2010 Audi TTS race car, shift paddles wont work
matus008
C?ID=78225
Hallo guys, I would like to ask if someone can help me out.
Im building 2010 Audi tts into a full race car, im keeping the original computers, I did removed a lot of th computers out( radio, navigation etc) coded is out of gateway and other computers looking for them, vehicle has no lights, no wiring in doors, roof, decklid etc
I did have to keep the airbag module in car for the traction control system to work and to be able to use launch control. module has only power, ground and can bus hooked to it.
The issue im having is regarding the paddle shifters under the steering wheel.
Steering module is seeing when im pressing it but if you go to dsg I do not see it being activated( of course it doesn't work when driving in any mode)
It was working before I started pulling wires out of the car.
I removed out of the car the connectors and wires from fuse box to it etc,
I did check continuity in comfort can bus, all is good same for powertrain can bus, information can bus is completely removed and coded out (since all the modules are removed out of car)
I keep only computers needed to run car.
to try to repair it:
I grab steering wheel from friends car (its working on his) and plug it in but same steering wheel module see it transmission module not
tried to put original coding in all computers and original software in engine and transmission and still didn't work
I replaced steering wheel control module and same result
Here is the scan
Sunday,14,June,2020,14:09:00:52297
VCDS Version: 20.4.1.0 (x64)
Chassis Type: FK (1K0)
Scan: 01 02 03 09 15 16 17 19 22 25 44 46
VIN: TRUK1AFK8A1020521   Mileage: 75050km-46633miles
Address 01: Engine (CDM)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8J0 907 115 AF    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH19---    Serial number: AUX7Z0J2FNS030
   Coding: 0113010A1C0B0160
   Shop #: WSC 66565 257 00032
   VCID: 70E437FE636F5A06FB-8024
Readiness: 0110 0000
   Part No SW: 02E 300 012 N    HW: 02E 927 770 AM
   Component: GSG DSG AG6     531 2117
   Revision:    53104    Serial number: 00001411040135
   Coding: 0001020
   Shop #: WSC 01286 386 08256
   VCID: 1B3E3052DA69895EFE-804E
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 D    HW: 8J0 614 517 D
   Component: ESP MK60E1          0030
   Revision: 00H60001
   Coding: 0593718
   Shop #: WSC 01236 785 00200
   VCID: 2E58E986B9DB0CF6A9-807A
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 E    HW: 8P0 907 063 E
   Component: BCM PQ35  H   105 0575
   Revision: 00105 AK
   Coding: 00000000000002042024C0200000000D100077AA000050395C0000400000
   Shop #: WSC 01236 758 00200
   VCID: 3668C1E6818B3436E1-8062
   Subsystem 1 - Part No SW: 8J1 955 119 A    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H07 0070
   Coding: 00FD10
21 Faults Found:
01134 - Alarm Horn (H12)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:28
                    Voltage: 11.75 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:28
                    Voltage: 11.75 V
                        Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:28
                    Voltage: 11.75 V
                        Term 50 Off
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:28
                    Voltage: 11.80 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 10
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:29
                    Voltage: 11.75 V
                        Term 50 Off
                    Fault Frequency: 10
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:29
                    Voltage: 11.75 V
                        Term 50 Off
                    Fault Frequency: 12
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:29
                    Voltage: 11.75 V
                        Term 50 Off
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Frequency: 12
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:29
                    Voltage: 11.75 V
                        Term 50 Off
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Frequency: 12
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:02:29
                    Voltage: 11.75 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:12:32
                    Voltage: 11.75 V
                        Term 50 Off
00834 - Signal for Activation of Heated Rear Window
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:12:34
                    Voltage: 11.75 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:12:34
                    Voltage: 11.75 V
                        Term 50 Off
01259 - Fuel Pump Relay (J17)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:12:34
                    Voltage: 11.75 V
                        Term 50 Off
01403 - Glass-Break Sensors; Rear
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:12:52
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:13:51
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:13:51
                    Voltage: 11.70 V
                        Term 50 Off
03134 - Motor for Rear Spoiler Movememt (V54)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:14:27
                        Term 15 Off
                    Voltage: 11.80 V
                        Term 50 Off
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:14:28
                        Term 15 Off
                    Voltage: 11.85 V
                        Term 50 Off
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101010
                    Reset counter: 240
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:41:28
                    Voltage: 13.75 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 22:17:45
                    Voltage: 13.95 V
                        Term 50 Off
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 22:17:46
                    Voltage: 13.95 V
                        Term 50 Off
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -E Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K004BC5I
   Coding: 0011589
   VCID: 79F20ADA30151B4E4C-802C
   Subsystem 1 - Part No: 000 000 000 00
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 04CUG
   Subsystem 3 - Serial number: 0001.01.000000000000000000ÿ
   Subsystem 4 - Serial number: 000000ÿ
20 Faults Found:
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Fault Status: 11101010
                    Mileage: 75017 km
                    Date: 2020.01.09
                    Time: 21:23:58
                    Fault Status: 11100001
                    Mileage: 75017 km
                    Date: 2020.01.09
                    Time: 21:24:00
00592 - Seat Belt Switch; Passenger (E25)
                    Reset counter: 194
                    Mileage: 75017 km
                    Date: 2020.01.09
                    Time: 21:24:00
02511 - Control Module for Seat Occupied Recognition (J706)
                    Fault Status: 11100100
                    Fault Frequency: 34
                    Mileage: 75017 km
                    Date: 2020.01.09
                    Time: 21:24:06
01217 - Side Airbag Igniter; Driver Side (N199)
                    Mileage: 75017 km
                    Date: 2020.01.13
                    Time: 19:49:08
00590 - Igniter 2 for Passenger Airbag (N132)
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:12
01742 - Igniter for Knee Airbag; Drivers Side (N295)
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:12
01743 - Igniter for Knee Airbag; Pass. Side (N296)
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:12
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 194
00591 - Seat Belt Switch; Driver (E24)
                    Reset counter: 194
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Reset counter: 194
01590 - Igniter for Battery Disconnect (N253)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:00:33
01587 - Igniter 2 for Airbag; Drivers Side (N250)
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:12
03084 - Ignitor for Front Passenger's Belt Force Limiter (G552)
                    Reset counter: 200
                    Mileage: 75056 km
                    Date: 2020.05.06
                    Time: 00:00:29
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                    Reset counter: 194
01221 - Crash Sensor Side Airbag; Driver Side (G179)
                    Reset counter: 194
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                    Reset counter: 194
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:10
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:11
00589 - Airbag Igniter 1; Passenger Side (N131)
                    Mileage: 75018 km
                    Date: 2020.01.15
                    Time: 00:00:12
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0011141
   VCID: 4688B126316BA4B671-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 J    HW: 8J0 920 990 J
   Component: KOMBIINSTR. VDO H03 0490
   Revision: D0H03005    Serial number: 2242J005000348
   Coding: 0003203
   Shop #: WSC 32144 003 104857
   VCID: 3972CADA7095DB4E0C-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4540K103208117
   Coding: ED820702000002004100
   VCID: 69D25A9A40B5ABCEBC-803C
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      T303
   Coding: 0000005
   Shop #: WSC 00001 000 00000
   VCID: 458AB62A0C6DAFAE78-8010
   Revision: D0H03005    Serial number: AUX7Z0J2FNS030
   Part No: 8J0 909 144 J
   Component: EPS_ZFLS Kl. 237    3001
   Revision: 00H17000
   VCID: 3776CCE24681CD3EFA-8062
End-------------------------(Elapsed Time: 01:22)--------------------------
I see no obvious reason for it. :confused:
matus008
C?ID=78225
same here.It drives me crazy
there is in steering wheel module in measuring blocks 6-4 malfunction recognized and result is yes, but cant see for what it is
matus008
C?ID=78225
Any info guys, even a hint, you never know
matus008
C?ID=78225
I got it solved!!!!!!!
When the coding (removing of stuff) happened VCDS coded everything but for some reason steering wheel module didn't reset itself.
after long hours and tracing steps back, nothing help.:banghead:
By mistake I forget vcds cable, so I used Autel, did reset with autel and everything woke up and works!!!!!!
Dana
Western PA, USA
As per our phone conversation I dug into this based on my fuzzy recollection of a noted VW problem with J527 in this time frame. That was NAR VW TPI 2017528/5 which directed you to a test plan to correct a "Software error of steering column electronics". I ran that test plan and it used a SA of 86611 followed by modifications to speicherzelle (EEPROM/memory cell) 883.
This aligns with what we suspected and discussed on the phone. Additionally the only other search result for "86611" in our forum was here:
https://forums.ross-tech.com/showth...dule-changeout&p=160793&viewfull=1#post160793
Don't get me wrong - those exact details (SA code and EEPROM location) may not apply to this Audi but the fact that you needed to run a special "replacement" operation with your Autel leads me to believe it likely made a correction for buggy control module software.
In conclusion, I don't believe this is a VCDS bug. Rather, I suspect Audi had a similar problem on their Golf 5/6 based model 16 modules. If I can locate an Audi specific TPI or test plan I'll report back with those details. If I cannot locate any documentation I'll still add a note to the lbl file for
MVB 006,4,Malfunction,recognized
... explaining Yes may be due to buggy software and that a Replacement test plan may need to be completed using ODIS (or similar).
