Results 11 to 20 of 21
Thread: Static maximum speed limit
    Magdeburg, Germany
    Well, guess it sucks being you now. If you had sticked to the "Individually adjustable maximum speed limit" you'd be able to reset/change that at any given time, yet with the "Static maximum speed limit" it is just that - static. Your best chance is finding a decent tuner who can fix that for you, other than that the official VW statement would be "purchase a new ECM".
  2. #12
    Feb 2015
    South Africa
    Thank you.
    For clarity, if i can find a tuner who can flash the ECU with a stock map, will that work?
  3. #13
    Magdeburg, Germany
    Depends on where the setting is stored specifically, I would however advocate against a full reset since you don't want to loose all general settings and learned values if you could avoid it.
  4. #14
    Jun 2014
    Newcastle, England
    MDMA, I really feel for you. Imagine if you'd been in a parking lot and set it to 10km/h
    At least 100km/h (62mph) is reasonably useable.
    What about that 'Deactivation of static maximum speed limit 00 00' channel? Anything you can put in there to, well, deactivate the static maximum speed limit?
  5. #15
    Feb 2015
    South Africa
    Quote Originally Posted by Zenerdiode View Post
    That would not have been fun - Thank you Z.
    I don't have much too loose so I can take a look at that channel.
    RT, can you share any insight into this channel?
  6. #16
    Administrator Andy's Avatar
    Sector 7G
    I don't think any of us have any experience with trying that channel but as you said you don't have much to lose.
  7. #17
    Feb 2015
    South Africa
    Thank you Andy
  8. #18
    Feb 2015
    Any luck with raising your speed limiter? I'm presently limited to approximately 165 and would like to raise it.
  9. #19
    Feb 2015
    South Africa
    Quote Originally Posted by K__dub View Post
    Could not be done with VCDS - I approached a leading tuner and at that stage even the base maps were not avail in the tuning databases.
    So I returned the courtesy car ashamedly without taking responsibility for my deed.
    If the ECU has been around for while, a tuner will be able to easily change your Vmax.
  10. #20
    Jan 2015
    Norway
    How did this turn out in the end ? I MIGHT have found a solution to raise the static speed limiter again with VCDS, but no, I am not sure it will work so I wont try it with my own car If no one has a car with a speed limiter set to a unbelivable low setting, then I will have to buy another ecu for my A3 and try it out.
