Results 1 to 5 of 5
Thread: Skoda Superb MY09 and special fault code
    Feb 2017
    Oulu, Finland
    Hey!
    I'm looking into a Skoda Superb MY09.
    We looked at the car for fault codes when the indicator lights on the instrument panel were on.
    First round:
    Sunday,07,June,2020,19:34:23:00464
    Dealer/Shop Name: J.P - V3lmu
    VIN: TMBAF73T599021176   License Plate:
    Mileage: 259370km-161165mi   Repair Order:
    Chassis Type: 3T-SK46 (1K0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 25 36 42 44 46 47 52 55 56
              62 69 72 77
    VIN: TMBAF73T599021176   Mileage: 259370km-161165miles
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 AP    HW: 03L 906 022 GA
       Component: R4 2.0l TDI G000AG  9979
       Revision: 13H01---    Serial number:
       Coding: 0000078
       Shop #: WSC 30432 002 1048576
       VCID: 73B3DFDBE7B535935E0-8026
    005642 - Internal Control Module Memory
                   P160A - 000 - Check Sum Error - MIL ON
                        Fault Status: 11100000
                        Mileage: 259336 km
                        Date: 2014.10.29
                        Time: 22:58:45
                        Voltage: 11.93 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00101100
                        Temperature: 32.4°C
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 000 - Signal too High (Rich)
                        Mileage: 259365 km
                        Date: 2014.10.29
                        Time: 19:13:43
                        RPM: 2070 /min
                        Speed: 105.0 km/h
                        Lambda: 22.1 %
                        Mass Air / Rev.: 535.0 mg/str
                        Voltage: 0.075 V
                        (no units): 16.0
                        Voltage: 0.975 V
    Readiness: 1 1 0 0 0
       Part No SW: 02E 300 051 T    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1980
       Revision: 04844002    Serial number: 00000810100265
       Shop #: WSC 35110 377 00999
       VCID: 2411EC8712DBE22B17A-8070
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 3T0 614 517 B    HW: 3T0 614 517 B
       Component: ESP FRONT MK60-AT   0102
       Revision: 00H12001
       Coding: 0039554
       VCID: 313F15D35D294783ECC-8064
       Part No SW: 3T0 907 044 AJ    HW: 3T0 907 044 AJ
       Component: Climatronic   122 0204
       Revision: 00003001
       Coding: 0100000000
       Shop #: WSC 35703 895 00999
       ASAM Dataset: EV_Climatronic A01001
       ROD: EV_ClimaAutoBasis_SK46.rod
       VCID: 7AADF2FFCC5F44DB1D6-802E
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                        Fault Frequency: 21
                        Reset counter: 131
                        Mileage: 258364 km
                        Date: 2020.05.27
                        Time: 12:31:34
       Part No SW: 1K0 937 087 A    HW: 1K0 937 087 A
       Component: BCM PQ35  H+  020 0360
       Revision: 00020000
       Coding: 40990ABAD841F1C040080084110089A401711BAE6320A5605C4040000000
       Shop #: WSC 51273 443 76827
       VCID: 2F3B13AB471D5173FA8-807A
       Subsystem 1 - Part No: 3T1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 30100  22  0602
       Coding: 00D7B7
       Component: RLS 061108 05  54  0402
       Coding: 0730ED
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
                        Fault Status: 00101010
                        Reset counter: 117
                        Mileage: 258049 km
                        Date: 2014.10.10
                        Time: 22:52:60
                        Voltage: 12.05 V
                            Term 50 Off
    00984 - Left Tail Light (M4)
                        Fault Status: 00101110
                        Fault Frequency: 36
                        Reset counter: 131
                        Mileage: 258049 km
                        Date: 2014.10.14
                        Time: 16:45:17
                        Voltage: 14.00 V
                            Term 50 Off
    00532 - Supply Voltage B+
                        Reset counter: 73
                        Mileage: 258134 km
                        Date: 2014.10.15
                        Time: 08:24:31
                        Voltage: 13.75 V
                            Term 50 Off
                        Reset counter: 75
                        Mileage: 258216 km
                        Date: 2014.10.17
                        Time: 07:23:52
                        Voltage: 13.80 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 3T0 919 475 B    HW: 3T0 919 475
       Component: PARKHILFE PLA H07 0003
       Revision: --------    Serial number: 66430829201646
       Coding: 010104
       VCID: 3C2134E7866BBAEB4FA-8068
       Part No SW: 3T0 959 655     HW: 3T0 959 655
       Component: J234__LA8 VW10 HI   1815
       Revision: 17013000    Serial number: 003CCPNC7SWP
       Coding: 0016696
       VCID: 7EA5FEEFDCF768FB21E-802A
       Subsystem 1 - Serial number: 6333FTS659552908
       Subsystem 2 - Serial number: 6343FTS673752958
       Subsystem 3 - Serial number: 6353ETS6Q2SPVVNR
       Subsystem 4 - Serial number: 6363ETS6594QVVNR
       Subsystem 5 - Serial number: 6373JTS6024QVVNJ
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Coding: 0001731
       VCID: 76B5E6CFF4C720BB79E-8022
       Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO   H07 0011
       Coding: 00000130
       Part No SW: 3T1 920 841 D    HW: 3T1 920 841 D
       Component: KOMBI         H06 0106
       Coding: 110F00
       Shop #: WSC 35703 895 09999
       VCID: 34311CC7AEBB72AB87A-8060
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 1K0 815 007 BT
       Component: Standheizer     022 3907
       Revision: 00022000    Serial number: 09020188000000
       Coding: 0021012
       Shop #: WSC 11310 000 1048576
       VCID: 77ABEBCBF3CD59B3628-8022
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K08A080889
       Coding: EDA1FF46100E023302
       VCID: 353721C3A9416BA3B04-8060
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H06 0106
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760     HW: 3C8 959 760
       Component: J810                0801
       Revision: 00002000    Serial number: 00000000000000
       Coding: 0000003
       VCID: 72BDDADF98AF3C9B556-8026
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
       Component: TSG FA        H03 0190
       Revision:             Serial number: 0000100396037
       Coding: 011D0220DE00121002
       VCID: 40D94017EA83DE0B132-8014
                        Fault Frequency: 30
                        Reset counter: 93
                        Mileage: 258455 km
                        Date: 2014.10.20
                        Time: 15:16:08
                        Fault Status: 01100010
                        Fault Frequency: 26
                        Reset counter: 93
                        Mileage: 258455 km
                        Date: 2014.10.20
                        Time: 15:39:45
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 196    2301
       Revision: 00H15000
       VCID: 2A0D02BF70FF345B2D6-807E
       Part No SW: 3T0 035 456     HW: 3T0 035 456
       Component: KonzernAmp10K H06 0320
       Revision: --------    Serial number: BP218289495691
       ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
       ROD: EV_AudioVerst10KanalBNO1_VW32.rod
       VCID: 6E85CEAF8017187BB1E-803A
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
       Component: TSG BF        H03 0190
       Revision:             Serial number: 0000100445693
       VCID: 3FDB43EB977DA1F36A8-806A
       Component: AFS-Steuergeraet    0136
       Coding: 1376839
       VCID: 34311CC7A23B72AB87A-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000021
       Coding: 00000021
       Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
       Component: BOLERO        006 0053
       Revision: 0A001001    Serial number: SKZ1Z3I9876138
       Coding: 0D0200000000
       Shop #: WSC 51273 443 86019
       VCID: 2D0709A34D112363C84-8078
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
       Part No SW: 7N0 959 795     HW: 7N0 959 795
       Component: TSG HL        H02 0190
       Revision:             Serial number: 0000100385620
       Coding: 010C00200000221002
       VCID: 015F8513A10917035CC-8054
       Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Component: Anhaenger     H07 0050
       Revision: 3A002002    Serial number: 00000115581569
       Coding: 4100000100000000
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794     HW: 7N0 959 795
       Component: TSG HR        H02 0190
       Revision:             Serial number: 0000100453614
       VCID: 55F7814305014BA3504-8000
    Address 77: Telephone        Labels: 3C0-035-730.lbl
       Part No SW: 5N0 035 730 A    HW: 5N0 035 730 A
       Component: J412                4100
       Revision: 00015000    Serial number: 0000B7A014875
       Coding: 0020121
       VCID: 2615F68F64E7103B09E-8072
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.2V)-----------
    DTC reset and second round
    Sunday,07,June,2020,19:40:43:00464
    VIN: TMBAF73T599021176   License Plate: 2. KIERROS
              62 69 72 77
       Coding: 0000078
                        Mileage: 259336 km
                        Date: 2014.10.29
                        Time: 22:58:45
                        Voltage: 11.93 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00101100
                        Temperature: 32.4°C
                        Mileage: 259365 km
                        Date: 2014.10.29
                        Time: 19:13:43
                        RPM: 2070 /min
                        Speed: 105.0 km/h
                        Lambda: 22.1 %
                        Voltage: 0.075 V
                        (no units): 16.0
                        Voltage: 0.975 V
       Revision: 00H12001
       Coding: 0039554
       Revision: 00003001
       Coding: 0100000000
       Revision: 00020000
       Coding: 00D7B7
       Coding: 0730ED
       Coding: 010104
       Coding: 0016696
       Coding: 0001731
       Coding: 00000130
       Coding: 110F00
       Coding: 0021012
       Coding: 0000003
                        Reset counter: 93
                        Mileage: 259377 km
                        Date: 2014.10.29
                        Time: 19:38:22
                        Reset counter: 93
                        Mileage: 259377 km
                        Date: 2014.10.29
                        Time: 19:38:22
       Revision: 00H15000
       Coding: 1376839
       Coding: 00000021
       Coding: 00000021
       Coding: 0020121
    End----(Elapsed Time: 01:31, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    This DTC did not reset. What this code mean? ECU broken?
    Regards: V3lmu
    I think the fault code description is pretty self-explanatory. There is a region of memory in this ECU that does not match the checksum stored for that region of memory.
    Is the ECU "tuned"?
    Feb 2017
    Oulu, Finland
    The owner has owned the car for a couple of days. We not have information on whether the car is tuned.
    Well, I think there are only two ways to fix that.
    1) I believe a Skoda dealer would simply tell you that the car needs a new ECU.
    2) It's possible (but not certain) that someone who does do ECU tuning could correct this error for you.
    Verified VCDS User AE Vlade's Avatar
    Feb 2020
    Serbia
    car tuner will help you for sure if car goes OK
    Regards
    AUDI A8 4.2 quttro
