Results 1 to 6 of 6
Thread: 2016 Tiguan 4MotionS Factory Trailer Hitch Needs Coding
    Apr 2019
    Good afternoon all!
    I installed the factory trailer hitch and wiring plug adapter, and attempted to have the system initialize but there is no drop-down menu for the 2016 Tiguan.
    Can someone please assist (with long coding if needed)?
    The only modification to the car is a factory 2017 Tiguan radio w/Apple Carplay that was "patched" to allow it to work with the 2016 electronics.
    Thank you in advance very much!
    Rich
    Friday,19,June,2020,16:59:59:09951
    VCDS Version: 20.4.1.0 (x64)
    VIN: WVGBV7AX3GW576621   License Plate: 6BTX80MA
    Mileage: 61140km-37990mi   Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 52 53 5F
              62 69 72
    VIN: WVGBV7AX3GW576621   Mileage: 61140km-37990miles
    69-Trailer -- Status: Cannot be reached 1100
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 07 1335
       Revision: P3H08---    Serial number:
       Coding: 0423010A190F0160
       VCID: 022570AE5D29CE961D-8056
       Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
       Component: AQ 250 6F           2627
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 073361BA760BEBBE4A-8052
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VD6E 0021
       Revision: --H07---    Serial number: 00000009078976
       Coding: 0005161
       VCID: 78D112460BF5944633-802C
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Fault Frequency: 18
                        Reset counter: 110
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:06
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 303
                        Hex Value: 0x0000
       Revision: 00092000    Serial number: 0389578479
       Coding: 030C0C
       VCID: 3753D17A8E6B5B3EFA-8062
       Part No SW: 561 907 426 G    HW: 561 907 426 G
       Component: AC Manuell    H03 0506
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1F6319DA069B037E12-804A
       Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
       Component: BCM PQ35 B    122 0183
       Revision: BG122001
       Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
       VCID: 3D5FC352A457716E20-8068
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 011215  24  0664
       Coding: 009795
       Component: RLS 141215 05  54  0403
       Coding: 02304D
                        Reset counter: 104
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:08
                        Voltage: 11.85 V
       Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
       Component: J234__005 VW10 HI   5418
       Revision: 36023000    Serial number: 003MAPRJW86N
       Coding: 0012341
       VCID: 7DDF035224D7B16E60-8028
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 0000000000PQE3
       Subsystem 3 - Serial number: 0019.10.150000300000650044˙†63
       Subsystem 4 - Serial number: 650044˙†6332MTS6864331252˙†63
       Subsystem 5 - Serial number: 331252˙†6342MTS6296731256˙†63
       Subsystem 6 - Serial number: 731256˙†6351HTS6J5ED4EKJV˙†63
       Subsystem 7 - Serial number: D4EKJV˙†6361HTS6VCM53EKJ7˙†63
       Subsystem 8 - Serial number: 53EKJ7˙†63727TS6JT9B3EKJ/˙†63
       Subsystem 9 - Serial number: B3EKJ/˙†63827TS6OCLA3EKR5˙
       Subsystem 10 - Serial number: A3EKR5˙
       Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20151215200213
       Coding: 1102140000
       VCID: 78D11246C3F5944633-802C
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0933045
       Coding: 820000
       Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
       Component: KOMBI         H04 1008
       Coding: 211F010000
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 3D5FC352AC57716E20-8068
    13654560 - Databus
                        Reset counter: 104
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:01
       Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1663
       Revision:   H57       Serial number: 141115F1001566
       Coding: 356022
       VCID: 022570AE9D29CE961D-8056
                        Reset counter: 104
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 18:03:55
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00016.11.15
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_002.rod
       VCID: 528580EE05C99E16ED-8006
       Component: IMMO          H04 1008
       Coding: 000007
       VCID: 6AF5380E8D5936D6B5-803E
       Revision: 00000000    Serial number: 15000260702002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X_VW31.rod
       VCID: 3041EA666B058C06BB-8064
       Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
       Component: TUER-SG FT    002 0601
       Revision: 13100010    Serial number: 0010185509
       Coding: 0004B4
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: 3A55C84EBD79465605-806E
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009635858
       Coding: 000490
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.285 1401
       Revision: 1BH04841    Serial number: 00153210176901
       Coding: 0000258
       VCID: 41A7BFA218AF158E44-8014
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0010265949
       Coding: 0004B4
       VCID: 3957D742B87F4D4E0C-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009648063
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000993370
       Coding: 0026156
       VCID: 3851D2464B755446F3-806C
       Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
       Component: MU-S-S-US     H31 0359
       Serial number: VWZAZ2S0600954
       Coding: 02130600FF00000011220001001808009F0100D40020010002
       Shop #: WSC 00040 028 00056
       ROD: EV_MUStd4CTSAT_VW32.rod
       VCID: 140946F6FF5D5026BF-8040
    8 Faults Found:
              B11CF 53 [009] - Deactivated
                        Reset counter: 94
                        Voltage terminal 30: 12.6 V
                        SDARS_tuner_status_2-Antenna current: 0 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
    0513 - Rear Right Treble Speaker
              B1068 13 [008] - Open Circuit
                        Reset counter: 144
                        Voltage terminal 30: 11.5 V
              B1064 13 [008] - Open Circuit
                        Reset counter: 144
    0521 - Connection to Front Right Loudspeakers
              B110A F0 [008] - Short Circuit Between Poles
                        Reset counter: 141
                        Mileage: 61003 km
                        Date: 2020.06.13
                        Time: 11:32:17
                        Voltage terminal 30: 12.5 V
              B1061 13 [008] - Open Circuit
                        Reset counter: 144
              B1066 13 [008] - Open Circuit
                        Reset counter: 144
    0009 - Antenna for Satellite Radio
              B10F4 13 [009] - Open Circuit
                        Reset counter: 95
    6714 - Databus
                        Reset counter: 78
    Address 69: Trailer
    End-------------------------(Elapsed Time: 02:20)--------------------------
    Since both the vehicle's Gateway and VCDS report that 69-Trailer "Cannot be reached", I think you have hardware (wiring or power supply) issues that need to be resolved before you worry about coding things. I mean it makes no sense trying to code in a module that the rest of the car can't talk to.
    Apr 2019
    Uwe, I inadvertently assumed that the 2016 Tiguan would have the trailer module pre-installed when I saw the trailer harness plugged into a dummy receptacle at the rear bumper.
    I hooked up the harness to the 7 pin receptacle and figured that I was good to go.
    Getting the trailer module and jumper on order today, then I should be in business.
    I went through this very exercise a few years ago with a 2011 Tiguan...
    Thank you very much!
  4. Likes Uwe liked this post
    Apr 2019
    Now it seems to be a coding issue?
    Quote Originally Posted by rcrowell View Post
    UPDATE:
    Purchased the trailer control module and jumper wire kit from VW; ran the Ross-Tech software; checked the "trailer" box in the software; and figured I'd be good to go.
    Next day I hooked up my small boat trailer and all lights worked except brake lights.
    Dash light indicator that there is a bulb failure is lit with trailer connected.
    Disconnect trailer - bulb failure indicator is extinguished.
    Went to Home Depot to borrow a small utility trailer - same exact symptoms.
    I double checked continuity through the 3-way jumper - OK.
    Purchased a 4-pin LED trailer light tester - shows that one side of car lights are inoperative (even though they were working with 2 actual trailers) and brake lighting inoperative.
    I ran the Ross-Tech self-test with the 4-pin tester installed:
    Monday,29,June,2020,17:09:08:09951
              62 69 72
    VIN: WVGBV7AX3GW576621   Mileage: 61470km-38195miles
    09-Cent. Elect. -- Status: Malfunction 1010
    46-Central Conv. -- Status: Sporadic communication error 1000
       Coding: 0000840
       Component: J104   C6 450M VD80 0021
       Coding: 0005161
                        Fault Frequency: 53
                        Reset counter: 161
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:06
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 303
                        Hex Value: 0x0000
    02214 - Tire Pressure Warning
                        Reset counter: 167
                        Mileage: 61440 km
                        Date: 2020.06.28
                        Time: 13:49:32
                        Speed: 97.0 km/h
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Coding: 030C0C
    133124 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:31
       Revision: 00001K02
       Coding: 0010001002
       Revision: BG122001
       Coding: 009795
       Coding: 02304D
                        Reset counter: 167
                            Term 15 Off
                        Voltage: 12.85 V
                        Reset counter: 161
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:08
                        Voltage: 11.85 V
                        Fault Status: 00101010
                        Reset counter: 161
                        Mileage: 61209 km
                        Date: 2020.06.23
                        Time: 19:43:36
                        Voltage: 14.00 V
       Coding: 0012341
       Coding: 1102140000
       Coding: 820000
       Coding: 211F010000
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:31
    13631488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:33
    13654560 - Databus
                        Reset counter: 161
                        Mileage: 61075 km
                        Date: 2020.06.16
                        Time: 17:49:01
       Coding: 356022
                        Fault Status: 00110100
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:31
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:31
       Coding: 0001
       Coding: 000007
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:31
                        ELV State: 0A
                        Information Clamps: 88 08
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Vehicle speed: 655.35 km/h
                        Voltage: 6F
    12665089 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:32
                        ELV State: 0A
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Voltage: 6E
       Coding: 0000258
       Coding: 0004B4
       Slave Passenger:
       Coding: 000490
    68098 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:32
    68100 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 167
                        Mileage: 61460 km
                        Date: 2020.06.28
                        Time: 16:25:32
       Coding: 0026156
    8 Faults Found:
                        Reset counter: 94
                        Reset counter: 144
                        Reset counter: 144
                        Reset counter: 141
                        Mileage: 61003 km
                        Date: 2020.06.13
                        Time: 11:32:17
                        Reset counter: 144
                        Reset counter: 144
                        Reset counter: 127
    6714 - Databus
                        Reset counter: 78
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000446146972
       Coding: 0100000100000000
       VCID: 3041EA6663058C06BB-8064
    02564 - Trailer; Left Tail Lamps (M60)
                        Fault Status: 11101010
                        Reset counter: 128
    02562 - Trailer; Brake Lamps
                        Reset counter: 128
    End-------------------------(Elapsed Time: 02:14)--------------------------
    Thanks again in advance for thoughts!
    Looks like you haven't coded the trailer module itself yet?
    I would try something like:
    020D000100000000
    PS: Please clear out the mess of Intermittent faults in all the other modules.
    Apr 2019
    020D000100000000
    That was it - Thank you very much Uwe!
  9. Likes Uwe liked this post
