Good morning,
I was installing a switch for my new LED light bar.
The location for the switch is under the drivers foot well (in front of the gas/brake pedals) and when I removed the plastic cover (2 screw & small foot well light) I noticed a male 4 pin electrical connector that was not paired up with any female electrical receptacle. I looked around for its mate, but didn't see one.
Please see the pics.
Question: Does anyone know if/where this male plug needs to be connected? Is it possible that my Touareg is lacking an option and therefore does not need to have this item plugged in?
Thank you very much as always for the help and happy VW'ing.
Dave
Dave
Tuesday,28,April,2020,18:25:37:54382
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Dave and Joey's Bone-Yard
VIN: WVGBC77L34D064021 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBC77L34D064021 Mileage: 252770km-157063miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 9779
Coding: 0000133
Shop #: WSC 19226 444 59215
VCID: 50F97738A6FE7567197-5160
15 Faults Found:
17069 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit - Intermittent
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground - Intermittent
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground - Intermittent
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground - Intermittent
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground - Intermittent
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1049 - 002 - Short to Ground - Intermittent
17925 - Power Supply Relay for ECU
P1517 - 008 - Electrical Malfunction - Intermittent
17935 - Camshaft Timing Adj. Bank1 (N205)
P1527 - 002 - Short to Ground - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
16840 - EVAP System
P0456 - 002 - Very Small Leak Detected
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BD
Component: AL 600 6Q 0582
Coding: 0004153
Shop #: WSC 19419 444 53362
VCID: 71BFD2BC0DB45C6F369-5160
01045 - Tiptronic Switch (F189)
008 - Implausible Signal - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 3A2D35901042DF37C73-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D070ECCD10C788F521-5160
Component: ELV XXXX
00189 - Control Circuit 2; Relay for Supply Voltage Terminal 50
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 353726AC395C304F2A1-5160
02100 - Footwell Flap Motor (V261)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0101599
Shop #: WSC 19400 444 85723
VCID: 44D14B68628699C7ADF-5160
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
02088 - Lights for Auxiliary High Beams
01964 - Control Module for Seat & Steering Column Memory (J136)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00009760
Coding: 0012341
VCID: 2313E8F487C8BEFFF45-5160
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 40D94778769E85E7897-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 RX
Component: KOMBIINSTRUMENT RB0 2035
Coding: 0007231
VCID: 1E65D900ACAA9317DBB-5160
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D7B806BE5567397-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04518B68220659C7EDF-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F5B04844BE03A1FB0D-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
VCID: 6695B1E0347A8BD753B-51A8
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABECA463D0025FF8D-5160
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
VCID: 678BBCE4337092DF68D-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2K HSG 0201
Coding: 0000085
VCID: 3E2539800C6AF317FBB-4B3C
Subsystem 1 - Part No: 7L0 959 701 A
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 A
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703
Subsystem 4 - Part No: 7L0 959 704
8 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180 B
Component: Radio DE2 0016
Coding: 0000401
VCID: 2C0103C8EA16718745F-5160
00881 - Connection to Speaker Rear Right
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0211390
VCID: 75B7E6AC79DC704FEA1-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 372B2CA42350C25F38D-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
End----------(Elapsed Time: 08:58, VBatt start/end: 12.2V/12.2V)-----------]
