Good morning all
Here I have an Audi Q5 Hybrid with ABS problem Bosch 8.0 coding
I attach the report if possible to help me
Merci
Thursday,11,June,2020,15:49:12:51995
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ8R9CA088076 License Plate:
Mileage: 148970km-92565mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 40 42 44 46 51 52 53 55 56
5F 62 69 6C 6D 72 8C
VIN: WAUZZZ8R9CA088076 Mileage: 148970km-92565miles
40-AC Compressor -- Status: OK 0000
Address 01: Engine (0-MA--CHJA) Labels: None
Part No SW: 8R0 907 115 N HW: 8R0 907 115 G
Component: 2.0l R4/4V TF X54 0006
Revision: NDX54---
Coding: 2A2A0013442600022000
Shop #: WSC 05912 002 1048576
ASAM Dataset: EV_ECM20TFS0118R0907115N 002012
ROD: EV_ECM20TFS0118R0907115N_002.rod
VCID: 3FCE62CCA6B6A77E32-806A
U1113 00 [047] - -
Fault Frequency: 22
Mileage: 148975 km
Date: 2020.06.01
Time: 16:39:01
Coolant temperature: 70 °C
Intake air temperature: 55 °C
Voltage terminal 30: 11.285 V
Median injection timing: 0.000 ms
U1113 00 [047] - -
Fault Frequency: 22
Mileage: 148975 km
Date: 2020.06.01
Time: 16:39:01
13056 - Control Circuit for Coolant Bypass Valve
P2681 00 [175] - Open Cricuit
Mileage: 148975 km
Date: 2020.06.01
Time: 16:39:04
Coolant temperature: 76 °C
Intake air temperature: 53 °C
Voltage terminal 30: 11.944 V
selected gear-Bits 0-7: 0
13059 - Control Circuit for Coolant Bypass Valve
P2682 00 [168] - Short to GND
Mileage: 148975 km
Date: 2020.06.01
Time: 16:39:02
Voltage terminal 30: 11.591 V
2967 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [237] - Implausible Signal
Mileage: 148975 km
Date: 2020.06.01
Time: 17:02:19
Engine speed: 3807.00 /min
Normed load value: 5.5 %
Coolant temperature: 96 °C
Intake air temperature: 40 °C
Voltage terminal 30: 13.900 V
Median injection timing: 0.424 ms
Readiness: 1110 0001
Part No SW: 8R0 927 158 AC HW: 0BW 927 156 M
Component: 0BW 20TFSIRdW H17 0002
Revision: --H17---
ASAM Dataset: EV_TCMAL551111 002020
ROD: EV_TCMAL551111.rod
VCID: 7EB0DFC8E13C6E7679-802A
Part No SW: 8R0 907 379 S HW: 8R0 907 379 S
Component: ESP8 quattro H09 0090
Coding: 13154C
Shop #: WSC 06334 000 00000
VCID: 50EC517003282806DB-8004
Fault Frequency: 7
Reset counter: 164
Mileage: 148975 km
Date: 2020.06.01
Time: 17:03:45
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x003B
Hex Value: 0x03AF
Hex Value: 0x0000
Part No SW: 8K0 907 064 FG HW: 8K0 907 064 FG
Component: BCM2 2.0 H10 0602
Coding: 01C54000000000000000
Shop #: WSC 06335 000 00000
VCID: 7AB8D3D8F514425645-802E
Subsystem 1 - Part No SW: 4G0 959 754 CE HW: 4G0 959 754 CE
Component: FBSAUDIC7 IDG H60 0072
Serial number: 0811000184733004
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8R1 820 043 D HW: 8R1 820 043 D
Component: KLIMA 3 ZONEN H03 0040
Revision: C3000000 Serial number: 01211020111402
Coding: 64D100C000
Shop #: WSC 53108 002 1048576
VCID: 302C31F063E84806BB-8064
Part No SW: 8K0 907 063 BE HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0400
Revision: 10030001 Serial number: 00000001261702
Coding: 260050914034AF000001000000001D0D0F1C470840010107000008
VCID: 73A6FEFCD27E331E06-8026
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 120130 H11 0050
Serial number: 90243014120127100141
Coding: 01DD13
Component: RLS H04 0003
Serial number: 20068410
Coding: 024D25
Component: E1 - LDS H03 0031
Serial number: 00000000000102124286
Subsystem 4 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0017235088
Coding: 0F0000
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Serial number: 0016902202
Coding: 0F0000
Component: AQ_Hum_Sensor H02 0002
Serial number: D3080F06000000000001
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12511204300095
Coding: 300105
VCID: 78BCC9D0CB18504633-802C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 H HW: 8R0 959 655 H
Component: AirbagVW-AU10 H44 0610
Serial number: 003K8D08119K
Coding: 30463331373230303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 49DA7C14E87219CE9C-801C
Serial number: 6334MSME6B414B6DT
Serial number: 6344MSME6B15766BR
Serial number: 6352QSME1F6D2240K
Serial number: 6362QSME246C4F7C/
Serial number: 63732SME536D1C523
Serial number: 63832SME6C0D2F48H
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372LB8000SP
Coding: 000037
VCID: 3D3218C4A4BAB56E20-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 L HW: 8R0 920 930 L
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTW281Z1D
Coding: 1327230002010008030000
Part No SW: 8R0 907 468 HW: 8R0 907 468
Component: GW-BEM 5CAN-M H09 0513
Revision: 2A090014 Serial number: 1442A11B048009
Coding: 00D00AFF00
VCID: 7CB4D5C0FF207C6657-8028
Subsystem 1 - Part No SW: 8R0 915 181 A HW: 8R0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900180702
Subsystem 2 - Part No SW: 8R0 915 181 B HW: 8R0 915 181 B
Component: J367-BDMLear2 H07 5040
Serial number: 00000000000020853094
Reset counter: 202
Mileage: 148975 km
Date: 2020.06.01
Time: 16:40:30
Bin. Bits: 10111
Voltage: 11.80 V
Count: 6
Text: 0000000000000000
Address 40: AC Compressor (J842) Labels: 8R0-260-797.clb
Part No SW: 8R0 260 797 C HW: 8R0 260 797 C
Component: ES34 H01 0001
ASAM Dataset: EV_AirCondiCompr_ES34 S03001
ROD: EV_AirCondiCompr_ES34_AU48.rod
VCID: 3C3415C0B7A0BC6617-8068
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000023868902
Coding: 011D02205000440004
VCID: 4DD24804141A05EEB0-8018
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0028182616
Coding: 000000000100
Shop #: WSC 49269 000 1048576
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B3616DCB2AEBB5E1E-806E
Revision: 00002001 Serial number: 0169741401
Coding: 0100062020B934948530053290000000
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 51: Electric Drive (J841) Labels: 06F-907-080.clb
Part No SW: 06F 907 080 J HW: 06F 907 080 J
Component: MLB HYBRID H16 0001
Revision: --------
ASAM Dataset: EV_DMCM030202106F907080J 001001
ROD: EV_DMCM030202106F907080F.rod
VCID: 2E102F8871DC5EF6A9-807A
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000023973799
VCID: 4CD44500EF000CE6A7-8018
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 10000000017159
ROD: EV_ParkiBrake_AU48.rod
VCID: 362007E8898C6636E1-8062
Part No: 8K0 907 357 E
Component: Dynamische LWR H01 0020
Revision: 00H01001 Serial number:
Coding: 0000006
VCID: 373E0AEC46869F3EFA-8062
Part No SW: 4G0 035 056 E HW: 4G0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 230BT0C7539325
Coding: 010003020100000001
VCID: 2306CEBC221EE39E36-8076
Part No SW: 8F1 035 666 A HW: 8F1 035 666
Component: H-BN-EU H43 0467
Revision: -------- Serial number: 140BW0C7504579
Coding: 17010006000581EF01018B1E00002403E40100020000000002
VCID: 2A182398453432D675-807E
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130B$0CS100394
Subsystem 3 - Part No SW: 8R0 919 609 HW: 8R0 919 609
Component: E0380 Bedient H01 0100
Serial number: 00000001053885
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000024084707
Coding: 010C02204000240004
VCID: 43C66E3CC25EC39E56-8016
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ÀÁ006789000000
Coding: 0100000100000000
VCID: 362007E8818C6636E1-8062
Part No SW: 8R0 907 441 D HW: 8T0 907 441 D
Component: J772__Rearview 0140
Revision: --H06--- Serial number: 525PA8-J21A0JX
Coding: 1020010
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B3616DCBAAEBB5E1E-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Component: TSG HR H01 0506
Revision: Serial number: 0000024084710
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 8R0 915 591 HW: 8R0 915 591
Component: BMS H08 0543
Coding: 0A0200
Shop #: WSC 12284 002 1048576
ASAM Dataset: EV_BECM0722011 004016
ROD: EV_BECM0722011_004_AU48.rod
VCID: 78BCC9D0C318504633-802C
End----(Elapsed Time: 02:17, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
