Results 1 to 10 of 19
Thread: Coding ABS Audi Q5 Hybride
    Jun 2020
    France
    Good morning all
    Here I have an Audi Q5 Hybrid with ABS problem Bosch 8.0 coding
    I attach the report if possible to help me
    Thursday,11,June,2020,15:49:12:51995
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ8R9CA088076   License Plate:
    Mileage: 148970km-92565mi   Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 40 42 44 46 51 52 53 55 56
              5F 62 69 6C 6D 72 8C
    VIN: WAUZZZ8R9CA088076   Mileage: 148970km-92565miles
    40-AC Compressor -- Status: OK 0000
    Address 01: Engine (0-MA--CHJA)       Labels: None
       Part No SW: 8R0 907 115 N    HW: 8R0 907 115 G
       Component: 2.0l R4/4V TF X54 0006
       Revision: NDX54---
       Coding: 2A2A0013442600022000
       Shop #: WSC 05912 002 1048576
       ASAM Dataset: EV_ECM20TFS0118R0907115N 002012
       ROD: EV_ECM20TFS0118R0907115N_002.rod
       VCID: 3FCE62CCA6B6A77E32-806A
              U1113 00 [047] - -
                        Fault Frequency: 22
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 16:39:01
                        Coolant temperature: 70 °C
                        Intake air temperature: 55 °C
                        Voltage terminal 30: 11.285 V
              U1113 00 [047] - -
                        Fault Frequency: 22
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 16:39:01
    13056 - Control Circuit for Coolant Bypass Valve
              P2681 00 [175] - Open Cricuit
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 16:39:04
                        Coolant temperature: 76 °C
                        Intake air temperature: 53 °C
                        Voltage terminal 30: 11.944 V
                        selected gear-Bits 0-7: 0
    13059 - Control Circuit for Coolant Bypass Valve
              P2682 00 [168] - Short to GND
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 16:39:02
                        Voltage terminal 30: 11.591 V
    2967 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [237] - Implausible Signal
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 17:02:19
                        Engine speed: 3807.00 /min
                        Normed load value: 5.5 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 40 °C
                        Voltage terminal 30: 13.900 V
                        Median injection timing: 0.424 ms
    Readiness: 1110 0001
       Part No SW: 8R0 927 158 AC    HW: 0BW 927 156 M
       Component: 0BW 20TFSIRdW H17 0002
       Revision: --H17---
       Coding: 000001
       ASAM Dataset: EV_TCMAL551111 002020
       ROD: EV_TCMAL551111.rod
       VCID: 7EB0DFC8E13C6E7679-802A
       Part No SW: 8R0 907 379 S    HW: 8R0 907 379 S
       Component: ESP8 quattro  H09 0090
       Coding: 13154C
       Shop #: WSC 06334 000 00000
       VCID: 50EC517003282806DB-8004
                        Fault Frequency: 7
                        Reset counter: 164
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 17:03:45
                        Hex Value: 0x0000
                        Hex Value: 0x47A2
                        Hex Value: 0x003B
                        Hex Value: 0x03AF
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 FG    HW: 8K0 907 064 FG
       Component: BCM2 2.0      H10 0602
       Coding: 01C54000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 7AB8D3D8F514425645-802E
       Subsystem 1 - Part No SW: 4G0 959 754 CE    HW: 4G0 959 754 CE
       Component: FBSAUDIC7 IDG  H60 0072
       Serial number: 0811000184733004
       Part No SW: 8R1 820 043 D    HW: 8R1 820 043 D
       Component: KLIMA 3 ZONEN H03 0040
       Revision: C3000000    Serial number: 01211020111402
       Coding: 64D100C000
       Shop #: WSC 53108 002 1048576
       VCID: 302C31F063E84806BB-8064
       Part No SW: 8K0 907 063 BE    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0400
       Revision: 10030001    Serial number: 00000001261702
       Coding: 260050914034AF000001000000001D0D0F1C470840010107000008
       VCID: 73A6FEFCD27E331E06-8026
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 120130  H11 0050
       Serial number: 90243014120127100141
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 20068410
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000102124286
       Subsystem 4 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
       Component: SLR-B8  H05 0006
       Serial number:           0017235088
       Coding: 0F0000
       Subsystem 5 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
       Serial number:           0016902202
       Coding: 0F0000
       Serial number: D3080F06000000000001
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0081
       Revision: 11001001    Serial number: 12511204300095
       Coding: 300105
       VCID: 78BCC9D0CB18504633-802C
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 H    HW: 8R0 959 655 H
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003K8D08119K
       Coding: 30463331373230303030554A304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 49DA7C14E87219CE9C-801C
       Serial number: 6334MSME6B414B6DT
       Serial number: 6344MSME6B15766BR
       Serial number: 6352QSME1F6D2240K
       Serial number: 6362QSME246C4F7C/
       Serial number: 63732SME536D1C523
       Serial number: 63832SME6C0D2F48H
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372LB8000SP
       Coding: 000037
       VCID: 3D3218C4A4BAB56E20-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 930 L    HW: 8R0 920 930 L
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTW281Z1D
       Coding: 1327230002010008030000
       Part No SW: 8R0 907 468     HW: 8R0 907 468
       Component: GW-BEM 5CAN-M H09 0513
       Revision: 2A090014    Serial number: 1442A11B048009
       Coding: 00D00AFF00
       VCID: 7CB4D5C0FF207C6657-8028
       Subsystem 1 - Part No SW: 8R0 915 181 A    HW: 8R0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900180702
       Subsystem 2 - Part No SW: 8R0 915 181 B    HW: 8R0 915 181 B
       Component: J367-BDMLear2  H07 5040
       Serial number: 00000000000020853094
                        Reset counter: 202
                        Mileage: 148975 km
                        Date: 2020.06.01
                        Time: 16:40:30
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Text: 0000000000000000
    Address 40: AC Compressor (J842)       Labels: 8R0-260-797.clb
       Part No SW: 8R0 260 797 C    HW: 8R0 260 797 C
       Component: ES34          H01 0001
       ASAM Dataset: EV_AirCondiCompr_ES34 S03001
       ROD: EV_AirCondiCompr_ES34_AU48.rod
       VCID: 3C3415C0B7A0BC6617-8068
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000023868902
       Coding: 011D02205000440004
       VCID: 4DD24804141A05EEB0-8018
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0028182616
       Coding: 000000000100
       Shop #: WSC 49269 000 1048576
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B3616DCB2AEBB5E1E-806E
       Revision: 00002001    Serial number: 0169741401
       Coding: 0100062020B934948530053290000000
       Component: J245EE20SKB13  H03 0220
       Component: J394EE20SKB13  H03 0220
    Address 51: Electric Drive (J841)       Labels: 06F-907-080.clb
       Part No SW: 06F 907 080 J    HW: 06F 907 080 J
       Component: MLB HYBRID    H16 0001
       Revision: --------
       ASAM Dataset: EV_DMCM030202106F907080J 001001
       ROD: EV_DMCM030202106F907080F.rod
       VCID: 2E102F8871DC5EF6A9-807A
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000023973799
       VCID: 4CD44500EF000CE6A7-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 10000000017159
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 362007E8898C6636E1-8062
       Part No: 8K0 907 357 E
       Component: Dynamische LWR  H01 0020
       Revision: 00H01001    Serial number:
       Coding: 0000006
       VCID: 373E0AEC46869F3EFA-8062
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230BT0C7539325
       Coding: 010003020100000001
       VCID: 2306CEBC221EE39E36-8076
       Part No SW: 8F1 035 666 A    HW: 8F1 035 666
       Component: H-BN-EU       H43 0467
       Revision: --------    Serial number: 140BW0C7504579
       Coding: 17010006000581EF01018B1E00002403E40100020000000002
       VCID: 2A182398453432D675-807E
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Component: DU7 High  H41 0104
       Serial number: A130B$0CS100394
       Subsystem 3 - Part No SW: 8R0 919 609     HW: 8R0 919 609
       Component: E0380 Bedient  H01 0100
       Serial number: 00000001053885
       Component: CD-Database  3638
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000024084707
       Coding: 010C02204000240004
       VCID: 43C66E3CC25EC39E56-8016
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: Towbar module H09 0100
       Revision: 3A001001    Serial number: ÀÁ006789000000
       Coding: 0100000100000000
       VCID: 362007E8818C6636E1-8062
       Part No SW: 8R0 907 441 D    HW: 8T0 907 441 D
       Component: J772__Rearview      0140
       Revision: --H06---    Serial number: 525PA8-J21A0JX
       Coding: 1020010
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B3616DCBAAEBB5E1E-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Revision:             Serial number: 0000024084710
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 8R0 915 591     HW: 8R0 915 591
       Component: BMS           H08 0543
       Coding: 0A0200
       Shop #: WSC 12284 002 1048576
       ASAM Dataset: EV_BECM0722011 004016
       ROD: EV_BECM0722011_004_AU48.rod
       VCID: 78BCC9D0C318504633-802C
    End----(Elapsed Time: 02:17, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
    Merci
    Hi and welcome.
    Please Get Verified.
    Please give us some background. How did the ABS module come to be "incorrectly coded"? Were any parts changed?
    United States
    My guess is 44 was replaced and isn't coded:
    That will cause a false incorrectly coded DTC in 03.
    If 44 won't accept coding you may need a dealer (ODIS) level replacement test plan completed on 44 via SVM code.
  4. Likes Uwe, Justin, PetrolDave, Djemai liked this post
    Jun 2020
    France
    Hi and welcome.
    Hello
    I received the car like this from my client.
    At Audi he says to change the Bosch 8.0 ABS block
    I dismantled and electronically check it and in good condition
    Thank you
    Jun 2020
    France
    Hi
    Did I not understand your message correctly? !!!
    Thank you
    United States
    Thanks for registering. I'll change your forum status to Verified so we can move this to the Car Repair Support sub-forum.
    The installed ABS:
    Coding: 13154C
    is the correct part number and it appears to be coded correctly. I can dig deeper to see if there are any alternative Hybrid coding options for 03 and will report back if I have any suggestions.
    What I meant in my initial reply is that I believe the steering rack (address 44) was replaced, or at the least had coding modified, and it does not appear to be coded properly at face value. That's the most likely explanation for the 03-ABS incorrectly coded DTC. I would try coding address 44 to something like:
    100100000100
    or
    100100000101
    Let us know if those are rejected or accepted by address 44. If either are accepted let us know if one of them happens to let you to clear the 03-ABS DTC or not.
  8. Likes Uwe, Djemai liked this post
    United States
    Update. Our Q5 Hybrid scan collection is extremely limited however I found a few with this engine code using 03-ABS brake coding of: 2D1D1C
    Those had factory TPMS and this one does not so it may be worth seeing if 2D1D0C is accepted. You will need to use Security Access code 61378 = Coding Enabling before coding is possible.
    If that is accepted you may not need to modify the 44-Steering Assist coding.
  10. Likes Uwe, Djemai liked this post
  11. #8
    Jun 2020
    France
    The installed ABS:
    Coding: 13154C
    100100000100
    or
    100100000101
    Thank you
    I did a test without result
  12. Likes Dana liked this post
  13. #9
    Yes, I have no European cars with this Engine, only 4 US.
    all 4 have this coding for [44]
    000000000100
    7X8
    But I get this for ABS: 2D1508
    7K0 and 7L3
  14. Likes Uwe, Dana liked this post
  15. #10
    United States
    Quote Originally Posted by Djemai View Post
    Thank you
    Thanks. In that case I think we should leave 44 at the original value and try coding 03-ABS to 2D1D0C (my coding) or 2D1508 (NEtech's coding) instead.
    Sorry this is so inclusive. We don't have a lot of Hybrid info to work with.
  16. Likes Uwe, Djemai liked this post
