Results 1 to 9 of 9
Thread: 2018 Seat Arona ACC Coding error
    Jun 2020
    Hi, I am trying to code a 2018 Seat Arona ACC module 13: Auto Dist. Reg which has been replaced due to an accident.
    After removing the comp prot, left with a coding fault.
    3 faults in Airbag too, but no airbag light.
    Any help grateful.
    regards PDL
    Friday,19,June,2020,09:30:27:41343
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
    VIN: VSSZZZKJZKR077867   License Plate: NATHAN
                    Address 13: Auto Dist. Reg       Labels: 2Q0-907-572.clb
    Control Module Part Number: 2Q0 907 572 M    HW: 2Q0 907 572 B
      Component and/or Version: ACCCONTIMQB   H02 0233
               Software Coding: 3200000340FF8728749C8144004087
                Work Shop Code: WSC 00049 770 00100
                  ASAM Dataset: EV_ACCMRRCONTIVW376 002012 (SE27)
                          VCID: 3E2539AD40FDA20B617-806A
    201217 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_CODING2SWAP_GRP_ACC_TYPE]
                        Reset counter: 103
                        Mileage: 6488 km
                        Date: 2020.06.13
                        Time: 11:09:43
                        Voltage terminal 15: 14.8 V
                        Control Module temperature: 65 C
                        Longitudinal_acceleration_vehicle_reference: 0.13 m/s
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8728749C8144004087,to,3200008340FF8728749C8144004087,(00049/770/00100),
    Address 13: DTCs cleared
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200008340FF8728749C8144004087,to,3200000300FF8728749C8144004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000300FF8728749C8144004087,to,3200000340FF8328749C8144004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8328749C8144004087,to,3200000340FFC728749C8144004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FFC728749C8144004087,to,3200000340FF8700749C8144004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8700749C8144004087,to,3200000340FF87000303818C000087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF87000303818C000087,to,2100600140FF8728749C8145004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,2100600140FF8728749C8145004087,to,3100600340FF8728749C8145004087,(00049/770/00100),
    Address 19,3Q0 907 530 AA,recoded (Long Coding-exp),from,030100046F085700E90002581C0F00010001070000000000000000000000,to,030100046F085700E90002481C0F00010001070000000000000000000000,(131071/1023/2097151),
    Address 19,3Q0 907 530 AA,recoded (Installation List),from,01543C0000000600404090000000C80000,to,01547C0000000600404090000000C80000,,
    Address 19: DTCs cleared
    Address 19,3Q0 907 530 AA,recoded (Installation List),from,01547C0000000600404090000000C80000,to,01543C0000000600404090000000C80000,,
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3100600340FF8728749C8145004087,to,3304600340FF8728749C8145004087,(00049/770/00100),
    Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3304600340FF8728749C8145004087,to,3304E08340FF8728749C8145004087,(00049/770/00100),
    Chassis Type: KJ-SE27 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 44 55 5F D6 D7
    VIN: VSSZZZKJZKR077867   Mileage: 6725km-4178miles
    Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 025 K    HW: 04C 907 309 BB
       Component: R3 1.0l TFS   H20 6203
       Revision: D7H20000
       Coding: 0125003223641D081000
       Shop #: WSC 00049 770 00136
       ASAM Dataset: EV_ECM10TFS01104C906025K 002002
       ROD: EV_ECM10TFS011_AU27.rod
       VCID: 2809FFF5B2790CBB3BB-807C
       Part No SW: 0CW 300 043     HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1604
       Revision: 00005008    Serial number: CU501811188790
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: 74B1DB853E31385B473-8020
       Part No SW: 2Q0 614 517 AF    HW: 2Q0 614 517 M
       Component: ESC_high_vFGS H34 0342
       Serial number: 08507977180929
       Coding: 8A0D4C573D4851B43204BC1C12E111A649344DE6226A24484454625445488865922CB26744562412222A462AA271D64FFD8E6BF2BF
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
       ROD: EV_Brake1BOSCHESPMQBA0_004.rod
       VCID: 72BDDD9D4425366B55F-8026
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0501389811
       Coding: 112E0E0703
       Shop #: WSC 00049 770 00024
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 43D348592B1FCFE30E9-8016
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 6F0 907 044 B    HW: 6F0 907 044 B
       Component: Climatronic   H03 0502
       Coding: 8101000008000100110008000240010D0000000000000000000000000000
       ASAM Dataset: EV_ACClimaBHBMQBA0 004017
       ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
       VCID: 2615F1CDB86D1ACB097-8072
       Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
       Component: BCM A0 Std+   H98 0926
       Serial number: 00001833800047
       ASAM Dataset: EV_BCMA0 204001
       ROD: EV_BCMA0_204.rod
       VCID: 303917958AA9447BE3B-8064
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S7Y18M11D30H19M28S26
       Coding: 00194D
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 2Q2 959 881 D    HW: 2Q2 959 881 D
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000024569620
       Coding: 1F000F
       Subsystem 3 - Part No SW: 2Q2 959 882 D    HW: 2Q2 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000024262959
       Coding: 05000F
       Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY182880Q2Y
       Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004 0007
       Serial number: 00000000000000271532
       Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000025802748
       Coding: 1D0000
       Subsystem 7 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000025751589
       Coding: 050000
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000308417318346
       Coding: 0371165851
       Shop #: WSC 43902 003 1048576
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       ROD: EV_EPHVA2CAU3700000_VW27.rod
       VCID: 51FF7211E1632D738C5-8004
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3304E08340FF8728749C8145004087
       Shop #: WSC 00049 770 00100
              U1014 00 [009] - -
                        Reset counter: 119
                        Mileage: 6725 km
                        Date: 2020.06.19
                        Time: 10:02:12
                        Voltage terminal 15: 11.9 V
                        Control Module temperature: 52 C
                        Longitudinal_acceleration_vehicle_reference: 0.06 m/s
       Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
       Component: Airbag VW22   006 0520
       Revision: --------    Serial number: 003XNPPQ2J1S
       Coding: 88CCC0C000000000585400CF008C00000065
       ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
       ROD: EV_AirbaVW22TS6VW48X.rod
       VCID: 5F9BA429A7B78B030A1-800A
       Subsystem 1 - Part No SW: -----------    HW: 454 002 011 18
       Serial number: 35700000000038584538
       Subsystem 2 - Part No SW: -----------    HW: 454 002 011 18
       Serial number: 35800000000268314535
       Subsystem 3 - Part No SW: -----------    HW: 454 801 711 18
       Serial number: 351001CEAE716000000V
       Subsystem 4 - Part No SW: -----------    HW: 454 802 711 18
       Serial number: 3520000B3DA16000000B
       Subsystem 5 - Part No SW: -----------    HW: 454 802 608 17
       Component: FrontSensor_D  307 0189
       Serial number: 355008324B8100000007
    1060614 - Databus
              [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                        Fault Frequency: 9
                        Reset counter: 119
                        Mileage: 6488 km
                        Date: 2020.06.13
                        Time: 11:13:42
    1060615 - Databus
              [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_v_rel]
                        Fault Frequency: 9
                        Reset counter: 119
                        Mileage: 6488 km
                        Date: 2020.06.13
                        Time: 11:13:42
    1060617 - Databus
              [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_CW]
                        Fault Frequency: 9
                        Reset counter: 119
                        Mileage: 6488 km
                        Date: 2020.06.13
                        Time: 11:13:42
       Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
       Revision: FF035035    Serial number: 20181126400604
       Coding: 6414
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7BA3F0B9136F7723069-802E
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 6F0 920 790     HW: 6F0 920 790
       Component: KOMBI         615 1701
       Coding: 24A4091D2D880600018862091001000080000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_SK25.rod
       VCID: 678BBCC97FE7C3C3F21-8032
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4366
       Revision: --------    Serial number: 0008873823
       Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
       ROD: EV_GatewNF_SK25.rod
       VCID: 6E85C9ED501D128BB17-803A
       Component: 0-00-00-00-00
       Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
       Serial number: 000000000H0972191118
       Coding: 002000
       Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 100BD2EF
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 18000394272011
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 313F129181A34D73EC5-8064
       Component: HRE_Master    H12 0081
       Serial number: 0500742825
       Coding: 02011203
       ROD: EV_HREntryHella_SE27.rod
       VCID: 3D273EA14DFBB91378D-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0500665492
       Coding: 020112
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q2 909 144 M    HW: 2Q2 909 144 F
       Component: TRW_G4L_MQBA0 621 6041
       Serial number: 0879188CB4J3383
       Coding: 010001010000000101010201010001010000010101
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
       ROD: EV_SteerAssisTRWG4LMQBA0.rod
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Coding: 078E000009200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
       VCID: 41DF42513103DDF31C5-8014
    Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
       Part No SW: 5F0 035 874 A    HW: 5F0 035 874 A
       Component: MU-S-ND-ER    H50 0514
       Serial number: SEZAZ2U0878848
       Coding: 04120601960A000011110101008808212F0100F601200400C6
       ASAM Dataset: EV_MUStd6C1TSAT 001015
       ROD: EV_MUStd6C1TSAT_SE27.rod
       VCID: 270BFCC9BF6703C3321-8072
       Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
       Component: ABT_Std-2_Nav  H53 8130
       Serial number: SEZ6ZHV3360428
       Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
       Component: ECE1 2018/19  --- 1030
       Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
       Component: LED1L         H06 0005
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
       VCID: 7EA5F9AD007D620B217-802A
       Component: LED1R         H06 0005
       ROD: EV_LEDPLUSRightKEBODVW416_VW27.rod
    End----(Elapsed Time: 01:28, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Tartu, Estonia
    I don't get it....If You had Online Link with car, why didn't You use SWC function to recode car?
    You may also need parameters that can be obtained via Online link.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  3. Likes darkchina811, Somnus liked this post
    Jun 2020
    I didn't remove comp protection. ODIS wouldn't code ACC module. That's why Im asking for help.
    May 2017
    And FeC was returned as well? To me it looks like it’s complaining about missing or incorrect FeC in radar.
    If the radar is exactly as the original one, like golfi_vend wrote, online swc works if the radar type is what is expected for your car.
    Jun 2020
    Sorry. What is FeC?
    Quote Originally Posted by PDL View Post
    Sorry. What is FeC?
    See how FeC is bold, green and underlined? Hover your mouse over it and a popup will appear with an explanation.
  8. Likes Uwe liked this post
    Dec 2016
    DE
    Doesn't work on mobile though
  10. #8
    ... why I always use a proper computer (Windows or Mac) for important things
  11. Likes Uwe, downtime, DV52 liked this post
  12. #9
    Jun 2020
    All sorted, owner had fitted incorrect ACC radar module.
  13. Likes Uwe liked this post
