Audi a6 Headlight slave unit recode
langyyyy
Slovakia
C?ID=44692
Hi, I have crashed car.
I replace left slave unit and now need recode it.
Right unit ( correct one ) have coding E01E00.
When trying recode left unit from E01800 to E01E00 I have error - rejected .... How to change coding on this unit??? ( number of importer etc is not 0000 )
Thanks guys for help!
Tuesday,09,June,2020,18:45:46:51262
VCDS Version: 20.4.1.0
Dealer/Shop Name: bekscrs
Workshop Code: 135 31518 016521
VIN: WAUZZZ4G1HN13xxxx   License Plate: KKAUDI
Mileage: 45914km-28529mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 3B 42 44 46 52 53 55 5F 62
          6C 72 8F AC
VIN: WAUZZZ4G1HN13xxxx   Mileage: 45914km-28529miles
17-Instruments -- Status: Cannot be reached 0100
62-Door, Rear Left -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
Address 01: Engine (J623-DDDA)       Labels: None
   Part No SW: 04L 906 021 HC    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 4164
   Revision: 8DH20---
   Coding: 0A254012232601080000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021HC 004004
   ROD: EV_ECM20TDI011_AU57.rod
   VCID: 6DD5F96FBC59C0EED0-8038
   Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H06 0004
   Revision: --H06---
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 387B183B839BB546F3-806C
   Coding: 06A69E41606579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 418D75DFD041F48E44-8014
217088 - System Function Test Activated
          C101F 00 [047] - -
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:18
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 8D
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01A8700E000000000000
   VCID: 7CF3C42BFF23596657-8028
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0113
   Serial number: 27041700111467
   Coding: 34010908210000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 61CD955F7081948E64-8034
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:18
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 16.5 °C
                    Temperature after evaporator: 20.43 °C
                    Engine speed: 0 /min
0318 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:18
                    Voltage terminal 30: 11.22 V
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001658636901
   Coding: 0105001440349FE0C101408720001800CF9CC3082E08020100000494E101150200400034030000
   Shop #: WSC 12345 123 12345
   VCID: 74E3EC0BD77311261F-8020
   Component: WWS57X 170218  H38 0080
   Serial number:         170222171857
   Coding: 0045F7
   Serial number: 20212664X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 03 05 2017  00001282
   Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H01 0006
   Serial number: DA2806A880PAG0FSA002
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:20
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100DLDLB
   Coding: 30333130313630323637554A304C34473053
   VCID: 3B710737B2AD9E5E1E-806E
   Serial number: 3575HRB401I596KS4P1O
   Serial number: 3585HRB405V1G0QM8HTK
   Serial number: 3515JRB400Q59OGAQ9F0
   Serial number: 3525JRB400E59H1U9HMS
   Serial number: 3554VRB40671EVLGB1O7
   Serial number: 3564VRB400M59ISIL8V-
7 Faults Found:
9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:21
9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:21
9447189 - Seat Occupied Sensor; Passenger's Side
          B1027 15 [137] - Open or Short to Plus
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:21
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:23
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:23
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:23
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:23
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QGQ000GH
   Coding: 000035
   VCID: 3B710737BAAD9E5E1E-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 02 03 2017  B0004652
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
                    Fault Status: 01101100
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
   Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
   Component: TDieRdw       H17 0225
   Revision: 17001311    Serial number: 658070517596041
   Coding: 13AF0D000B410008080B00
   Shop #: WSC 09038 123 61029
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 408B70DBDB4BFD864B-8014
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002600874
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 002011
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 9202473804
   Voltage stabilizer:
   Serial number: 170222000000000004C4
5074 - Door Control Module - Rear Left
          U0201 00 [009] - No Communications
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:18
                    Voltage terminal 30: 11.1 V
                    Voltage terminal 15: 11.1 V
                    Control Module temperature: 22 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
          U140B 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:41:03
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 0.0 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 1
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04018264747464545425363E00
   VCID: 67D98B4796A5EABEAA-8032
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720WKUVU
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33612F179AFD561EC6-8066
   Component: TSG FA        H03 0511
   Coding: 011F16015C00628002080002
   VCID: 47996BC7F665CABE8A-8012
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
   Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000827893
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7F0233BD97A75605-806E
   Revision: 00002001    Serial number: 0440911038
   Coding: 011A062080B90080C320088408010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00033277796
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
00216 - Signal EC-mirror Fade Out
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:22
   Coding: 011F16015E00628002080002
   VCID: 468766C3F16FD3B671-8012
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:17
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002187371
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326F2A1365E75F16CD-8066
   Coding: 04FA02102A600200
   Shop #: WSC 31518 135 16521
   VCID: 34632C0B9FF35126DF-8060
   Coding: E01800
   Coding: E01E00
          U1014 00 [137] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:20
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:20
5545201 - Output Stage for LED Headlamp; Left
          B149C F1 [137] - Incorrectly Coded
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:20
5538066 - Temperature Sensor for Left High Beam
          C116F 01 [009] - Electrical Failure
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:21
5538067 - Bulb for High Beam Headlamp; Left
          B1219 F0 [137] - Current Coding Electrical Error
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:21
   Part No SW: 4G1 035 044 G    HW: 4G1 035 044 D
   Component: MU-H-LN-EU    053 0910
   Serial number: A734E0H7543435
   Coding: 01750101FF0A000013110001000A00332F0006A5F1708100DF
   VCID: 2341DF572A1DC69E36-8076
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9HY807TCX
   Multimedia Operating Unit:
   Serial number: 90349QDS000N0
   Component: Gracenote2  --- 1015
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:43
                    Voltage terminal 30: 11.4 V
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:40
Address 62: Door, Rear Left
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78FBD83BC31B754633-802C
   Component: TSG HR        H03 0511
   Coding: 010F14004000628002080002
   VCID: 499D6DFFE0713CCE9C-801C
   Component: RGS-VL        H16 0080
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 316D251F60E1640EB4-8064
12583695 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.09
                    Time: 17:40:18
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 170960053
   ROD: EV_RDCMA00100.rod
   VCID: 2F69236776D572FEA2-807A
End-------------------------(Elapsed Time: 04:48)--------------------------
Do you have a saved Auto-Scan from before the crash (look in the C:\Ross-Tech\VCDS\Scans folder)? That will show the correct coding.
langyyyy
Slovakia
C?ID=44692
I have this in my first scan but still after crash ( NOT ENG LANG ):
Adresa 55: Reg.sklonu světel (J745)       Labely:| SVO\4H4-907-357-V2.clb
   Řídící jednotka SW: 4H4 907 357 E    HW: 7P6 907 357 B
   Díl: MxB-ECU       001 0100
   Revize: --------    Seriové číslo: --------------
   Coding: 04FA02102A630200
   Dílna #: WSC 02391 785 00200
   VCID: 34632C0B9FF351EF4D-8060
   Výkonový modul 1: levý světlomet LED:
   Díl: LED LeiMo li.
   Výkonový modul 1: pravý světlomet LED:
   Díl: LED LeiMo re.
Dana
Western PA, USA
Try recoding the 55 master back to the original value (likely 04FA02102A630200).
langyyyy
Slovakia
C?ID=44692
Not working, the same situation
NEtech
C?ID=56995
And the left module is maybe a used one from a Audi TT ?
Dana
Western PA, USA
OK. Part of me wonders if the electrical errors
MIL ON - Confirmed - Tested Since Memory Clear​
.. might be directly causing problems however the existing left slave coding of E01800 appears to be found only in Golf 7 (MQB) based vehicles using LED headlights and chassis codes such as 8V, FV, AU and similar. For that reason I wonder if a used Golf-based slave isn't going to re-code in a 4G chassis vehicle? The scan in post #6 here includes a 4-slave setup with Coding: E01800 example:
https://forums.ross-tech.com/showth...udi-TTS-US-car&p=201106&viewfull=1#post201106
I suppose it is possible that the electrical DTCs are the end result of wrong slave coding rather than missing/damaged parts. If the car isn't reassembled yet I would move the 7PP 941 472 J modules from left to right (so they are installed in the opposite headlights) and re-scan it to see if the temp sensor and high beam DTCs move to the right side. Doing so may help determine if there are actual problems in the light itself (or not) but I'm not sure if it will get you closer to resolving this problem.
Edit; NEtech and I appear to have similar concerns. Just noticed his reply.
langyyyy
Slovakia
C?ID=44692
Yes, its from audi TT used part
scan after slaves swap
Wednesday,10,June,2020,17:30:25:51262
VIN: WAUZZZ4G1HN13xxxx   License Plate: SWAP SLAVES
          6C 72 8F AC
   Revision: 8DH20---
   Revision: --H06---
   Coding: 100001
          C101F 00 [047] - -
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 94
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Temperature after evaporator: 19.34 °C
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Voltage terminal 30: 11.71 V
   Coding: 0045F7
   Coding: 02006D
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
7 Faults Found:
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:11
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:11
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:11
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:11
   Coding: 000035
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
   Coding: C0CD074418
   Voltage stabilizer:
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 18 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:27
                    Voltage terminal 30: 11.6 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Revision: AA001002
   ROD: EV_SARA2.rod
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
00984 - Left Tail Light (M4)
                    Fault Status: 11101100
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
00985 - Right Tail Light (M2)
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
   Coding: E01E00
   Coding: E01800
7 Faults Found:
13706047 - Databus
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:14
          U1014 00 [137] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:08
5275220 - Headlight
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:08
5544945 - Output Stage for LED Headlamp; Right
          B149B F1 [137] - Incorrectly Coded
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:08
5538304 - Bulb for Low Beam Headlamp Right
          B1218 01 [137] - Electrical Failure
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
5538322 - Temperature Sensor for Right High Beam
          C1170 01 [009] - Electrical Failure
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
5538323 - Bulb for High Beam Headlamp; Right
          B121A F0 [137] - Current Coding Electrical Error
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:09
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:11
                    Voltage terminal 30: 11.8 V
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:13
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:24:05
End-------------------------(Elapsed Time: 04:49)--------------------------
EDIT:
I recode 09 channel with the same coding, then make basic setting in 55 channel and it works!
thanks everybody for help
Dana
Western PA, USA
Nice! If you don't mind posting the final scan it would be extremely helpful.
langyyyy
Slovakia
C?ID=44692
Of course!
Here
Thursday,11,June,2020,16:30:51:51262
VIN: WAUZZZ4G1HN13xxxx   License Plate: FIN A6
          6C 72 8F AC
   Revision: 8DH20---
   Revision: --H06---
   Coding: 100001
          C101F 00 [047] - -
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 94
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Temperature after evaporator: 19.64 °C
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Voltage terminal 30: 11.77 V
   Coding: 0105001440349FE0C101408320001800CF9CC3082E08020100000494E101150200400034030000
   Coding: 0045F7
   Coding: 02006D
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:52:46
04082 - Supply Voltage for Parking Aid
                    Reset counter: 102
                    Mileage: 45914 km
                    Date: 2020.06.11
                    Time: 15:25:05
                    Reset counter: 102
                    Mileage: 45914 km
                    Date: 2020.06.11
                    Time: 15:25:05
7 Faults Found:
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:41
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:41
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:41
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:43
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:43
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:43
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:43
   Coding: 000035
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
   Coding: C0CD074418
   Voltage stabilizer:
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:36
                    Voltage terminal 15: 11.5 V
                    Control Module temperature: 21 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0281 - Extended CAN in One-Wire Mode
          U0054 00 [008] - -
                    Reset counter: 102
                    Mileage: 45914 km
                    Date: 2020.06.11
                    Time: 15:25:04
                    Voltage terminal 30: 10.8 V
                    Voltage terminal 15: 10.8 V
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 42
          U140B 00 [008] - -
                    Reset counter: 102
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Revision: AA001002
   ROD: EV_SARA2.rod
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
02117 - Motor for Mirror Folding
                    Fault Status: 01101011
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:54:31
00109 - Left Mirror Turn Signal Lamp (L131)
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 17:02:33
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:41
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 17:02:36
01505 - Bulb for Blinkers; Rear Right (M8)
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 17:03:07
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:54:31
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 17:03:03
   Coding: E01E00
   Coding: E01E00
5275220 - Headlight
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:59:21
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:46
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:44
          U1111 00 [009] - -
                    Reset counter: 62
                    Mileage: 45914 km
                    Date: 2020.06.10
                    Time: 16:30:37
Dana
Western PA, USA
Thanks! I left this tab open as a reminder to followup.
We didn't have a MxB-ECU Wiki page at all so I created one today:
Audi A6 (4G/4H) MxB-ECU Headlight Regulation
I used your example in the scan snippet at the top -and- noted the good old re-code J519 tip which is sorta similar to the MLB models that did NOT use AW 55 at all but that was a matter of BS 011 rather than re-coding 09.
Hopefully the Wiki page helps the next MxB-ECU guy that installs proper used part numbers which refuse to code due to their former (MQB in this case) identity!
Vasse
C?ID=525387
Hi.
I have similar problem. I made to my friend matrix retrofit. All works fine, but was little problem with power modules, when put blinkers on. On the dash comes faults.
Then we decide to put bcm1 and headlight range modules to another friend car, his car is S6 -17 with factory matrix. And make SVM with ODIS.
SVM vend good, but now in 55 module is faults. All lights modules is wrongly coded and 55 module too.
Now i attached that led modules have different coding and old 55 module coding was wrong. Coding was from A7, now i think that power modules are coded for a7.
So how you recoded yours used power modules?
I tryed to recode bcm1, but nothink.
Modules was new, when we did retrofit.
If you can give some instructions?
Thanks!
