Battery Meter/Sweep Dials?
the_dread
Jamaica
C?ID=23163
How may I enable the subject tweaks on a 2020 Q5 (non-US)?
the_dread
Jamaica
C?ID=23163
I recall seeing a msg at some point after receiving my HEX-V2 indicating that I need to open the car bonnet to work on some aspects of the system. Could that be the problem?
MartinsX
Riga, Latvia
C?ID=268515
Indeed for some latest VAG cars bonnet has to be opened (bonnet switch triggered) to access diagnostic functions.
P.S. Interesting, what is a official dealer's procedure for monitoring/logging data from vehicle in motion...??? :D
NEtech
C?ID=56995
For Needle sweep, try coding [17-Instrument] Byte 1 Bit 0
24A58EC4A88000080123A8001000000000000000
It should not be necessary for any "read" operations such as monitoring or logging measuring values; it generally only blocks "write" operations.
the_dread
Jamaica
C?ID=23163
Thanks, Uwe.
Should I try again with the bonnet open?
the_dread
Jamaica
C?ID=23163
Thanks, NEtech.
the_dread
Jamaica
C?ID=23163
Update:
I was able to successfully "accept" coding changes with the bonnet open. I activated the gauge "sweep" & it works. It is still bit 0 but has a slightly different label.
Note: I subsequently reversed a coding change with the bonnet closed.
I think once the hood has been opened and you've done something that requires write access, write access will remain available for a period of time (or miles?) even with the hood closed again...?
the_dread
Jamaica
C?ID=23163
OK. Thanks.
rs5iswicked
C?ID=116247
But can we enable the battery level/meter???? Somewhere?
