Results 1 to 10 of 11
Thread: Audi a6 Headlight slave unit recode
    Verified VCDS User langyyyy's Avatar
    Jun 2014
    Slovakia
    Lightbulb Audi a6 Headlight slave unit recode
    Hi, I have crashed car.
    I replace left slave unit and now need recode it.
    Right unit ( correct one ) have coding E01E00.
    When trying recode left unit from E01800 to E01E00 I have error - rejected .... How to change coding on this unit??? ( number of importer etc is not 0000 )
    Thanks guys for help!
    Tuesday,09,June,2020,18:45:46:51262
    VCDS Version: 20.4.1.0
    Dealer/Shop Name: bekscrs
    Workshop Code: 135 31518 016521
    VIN: WAUZZZ4G1HN132740   License Plate: KKAUDI
    Mileage: 45914km-28529mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 3B 42 44 46 52 53 55 5F 62
              6C 72 8F AC
    VIN: WAUZZZ4G1HN132740   Mileage: 45914km-28529miles
    17-Instruments -- Status: Cannot be reached 0100
    62-Door, Rear Left -- Status: Cannot be reached 0100
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    Address 01: Engine (J623-DDDA)       Labels: None
       Part No SW: 04L 906 021 HC    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 4164
       Revision: 8DH20---
       Coding: 0A254012232601080000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM20TDI01104L906021HC 004004
       ROD: EV_ECM20TDI011_AU57.rod
       VCID: 6DD5F96FBC59C0EED0-8038
       Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
       Component: 0B5 20 TDIRdW H06 0004
       Revision: --H06---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001022
       ROD: EV_TCMDL501021.rod
       VCID: 387B183B839BB546F3-806C
       Coding: 06A69E41606579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 418D75DFD041F48E44-8014
    217088 - System Function Test Activated
              C101F 00 [047] - -
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:18
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8D
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01A8700E000000000000
       VCID: 7CF3C42BFF23596657-8028
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0113
       Serial number: 27041700111467
       Coding: 34010908210000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 61CD955F7081948E64-8034
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:18
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 16.5 °C
                        Temperature after evaporator: 20.43 °C
                        Engine speed: 0 /min
    0318 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:18
                        Voltage terminal 30: 11.22 V
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 1502003S    Serial number: 00001658636901
       Coding: 0105001440349FE0C101408720001800CF9CC3082E08020100000494E101150200400034030000
       VCID: 74E3EC0BD77311261F-8020
       Component: WWS57X 170218  H38 0080
       Serial number:         170222171857
       Coding: 0045F7
       Serial number: 20212664X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 03 05 2017  00001282
       Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H01 0006
       Serial number: DA2806A880PAG0FSA002
    03455 - Function Restriction due to Faults in Other Modules
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:20
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0092
       Revision: --------    Serial number: 003P100DLDLB
       Coding: 30333130313630323637554A304C34473053
       VCID: 3B710737B2AD9E5E1E-806E
       Serial number: 3575HRB401I596KS4P1O
       Serial number: 3585HRB405V1G0QM8HTK
       Serial number: 3515JRB400Q59OGAQ9F0
       Serial number: 3525JRB400E59H1U9HMS
       Serial number: 3554VRB40671EVLGB1O7
       Serial number: 3564VRB400M59ISIL8V-
    7 Faults Found:
    9444885 - Driver's seat position sensor
              B101E 15 [137] - Open or Short to Plus
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:21
    9445141 - Passenger's seat position sensor
              B101F 15 [137] - Open or Short to Plus
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:21
    9447189 - Seat Occupied Sensor; Passenger's Side
              B1027 15 [137] - Open or Short to Plus
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:21
    9442331 - Passenger's Belt Force Limiter Igniter
              B1014 1B [137] - Resistance Too High
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:23
              B1007 1B [137] - Resistance Too High
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:23
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:23
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:23
       Revision: C0068538    Serial number: 91560QGQ000GH
       Coding: 000035
       VCID: 3B710737BAAD9E5E1E-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 02 03 2017  B0004652
    01748 - Switch for Tiptronic in Steering Wheel (E438); Up
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
    01749 - Switch for Tiptronic in Steering Wheel (E439); Down
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
       Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
       Component: TDieRdw       H17 0225
       Revision: 17001311    Serial number: 658070517596041
       Coding: 13AF0D000B410008080B00
       Shop #: WSC 09038 123 61029
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K_AU57.rod
       VCID: 408B70DBDB4BFD864B-8014
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002600874
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 002011
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 9202473804
       Voltage stabilizer:
       Serial number: 170222000000000004C4
    5074 - Door Control Module - Rear Left
              U0201 00 [009] - No Communications
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:18
                        Voltage terminal 30: 11.1 V
                        Voltage terminal 15: 11.1 V
                        Control Module temperature: 22 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
              U140B 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:41:03
                        Voltage terminal 30: 11.2 V
                        Voltage terminal 15: 0.0 V
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 1
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       VCID: 67D98B4796A5EABEAA-8032
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720WKUVU
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33612F179AFD561EC6-8066
       Coding: 011F16015C00628002080002
       VCID: 47996BC7F665CABE8A-8012
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
    02123 - Door Warning Light / Entry Light
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000827893
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A7F0233BD97A75605-806E
       Revision: 00002001    Serial number: 0440911038
       Coding: 011A062080B90080C320088408010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00033277796
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
    00216 - Signal EC-mirror Fade Out
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:22
       Coding: 011F16015E00628002080002
       VCID: 468766C3F16FD3B671-8012
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:17
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002187371
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 326F2A1365E75F16CD-8066
       Coding: 04FA02102A600200
       Shop #: WSC 31518 135 16521
       VCID: 34632C0B9FF35126DF-8060
       Coding: E01800
       Coding: E01E00
              U1014 00 [137] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:20
    5275220 - Headlight
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:20
    5545201 - Output Stage for LED Headlamp; Left
              B149C F1 [137] - Incorrectly Coded
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:20
    5538066 - Temperature Sensor for Left High Beam
              C116F 01 [009] - Electrical Failure
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:21
    5538067 - Bulb for High Beam Headlamp; Left
              B1219 F0 [137] - Current Coding Electrical Error
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:21
       Part No SW: 4G1 035 044 G    HW: 4G1 035 044 D
       Component: MU-H-LN-EU    053 0910
       Serial number: A734E0H7543435
       Coding: 01750101FF0A000013110001000A00332F0006A5F1708100DF
       VCID: 2341DF572A1DC69E36-8076
       Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY807TCX
       Multimedia Operating Unit:
       Serial number: 90349QDS000N0
       Component: Gracenote2  --- 1015
    0527 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:43
                        Voltage terminal 30: 11.4 V
              B1066 13 [009] - Open Circuit
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:40
    Address 62: Door, Rear Left
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 0275000102002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001.rod
       VCID: 78FBD83BC31B754633-802C
       Coding: 010F14004000628002080002
       VCID: 499D6DFFE0713CCE9C-801C
       Component: RGS-VL        H16 0080
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 316D251F60E1640EB4-8064
    12583695 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.09
                        Time: 17:40:18
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 170960053
       ROD: EV_RDCMA00100.rod
       VCID: 2F69236776D572FEA2-807A
    End-------------------------(Elapsed Time: 04:48)--------------------------
    Do you have a saved Auto-Scan from before the crash (look in the C:\Ross-Tech\VCDS\Scans folder)? That will show the correct coding.
  3. Likes Dana, langyyyy liked this post
    Jun 2014
    Slovakia
    I have this in my first scan but still after crash ( NOT ENG LANG ):
    Adresa 55: Reg.sklonu světel (J745)       Labely:| SVO\4H4-907-357-V2.clb
       Řídící jednotka SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Díl: MxB-ECU       001 0100
       Revize: --------    Seriové číslo: --------------
       Coding: 04FA02102A630200
       Dílna #: WSC 02391 785 00200
       VCID: 34632C0B9FF351EF4D-8060
       Výkonový modul 1: levý světlomet LED:
       Díl: LED LeiMo li.
       Výkonový modul 1: pravý světlomet LED:
       Díl: LED LeiMo re.
  5. Likes Dana liked this post
  6. #4
    United States
    Try recoding the 55 master back to the original value (likely 04FA02102A630200).
  7. Likes Uwe, PetrolDave liked this post
  8. #5
    Jun 2014
    Slovakia
    Not working, the same situation
  9. #6
    And the left module is maybe a used one from a Audi TT ?
  10. Likes Dana, Uwe, langyyyy liked this post
  11. #7
    United States
    OK. Part of me wonders if the electrical errors
    .. might be directly causing problems however the existing left slave coding of E01800 appears to be found only in Golf 7 (MQB) based vehicles using LED headlights and chassis codes such as 8V, FV, AU and similar. For that reason I wonder if a used Golf-based slave isn't going to re-code in a 4G chassis vehicle? The scan in post #6 here includes a 4-slave setup with Coding: E01800 example:
    https://forums.ross-tech.com/showthr...l=1#post201106
    I suppose it is possible that the electrical DTCs are the end result of wrong slave coding rather than missing/damaged parts. If the car isn't reassembled yet I would move the 7PP 941 472 J modules from left to right (so they are installed in the opposite headlights) and re-scan it to see if the temp sensor and high beam DTCs move to the right side. Doing so may help determine if there are actual problems in the light itself (or not) but I'm not sure if it will get you closer to resolving this problem.
    Edit; NEtech and I appear to have similar concerns. Just noticed his reply.
  12. Likes Uwe, langyyyy liked this post
  13. #8
    Jun 2014
    Slovakia
    Yes, its from audi TT used part
    scan after slaves swap
    Wednesday,10,June,2020,17:30:25:51262
    VIN: WAUZZZ4G1HN132740   License Plate: SWAP SLAVES
              6C 72 8F AC
       Revision: 8DH20---
       Revision: --H06---
       Coding: 100001
              C101F 00 [047] - -
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 94
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Temperature after evaporator: 19.34 °C
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Voltage terminal 30: 11.71 V
       Coding: 0045F7
       Coding: 02006D
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
    7 Faults Found:
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:11
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:11
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:11
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:11
       Coding: 000035
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
       Coding: C0CD074418
       Voltage stabilizer:
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Voltage terminal 30: 11.5 V
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 18 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U140B 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:27
                        Voltage terminal 30: 11.6 V
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 1
       Revision: AA001002
       ROD: EV_SARA2.rod
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
    00984 - Left Tail Light (M4)
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
    00985 - Right Tail Light (M2)
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
       Coding: E01E00
       Coding: E01800
    7 Faults Found:
    13706047 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:14
              U1014 00 [137] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:08
    5275220 - Headlight
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:08
    5544945 - Output Stage for LED Headlamp; Right
              B149B F1 [137] - Incorrectly Coded
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:08
    5538304 - Bulb for Low Beam Headlamp Right
              B1218 01 [137] - Electrical Failure
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
    5538322 - Temperature Sensor for Right High Beam
              C1170 01 [009] - Electrical Failure
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
    5538323 - Bulb for High Beam Headlamp; Right
              B121A F0 [137] - Current Coding Electrical Error
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:09
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:11
                        Voltage terminal 30: 11.8 V
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:13
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:24:05
    End-------------------------(Elapsed Time: 04:49)--------------------------
    EDIT:
    I recode 09 channel with the same coding, then make basic setting in 55 channel and it works!
    thanks everybody for help
  14. Likes Dana liked this post
  15. #9
    United States
    Nice! If you don't mind posting the final scan it would be extremely helpful.
  16. Likes Uwe liked this post
  17. #10
    Jun 2014
    Slovakia
    Of course!
    Here
    Thursday,11,June,2020,16:30:51:51262
    VIN: WAUZZZ4G1HN132740   License Plate: FIN A6
              6C 72 8F AC
       Revision: 8DH20---
       Revision: --H06---
       Coding: 100001
              C101F 00 [047] - -
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 94
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Temperature after evaporator: 19.64 °C
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Voltage terminal 30: 11.77 V
       Coding: 0105001440349FE0C101408320001800CF9CC3082E08020100000494E101150200400034030000
       Coding: 0045F7
       Coding: 02006D
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:52:46
    04082 - Supply Voltage for Parking Aid
                        Reset counter: 102
                        Mileage: 45914 km
                        Date: 2020.06.11
                        Time: 15:25:05
                        Reset counter: 102
                        Mileage: 45914 km
                        Date: 2020.06.11
                        Time: 15:25:05
    7 Faults Found:
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:41
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:41
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:41
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:43
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:43
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:43
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:43
       Coding: 000035
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
       Coding: C0CD074418
       Voltage stabilizer:
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:36
                        Voltage terminal 15: 11.5 V
                        Control Module temperature: 21 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0281 - Extended CAN in One-Wire Mode
              U0054 00 [008] - -
                        Reset counter: 102
                        Mileage: 45914 km
                        Date: 2020.06.11
                        Time: 15:25:04
                        Voltage terminal 30: 10.8 V
                        Voltage terminal 15: 10.8 V
                        Control Module temperature: 23 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 42
              U140B 00 [008] - -
                        Reset counter: 102
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 1
       Revision: AA001002
       ROD: EV_SARA2.rod
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
    02117 - Motor for Mirror Folding
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:54:31
    00109 - Left Mirror Turn Signal Lamp (L131)
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 17:02:33
    6 Faults Found:
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:41
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 17:02:36
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 17:03:07
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:54:31
    00110 - Right Mirror Turn Signal Lamp (L132)
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 17:03:03
       Coding: E01E00
       Coding: E01E00
    5275220 - Headlight
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:59:21
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:46
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:44
              U1111 00 [009] - -
                        Reset counter: 62
                        Mileage: 45914 km
                        Date: 2020.06.10
                        Time: 16:30:37
  18. Likes Uwe, Dana liked this post
