Hallo guys, I would like to ask if someone can help me out.
Im building 2010 Audi tts into a full race car, im keeping the original computers, I did removed a lot of th computers out( radio, navigation etc) coded is out of gateway and other computers looking for them, vehicle has no lights, no wiring in doors, roof, decklid etc
I did have to keep the airbag module in car for the traction control system to work and to be able to use launch control. module has only power, ground and can bus hooked to it.
The issue im having is regarding the paddle shifters under the steering wheel.
Steering module is seeing when im pressing it but if you go to dsg I do not see it being activated( of course it doesn't work when driving in any mode)
It was working before I started pulling wires out of the car.
I removed out of the car the connectors and wires from fuse box to it etc,
I did check continuity in comfort can bus, all is good same for powertrain can bus, information can bus is completely removed and coded out (since all the modules are removed out of car)
I keep only computers needed to run car.
to try to repair it:
I grab steering wheel from friends car (its working on his) and plug it in but same steering wheel module see it transmission module not
tried to put original coding in all computers and original software in engine and transmission and still didn't work
I replaced steering wheel control module and same result
Here is the scan
Here is the scan
Sunday,14,June,2020,14:09:00:52297
VCDS Version: 20.4.1.0 (x64)
Chassis Type: FK (1K0)
Scan: 01 02 03 09 15 16 17 19 22 25 44 46
VIN: TRUK1AFK8A1020521 Mileage: 75050km-46633miles
Address 01: Engine (CDM) Labels:. 06F-907-115-CDL.clb
Part No SW: 8J0 907 115 AF HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH19--- Serial number: AUX7Z0J2FNS030
Coding: 0113010A1C0B0160
Shop #: WSC 66565 257 00032
VCID: 70E437FE636F5A06FB-8024
Readiness: 0110 0000
Part No SW: 02E 300 012 N HW: 02E 927 770 AM
Component: GSG DSG AG6 531 2117
Revision: 53104 Serial number: 00001411040135
Coding: 0001020
Shop #: WSC 01286 386 08256
VCID: 1B3E3052DA69895EFE-804E
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 D HW: 8J0 614 517 D
Component: ESP MK60E1 0030
Revision: 00H60001
Coding: 0593718
Shop #: WSC 01236 785 00200
VCID: 2E58E986B9DB0CF6A9-807A
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 E HW: 8P0 907 063 E
Component: BCM PQ35 H 105 0575
Revision: 00105 AK
Coding: 00000000000002042024C0200000000D100077AA000050395C0000400000
Shop #: WSC 01236 758 00200
VCID: 3668C1E6818B3436E1-8062
Subsystem 1 - Part No SW: 8J1 955 119 A HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0070
Coding: 00FD10
21 Faults Found:
01134 - Alarm Horn (H12)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:28
Term 15 On
Voltage: 11.75 V
Term 50 Off
01800 - Light Switch (E1)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:28
Term 15 On
Voltage: 11.75 V
Term 50 Off
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:28
Term 15 On
Voltage: 11.75 V
Term 50 Off
03266 - Control Circuit for Signal Horn
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:28
Term 15 On
Voltage: 11.80 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 10
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:29
Term 15 On
Voltage: 11.75 V
Term 50 Off
Fault Frequency: 10
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:29
Term 15 On
Voltage: 11.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:29
Term 15 On
Voltage: 11.75 V
Term 50 Off
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Frequency: 12
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:29
Term 15 On
Voltage: 11.75 V
Term 50 Off
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Frequency: 12
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:02:29
Term 15 On
Voltage: 11.75 V
Term 50 Off
Fault Frequency: 6
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:12:32
Term 15 On
Voltage: 11.75 V
Term 50 Off
00834 - Signal for Activation of Heated Rear Window
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:12:34
Term 15 On
Voltage: 11.75 V
Term 50 Off
00924 - Relay for Headlamp Cleaning System (J39)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:12:34
Term 15 On
Voltage: 11.75 V
Term 50 Off
01259 - Fuel Pump Relay (J17)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:12:34
Term 15 On
Voltage: 11.75 V
Term 50 Off
01403 - Glass-Break Sensors; Rear
Fault Status: 01101011
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:12:52
Term 15 On
Voltage: 11.70 V
Term 50 Off
Fault Frequency: 8
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:13:51
Term 15 On
Voltage: 11.70 V
Term 50 Off
Fault Frequency: 8
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:13:51
Term 15 On
Voltage: 11.70 V
Term 50 Off
03134 - Motor for Rear Spoiler Movememt (V54)
Fault Status: 01101100
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:14:27
Term 15 Off
Voltage: 11.80 V
Term 50 Off
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:14:28
Term 15 Off
Voltage: 11.85 V
Term 50 Off
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101010
Reset counter: 240
Mileage: 75056 km
Date: 2020.05.06
Time: 00:41:28
Term 15 On
Voltage: 13.75 V
Term 50 Off
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 22:17:45
Term 15 On
Voltage: 13.95 V
Term 50 Off
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 22:17:46
Term 15 On
Voltage: 13.95 V
Term 50 Off
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -E Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K004BC5I
Coding: 0011589
VCID: 79F20ADA30151B4E4C-802C
Subsystem 1 - Part No: 000 000 000 00
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 04CUG
Subsystem 3 - Serial number: 0001.01.000000000000000000ÿ
Subsystem 4 - Serial number: 000000ÿ
20 Faults Found:
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Fault Status: 11101010
Mileage: 75017 km
Date: 2020.01.09
Time: 21:23:58
Fault Status: 11100001
Mileage: 75017 km
Date: 2020.01.09
Time: 21:24:00
00592 - Seat Belt Switch; Passenger (E25)
Reset counter: 194
Mileage: 75017 km
Date: 2020.01.09
Time: 21:24:00
02511 - Control Module for Seat Occupied Recognition (J706)
Fault Status: 11100100
Fault Frequency: 34
Mileage: 75017 km
Date: 2020.01.09
Time: 21:24:06
Mileage: 75017 km
Date: 2020.01.13
Time: 19:49:08
00590 - Igniter 2 for Passenger Airbag (N132)
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:12
01742 - Igniter for Knee Airbag; Drivers Side (N295)
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:12
01743 - Igniter for Knee Airbag; Pass. Side (N296)
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:12
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 194
00591 - Seat Belt Switch; Driver (E24)
Reset counter: 194
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
Reset counter: 194
01590 - Igniter for Battery Disconnect (N253)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:00:33
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:12
03084 - Ignitor for Front Passenger's Belt Force Limiter (G552)
Reset counter: 200
Mileage: 75056 km
Date: 2020.05.06
Time: 00:00:29
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Reset counter: 194
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Reset counter: 194
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
Reset counter: 194
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Fault Status: 11101001
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:10
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:11
Mileage: 75018 km
Date: 2020.01.15
Time: 00:00:12
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0011141
VCID: 4688B126316BA4B671-8012
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 990 J HW: 8J0 920 990 J
Component: KOMBIINSTR. VDO H03 0490
Revision: D0H03005 Serial number: 2242J005000348
Coding: 0003203
Shop #: WSC 32144 003 104857
VCID: 3972CADA7095DB4E0C-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4540K103208117
Coding: ED820702000002004100
VCID: 69D25A9A40B5ABCEBC-803C
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion T303
Coding: 0000005
Shop #: WSC 00001 000 00000
VCID: 458AB62A0C6DAFAE78-8010
Revision: D0H03005 Serial number: AUX7Z0J2FNS030
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 237 3001
Revision: 00H17000
VCID: 3776CCE24681CD3EFA-8062
End-------------------------(Elapsed Time: 01:22)--------------------------
