2010 Passat CC Dynaudio retrofit
Bwant
C?ID=130834
Hi all,
I am considering installing Dynaudio in my 2010 Passat CC but have a few questions.
Firstly, I have made a few changes to the car over the years as can be seen in the scan. The Canbus for example is from a B7 to enable various other retrofits. The RNS510 is the latest SSD with Dab etc. So, do I need a B6 amp (3C8) or B7 (3AA) due to these upgrades? Or will either be compatible?
Secondly, the B7 front tweeters are much nicer looking but are they the same fitment as the B6 so, a direct replacement?
Thirdly, there is a retrofit wiring loom available on AliExpress which would make the job much easier. Has anyone used one of these?
If anyone has any info at all regarding this upgrade I’d love to hear it. I have been told that an aftermarket set up would be better for sound but I am a big fan of OEM so I’m only interested doing the factory offered sound system.
Many thanks,
Bwant.
 Thursday,15,September,2016,16:42:10:44665
VCDS Version: 16.8.1.1
Data version: 20160902 DS256
Workshop Code: 000 00000 012345
VIN: WVWZZZ3CZAEXXXXXX   License Plate:
Mileage: 81310km-50523mi   Repair Order:
Gateway Installation List:  7N0 907 530 AN
5D-Operations -- Status: OK 0000
Thursday,15,September,2016,17:13:50:44665
VIN: WVWZZZ3CZAE561328   License Plate: PA55TCC
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 13 14 15 16 17 19 25 2E 37 3C 42 44 46 52 53
          56 57 5D 62 65 6C 72 77 A5
VIN: WVWZZZ3CZAE561328   Mileage: 81310km-50523miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QC    HW: 03L 907 309
   Component: R4 2,0L EDC A000SG  6208
   Revision: 13H03---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 83712 152 534184
   VCID: 76E9D8B5016944F282-8022
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 698 109 E    HW: 3C0 614 109 P
   Component: J104    C4 440 V3   0017
   Revision: --025---    Serial number: 00000785920829
   Coding: 0011539
   Shop #: WSC 00046 000 00000
   VCID: 2C5D3ADD8FA54E2224-8078
   Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 001C000002
   Shop #: WSC 00028 028 00020
   VCID: 79F3D389F8772B8AEF-802C
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 76
                    Mileage: 81317 km
                    Date: 2016.09.15
                    Time: 16:41:43
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 AC    HW: 3C8 937 049 AC
   Component: Bordnetz-SG     H64 3205
   Revision: 00H64000    Serial number: 00000006247589
   Coding: E5808D8B00041A0047970F8817000000800DFF475C40017C174000000000
   Shop #: WSC 78638 146 12345
   VCID: 72E1E4A56D0158D2AE-8026
   Subsystem 1 - Part No: 3C8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 250310 022  0613
   Coding: 00049045
   Shop #: WSC 78638
   Subsystem 2 - Part No: 5K7 955 559 B
   Component: RLS     260215 037  0059
   Coding: 00471277
   Shop #: WSC 78638
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0116
   Revision: --------    Serial number: 13901216701390
   Coding: 301007
   VCID: 4895664DFB1D820220-801C
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3AA 907 567
   Component: AC201  RDW M    036 0243
   Revision: 00036000    Serial number: 00000000598658
   Coding: 0010100
   Shop #: WSC 05311 000 12345
   VCID: 356B1FB95CEF0FEA4B-8060
Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 07041005160001
   Coding: 030180
   Shop #: WSC 05314 123 12345
   VCID: 2757C5F156436D7AC9-8072
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__305 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P7DX4L-
   Coding: 0012341
   Shop #: WSC 05311 000 00000
   VCID: 448D727D0735A662CC-8010
   Subsystem 1 - Serial number: 6332MTS639990770
   Subsystem 2 - Serial number: 6342MTS609830790
   Subsystem 3 - Serial number: 6351HTS6JTDU69KR
   Subsystem 4 - Serial number: 6361HTS6H2IV96KR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100415100235
   Coding: 218AA70002
   Shop #: WSC 05311 115 12345
   VCID: 72E1E4A5A50158D2AE-8026
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 981 D    HW: 3C8 920 981 D
   Component: KOMBI         H04 0611
   Coding: 140F01
   Shop #: WSC 05314 115 12345
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 2F672DD176B3353A01-807A
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1642
   Revision:   H51       Serial number: 15061300F11108
   Coding: 464007
   Shop #: WSC 00079 790 45725
   VCID: 7CFDCA9DFF451EA2F4-8028
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0400
   Shop #: WSC 00659 210 104202
   VCID: 7AF1CC8535712092E6-802E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Revision: A1001003    Serial number: 7660932684
   VCID: 2953C3C940575B0ADF-807C
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
   Component: RNS-MID       H09 5238
   Revision: AB001001    Serial number: VWZ6Z7N6026019
   Coding: 04000402040000A0200F
   Shop #: WSC 00066 123 12345
   VCID: 346D22BD979516E27C-8060
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V10  8048
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0030
   Revision: 00H03000    Serial number: 6PZ 010 316-09
   Coding: 0001174
   Shop #: WSC 00000 000 12345
   VCID: 3A710C8575F1E092A6-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J0770_SWA_Slave_H03 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F12.04.1400H03000AMS14975ÿ
   Subsystem 4 - Serial number: S14975ÿ
   Part No SW: 1T0 959 701 AG    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0308
   Revision: 12101005    Serial number: 0000746448
   Coding: 0012FF
   Shop #: WSC 00124 012 00001
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 7CFDCA9DF7451EA2F4-8028
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001407098
   Coding: 0000D8
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 207    3001
   Revision: 00H17000
   VCID: 31632BA9A88723CA17-8064
   Component:    KSG PQ47 ELV 043 0612
   Coding: 01910A0001864E763602141F70089FCE105F01
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0308
   Revision: 14101005    Serial number: 0000738894
   Coding: 0012FE
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001409269
   Coding: 0000D8
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000248663
   Coding: 0000057
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 57: TV Tuner        Labels: 7L6-919-148.clb
   Part No SW: 7L6 919 148 A    HW: 7L6 919 148
   Component: R0078 TVhybridDVB   0150
   Revision: R0H21000    Serial number: 93900500528102
   Coding: 0000803
   Shop #: WSC 00028 028 00001
Address 5D: Operations        Labels: 3C0-035-151.lbl
   Part No SW: 3C0 035 151 D    HW: 3C0 035 151 D
   Component: J738            012 0020
   Revision: 00012000
   VCID: 1933F309D037CB8A4F-804C
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000229015
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_VW36.rod
   VCID: 356B1FB994EF0FEA4B-8060
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H09000    Serial number: 525PA8-J182362
   Coding: 0020008
   VCID: 67D785F156C3AD7A09-8032
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0946
   Revision: --------    Serial number: 35502105027384
   Coding: 020000010100000000000101
   ASAM Dataset: EV_UHVPremi 002708
   ROD: EV_UHVPremi_VW32.rod
   VCID: 244DD2FD2F758662EC-8070
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0195243832
   Coding: 01010101010202110201000000010100
   Shop #: WSC 18207 123 104857
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 39731389B8F7EB8AAF-806C
End-------------------------(Elapsed Time: 03:44)--------------------------
dieseltje
Groningen, The Netherlands
C?ID=148044
Both Amps will do. 3C0 J type is the most powerfull.
Good alternative is a Helix subwoofer compatible for RNS510. You can lett the old speakers in the door and they will be powered via the Subs amp. Nice system
siLc
Tallinn, Estonia
C?ID=330192
I don't think the B7 front tweeter will fit because of the different shape of the window triangle.
Dynaudio midbass speakers can be expensive and are known to fail, so try to get items as new as possible.
Bwant
C?ID=130834
Thanks for the info.
The Helix sub sounds interesting. I’ll have a search around for that set up. Do you have any more info regarding this dieseltje? Part numbers etc?
Having looked at the front tweeters a little more, it seems there are also updated front tweeters for the later CC with the Dynaudio logo rather than the plain black that comes with the earlier model. Unfortunately, I can’t find these for sale but will keep looking.
Any other info would be a great help.
dieseltje
C?ID=148044
https://parts.vwofmurrieta.com/p/Vo...jHoyg9nCBTk23Keq7y76ailaQGB8ThRTgXvz9-TfxMwVA
If you use google HELIX audio VW you get many hits. Its a prity straigt forward installation.
Unhook the quadlock connector and pull out the speaker connector. Insert the version from the amp and connect the cars connector into the male part from amp.
Then power supply and system is opperational. U can also rent a tool to adjust sound setting.
If you allready have Dynaudio or a VW Soundsystem AMP, then this is not compatible.
Bwant
C?ID=130834
Just had a look at the RNS510 coding options in my car. In byte 1 there are a few options. Mine is currently set to “00 Control Module NOT Installed” as expected. There are a few others but two options for Dynaudio caught my eye.
05 Dynaudio Sound System (CAN DSP)
07 Dynaudio Sound System (BAP DSP)
Anyone have an explanation for these?
Thanks.
dieseltje
C?ID=148044
Can dsp is the normal dynaudio amp
BAP DSP is the 12channel panasonic amp that needs also the correct dataset for the 10channel system in the passat.
If you buy the same part number with other dataset, you will have no sound or only via 1 or 2 speakers.
3C0 /3C8 / 3AA 035 456 x are CAN DSP
3AA 035 466 are BAP DSP
Bwant
C?ID=130834
Thank you dieseltje. That answered the question perfectly.
As I have a CC I’m looking for a 3C8 amplifier which will be coded CAN DSP.
Bwant
C?ID=130834
Managed to get a full system for the Passat CC from an online retailer including door speaker grilles and a full wiring loom.
The installation was successful, everything worked first time after coding! The only thing was the front tweeter covers were the early ones without the ‘Dynaudio’ logo so I bought these separately.
Strangely, a couple of threads I read about replacing speakers mentioned about them being riveted on. Mine were screwed which made the job much easier.
Thanks to all that offered assistance.
luisfa
Brazil
C?ID=206461
Hi there!
Did you get a new harness? Or had already on your car? How did you deal with harness?
I have a VW Passat CC as well, I got the kit plus harness, but the guy cut a lot of cables.
Bwant
C?ID=130834
Hi Luisa,
The harness I used was complete apart from the speaker input plug which was cut off unfortunately. I cut my original one off and soldered the wires directly to the harness.
The 4 door connector plugs were complete. I removed the relevant pins and installed them into my door plugs. Same with the door harnesses.
There is an earth connection in the footwell. The main power was connected to fuse 19 in the engine bay fuse box(30 amp).
Canbus connections were made behind the radio.
Hope this is helpful.
