Hello all
i have skoda car with strange sound when pressing accelerator pedal, we changed injector #1 but still same problem
here is a link for youtube video for the car https://www.youtube.com/watch?v=ypuFjfZhZIM
and here an autoscan
Monday,15,June,2020,19:28:42:04619
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBCT61Z4B2159759 License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCT61Z4B2159759 Mileage: 177480km-110280miles
15-Airbags -- Status: Not registered 0011
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LP HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 8810
Revision: --H43--- Serial number:
Coding: 00114016032400080000
Shop #: WSC 73430 031 00066
ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
ROD: EV_ECM16TDI02103L997557A.rod
VCID: 7F5B05C7977C5C432A8-802A
6116 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 177329 km
Date: 2020.06.15
Time: 09:08:16
Engine speed: 780.50 /min
Normed load value: 27.5 %
Coolant temperature: 78 °C
Intake air temperature: 47 °C
Voltage terminal 30: 14.118 V
Accelerator position: normalized-Accelerator position: 0.00 %
Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 00000010
Readiness: 1010 1000
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B201C09270003881204E990220041300000
Shop #: WSC 73430 790 00066
VCID: 75B7E7EFA5C01613704-8020
Fault Status: 01100101
Reset counter: 108
Mileage: 177486 km
Date: 2014.11.06
Time: 09:06:28
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 49920
Count: 65280
Count: 62720
Part No SW: 3T0 907 044 BD HW: 3T0 907 044 BD
Component: Climatronic H16 0402
Revision: 00006001
Coding: 0000000002
VCID: 75B7E7EFA5401613704-8020
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AE
Coding: 40000AB8A03708C040100080110081E4436151AE52008160DC8440000040
VCID: 38292EDBF252AB7BAB2-806C
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 21041 26 0601
Coding: 00D7B7
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 108
Mileage: 177486 km
Date: 2014.11.06
Time: 09:08:18
Voltage: 14.15 V
Term 50 Off
Reset counter: 108
Mileage: 177486 km
Date: 2014.11.06
Time: 09:08:18
Voltage: 14.15 V
Term 50 Off
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC2549J1
Coding: 0020790
VCID: 3D273FCFD1708E53784-8068
Subsystem 1 - Serial number: 6332MSME5F103220%
Subsystem 2 - Serial number: 6342MSME5F04504EJ
Subsystem 3 - Serial number: 6351HSME2701413E%
Subsystem 4 - Serial number: 6361HSME2701504B+
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01217 - Side Airbag Igniter; Driver Side (N199)
Part No SW: 1K5 953 521 AG HW: 5K0 953 569
Revision: FF010040 Serial number: 20110426201382
Coding: 4080140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 72BDDCF3D42E012B556-8026
147462 - Terminal 15
B1148 12 [009] - Short to Plus
Reset counter: 108
Mileage: 177486 km
Date: 2020.06.15
Time: 09:08:14
226057 - Ignition Starter Switch; Terminal S
B1147 F1 [009] - Open or Short to GND
Reset counter: 108
Mileage: 177486 km
Date: 2020.06.15
Time: 09:08:14
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Reset counter: 108
Mileage: 177486 km
Date: 2020.06.15
Time: 09:08:14
Part No SW: 1Z0 920 803 M HW: 1Z0 920 803 M
Component: KOMBI H05 0405
Coding: 110800
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 3E2538C3D0F6954B61E-806A
9453841 - Oil Level Thermal Sensor
B1041 33 [009] - Signal low time > maximum
Reset counter: 108
Mileage: 177486 km
Date: 2020.06.15
Time: 09:08:14
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 250411F1002226
Coding: 351302
Shop #: WSC 73430 444 00550
VCID: 303916FB1A22733BE32-8064
Reset counter: 108
Mileage: 177486 km
Date: 2014.11.06
Time: 09:08:15
Mileage: 177486 km
Date: 2014.11.06
Time: 09:08:15
Component: IMMO H05 0405
VCID: 6A8DC493FCFEC9EBED6-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2119
Coding: 0004340
VCID: 48C95E1B8EB2DBFBDB2-801C
00913 - Window Regulator Switch; Front Right Driver (E81)
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H17000
Shop #: WSC 73430 790 00000
VCID: 2F3B15870B1C6CC3FA8-807A
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0004340
VCID: 47CB5D2783ACD483D28-8012
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2L9051551
Coding: 050004000001
VCID: 313F13FF11287A33ECC-8064
03138 - Input AUX IN
Reset counter: 108
Mileage: 177486 km
Date: 2014.11.06
Time: 09:08:18
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012546
VCID: 323D1CF3182E412B956-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 333319F7E73448239E0-8066
End----------(Elapsed Time: 00:53, VBatt start/end: 14.1V/14.1V)-----------
