Hello all,
wonder if anyone knows if pre sense rear requires some dedicated coding.
Long story short - car was w/o lane change assist, park distnace control and 360. I have installed all those systems and coded everywhere i find. Lane change is working good, RTCA also. Now wondering if pre sense rear will work too.
So far i have made only one change in the ABS
RCTA=Rear Cross-Traffic Alert (Blind Spot Monitoring)
Address 03 - Byte 18 - Bit 3=1
Address 03 - Byte 30 - Bit 4=1
Airbag controller coding is 1:1 with car that have those systems from factory, same goes for A5 cam.
Sunday,14,June,2020,23:03:11:52816
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
Workshop Code: 790 06334 000001
VIN: removed License Plate:
Chassis Type: F5-AU49 (80A)
Scan: 01 02 03 08 09 15 16 17 19 29 39 3C 42 44 46 52 5F 6C 6D 81
A5 A9 BB BC CA CF D6 D7
VIN: removed Mileage: 7847km-4875miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06L-907-115-V1.clb
Part No SW: 8W0 906 259 AB HW: 06L 907 425 C
Component: R4 2.0l TFSI H15 0003
Revision: --H15---
Coding: 1A2500322326010E34000000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259AB 001004
ROD: EV_ECM20TFS0208W0906259AB.rod
VCID: 814AF5ED10C7DA8E8D-80D4
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 CG HW: 0HK 927 156 B
Component: 0CL 20TFSINAR H01 0002
Revision: --H01--- Serial number: 0000001629
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
VCID: 885CE8C933FDEBC6CA-80DC
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190113000395
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 AF HW: 8W0 907 379 J
Component: ESP9 Plus H16 0777
Coding: 18AA409A28A80A9611A74897007E5292E5359A180214508812004A49A7AC59
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 895AEDCD28F792CED5-80DC
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Coding: 140805095544000D10000100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: C4C43CF94F550FA6E6-8090
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000003662704
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 4B8097A900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E17900CD05158714182C10B9110B3D08000000200000000020001A010A640123025709
Shop #: WSC 06443 128 28888
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 8248FAE115C1C19694-80D6
Subsystem 1 - Part No SW: 8W6 955 119 B HW: 8W6 955 119
Component: 494 LL 030419 036 0481
Serial number: 00000001903290302082
Coding: FFC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22949987X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 11 11 2017 01176311
Subsystem 4 - Part No SW: 4N0 907 410 B HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600368Z00IA02
Coding: 350000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20190309133217 00748
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE108021923610263
Interior Light Module:
Subsystem 7 - Part No SW: 4K0 947 135 BB HW: 4K0 947 135 BB
Component: Dachmodul H42 0415
Serial number: B01177175
Coding: 0D0104
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000041316006
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 M HW: 8W0 959 655 M
Component: Airbag10.44 H05 0108
Serial number: 0030C001745W
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: D3E60FA5BA3B981E6F-8086
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2040
Serial number: 8W0857705G0130T00391
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2040
Serial number: 8W0857706J0123T00503
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J19000BKHJR0/
Subsystem 4 - Part No SW: ----------- HW: 442 061 004 19
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00B330649B0C36
Subsystem 5 - Part No SW: ----------- HW: 442 060 904 19
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y009B303FF614397
Subsystem 6 - Part No SW: ----------- HW: 442 0B3 004 19
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700AD3156A427378
Subsystem 7 - Part No SW: ----------- HW: 442 0B0 105 19
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700A331041A5104N
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 404 19
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AB30356A4034+
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 404 19
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A930356A6D24B
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GF HW: 4M0 907 129 GF
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: FAB882017D118956CC-80AE
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 HW: 8W5 920 790
Component: FBenRDW H11 0379
Coding: 05E641C7688808090100EC685800000000000000
Shop #: WSC 06798 128 28888
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: FF4E73156633AC7EFB-80AA
Part No SW: 80A 907 468 C HW: 80A 907 468 A
Component: Gateway H05 0207
Serial number: 1HF08047386301
Coding: 030100010000064029070000005900126C180007100000000100040E00000000
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x.rod
VCID: AE107E51F1D995F620-80FA
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20160629114728 01599
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 9718011205
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: F8BC9809431D9B46BA-80AC
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H13 0410
Revision: --------
Coding: 0EC002
Shop #: WSC 06758 128 28888
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: B62056310989AD3668-80E2
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 D HW: 4M0 959 793 C
Component: TSG FS 009 0038
Serial number: 0000159744265
Coding: 001F5B625000008000010490
Shop #: WSC 02391 785 00200
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: BFCE331526B36C7EBB-80EA
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09008380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: C2C83AE155410196D4-8096
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 GH HW: 8W0 907 064 DH
Component: BCM2 MLBevo 025 0424
Coding: 01340000482000C0650BA0006E01080203024000010026502F0400000B04803F001E0000000010
Shop #: WSC 10452 758 00000
ASAM Dataset: EV_BCM2HellaAU736 016016
ROD: EV_BCM2HellaAU736_016_AU49.rod
Subsystem 1 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000047083400
Subsystem 2 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94033588
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 792 D HW: 4M0 959 792 C
Component: TSG BFS 009 0038
Serial number: 0000159758285
Coding: 001F5B225C00008000010490
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: BE304E1121B96576B0-80EA
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 B HW: 8W5 035 035
Component: MU-P-LND-EU 034 1177
Serial number: A829A0JB054508
Coding: 01940301FF0A000051110001061A0010AF000EE471F08004FF
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
Subsystem 1 - Part No SW: V03 959 802 TH HW: -----------
Component: ECE 2020 --- 0184
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9GBL0039B
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK122081600040388
Component: Gracenote2 --- 1016
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 215
Mileage: 7847 km
Date: 2020.06.14
Time: 22:59:32
Voltage terminal 30: 12.5 V
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H11 0311
Serial number: C854606JG004694
Coding: 02940301BA0FA10008004004
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: B3266F251AFBB81E4F-80E6
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 215
Mileage: 7847 km
Date: 2020.06.14
Time: 22:59:30
9616994 - Front Surroundings Camera
B127C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 215
Mileage: 7847 km
Date: 2020.06.14
Time: 22:59:30
9618000 - Left Surroundings Camera
B127E 54 [009] - Missing Calibration / Basic Setting
Reset counter: 215
Mileage: 7847 km
Date: 2020.06.14
Time: 22:59:30
9618001 - Right Surroundings Camera
B127F 54 [009] - Missing Calibration / Basic Setting
Reset counter: 215
Mileage: 7847 km
Date: 2020.06.14
Time: 22:59:30
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C744-8781-0
Coding: 0618
ASAM Dataset: EV_DeckLidCONTIAU736 001016
VCID: CAD812C16D71D9D61C-809E
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19050752095777
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 B HW: 8W6 907 217 A
Component: BVS H17 0052
Coding: 0404090300000401022023A2AC0000FC80F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: C1CA35ED50471A8ECD-8094
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 190312200423
VCID: C6C026F179693DB6F8-8092
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 009 0130
Serial number: 0000375151172
Coding: 000F4B220000108040000000
ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
VCID: D1EA05AD8027EA0E5D-8084
Component: TSG HBFS 009 0130
Serial number: 0000375151175
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 228000049301
ROD: EV_SunRoofCONTIAU736_009_AU49.rod
VCID: F5A2913D540FE62EA1-80A0
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 977EBBB56E43743E53-80C2
Component: LED1R H09 0008
End----------(Elapsed Time: 02:07, VBatt start/end: 12.4V/12.4V)-----------
