Results 1 to 10 of 12
Thread: Retrofit a 5G0 919 606 to replace 3G0 919 605D - 2017 VW Touran 2.0L TDI SE DSG
    Apr 2020
    Hello All
    Hoping someone has some advice here as have just completed a retrofit of a 5G0 919 606 which has replaced a 3G0 919 605D, the replacement screen is hooked up to a 3Q0 035 874B
    I have the following error code 1555, which I only discovered when I went to do some adaptations for something else.
    This is the read out from the VCDS scan from today 6th June 2020, the screen is not listed in the readout here like the old one (also listed below) was on a scan I did on the 30th March
    Am I missing something (Not unusual)
    NEW READING 6th June 2020
    5F Multimedia
    System description: MU-S-ND-ER
    Software number: 3Q0035874B
    Software version: 0751
    Hardware number: 3Q0035874B
    Hardware version: 840
    ODX name: EV_MUStd4CDELP
    ODX version: 001001
    Long coding: 02730801FF00000051110101008808001F0201C601200100CF
    Subsystems:
    System description: ABT_High
    Software version: 0032
    Hardware version: H63
    Serial number: VWZ8Z9SKL031UP
    System description: ECE AS 20/21
    Software version: 1430
    Hardware version: ---
    Trouble codes:
    B201A00 - Checking software version management
    static
    This is a reading 30th May 20 - before the screen swap:
    Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
    Component: MU-S-ND-ER 840 0751
    Coding: 02730801FF00000051110101008808001F0100C601200100CF
    ROD: EV_MUStd4CDELP_VW37.rod
    VCID: 313EEE2331ADDEBF769-8064
    Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
    Component: ABT_Std-2_Nav H71 6121
    Serial number: VWZ6Z9S3481544
    Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
    Component: ECE AS 20/21 --- 1430
    After a lot of checking out over a 3 month period, I was informed the the 5G0 919 606 would be a straight swap with the appropriate trim, the screen works fine, the display on switch on after the VW Logo displays TWIN DRIVE, which I want to change, which is one of the things I was going to do, can get into adaptation for the new 5F list, also into the adaptations list.
    Please, any ideas, spent 4 hours this afternoon trying to figure this out and have got nowhere.
    Thank You
    Take care
    Tartu, Estonia
    There is adaption called: Confirmation of Installation Change. You need to XOR this value with C9D2 and paste as new value.
    The world is my oyster...
  3. Likes Uwe, PetrolDave liked this post
    Apr 2018
    ITALY
    screens are usually a direct swap, I did it on my Golf as well. I am not sure what you are complaining about.
    if you are concerned about the "Check Software Version Management" error, it can easily be cleared out with the XOR method, but if you leave it there it will not affect anything.
    if the screen does not show when you scan the car, there is something wrong.
    my Golf left the factory with 18 ECUs. now she has 27. and counting
    Apr 2020
    Hello Golfi Vend and Darkchina811
    Thank You both for your quick assistance, this was not a complaint, just I never have liked a mystery and like things in order, if something is not right it bugs me BIG time, cannot stop until I have corrected the issue, whatever it is.
    I discovered about Bitwise, whilst browsing after posting the above, I presume I set it to data type: hexidecimal and note there are places for 2 numbers do I put C9D2 in the first one and then the B201A00 in the second, or am I on the wrong track.
    Thanks again both of you for your help, have added components like retrofitting fog lights and coding static cornering lights, but this is the first swap out of a part I have done.
    Apr 2018
    ITALY
    even if you're from UK your english sounds a bit broken to me and I am not sure if you sorted it out. whatever
    Apr 2020
    Hello again
    No, have not sorted it yet, on a little more investigation, I believe I have to put the number from Confirmation of change in Number 1 and C9D2 in Number 2 and XOR it to bits.
    Tartu, Estonia
    Please tell us the value from mentioned adaption channel.
  9. Likes Uwe liked this post
  10. #8
    Apr 2020
    Sorry for being dumb, is this the value that confirmation of change states
  11. #9
    Apr 2020
    Hi
    Sorry for delay, gone into Information Electric 5F and Adaptation andfound confirmation of installation change and the code in old and new value is - Drum Roll:
    F7 C0
  12. #10
    Apr 2018
    ITALY
    then replace it with 3E12, don't worry if you don't see the value changing.
    cycle ignition and clear errors. done.
