Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: Audi A3 Virtual Cockpit Check Engine Light
    Apr 2020
    Washington, USA
    That's a good question.. I got one from a car with Nav (it has the LTE antenna areal port and a SIM card slot). I plugged it in to my car to verify it works and I noticed it doesn't have navigation on the main home screen. Really all I wanted was an MMI unit with all the correct fakra connectors on the back for the VC as well as nav. My car had every other program on MMI already. It sounds like navigation may need to be flashed onto the module..
    When I plug it in to my car everything starts up and appears to work, but there is no sound from the radio, and it won't allow me to connect bluetooth/use apple CarPlay. It also doesn't have all the correct vehicle settings, it seems as though I can add those with VCDS but navigation may not be on it...
  2. #12
    hro0250: I note your continued attempts to resolve this matter.
    If you have purchased a new MMI from eBay and if "everything starts up and appears to work, but there is no sound from the radio" -I suspect that you have Component Protection DTC s in both the hex5F and Hex19 modules.
    Of course, the only way to confirm this suspicion is for you to follow Uwe's tactful, but nevertheless necessary advice below:
    May I be so bold as to suggest that the owner of a 2020 Audi, who is doing retrofit/upgrades to his car and is seeking help in this forum, should consider spending the $199 it would take to have his own VCDS so he can post data here?
    Without a current, complete (meaning unedited) copy of an auto-scan for the car - all responses by others on this forum (including my reply) are just sheer speculation!!
  3. Likes PetrolDave liked this post
  4. #13
    Apr 2020
    Washington, USA
    Thanks Don, as I said in my previous post, I have purchased VCDS and I will be posting an autoscan hopefully tomorrow. I will also plug in my new MMI unit to ensure its fault codes show up on the autoscan as well. However even speculation at this point is helpful as I was kind of thrown to the wind by this company, so I am trying my best to gather info and learn as I go.
  5. Likes DV52 liked this post
  6. #14
    Apr 2020
    Washington, USA
    Alright.. I see more error codes than I'd like, hopefully now they make sense to you guys.
    Tuesday,30,June,2020,16:56:44:03229
    VIN: WAUJEGFF4LA039731   License Plate:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
              52 5F 6C A5 BB BC CF D6 D7
    VIN: WAUJEGFF4LA039731   Mileage: 3227km-2005miles
    Address 01: Engine (J623-DHHA)       Labels: None
       Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
       Revision: --H13---
       Coding: 0A2500324466010F3000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
       ROD: EV_ECM20TFS0205G0906259Q.rod
       VCID: 3C21313366EB6E3B4F3-8068
    38649 - EVAP Purge System
              P00FE 00 [096] - Line Restricted / Blocked
                        Mileage: 3003 km
                        Date: 2020.06.25
                        Time: 15:55:56
                        Engine speed: 1504.00 /min
                        Vehicle speed: 60 km/h
                        Coolant temperature: 100 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 14.433 V
                        Unlearning counter according OBD: 30
                        Engine: operating status: PUC
                        STATE_LS_SAE[1]: OL_INTR
                        T_AST_SAE: 643 s
                        MAP_MES_SAE: 30 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.071 V
                        FAC_TPS_1_SAE: 13.281250 %
                        FUP_H_SAE: 8060.0 kPa
    19868 - No Communication with Instrument Cluster
              U0155 00 [175] - -
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 18:15:37
                        Engine speed: 1135.75 /min
                        Normed load value: 8.6 %
                        Coolant temperature: 78 °C
                        Intake air temperature: 46 °C
                        Voltage terminal 30: 13.750 V
                        Engine: operating status: IS
                        ECU_STATE: SYN_ENG_IGK_ON
                        Engine oil temperature: 67.0 °C
                        Time since engine start: 52.0 s
                        T_ES: 0 min
                        Cruise control switch actuation-Main switch hardware: operated
                        Cruise control switch actuation-Main switch CAN: operated
                        T_AST_SAE: 0 s
    23079 - Control unit for information electronics 1
              U1054 00 [047] - No Communication
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 18:15:37
                        T_ES: 0 min
                        T_AST_SAE: 0 s
       Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2402
       Revision: 00H06V09
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061.rod
       VCID: 2E050B7BA0978CABF17-807A
       Part No SW: 5Q0 614 517 FH    HW: 5Q0 614 517 BS
       Component: ESC           H82 0191
       Revision: 00000000    Serial number: 61709000000162
       Coding: 13FF6B9250232275897E0B03A0C469C8D60A4491D005967C1841505492A84A0B0000000012121212B835351919323200
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 7CA1F133266BAE3B0F3-8028
    8236 - Databus
              [FCAN: Kombi_01 messagei is not received]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0533132295
       Coding: 030C0C1720
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 45D754D715212FF320D-8010
    12718086 - Databus
              [Message WFS_01 missing]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:38:00
                        Terminal_15_Kessy_specified_value: OFF
                        Terminal_15_Kessy_actual_value: OFF
                        Terminal_15_central electric_actual_value: OFF
                        Terminal_15red_Kessy_specified_value: OFF
                        Terminal_15red_Kessy_actual_value: OFF
                        Terminal_S_Kessy_specified_value: OFF
                        Terminal_S_Kessy_actual_value: OFF
                        Terminal_S_central electric_actual_value: OFF
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 12.439 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: Open
                        Front Passenger Door: Open
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
       Component: AC Automat    H03 0161
       Revision: 20001000    Serial number: 00000001931597
       Coding: 03000014010000001000000000001400
       Shop #: WSC 06335 790 00021
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
       Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
       Component: G935 MuFu  H04 0010
       Serial number: 2510191409PAG0MUFU05
    459011 - Databus
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
       Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H40 0312
       Serial number: 01001931300722
       Shop #: WSC 06324 790 00021
       ASAM Dataset: EV_BCMMQB 020001
       ROD: EV_BCMBOSCH_020.rod
       VCID: 7BA3F22F2365A903069-802E
       Component: WWS371 190823  043  0585
       Serial number:         190913083158
       Coding: 0A47F7
       Component: G397_RLFS  H06  0002
       Serial number: 22072612X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06  0032
       Serial number: 28 08 2019  20001138
       Component: Sensor, DWA  005  0316
       Serial number: 000000000ZY1928019A7
       Component: Sirene, DWA  005  0314
       Serial number: 00000000000031914425
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H04  0005
       Serial number: 0000FST002FEBW200000
       Coding: 101F00
       Steering Column Switch:
       Subsystem 7 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004  0070
       Serial number: 00000026101904401337
    395273 - Control Circuit for Signal Horn
              B1344 14 [008] - Open or Short to Ground
                        Reset counter: 161
                        Mileage: 2958 km
                        Date: 2020.06.24
                        Time: 17:12:50
    539925 - Databus
              [Kombi_02 Datenbus fehlende Botschaft]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:38:00
    558869 - Databus
              [Kombi_01 Datenbus fehlende Botschaft]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
       Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
       Component: PLA 3.0 12K   H08 0061
       Serial number: 000150057319291
       Coding: 0270167851
       ASAM Dataset: EV_EPHVA2CAU3700000 009048
       ROD: EV_EPHVA2CAU3700000_009_AU37.rod
       VCID: 55F78497E5819F7350D-8000
    12670209 - Databus
              [Steuergerät für Schalttafeleinsatz-J285 - Kombi_01 - kein Signal/keine Kommunikation]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
       Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
       Component: ACC BOSCH MQB H11 0682
       Coding: B50087C111FFC428949C815580302600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D149D31E1B16FB373-8010
    1080 - Databus
              [FAULT_TIMEOUT_KOMBI_01]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
                        Control Module temperature: 35 °C
                        Voltage terminal 15: 11.1 V
       Component: AirbagVW20    012 0830
       Serial number: 003GCR0GXXFQ
       Coding: 9DCCFCC0000000005000001AC248000000C5
       ROD: EV_AirbaVW20SMEVW37X_VW48.rod
       VCID: 47CB5EDF2F2D3DE3D21-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A25101920306
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A22101920366
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001X8DVJ
       Coding: 303430
       Subsystem 4 - Part No SW: -----------    HW: 480 003 010 19
       Serial number: 357000000002F3512044
       Subsystem 5 - Part No SW: -----------    HW: 480 003 010 19
       Serial number: 35800000000DF658BF36
       Subsystem 6 - Part No SW: -----------    HW: 480 400 511 19
       Component: SideSensor_Dr  002 6149
       Serial number: 35100012A62E7526950Z
       Subsystem 7 - Part No SW: -----------    HW: 480 400 511 19
       Component: SideSensor_Pr  002 6149
       Serial number: 35200012A62E7524816Z
       Subsystem 8 - Part No SW: -----------    HW: 480 402 210 19
       Component: FrontSensor_D  004 6149
       Serial number: 35500012C62E74E485CI
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 210 19
       Component: FrontSensor_P  004 6149
       Serial number: 35600012C62E74E2F40B
    1051904 - Databus
              [NWD: 0x30B Kombi_01Timeout]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790     HW: 8V0 920 790
       Component: FBenRDW       H13 0045
       Coding: 048418506F80CE080085E8001000500000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 79AFE82729599B13145-802C
              U1014 00 [009] - -
              [ECU incorrectly coded]
                        Fault Frequency: 89
                        Reset counter: 134
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:42:11
    9582600 - Switch for Instrument Cluster
              B1893 13 [009] - Open Circuit
                        Fault Frequency: 202
                        Reset counter: 134
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:42:11
    16777022 - Control unit for information electronics 1
              U1054 00 [008] - No Communication
              [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                        Fault Frequency: 9
                        Reset counter: 164
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:42:11
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0000233123
       Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF_AU37.rod
       VCID: 70B9D5037A23DA5BA3B-8024
       Component: 4-01-0D-01-04
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20200122020402 20064
       Component: J367-BDMConti  H03 1051
       Serial number: 75886003911910250CF1
    131604 - No Communication with Instrument Cluster
              U0155 00 [008] - -
              [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:38:00
                        Supply voltage: Terminal 30: 12.3 V
                        Terminal 15: OFF
    131699 - Control unit for information electronics 1
              [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                        Reset counter: 143
                        Mileage: 2289 km
                        Date: 2020.06.08
                        Time: 16:23:19
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
    197169 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
              [MFL (LIN#2) Timeout]
                        Reset counter: 161
                        Mileage: 2958 km
                        Date: 2020.06.24
                        Time: 17:35:44
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
    8526361 - LV Energy Management
              B1802 F1 [008] - Warning Triggered
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:15:22
                        Supply voltage: Terminal 30: 11.2 V
                        Terminal 15: On
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00025.09.19
       Coding: 0001
       Shop #: WSC 06325 790 00021
       VCID: 4CC161F3364BDEBBFF3-8018
    16654 - Databus
              [Kombi - TO -- Kombi_01]
                        Fault Priority: 8
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DD4FCB040F18CB05F-8016
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000307431007
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: 313F1007B1A99353EC5-8064
    12666387 - Databus
              [Timeout Message WFS_01]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:38:00
                        Result lock conditions: valid
                        ESCL locked: Yes
                        ESCL unlocked: No
                        Lock sensor: operated
                        Unlock sensor: not activated
                        Error mode 1: not active
                        Error mode 2: not active
                        Clamp S: OFF
                        Clamp 15: OFF
                        Clamp 15 Status: valid
                        Remote Start: not active
                        Driver door: Open
                        Central locking locked external: unlocked
                        Central locking safed external: Vehicle not secured
                        Clamp Request: No
                        Request highside lock: No
                        HW highside lock: OFF
                        Highside unlock: No
                        Motor break: not active
                        Activation lowside unlock: OFF
                        Activation lowside lock: OFF
                        I2C overflow: No
                        I2C error pathflags: No
                        I2C resetinfo: No
                        I2C error cpu: No
                        I2C error rom: No
                        I2C error ram: No
                        I2C length failure: No
                        I2C error sda: No
                        I2C communication failure: i2c no comm failure
                        I2C state esp 10: i2c cnd true
                        I2C cnd haco message: valid
                        Coco reset: No
                        Coco supply: On
                        Password IMS OK: Yes
                        Signature IMS OK: Yes
                        IMS responded: Yes
                        Positive authentification in current KL15 cycle: No
                        Lifestate: Immobilizer download obtained
                        Learn mode: Adapted
                        Authentication valid (T1): No
                        State of authentication state machine: WFS_AUTH_INIT_e
                        Vehicle speed: 0.00 km/h
                        UBat internal: 11.7 V
                        UMotorBridge: 6.4 V
                        Lock condition engine speed: Condition met
                        Lock condition clamp S: Condition met
                        Lock condition clamp 15: Condition met
                        Lock condition E2E clamp status: Condition met
                        Lock condition timeout clamp status: Condition met
                        Lock condition vehicle speed: Condition met
                        Lock condition E2E vehicle speed: Condition met
                        Lock condition timeout vehicle speed: Condition met
                        Lock condition Mode1: Condition met
                        Lock condition drive readiness: Condition met
                        Lock condition selector lever position parking: Condition met
                        Clamp enable ESCL: not enabled
                        Lock condition timeout distance pulse: Condition met
                        Lock condition E2E distance pulse: Condition met
                        Lock condition difference distance pulse: Condition met
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 J    HW: 3Q0 907 566
       Component: MRR1Rear      H25 0640
       Revision: --------
       Coding: 04C002
       VCID: 3FDB463F77FD75236A1-806A
    1311234 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Reset counter: 144
                        Mileage: 2308 km
                        Date: 2020.06.09
                        Time: 06:17:15
                        Control Module temperature: 32 °C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 75.85 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 12.60 V
    1183837 - Databus
              [databus message missing - Kombi]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
                        Control Module temperature: 43 °C
                        Voltage terminal 15: 10.80 V
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0325
       Serial number: YE007SIU1030A
       Coding: 005E1B204000008000000002
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       ROD: EV_DCU2DriveSideMAXHKLO.rod
       VCID: 49CF58E73939CB93C45-801C
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1082
       Coding: 931F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1D9130E3BE67B473-8020
    22016 - Databus
              [KFC_KOMBI_01 Botschaft - CAN-Timeout]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
                        Motor status: 00
                        Supply voltage: 11.25 V
                        Temperature: 25.0 °C
                        KFC: 56
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 11.41 V
                        uAdSensI_SwitchedKl30_xdu16: 11.32 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAK5F02TC51
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 2411E953FE5B36FB173-8070
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 02111910802027
       Coding: 000000050900147200112300040000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003_VW41.rod
       VCID: 372B2E1F5FCD4D63A21-8062
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0325
       Serial number: YE007SJ112625
       Coding: 005E13204000008000000002
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 48C95DE32233329BDBB-801C
       Part No SW: 8V1 035 652 D    HW: 8V1 035 652
       Component: MU-HS-S-US    050 0185
       Coding: 017301000000000011220002061A00232F002DE401F001040A
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 38292D2352D3421BABB-806C
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9K1Y0LRB2
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
       Component: ControlUnit_B  H50 0106
       Serial number: ALJAL112091900050238
    11 Faults Found:
              B201A 00 [009] - -
                        Fault Frequency: 84
                        Reset counter: 134
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 10:32:25
                        Voltage terminal 30: 11.5 V
                        Status_Software_Version_Management-module_name: C
    0005 - Antenna Amplifier 1 for Radio
              B126D 13 [008] - Open Circuit
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:00:43
                        Voltage terminal 30: 11.3 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
    0006 - Antenna Amplifier 2 for Radio
              B126E 13 [008] - Open Circuit
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:00:43
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
    0009 - Antenna for Satellite Radio
              B10F4 13 [008] - Open Circuit
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:00:43
                        Satellite radio tuner status-Antenna current: 255 mA
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: FF
    2565 - GPS Antenna
              B1054 13 [008] - Open Circuit
              [GPS aerial - open circuit]
                        Reset counter: 143
                        Voltage terminal 30: 12.5 V
    1562 - Microphone 1
              B129B 11 [008] - Short to Ground
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:16:39
    6179 - Display Module 1 for Multimedia System
              B1297 F6 [008] - Cable for Video Signal; Open Circuit
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:00:43
    6666 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:37:59
                        Voltage terminal 30: 12.4 V
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: 0 °C
                        Temperature of MOST transceiver-Current: 35 °C
    6698 - Optical data bus
              [Optical data bus: open circuit: wakeup]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 16:38:00
    6667 - Optical Data Bus for Information Electronics 1
              U10CA 00 [008] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in central processor]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:02:12
                        Voltage terminal 30: 13.8 V
                        Temperature of MOST transceiver-Current: 27 °C
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [008] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in sound]
                        Reset counter: 143
                        Mileage: 2288 km
                        Date: 2020.06.08
                        Time: 00:01:02
                        Voltage terminal 30: 13.3 V
                        Temperature of MOST transceiver-Current: 29 °C
       Component: RVC Compact   H18 0231
       Coding: 0273010102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       VCID: 392F282769D95B13545-806C
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 08111915P10142
       Coding: 040307010000020101220046C14E490080000E20012000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_002.rod
       VCID: 40D945C30A030ADB13B-8014
    1122612 - Databus
              [TIMEOUT_Kombi_01]
                        Reset counter: 141
                        Mileage: 2230 km
                        Date: 2020.06.08
                        Time: 11:38:20
                        Control Module temperature: 52 °C
                        Outside air temperature: 13.5 °C
                        System run time: 5849.3 s
                        Voltage terminal 15: 11.2 V
                        mid: 01 CF
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
       Part No SW: 5Q0 959 395 K    HW: 8W1 959 395 D
       Component: TSG HFS004 0325
       Serial number: YE007SJ51109E
       Coding: 000C13204000008000000002
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
       Component: TSG HBFS004 0325
       Serial number: YE007SJ51109B
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 J    HW: 3Q0 907 590
       Revision: --------
       Coding: 04C002
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       ROD: EV_LEDModLeftMELCOAU736_AU37.rod
       VCID: 176BCE9F3F0D6D63821-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.2V)-----------
  7. #15
    OP is now verified. Moving to Retrofits.
    This car has a boatload of fault codes that are flagged "Intermittent". Please clear all fault codes, cycle the ignition, and then re-scan it. Doing so should improve the signal-to-noise ratio in the data tremendously.
  8. Likes PetrolDave, hro0250 liked this post
  9. #16
    Apr 2020
    Washington, USA
    Will do, updated autoscan coming this evening.
    Thanks!
  10. #17
    Quote Originally Posted by hro0250 View Post
    Arrrrh.......... that's better (thanks for posting) - now we can see the heart-beat of the car in all of its pristine detail!!!
    It looks like you were a busy boy on the 8th June 2020 @ about 11:30 AM - I'm guessing that's when you did the hex 17 module swap, maybe (with an auto-scan we can even see what color underpants you were wearing on that day - but that's probably too much information ).
    I'm looking forward to seeing the refreshed auto-scan as Uwe has suggested; sans the misdemeanor DTC s which were likely generated while you were busy unplugging/reconnecting various wires/sockets.
    In any event, if I look only at those DTC s in your auto-scan that have a respectable "Fault frequency" (meaning the number of times that the fault has been re-recorded by the CAN network on any subsequent ignition cycle after first registration), it seems that it's all happening in the hex 17 module (perhaps unsurprisingly)
    So, in repesct of the "Control Module Incorrectly Coded" DTC on the hex17 module - here's how the long-code looks in a more readable form:
    Byte	Hex	Binary
    0	04	00000100
    1	84	10000100
    2	18	00011000
    3	50	01010000
    4	6F	01101111
    5	80	10000000
    6	CE	11001110
    7	08	00001000
    8	00	00000000
    9	85	10000101
    10	E8	11101000
    11	00	00000000
    12	10	00010000
    13	00	00000000
    14	50	01010000
    15	00	00000000
    16	00	00000000
    17	00	00000000
    18	00	00000000
    19	00	00000000
    I've highlighted Byte 14, Bit 5 which according to my database is the software switch for intelligent park assist - I note that on the hex44 module, Byte 0, Bit 1 is set -suggesting that the car has parallel parking capabilities, Can you confirm that the car has this facility?
    In respect of the only other "respectable" fault frequency DTC - Switch for Instrument Cluster B1893 13 [009] - Open Circuit, this very much looks like this is a wiring matter. Given the non-specific nature of the fault descriptor, its difficult to be precise as to which switch this is - perhaps some one else here can advise?
  11. Likes Uwe liked this post
  12. #18
    Apr 2020
    Washington, USA
    I can confirm my car does have self-park capabilities. The open circuit is also me, I do not have the 0.0 trip reset button installed. It was on back order so for now it is not wired in. The garbage trip button that came with my Aliexpress kit broke before I could even install it so I decided to buy the OEM, it just took a month coming from Germany.
    This autoscan looks better. Any thoughts?
    Wednesday,01,July,2020,17:07:30:03229
    VIN: WAUJEGFF4LA039731   Mileage: 3295km-2047miles
       Revision: --H13---
              U0155 00 [039] - -
                        Mileage: 3295 km
                        Date: 2020.07.01
                        Time: 16:58:25
                        Coolant temperature: 92 °C
                        Intake air temperature: 50 °C
                        Voltage terminal 30: 12.265 V
                        Engine: operating status: ES
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 104.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 14 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        T_AST_SAE: 0 s
              U1054 00 [039] - No Communication
                        Mileage: 3295 km
                        Date: 2020.07.01
                        Time: 16:58:25
                        ECU_STATE: ENG_STOP
                        T_ES: 14 min
                        T_AST_SAE: 0 s
    Readiness: 1110 1101
       Revision: 00H06V09
       Coding: 030C0C1720
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 101F00
       Coding: 0270167851
       Coding: 333135
       Coding: 333135
       Occupant Detection:
       Coding: 303430
              U1014 00 [009] - -
                        Reset counter: 136
                        Mileage: 3295 km
                        Date: 2020.07.01
                        Time: 17:00:44
                        Reset counter: 136
                        Mileage: 3295 km
                        Date: 2020.07.01
                        Time: 17:00:44
       Coding: 0001
       Revision: --------
       Coding: 04C002
       Coding: 931F0000
              B201A 00 [009] - -
                        Reset counter: 136
                        Mileage: 3295 km
                        Date: 2020.07.01
                        Time: 17:02:45
                        Voltage terminal 30: 12.2 V
       Revision: --------
       Coding: 04C002
    End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V)-----------
  13. #19
    ^^^ more information please: As I understand, this car has 2 x retrofitted modules; hex17 and hex5F.
    If I'm reading the last auto-scan above correctly, it was generated with an NAR hex5F module (note: Component: MU-HS-S-US ). The fact that the scan doesn't have CP errors kind-of confirms this speculation. So, if the scan was made with the original factory fitted MIB (which worked perfectly well with the factory fitted hex01 module - I assume), why is the ECU complaining about comms loss with the MIB? Incidentally, this MIB also doesn't have SATNAV (Byte 3 = hex0). Have you checked the integrity of the hex 5F quad-connector/wires after replacing the eBay module with the original MIB?
  14. Likes iichel liked this post
  15. #20
    Apr 2020
    Washington, USA
    Sorry I should've clarified, that is my OEM MIB. I didn't want to add the eBay one and confuse anyone until I could solve the check engine light. So it should not have navigation fitted nor component protection. I will post an autoscan of the eBay MIB later on. So for now the only retrofitted module is the hex17.
