This scan is from a 4/19 built US-spec Golf R manual transmission before any VCDS alterations.
Friday,22,May,2020,13:19:43:41546
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWWA7AU1KW174984   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 75 A5 A9 D6 D7
VIN: WVWWA7AU1KW174984   Mileage: 422km-262miles
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4ED0462C11756FF6C9-801B
Readiness: 1110 0101
   Part No SW: 5Q0 614 517 DS    HW: 5Q0 614 517 BN
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 60279000000176
   Coding: 01FA6BA1502709704580030860C76980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0542B90084836CAE38-8051
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6098747383
   Coding: 132C0C0623
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C66718CA37929E56-8017
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000010500001211140A
   VCID: 6D92E1A0BC33B4EED0-8039
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001909400092
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B568F38A2E71ADE6E-805F
   Component: WWS    190303  043 0551
   Serial number:         190319133803
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M04D04H19M21S13
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000030031904221076
   Serial number: 000308418019090
   Coding: 0471155801
   VCID: 4CD44C24E7695DE6A7-8019
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B0000C159FFC728949C810560401600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44C46404CF3995A66F-8011
   Serial number: 23031941351122
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383C00F483F1C146F3-806D
   Serial number: 003GCR0BJGFX
   VCID: 47DE7308FE0FBEBE8A-8013
   Occupant Detection:
   Serial number: IBH00000000000B6C2QH
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 000 404 19
   Serial number: 35700000000E9971AA3Z
   Subsystem 3 - Part No SW: -----------    HW: 480 000 404 19
   Serial number: 35800000000FF6482B3.
   Subsystem 4 - Part No SW: -----------    HW: 480 400 804 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BB2FA4F14274A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 404 19
   Component: SideSensor_Pr  005 6149
   Serial number: 352000198EF13DD8253J
   Subsystem 6 - Part No SW: -----------    HW: 480 400 504 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A6EF13DD71A3O
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 504 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001AAEF13DDA761W
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD30127F88CF0502886B0B5401000080000000
   VCID: 2C142CA447A97DE687-8079
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 10011911601402
   Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90E6ACB1354FF6E9-803B
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000417260059083
   Coding: 2CFFFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00012.03.19
   Coding: 0001
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000093612001
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A3DD0608B100EB4-8065
   Component: HRE_Master    H12 0081
   Serial number: 0511783055
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D3211E0ACD3E46E20-8069
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0512058572
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SCF0806E
   Coding: 003E13208000040000000000
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000029051893
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 910A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C341CE4B7C9ED6617-8069
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD04UJUM
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E1026AC71B50FF6A9-807B
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 25031910521265
   Coding: 000000050900161206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 352209C094E33C2EE8-8061
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SBS21428
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000029054654
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 332637D89A97221EC6-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJW0872489
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 25031915P22196
   Coding: 0003070000000201002213548150490084000E200120
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190305202091
   VCID: 2F2E3BA876BF06FEA2-807B
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A05F0B8FBD84E0C-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:42, VBatt start/end: 12.1V/12.0V)-----------
