Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Static maximum speed limit
    Feb 2015
    South Africa
    I went to ENGINE, and then ADAPTATION.
    From the drop down menu, I selected Static maximum speed limit.
    It had the value of 250 km/h and I put in 100 km/h to see if it would accept it.
    It did!
    I drove around and sure enough it restricted speed to 100 km/h.
    Now when I try to set a higher number it will not update the speed.
    it does say that a new value is accepted but does not change/update the limit.
    Please help?
    Thank you.
    Jan 2015
    Norway
    Ups, sorry, but afak it is NOT possible to increase this value, only decrease it. From the ross-tech faq:
    http://www.ross-tech.com/vag-com/cars/tdi.html
    On some EDC-15 ECUs, this channel has a non-zero value in it like 190.
    Yes, that's the "speed limiter". Don't mess with it!
    It can only be adjusted downward, and it's one-way! You cannot increase the value, and if you decrease it, you're stuck with it.
    So unless you want to permanently decrease your car's top speed, Don't mess with it!
    If you do mess with it and your car ends up with a lower top speed than it had before, don't call us, don't e-mail us, and don't complain that we didn't warn you!
  3. Likes Eric liked this post
    Feb 2015
    South Africa
    Quote Originally Posted by LN-TAL View Post
    Thank you. If only I had read this before.
    Too late now...
    Jan 2015
    Norway
    Maybe the guys at RT has a solution, we better wait until they wake up. But I am also sure that if you contact a shop who does chip tuning, they can fix this for you. But as said: I really doubt it is possible to fix with VCDS.
    Magdeburg, Germany
    Let's start with an Auto-Scan so we actually know which engine type etc. we're talking about, in addition please attach a control module map (adaptation) from the ECM.
  7. Likes LN-TAL liked this post
    Feb 2015
    South Africa
    Monday,16,February,2015,07:41:55:04480
    VCDS Version: 14.10.1.1
    Data version: 20150130
    VIN: WVWZZZ16ZEM042726   License Plate:
    Mileage: 11140km-6922mi   Repair Order:
    Chassis Type: 16 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ16ZEM042726   Mileage: 11140km-6922miles
    Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 JF    HW: 03F 907 309 R
       Component: SIMOS10.12AH10 5417
       Revision: --H10---    Serial number: 00000000000000
       Coding: 001900D6230400080000
       Shop #: WSC 00066 790 00016
       ASAM Dataset: EV_ECM12TFS02103F906070JF 004005
       ROD: EV_ECM12TFS02103F906070FS_VW32.rod
       VCID: 6FE8BBAAB68C8C5987A-803A
    Readiness: 0010 0101
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: A33B20F8092600FCC51204E6901F0080A1100010
       VCID: 7EF696EEE9E6F5D11CC-802B
       Part No SW: 5C6 920 873     HW: 5C6 920 873
       Component: KOMBI         H04 0811
       Coding: 171B00
       VCID: 6BD0AFBA82947079AB2-803E
       Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1642
       Revision:   H57       Serial number: 26021403000051
       Coding: 351003
       VCID: 79FC85F2F0C8D2E929E-802C
    Feb 2015
    South Africa
    from my coding log file in the debug folder:
    Address 01:03F 906 070 JF recoded (ADP-Individually adjustable maximum speed limit) from 250.0 km/h to 200 km/h Sunday,15,February,2015,19:51:03:04480
    Address 01:03F 906 070 JF recoded (ADP-Individually adjustable maximum speed limit) from 200.0 km/h to 100 km/h Sunday,15,February,2015,19:51:44:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 250.0 km/h to 100 km/h Sunday,15,February,2015,19:53:42:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 260 km/h Sunday,15,February,2015,20:01:37:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 255 km/h Sunday,15,February,2015,20:01:59:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Sunday,15,February,2015,20:02:11:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Sunday,15,February,2015,20:02:43:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,07:37:37:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,07:38:33:04480
    Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,08:06:50:04480
  10. #8
    Feb 2015
    South Africa
    Monday,16,February,2015,07:37:52:04480
    UDS Adaptation Channel: Static maximum speed limit
    Stored value 100.0 km/h
    Monday,16,February,2015,08:07:02:04480
  11. #9
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    To get a dump of the Control Module Map, see the following wiki page. You need to do a dump for controller "01". If you select CSV as the output format you can then just copy and paste the contents of the CSV file into a post.
  12. #10
    Feb 2015
    South Africa
    Quote Originally Posted by GaryM View Post
    Thank you GaryM and Sebastian,
    ;SW:03F-906-070-JF   HW:03F-907-309-R ---  Engine
    ;Component:SIMOS10.12AH10 5417	 Coding:001900D6230400080000
    ;EV_ECM12TFS02103F906070JF	4005	EV_ECM12TFS02103F906070FS_VW32.rod
    ;Monday	16	February
    ;VCDS Version: Release 14.10.1  Data version: 20150130
    ;VCID: 6FE8BBAAB68C8C5987A-803A
    Activating and deactivating all development messages	not active
    Activation of start-stop function	not active
    Activation of static maximum speed limit	OFF
    Chain elongation; initial values valid; exhaust bank 1	not active
    Chain elongation; initial values valid; intake bank 1	active
    Chain elongation; no. of valid initial values; exhaust bank 1	0
    Chain elongation; no. of valid initial values; intake bank 1	5
    Deactivate production mode	00 00 00
    Deactivation of static maximum speed limit	00 00
    Idle RPM correction	80
    Individually adjustable maximum speed limit	100.0 km/h
    Production mode	00 00 00
    Protective function	Enabled
    Static maximum speed limit	100.0 km/h
    Timing deviation after chain replacement; exhaust bank 1	0.00 °
    Timing deviation after chain replacement; intake bank 1	-0.75 °
    Timing deviation after other repairs; exhaust bank 1	0.00 °
    Timing deviation after other repairs; intake bank 1	0.00 °
    Timing deviation; current value exhaust bank 1	0.00 °
    Timing deviation; current value intake bank 1	-0.43 °
    ;Monday	16	February
