594-AC HW:4K0-907-594 --- Sunroof
;Component:SAD_STG_1 006 0002, Coding:00804073260C
;EV_SunRoofCONTIAU736,009011,EV_SunRoofCONTIAU736_009_VW37.rod
;Thursday,18,June,2020,11:58:34:14741
;VCID: F5BC0A9E85422FF3F0D-80A0
IDE03114-MAS02447,Comfort function-Release,Not Present,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,not active,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,not active,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,operated,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,Not operated,
IDE09422-MAS02282,Roof Blind-Position,0, %
IDE09422-MAS05370,Roof Blind-Direction of movement,Not moving,
IDE09422-MAS05563,Roof Blind-Norming,normed,
IDE09422-MAS08536,Roof Blind-Excessive temperature protection,not active,
IDE09422-MAS08862,Roof Blind-Reversing,not active,
IDE09422-MAS08866,Roof Blind-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,normed,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,not installed,
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,11,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,2,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,3,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,1,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,10,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,1,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,10,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,2,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,0,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,1,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,7,
IDE09430-MAS00106,History data sunroof reversing-Year,2016,
IDE09430-MAS00107,History data sunroof reversing-Month,6,
IDE09430-MAS00108,History data sunroof reversing-Day,15,
IDE09430-MAS00109,History data sunroof reversing-Hours,18,
IDE09430-MAS00110,History data sunroof reversing-Minutes,0,
IDE09430-MAS00111,History data sunroof reversing-Seconds,0,
IDE09430-MAS00370,History data sunroof reversing-Vehicle speed,0.00, km/h
IDE09430-MAS01453,History data sunroof reversing-Blocking detection,not active,
IDE09430-MAS01634,History data sunroof reversing-Supply voltage,10.00, V
IDE09430-MAS02282,History data sunroof reversing-Position,61, %
IDE09430-MAS02289,History data sunroof reversing-Outside air temperature,25.00, °C
IDE09430-MAS05622,History data sunroof reversing-Cold start,not active,
IDE09430-MAS05737,History data sunroof reversing-Position,Slid.position,
IDE09430-MAS09456,History data sunroof reversing-Counter reading sunroof reversals,1,
IDE09430-MAS10923,History data sunroof reversing-Absolute Position,4246,
IDE09430-MAS10991,History data sunroof reversing-Restart,not active,
IDE09430-MAS10992,History data sunroof reversing-Absolute start position,5809,
IDE09431-MAS00106,History data sunroof shade reversing-Year,2016,
IDE09431-MAS00107,History data sunroof shade reversing-Month,6,
IDE09431-MAS00108,History data sunroof shade reversing-Day,15,
IDE09431-MAS00109,History data sunroof shade reversing-Hours,18,
IDE09431-MAS00110,History data sunroof shade reversing-Minutes,0,
IDE09431-MAS00111,History data sunroof shade reversing-Seconds,0,
IDE09431-MAS01453,History data sunroof shade reversing-Blocking detection,not active,
IDE09431-MAS01634,History data sunroof shade reversing-Supply voltage,12.10, V
IDE09431-MAS02282,History data sunroof shade reversing-Position,23, %
IDE09431-MAS02289,History data sunroof shade reversing-Outside air temperature,25.00, °C
IDE09431-MAS05622,History data sunroof shade reversing-Cold start,not active,
IDE09431-MAS09457,History data sunroof shade reversing-Counter readings roof blind reversals,1,
IDE09431-MAS10923,History data sunroof shade reversing-Absolute Position,2769,
IDE09431-MAS10991,History data sunroof shade reversing-Restart,not active,
IDE09431-MAS10992,History data sunroof shade reversing-Absolute start position,6948,
IDE09492-MAS01155,Temperatures-Control module,26.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,22.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,27.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,27.00, °C
IDE09515-MAS08884,Controls-Sunroof button,not activated,
IDE09515-MAS08932,Controls-Sunroof shade button,not activated,
IDE09515-MAS08992,Controls-Button for sliding roof,not activated,
IDE09515-MAS12701,Controls-Search lights,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Frt. pass. side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Panel lighting for controls,0, %
IDE09517-MAS11499,Control module-Rear indicator light for tilting sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,14.40, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE09844-MAS00106,History data sunroof standardization-Year,2020,
IDE09844-MAS00107,History data sunroof standardization-Month,3,
IDE09844-MAS00108,History data sunroof standardization-Day,4,
IDE09844-MAS00109,History data sunroof standardization-Hours,0,
IDE09844-MAS00110,History data sunroof standardization-Minutes,11,
IDE09844-MAS00111,History data sunroof standardization-Seconds,42,
IDE09844-MAS00370,History data sunroof standardization-Vehicle speed,0.00, km/h
IDE09844-MAS01155,History data sunroof standardization-Control module,15.00, °C
IDE09844-MAS01634,History data sunroof standardization-Supply voltage,12.30, V
IDE09844-MAS02289,History data sunroof standardization-Outside air temperature,24.00, °C
IDE09844-MAS04447,History data sunroof standardization-Engine running status,Motor not running,
IDE09844-MAS09458,History data sunroof standardization-Counter reading sunroof calibrations,3,
IDE09845-MAS00106,History data roof blind standardization-Year,2020,
IDE09845-MAS00107,History data roof blind standardization-Month,3,
IDE09845-MAS00108,History data roof blind standardization-Day,4,
IDE09845-MAS00109,History data roof blind standardization-Hours,0,
IDE09845-MAS00110,History data roof blind standardization-Minutes,12,
IDE09845-MAS00111,History data roof blind standardization-Seconds,34,
IDE09845-MAS00370,History data roof blind standardization-Vehicle speed,0.00, km/h
IDE09845-MAS01155,History data roof blind standardization-Control module,16.00, °C
IDE09845-MAS01634,History data roof blind standardization-Supply voltage,12.30, V
IDE09845-MAS02289,History data roof blind standardization-Outside air temperature,24.00, °C
IDE09845-MAS04447,History data roof blind standardization-Engine running status,Motor not running,
IDE09845-MAS09459,History data roof blind standardization-Counter read. roof blind calibrations,2,
IDE09846-MAS00106,History data sunroof control point-Year,2000,
IDE09846-MAS00107,History data sunroof control point-Month,0,
IDE09846-MAS00108,History data sunroof control point-Day,0,
IDE09846-MAS00109,History data sunroof control point-Hours,0,
IDE09846-MAS00110,History data sunroof control point-Minutes,0,
IDE09846-MAS00111,History data sunroof control point-Seconds,0,
IDE09846-MAS02282,History data sunroof control point-Position,0, %
IDE09846-MAS05737,History data sunroof control point-Position,Tilt out posi.,
IDE09846-MAS09430,History data sunroof control point-Operating pts.,Button for sliding roof,
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Unknown (255),
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Unknown (255),
IDE12985-MAS15419,Operating signals: rear door control modules-Operating signal: rear: driver side sliding/tilting sunroof,not activated,
IDE12985-MAS15420,Operating signals: rear door control modules-Operating signal: rear: passenger side sliding/tilting sunroof,not activated,
IDE12985-MAS15421,Operating signals: rear door control modules-Operating signal: rear: driver side roof shade,not activated,
IDE12985-MAS15422,Operating signals: rear door control modules-Operating signal: rear: passenger side roof shade,not activated,
IDE14139-MAS01161,Wind deflector control module: status-Communication error,not installed,
IDE14139-MAS02282,Wind deflector control module: status-Position,not installed,
IDE14139-MAS04183,Wind deflector control module: status-Position error,not installed,
IDE14139-MAS08536,Wind deflector control module: status-Excessive temperature protection,not installed,
IDE14139-MAS17855,Wind deflector control module: status-Wagon message,Not available,
IDE14139-MAS17856,Wind deflector control module: status-Forced connection requirement,Not available,
IDE14139-MAS17857,Wind deflector control module: status-Position,not installed,
IDE14139-MAS17858,Wind deflector control module: status-Drive initializing,not installed,
IDE14139-MAS17859,Wind deflector control module: status-Adaptation run successful,not installed,
IDE14139-MAS17860,Wind deflector control module: status-Cancel function,not installed,
IDE14140-IDE02021,Wind deflector control module: reception signal-Comfort closing,Not available,
IDE14140-IDE02022,Wind deflector control module: reception signal-Comfort opening,Not available,
IDE14140-IDE14099,Wind deflector control module: reception signal-Wind deflector: denormalization,Not available,
IDE14140-MAS00370,Wind deflector control module: reception signal-Vehicle speed,Not available,
IDE14140-MAS01468,Wind deflector control module: reception signal-Terminal 15,Not available,
IDE14140-MAS02447,Wind deflector control module: reception signal-Release,Not available,
IDE14140-MAS05563,Wind deflector control module: reception signal-Norming,Not available,
IDE14140-MAS05737,Wind deflector control module: reception signal-Position,Not available,
IDE14140-MAS17871,Wind deflector control module: reception signal-Teaching-in run,Not available,
IDE14231-IDE09422,Power sunroof control module: absolute position values-Roof Blind,66,
IDE14231-IDE09423,Power sunroof control module: absolute position values-Sunroof,77,
Elapsed Time: 00:05
OBDII:
;33-OBD2
;Thursday,18,June,2020,11:58:42:14741
03,Fuel system 1/2 status,Closed loop,,using O2 sensors,Engine off
04,Calculated load value,17.6 %,18.4 %
05,Engine coolant temperature,85 °C,85 °C
06,Short Term Trim - Bank 1,0.8 %
07,Long Term Trim - Bank 1,0.0 %
0B,Intake Manifold Absolute Pressure,34 kPa abs
0C,Engine RPM,800 /min,806 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,-1.0 Degrees
0F,Intake air temperature,34 °C
10,Mass Air Flow,3.05 g/s
11,Throttle position sensor,11.4 %,11.4 %
12,Secondary Air Status,Atmosphere/off
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.725 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,506 s
21,Distance travelled with MIL on,0 km
23,Fuel Rail Press (rel),6530 kPa rel
2E,Commanded Evaporative Purge,4.7 %
2F,Fuel Level Input,100.0 %
30,Warm-ups since DTC cleared,2
31,Distance since DTC cleared,40 km
33,Barometric pressure,98 kPa abs
34,Bank 1 Sensor 1 Status,0.989 Lambda,-0.031 mA
3C,B1S1 Cat. Temp.,401.0 °C
42,Control module voltage,14.420 V,14.496 V
43,Absolute Load Value,20 %,20 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,2 %
46,Ambient Air Temp,23 °C
47,Absolute Throttle Position B,11 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,2 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
62,Torque actual,10 %
63,Torque Reference,320 Nm
65,Auxiliary Input/Output,
67,Engine Coolant Temp,ECT 1:84 °C,ECT 2:28 °C
70,Boost Press Ctrl A/B,BP_A act:99 kPa
Mode 9 : Calibration Identification
Type 02 - VIN : 3VV3B7AX1LM125622 (Address E8)
Type 04 - Calibration ID : 83A115B 0004DXBA (Address E8)
Type 04 - Calibration ID : 09G927158DS 3699 (Address E9)
Type 06 - Calibration Verification Number : 0CF66323 (Address E8)
Type 06 - Calibration Verification Number : 709F86AC (Address E9)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 2
Ignition cycle count : 74
Conditions completion count / Specified conditions encountered count
Catalyst monitor bank 1 : 0 / 2
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 0 / 2
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 1 / 2
AIR monitor : 17 / 0
EVAP monitor : 2 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
