Results 1 to 10 of 10
Thread: Audi a4 2013 - 01319 - Control Module for Distance Control (J428) plus more
    Jun 2020
    Cool Audi a4 2013 - 01319 - Control Module for Distance Control (J428) plus more
    hi everyone,
    got my vcds cable not long ago and a friend came over today with his audi a4 13 plate to do some tweaks, I won't post the first scan as I have managed to code a lot of those errors out, however I couldn't code a few (I know the 00862 - Antenna for GPS Navigation means he needs to look into his antenna connections and etc so ignore that) so could any of you more experienced people out there help with the rest?
    would like to mention that I spent a good amount of time on trying to figure out what could be wrong coded in the Instruments and what would request the Control Module for distance from Central Electronics but no luck.
    Also if you look at Address 56: Radio (R) Labels: Redir Fail! - I have send a map to Rosstech and waiting a reply from them regarding that
    thank you in advance
    Last scan of his car here:
    Sunday,14,June,2020,13:18:20:43136
    VIN: WAUZZZ8K6DA248709   License Plate:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 44 46 52 53 56 5F 62 72
    VIN: WAUZZZ8K6DA248709   Mileage: 122010km-75813miles
    Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9977
       Revision: 45H25---
       Coding: 12034012242401080000
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ECM20TDI01103L906018HT 003008
       ROD: EV_ECM20TDI01103L906018HT.rod
       VCID: 03538A2ACB9F90134E9-8056
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000000219
       Coding: 000002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       VCID: 3A2D37CEFCD511DB5DF-806E
       Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
       Component: ESP8 front    H09 0100
       Coding: 171544
       VCID: 00598526DA098B0B53B-8054
       Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
       Component: BCM2 2.0      H12 0633
       Coding: 01B24040000000000000
       VCID: 79AFE8C2B9D3DAC3145-802C
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0513000030951021
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2313000070039001
       Part No SW: 8K2 820 043 AH    HW: 8K2 820 043 AH
       Revision: D0000000    Serial number: 01260420131899
       Coding: 342402E000
       VCID: 6FBBD69AF7978473BA1-803A
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
       Revision: 07016001    Serial number: 00000599900301
       Coding: 2700C0398720AFE2948142800000010D43DD470827090241000008004400020100000024000000
       VCID: 77ABEEFA8FC7CCB3621-8022
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 260413  H06 0080
       Serial number: SWF13040260063
       Coding: 00FD11
       Serial number: 21243658
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002004134648
       Serial number: 9E08C4A6000000000001
                        Reset counter: 171
                        Mileage: 122011 km
                        Date: 2020.06.14
                        Time: 13:12:57
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 C    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0490
       Revision: 00000008
       VCID: 2D070C923D1BB663C8D-8078
       Serial number: 003KFD99WT56
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 33830 001 1048576
       VCID: 48C95D06B239734BDBB-801C
       Serial number: 6334MSME7B156671H
       Serial number: 6344MSME7B1624308
       Serial number: 6352QSME20300F5CE
       Serial number: 6362QSME2E3051429
       Serial number: 63732SME13302F54W
       Serial number: 63832SME0F300966$
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130502000221
       Coding: 000037
       VCID: 4FFB761A57D7A4739A1-801A
       Part No SW: 8K0 920 982 E    HW: 8K0 920 982 E
       Component: KOMBIINSTR.   H35 0556
       Revision: 00400000    Serial number: UVR34YK4E
       Coding: AFDD10000A20A700010403
       VCID: 363523FEC84DF5BBB97-8062
                        Reset counter: 171
                        Mileage: 122011 km
                        Date: 2020.06.14
                        Time: 13:12:57
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y13417009F
       Coding: 80CF07FF00
       VCID: 4ACD670EACB5815BCDF-801E
       Serial number: 9621140403
       Serial number: 13114000840011200181
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000058498377
       Coding: 011702004C01410001
       VCID: 50F975664AE9BB8B83B-8004
       Revision: 00001000    Serial number: 0026432783
       Coding: 100000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 343119F6DEB1E7AB873-8060
       Revision: 00002001    Serial number: 0305974411
       Coding: 013F162220B900808320023280000000
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000059278804
       Coding: 011702205C01410001
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 30000000045206
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 38292DC6C2D903CBABB-806C
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230DY0D2759562
       Coding: 010003020100000001
       VCID: 2809FD8612F9934B3BB-807C
       Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
       Component: H-BN-EU       H45 1036
       Revision: --------    Serial number: 206DS0D7526142
       Coding: 0F0101010106C1FD07008F3E1E200403000200000200000200
       VCID: 42DD4F2E9485591B05F-8016
       Subsystem 1 - Part No: 8R0 060 884 GS
       Component: EUR 2020  3001
       Component: DU7 High  H42 0104
       Serial number: A130DK0D2714432
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001488130
       Component: CD-Database  4949
    00862 - Antenna for GPS Navigation (R50/R52)
                        Reset counter: 171
                        Mileage: 122011 km
                        Date: 2020.06.14
                        Time: 13:14:49
                        Voltage: 11.30 V
       Revision:             Serial number: 0000059339418
       Coding: 011402204001210001
       VCID: 46D5533EB8AD653B297-8012
       Revision:             Serial number: 0000059339639
    End----(Elapsed Time: 01:41, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
    May 2017
    Leicestershire, UK
    With the info posted it is a little difficult to say what is wrong here. Can you post the first scan of the car before you did anything and list what tweaks you did? This may help answer some questions although I am no expert at tweaks/coding mods. If I can't help hopefully someone else may be able to give some info then
    I would say it is a bad idea to adjust coding to remove errors as this usually causes bigger problems than you started with. If errors are current the cause has to be fixed to allow them to clear using the "Clear Fault Codes" command.
  3. Likes PetrolDave, Dana liked this post
    Jun 2020
    Quote Originally Posted by Mr. M View Post
    I've actually asked for help to adjust coding to remove the errors specified above, as I'm aware they're triggered from incorrect coding. Thanks
    Test this:
    AFDD10000A20A700010401
  6. Likes Dana, vagcodinguk liked this post
    Jun 2020
    Test this:
    Thank you for that, will try it and let u know if it worked.
    Any clue about the Central elect - 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication?!? I know something needs to be unticked but haven't got a clue what
  8. Likes Dana liked this post
  9. #6
    United States
    I don't see anything obviously wrong with 09's coding in regards to Byte 35 but the original (to you) condition scan and CodingLog.CSV may shed light on the changes that were made that caused the initial conflicts.
    I can move this to the Car Repair Support Sub-forum.
  10. Likes Uwe liked this post
  11. #7
    United States
    Andrei sent the original (to him) condition scan via e-mail (in regards to the 56 lbl) and it wasn't a disaster. No doubt, it appears as if J519 (AW09), J285 (AW17) and J794 (AW5F) at the least were tinkered with previously but it wasn't wall-of-shame worthy DTC wise
    He's going to test the new 17 coding suggestion above.
    In the meanwhile I think I spotted the major discrepancy in 09.
    Older condition scan:
       Coding: 2700C0398720AFF2948142800000010D43DD470827090241000008004400020100000024000000
    03110 - Active Steering Control Module (J792)
    Current:
    The Active Steering config lives in Byte 7 and I have this commented out (unconfirmed) in that label:
    ;LC,07,1,Distance Regulation/Adaptive Cruise Control installed with Drive Select/Charisma active [PR-8T4] ??
    Some of this documentation is a carry-over from the newer MLB based cars using 4G and 4H BCMs at which point ACC was nearly standard equipment but there wasn't much info available on the early B8/8K models. Although I believe something is goofy with the Headlight config in Byte 0 I'm pretty sure this will resolve the ACC DTC:
    2700C0398720AFE0948142800000010D43DD470827090241000008004400020100 000024000000
    Feedback would be highly appreciated so I can unmask that Byte in the label if it applies to J428/ACC in this BCM1.
  12. Likes Uwe, vagcodinguk liked this post
  13. #8
    Jun 2020
    Test this:
    tried today and not worked, thank you
  14. #9
    Jun 2020
    Current:
    Hi Dana, Central Elec doesn't show any errors after trying your code, so it worked!
    Thank you
  15. Likes Uwe, PetrolDave, Dana liked this post
  16. #10
    United States
    Excellent! I'm not sure if the PR-Codes are correct but I'll slip that into the label file so the Bit isn't missing documentation entirely.
  17. Likes Uwe, vagcodinguk liked this post
