Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Audi A3 Virtual Cockpit Check Engine Light
  1. #21
    Apr 2020
    Washington, USA
    I also had to add a wire that did not come in my AliExpress wiring harness which went from pin 1 on the hex17 module to the quad-connector on the MIB unit. It is for the H20 connection which is listed as "Connection 1, in diagnosis wiring harness" on the schematic... hope this helps.. and thank you!!
  2. #22
    Quote Originally Posted by hro0250 View Post
    Sorry I should've clarified, that is my OEM MIB. I didn't want to add the eBay one and confuse anyone until I could solve the check engine light. So it should not have navigation fitted nor component protection. I will post an autoscan of the eBay MIB later on. So for now the only retrofitted module is the hex17.
    No - you were correct in leaving the old MIB in the auto-scan. My question was intended to focus on why the comms DTC by the ECU appeared (in both auto-scans) despite the original MIB beng installed. Might be better to solve this problem first - check wiring/connectors
  3. Likes hro0250 liked this post
  4. #23
    Apr 2020
    Washington, USA
    Hmm.. Let me take out the H20 connection I added and see if that solves that problem. That is the only wiring change I've made.
  5. #24
    Apr 2020
    Washington, USA
    So I removed the wire I added and reset the DTCs and it is still there.. I'm not sure what "Check software version management" is referring too.
     Thursday,02,July,2020,16:29:13:03229
    VIN: WAUJEGFF4LA039731   License Plate:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
              52 5F 6C A5 BB BC CF D6 D7
    VIN: WAUJEGFF4LA039731   Mileage: 3294km-2046miles
    Address 01: Engine (J623-DHHA)       Labels: None
       Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
       Revision: --H13---
       Coding: 0A2500324466010F3000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
       ROD: EV_ECM20TFS0205G0906259Q.rod
       VCID: 3C21313366EB6E3B4F3-8068
    19868 - No Communication with Instrument Cluster
              U0155 00 [039] - -
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:20
                        Coolant temperature: 17 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 11.953 V
                        Engine: operating status: ES
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 16.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 1421 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        T_AST_SAE: 0 s
    23079 - Control unit for information electronics 1
              U1054 00 [039] - No Communication
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:20
                        ECU_STATE: ENG_STOP
                        T_ES: 1421 min
                        T_AST_SAE: 0 s
    Readiness: 1110 1101
       Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2402
       Revision: 00H06V09
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061.rod
       VCID: 2E050B7BA0978CABF17-807A
       Part No SW: 5Q0 614 517 FH    HW: 5Q0 614 517 BS
       Component: ESC           H82 0191
       Revision: 00000000    Serial number: 61709000000162
       Coding: 13FF6B9250232275897E0B03A0C469C8D60A4491D005967C1841505492A84A0B0000000012121212B835351919323200
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 7CA1F133266BAE3B0F3-8028
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0533132295
       Coding: 030C0C1720
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 45D754D715212FF320D-8010
       Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
       Component: AC Automat    H03 0161
       Revision: 20001000    Serial number: 00000001931597
       Coding: 03000014010000001000000000001400
       Shop #: WSC 06335 790 00021
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
       Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
       Component: G935 MuFu  H04 0010
       Serial number: 2510191409PAG0MUFU05
       Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H40 0312
       Serial number: 01001931300722
       Shop #: WSC 06324 790 00021
       ASAM Dataset: EV_BCMMQB 020001
       ROD: EV_BCMBOSCH_020.rod
       VCID: 7BA3F22F2365A903069-802E
       Component: WWS371 190823  043  0585
       Serial number:         190913083158
       Coding: 0A47F7
       Component: G397_RLFS  H06  0002
       Serial number: 22072612X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06  0032
       Serial number: 28 08 2019  20001138
       Component: Sensor, DWA  005  0316
       Serial number: 000000000ZY1928019A7
       Component: Sirene, DWA  005  0314
       Serial number: 00000000000031914425
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H04  0005
       Serial number: 0000FST002FEBW200000
       Coding: 101F00
       Steering Column Switch:
       Subsystem 7 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004  0070
       Serial number: 00000026101904401337
       Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
       Component: PLA 3.0 12K   H08 0061
       Serial number: 000150057319291
       Coding: 0270167851
       ASAM Dataset: EV_EPHVA2CAU3700000 009048
       ROD: EV_EPHVA2CAU3700000_009_AU37.rod
       VCID: 55F78497E5819F7350D-8000
       Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
       Component: ACC BOSCH MQB H11 0682
       Coding: B50087C111FFC428949C815580302600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D149D31E1B16FB373-8010
       Component: AirbagVW20    012 0830
       Serial number: 003GCR0GXXFQ
       Coding: 9DCCFCC0000000005000001AC248000000C5
       ROD: EV_AirbaVW20SMEVW37X_VW48.rod
       VCID: 47CB5EDF2F2D3DE3D21-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A25101920306
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A22101920366
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001X8DVJ
       Coding: 303430
       Subsystem 4 - Part No SW: -----------    HW: 480 003 010 19
       Serial number: 357000000002F3512044
       Subsystem 5 - Part No SW: -----------    HW: 480 003 010 19
       Serial number: 35800000000DF658BF36
       Subsystem 6 - Part No SW: -----------    HW: 480 400 511 19
       Component: SideSensor_Dr  002 6149
       Serial number: 35100012A62E7526950Z
       Subsystem 7 - Part No SW: -----------    HW: 480 400 511 19
       Component: SideSensor_Pr  002 6149
       Serial number: 35200012A62E7524816Z
       Subsystem 8 - Part No SW: -----------    HW: 480 402 210 19
       Component: FrontSensor_D  004 6149
       Serial number: 35500012C62E74E485CI
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 210 19
       Component: FrontSensor_P  004 6149
       Serial number: 35600012C62E74E2F40B
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790     HW: 8V0 920 790
       Component: FBenRDW       H13 0045
       Coding: 048418506F80CE080085E8001000500000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 79AFE82729599B13145-802C
              U1014 00 [009] - -
              [ECU incorrectly coded]
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:19
    9582600 - Switch for Instrument Cluster
              B1893 13 [009] - Open Circuit
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:19
    16777022 - Control unit for information electronics 1
              U1054 00 [009] - No Communication
              [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:19
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0000233123
       Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF_AU37.rod
       VCID: 70B9D5037A23DA5BA3B-8024
       Component: 4-01-0D-01-04
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20200122020402 20064
       Component: J367-BDMConti  H03 1051
       Serial number: 75886003911910250CF1
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00025.09.19
       Coding: 0001
       Shop #: WSC 06325 790 00021
       VCID: 4CC161F3364BDEBBFF3-8018
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DD4FCB040F18CB05F-8016
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000307431007
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: 313F1007B1A99353EC5-8064
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 J    HW: 3Q0 907 566
       Component: MRR1Rear      H25 0640
       Revision: --------
       Coding: 04C002
       VCID: 3FDB463F77FD75236A1-806A
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0325
       Serial number: YE007SIU1030A
       Coding: 005E1B204000008000000002
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       ROD: EV_DCU2DriveSideMAXHKLO.rod
       VCID: 49CF58E73939CB93C45-801C
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1082
       Coding: 931F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1D9130E3BE67B473-8020
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAK5F02TC51
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 2411E953FE5B36FB173-8070
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 02111910802027
       Coding: 000000050900147200112300040000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003_VW41.rod
       VCID: 372B2E1F5FCD4D63A21-8062
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0325
       Serial number: YE007SJ112625
       Coding: 005E13204000008000000002
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 48C95DE32233329BDBB-801C
       Part No SW: 8V1 035 652 D    HW: 8V1 035 652
       Component: MU-HS-S-US    050 0185
       Coding: 017301000000000011220002061A00232F002DE401F001040A
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 38292D2352D3421BABB-806C
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9K1Y0LRB2
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
       Component: ControlUnit_B  H50 0106
       Serial number: ALJAL112091900050238
              B201A 00 [009] - -
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 16:26:19
                        Voltage terminal 30: 12.0 V
                        Status_Software_Version_Management-module_name: C
       Component: RVC Compact   H18 0231
       Coding: 0273010102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       VCID: 392F282769D95B13545-806C
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 08111915P10142
       Coding: 040307010000020101220046C14E490080000E20012000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_002.rod
       VCID: 40D945C30A030ADB13B-8014
       Part No SW: 5Q0 959 395 K    HW: 8W1 959 395 D
       Component: TSG HFS004 0325
       Serial number: YE007SJ51109E
       Coding: 000C13204000008000000002
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
       Component: TSG HBFS004 0325
       Serial number: YE007SJ51109B
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 J    HW: 3Q0 907 590
       Revision: --------
       Coding: 04C002
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       ROD: EV_LEDModLeftMELCOAU736_AU37.rod
       VCID: 176BCE9F3F0D6D63821-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 01:43, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  6. #25
    https://duckduckgo.com/?t=ffsb&q=%22....ross-tech.com
  7. Likes hro0250, PetrolDave liked this post
  8. #26
    Apr 2020
    Washington, USA
    Thank you, that solved that issue! However the engine and the instruments still have the lost communication error...
     Thursday,02,July,2020,19:03:42:03229
       Revision: --H13---
              U0155 00 [039] - -
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 18:59:32
                        Coolant temperature: 18 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 11.855 V
                        ECU_STATE: ENG_STOP
                        T_ES: 1574 min
                        T_AST_SAE: 0 s
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 18:59:32
                        ECU_STATE: ENG_STOP
                        T_ES: 1574 min
                        T_AST_SAE: 0 s
       Revision: 00H06V09
       Coding: 030C0C1720
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 101F00
       Coding: 0270167851
       Coding: 333135
       Coding: 333135
       Occupant Detection:
       Coding: 303430
              U1014 00 [009] - -
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 18:59:48
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 18:59:48
                        Reset counter: 136
                        Mileage: 3294 km
                        Date: 2020.07.02
                        Time: 18:59:48
       Coding: 0001
       Revision: --------
       Coding: 04C002
       Coding: 931F0000
       Revision: --------
       Coding: 04C002
    End----(Elapsed Time: 01:43, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  9. #27
    OK: latest auto-scan still has the principal DTCs.
    In an effort to examine your long - code string, I've managed to find 3 x similar hex17 modules with the following characteristics:
    • Late model A3/R3/RS3 NAR build
    • hex17 module with Component = FBenRDW (most NAR models have FBenUSA modules and most/All? Row models have FBenRDW- I have no idea of the difference)
    The associated scan for these cars can be found at the forum posts below:
    case 1
    case 2
    case 3
    Here's a comparison of your hex17 long code string and the 3 x cases above:
    Name	hro0250		        case 1		        case 2		        case 3
    Byte	Hex	Binary	        Hex	Binary	        Hex	Binary	        Hex	Binary
    0	04	00000100	08	00001000	08	00001000	08	00001000
    1	84	10000100	2D	00101101	0F	00001111	0D	00001101
    2	18	00011000	18	00011000	18	00011000	18	00011000
    3	50	01010000	53	01010011	53	01010011	53	01010011
    4	6F	01101111	2B	00101011	7F	01111111	6F	01101111
    5	80	10000000	88	10001000	88	10001000	88	10001000
    6	CE	11001110	00	00000000	00	00000000	00	00000000
    7	08	00001000	08	00001000	08	00001000	08	00001000
    8	00	00000000	02	00000010	02	00000010	02	00000010
    9	85	10000101	04	00000100	84	10000100	84	10000100
    10	E8	11101000	EC	11101100	EC	11101100	EC	11101100
    11	00	00000000	04	00000100	00	00000000	04	00000100
    12	10	00010000	18	00011000	18	00011000	18	00011000
    13	00	00000000	00	00000000	00	00000000	00	00000000
    14	50	01010000	00	00000000	00	00000000	00	00000000
    15	00	00000000	10	00010000	10	00010000	10	00010000
    16	00	00000000	00	00000000	00	00000000	00	00000000
    17	00	00000000	00	00000000	00	00000000	00	00000000
    18	00	00000000	00	00000000	00	00000000	00	00000000
    19	00	00000000	00	00000000	00	00000000	00	00000000
    Nothing jumps out (for me, at least) -except perhaps for Byte 15, Bit 4 (enable engine data display) - as you can see the other 3 x modules have this software switch set. Maybe someone else has further insights?
    The other possible cause for the Control Module Incorrectly Coded DTC could be one, or more dubious channel settings in the hex17 module. Have you created an admap for the new module?
  10. Likes Uwe liked this post
  11. #28
    Apr 2020
    Washington, USA
    No I haven't made an admap, I'm sorry I don't fully know what that is. I see from your links to make one is (VCDS Main Screen --> Applications --> Controller Channel Map --> check Adaptations and CSV --> enter appropriate Login for control unit (e.g. 31347 for unit 09, 20103 for unit A5 and so on...) but I don't know the code for module 17 and when I tried it it didn't give me an option to save or copy. It said "350 lines added" or something along those lines.
    I received the trip reset button today and cleared the fault for short to ground, so the only errors left are module 17 incorrectly coded and no connection with MMI, and engine module no communication with instrument cluster or MMI.
    I really appreciate the help, I'm trying to learn how to use this as I go.
  12. #29
    Look in the C:\Ross-Tech\VCDS\Logs folder ...
  13. Likes Uwe, DV52 liked this post
  14. #30
    Apr 2020
    Washington, USA
    Thanks I knew I was missing it somewhere! This cluster was from an EU spec car, does that make a difference? I know in the original post I saw that guy also used an EU cluster and he had no issues...
     ;SW:8V0-920-790   HW:8V0-920-790 ---  Instruments
    ;Component:FBenRDW       H13 0045	 Coding:048418506F80CE080085E8001000500000000000
    ;EV_DashBoardFPKAU37X	1023	EV_DashBoardFPKAU37X.rod
    ;Friday	3	July	2020	17:49:11:03229
    ;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
    ;VCID: 79AFE82729599B13145-802C
    IDE00001-Production mode	not active 	3
    IDE00301-Distance	3294 km	3
    IDE00342-ESI: Resetting ESI	no warning 	1
    IDE00343-Language version	US English 	1
    IDE00499-Display correction of consumptions and operating range	100%	1
    IDE00500-Hour	17 H	1
    IDE00501-Minute	48 min	1
    IDE00502-Year	2020 yr	2
    IDE00503-Month	7 mon	1
    IDE00504-Day	3 d	1
    IDE00510-ESI: distance driven from inspection	1200 km	3
    IDE00511-ESI: time from inspection	37 d	2
    IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
    IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
    IDE00514-ESI: maximum value of time between inspections	730 d	2
    IDE00515-ESI: oil quality	poor oil quality 	1
    IDE00517-ESI: soot entry	0 km	2
    IDE00518-ESI: thermal load	2500 km	2
    IDE00819-Day counter	564 d	2
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE00827-ESI: minimum value of time between inspections	365 d	2
    IDE01153-SIA: maximum value of distance to service	15000 km	2
    IDE01154-SIA: maximum value of time to service	365 d	2
    IDE02332-Deactivate production mode	0	3
    IDE02489-Display depiction	Version 1 	1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.80 l	5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.80 l	5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.80 l	5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.70 l	5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.70 l	5
    IDE03329-Driving profiled for range remaining	7.90 l/100km	2
    IDE03346-IDE00301-Units adjusted-Distance	miles 	3
    IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy 	3
    IDE03346-MAS01456-Units adjusted-Speed	Miles per hour 	3
    IDE03346-MAS02201-Units adjusted-Temperature	°F 	3
    IDE03346-MAS02957-Units adjusted-Time	12h AM_PM 	3
    IDE03346-MAS03032-Units adjusted-Volume	gallons (US) 	3
    IDE03346-MAS03034-Units adjusted-Pressure	psi 	3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (US) 	3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
    IDE03348-MAS01456-Speed warning-Speed	0	2
    IDE03348-MAS01561-Speed warning-Unit	Miles per hour 	2
    IDE03348-Speed warning-	not active 	2
    IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	3
    IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	2800 km	3
    IDE03352-FIX: Time since last time-dependent inspection	574 d	2
    IDE03372-Source for synchronization of time	GPS 	1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	OFF 	5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
    IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
    IDE03867-Deactivate seat belt warning	No 	1
    IDE04169-Display correction of consumption and operating range: gas	100%	1
    IDE05930-Service notification in days	30 d	1
    IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06588-Ignition active message: actuator	Driver door 	1
    IDE06922-No-voltage display	No display 	1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
    IDE07221-Cylinder shut-off	Display 	1
    IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage	10.00 A	8
    IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive	25	8
    IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer	0.2	8
    IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer	0.5	8
    IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0	25	14
    IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1	25	14
    IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2	25	14
    IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3	25	14
    IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4	25	14
    IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5	25	14
    IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6	25	14
    IDE08140-Driving profiled for range remaining CNG	0.00 kg/100 km	2
    IDE08247-Driving profile for range remaining LPG	0.00 l/100km	2
    IDE10208-Display correct. of consump. and operating range: elec.	100%	1
    IDE10693-Initialize sensor for fuel level	No 	1
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0	7.90 l/100km	14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1	10.00 l/100km	14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2	10.00 l/100km	14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3	10.00 l/100km	14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4	10.00 l/100km	14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5	10.00 l/100km	14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6	10.00 l/100km	14
    IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel	No display 	4
    IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality	No display 	4
    IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required	No display 	4
    IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement	No display 	4
    IDE11472-MAS18774-Configuration of displayable contents-Drag indicator	No display 	4
    IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color	Standard 	4
    IDE12050-Acoustic: drive position R	not active 	1
    MAS03555-Lap counter	No display 	1
    MAS03685-Digital speedometer	Display 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	21
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	21
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	21
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	21
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	21
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	21
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	21
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	21
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	21
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	21
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	21
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	21
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	21
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	21
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	21
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	21
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	21
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	21
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	21
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	21
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	21
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	21
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	21
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	21
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	21
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	21
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	21
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	21
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	21
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	21
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	21
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	21
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	21
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	21
    ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40	OFF 	21
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	21
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	21
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	21
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	21
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	50ms 	21
    ENG128731-MAS01129-designvariant_activation-Version 1	not active 	2
    ENG128731-MAS01130-designvariant_activation-Version 2	not active 	2
    ENG128731-MAS01131-designvariant_activation-Version 3	not active 	2
    ENG128731-MAS03101-designvariant_activation-Version 4	not active 	2
    ENG128731-MAS03102-designvariant_activation-Version 5	not active 	2
    ENG128731-MAS03103-designvariant_activation-Version 6	not active 	2
    ENG128731-MAS03104-designvariant_activation-Version 7	not active 	2
    ENG128731-MAS03105-designvariant_activation-Version 8	not active 	2
    ENG99320-Developers_menu	not active 	1
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1	0	12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2	0A 	12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3	32	12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4	64	12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5	DC 	12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6	FD 	12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1	2	12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2	2	12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3	6	12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4	0A 	12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5	50	12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6	64	12
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	0A 	12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	32	12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	64	12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	96	12
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	2	12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	2	12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0E 	12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	1E 	12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	32	12
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	0E 	12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	1E 	12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	32	12
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	14	12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	1E 	12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	32	12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	46	12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	64	12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	0	12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	14	12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	1E 	12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	32	12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	46	12
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	DC 	12
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	2	12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	2	12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	6	12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	0A 	12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	50	12
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 96 	20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 32 	20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 64 	20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	DC 	12
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	2	12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	2	12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	6	12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	0A 	12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	50	12
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xs_bus 	1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	lds 	1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.00 km	16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.00 °C	16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
    ENG126283-parameter_hmi	41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	100
    ENG135292-phev_stat_intervall-	5	3
    ENG135292-phev_stat_intervall-	100 m	3
    ENG135292-phev_stat_intervall-	0 min	3
    ENG119825-Picture_Upload_Download	not active 	1
    ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures	6	3
    ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate	150 s	3
    ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal	300 s	3
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
    ENG109442-ENG101663-time_parameter_display-tDD15_off	0.25	18
    ENG109442-ENG103975-time_parameter_display-tDD15_on	0.5	18
    ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
    ENG112418-ENG112412-total_range_gas-consumption_factor	1.4	4
    ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
    ENG112418-ENG99298-total_range_gas-State	active 	4
    Elapsed Time: 00:38
