Results 1 to 8 of 8
Thread: Audi s5 2008 6 manual that I changed the ABS pump with used unit. I help coding it
    Jun 2020
    Vancouver
    Hello Gents, Adam here new user to Ross-tech. I have an Audi s5 2008 6 speed manual that I changed the ABS pump with a good used unit but sadly its not coded to my car. Now you know stupidly I swapped the used unit and need to code it. I am a skilled home mechanic and restored a 71 911e in my garage including a full engine rebuild with lots of goodies. Now I need to learn this stuff for my lovely S5. Thanks for any help
    Jun 2020
    Vancouver
    Friday,05,June,2020,12:57:12:18489
    VIN: WAURV78T68A010583   License Plate: ADAM
    Mileage: 132860km-82555mi   Repair Order:
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 65 6C 77
    VIN: WAURV78T68A010583   Mileage: 132860km-82555miles
    Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
       Part No SW: 8T0 907 560 A    HW: 8T0 907 560
       Component: 4.2l V8/4V    H10 0003
       Revision: 76H10---
       Coding: 01140009180F0120
       Shop #: WSC 12345 123 61029
       VCID: 38292D8E0257085BABB-806C
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 001 -
                        Fault Status: 01100001
                        Fault Frequency: 211
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:59
                        RPM: 1033 /min
                        Load: 26.7 %
                        Temperature: 40.0∞C
                        Temperature: 33.0∞C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 12.827 V
                   P1653 - 008 -
                        Fault Frequency: 213
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:59
                        RPM: 1033 /min
                        Load: 26.7 %
                        Temperature: 40.0∞C
                        Temperature: 33.0∞C
                        Voltage: 12.827 V
                   P1653 - 004 -
                        Mileage: 132315 km
                        Date: 2019.12.02
                        Time: 15:04:37
                        RPM: 1038 /min
                        Load: 29.0 %
                        Temperature: 37.0∞C
                        Temperature: 33.0∞C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.065 V
    005386 - Engine Off Timer Performance
                   P150A - 002 -  - Intermittent
                        Mileage: 132676 km
                        Date: 2020.01.20
                        Time: 15:33:24
                        RPM: 1243 /min
                        Load: 33.7 %
                        Temperature: 13.0∞C
                        Temperature: 16.0∞C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.303 V
    012555 - Low Pressure Fuel regulation
                   P310B - 002 - Fuel Pressure Outside Specification - Intermittent
                        Mileage: 132677 km
                        Date: 2020.05.23
                        Time: 10:51:45
                        RPM: 701 /min
                        Load: 32.1 %
                        Speed: 7.0 km/h
                        Temperature: 40.0∞C
                        Temperature: 18.0∞C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.970 V
       Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
       Component: ESP8 quattro  H04 0080
       Coding: 150500
       Shop #: WSC 02391 823 56573
       VCID: 03538A620B119B834E9-8056
                        Reset counter: 44
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:44
                        Hex Value: 0x0040
                        Hex Value: 0x47A2
                        Hex Value: 0x002D
                        Hex Value: 0x31AF
                        Hex Value: 0x00FF
                        Fault Frequency: 193
                        Reset counter: 44
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:44
                        Hex Value: 0x0040
                        Hex Value: 0x47A2
                        Hex Value: 0x0026
                        Hex Value: 0x85AF
                        Hex Value: 0x00FF
    01794 - Control Module - Incorrect Chassis (VIN) Number
                000 - - - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 205
                        Reset counter: 44
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:47
                        Hex Value: 0x0040
                        Hex Value: 0x42A2
                        Hex Value: 0x0014
                        Hex Value: 0x13B1
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 289 G    HW: 8K0 907 289 G
       Component: BCM2.01       H38 0253
       Coding: 0F0000
       Shop #: WSC 06325 000 00000
       VCID: 3D273C9A2D752D7378D-8068
       Subsystem 1 - Part No SW: 8T0 959 754 S    HW: 8T0 959 754 S
       Component: FBSAUDIB8 IDG  H34 0050
       Serial number: 0107000109575012
       Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
       Component: ELVAUDIB8  H33 0039
       Serial number: 0107000060782011
       Part No SW: 8T0 959 760     HW: 8T0 959 760
       Component: MEM-BFS       H08 0027
       Revision: AA000000    Serial number: 00001001016870
       Coding: 00017025002C44440000
       VCID: 55F7843AB505D53350D-8000
    03332 - Motor for Height Adjustment
                        Fault Status: 00100101
                        Reset counter: 81
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:00
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 D    HW: 4E0 035 729 A
       Component: Interfacebox    H43 3010
       Revision: 00000000    Serial number: 340HN077503851
       Coding: 0025003
       Shop #: WSC 12345 111 45725
       VCID: 3A2D3786305B1A4B5DF-806E
       Subsystem 1 - Part No: 8T0 919 609 D
       Component: E0380 BedienteilH07 0100
       Subsystem 2 - Serial number: 00000000010062
       Subsystem 3 - Serial number: 0129.06.070000000100010034ˇ
       Subsystem 4 - Serial number: 010034ˇ
                        Reset counter: 7
                        Mileage: 132313 km
                        Date: 2019.12.02
                        Time: 11:34:57
                        Bin. Bits: 00000001 00000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
       Component: KLIMA 3 ZONEN H05 0110
       Revision: C1000000    Serial number: 0114.08.070060
       Coding: 48022000
       VCID: 40D9456E5A87409B13B-8014
    00710 - Defroster Flap Positioning Motor (V107)
                        Fault Status: 00100001
                        Reset counter: 76
                        Mileage: 132440 km
                        Date: 2019.12.10
                        Time: 09:35:04
                        Voltage: 13.70 V
                        Temperature: 14.0∞C
                        Temperature: 11.0∞C
                        Count: 11271
                        Count: 17488
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H20 0253
       Revision: 05020001    Serial number: 00000000029792
       Coding: 26009091061CAF210000080300003D3D0F1C138800010141000000
       VCID: 303915AEEA27D01BE3B-8064
       Subsystem 1 - Part No SW: 8T1 955 119 B    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 310707  H13 0040
       Serial number: SWFBIE 0000134
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
       Component: RLS  H12 0001
       Serial number: 10013040
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
       Component: E1 - LDS  H07 0070
       Serial number: 00000000001307070650
    03207 - Charisma Switch Module
                        Reset counter: 7
                        Mileage: 132311 km
                        Date: 2019.12.02
                        Time: 10:31:00
       Part No SW: 8T1 035 110 A    HW: 8T1 035 110 A
       Component: MP3-Changer     H41 0350
       Revision: 00041003    Serial number: AUZ5ZBG4019455
       VCID: 2809FDCEDEF798DB3BB-807C
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0140
       Revision: 00000000    Serial number: AUZ4Z7G0122909
       Coding: 0000100
       VCID: 2F3B16D2FB19CFE3FA1-807A
       Part No SW: 8K0 919 475     HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0003
       Revision: 11001001    Serial number: 46130720803414
       Coding: 200002
       VCID: 76B5E3B648C3BE2B797-8022
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H49 0610
       Serial number: 003GLDD083F6
       Coding: 303338334330303030304A55304C38543053
       Shop #: WSC 12655 003 1048576
       VCID: 45D7547A452565B320D-8010
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0040
       Serial number: 5810000R07000005H1
       Serial number: 6334MSME607D6F18T
       Serial number: 6344MSME606B6508G
       Serial number: 6352QSME36500E23A
       Serial number: 6362QSME36410F1BJ
       Serial number: 63732SME18120144K
       Serial number: 63832SME37192941-
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90304JHJ0000B
       Coding: 000016
       Shop #: WSC 22102 444 999999
       VCID: 3E253B962073366B617-806A
       Part No SW: 8T0 920 980 P    HW: 8T0 920 980 P
       Component: KOMBIINSTR.   H21 0212
       Revision: 00000000    Serial number: 6C421UD87
       Coding: 8B3F01000B00D705020002
       VCID: 48C95D4E72B778DBDBB-801C
       Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
       Component: GW-BEM 4CAN-M H07 0084
       Revision: EB002032    Serial number: 3200E0772580D3
       Coding: 000003
       VCID: 44D1497E4E9F5CBB373-8010
       Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
       Component: J367-BDM  H06 0150
       Serial number: 17002C03230707
    01312 - Powertrain Data Bus
                        Reset counter: 57
                        Mileage: 132469 km
                        Date: 2019.12.11
                        Time: 09:11:17
    Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
       Component: SG ext.Player H09 0700
       Revision: 00000000
       VCID: 270BFEF2DFE997A3321-8072
       Component: MEM-FS        H08 0027
       Revision: AA000000    Serial number: 00001001016790
       Coding: 00197B25002C44440000
       Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
       Component: MNS US          H50 0990
       Revision: 00000000    Serial number: 341HO077503734
       Shop #: WSC 05141 444 69268
       VCID: 313F10AAED2DD913EC5-8064
       Part No SW: 8K0 959 793     HW: 8K0 959 793
       Component: TSG FA        H09 0149
       Revision:             Serial number: 0F`
       Coding: 011C13225E002201
       VCID: 7DA7FC9A6DF5ED7338D-8028
       Revision: 00002001    Serial number: 0105558839
       Coding: 0106069A007A04C503B000
       Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J245EE16SKB09  H01 0170
    02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                        Fault Status: 00101100
                        Reset counter: 75
                        Mileage: 132483 km
                        Date: 2019.12.12
                        Time: 09:14:22
       Part No SW: 8T0 035 223 M    HW: 8T0 035 223 C
       Component: DSP Prem      H12 0280
       Revision: 00H12003    Serial number: 34813000413602
       Coding: 020101
       Shop #: WSC 12336 024 394758
       Part No SW: 8K0 959 792     HW: 8K0 959 792
       Component: TSG BF        H09 0149
       Revision:             Serial number: 0Tb
       VCID: 7CA1F19E76EFE47B0F3-8028
                        Fault Frequency: 16
                        Reset counter: 55
                        Mileage: 132422 km
                        Date: 2019.12.09
                        Time: 14:30:45
       Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
       Component: EPB Audi B8   H03 0040
       Revision: 00000003    Serial number: 00000000013962
       VCID: 2F3B16D2F719CFE3FA1-807A
    Address 55: Headlight Range        Labels: 8T0-907-357.clb
       Part No SW: 8T0 907 357 A    HW: 4F0 907 357 F
       Coding: 0000017
       Shop #: WSC 05111 444 52605
       VCID: 3C21319E3A6F247B4F3-8068
       Component: AFS-Modul links H07 0004
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336HW077514088
       VCID: 2E050BD6FC13C6EBF17-807A
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0240
       Revision: 00001001    Serial number: 12822707120219
       Coding: 0CD154
    02214 - Tire Pressure Warning
                        Reset counter: 69
                        Mileage: 132677 km
                        Date: 2020.05.23
                        Time: 10:51:50
                        Bin. Bits: 00000000 00100101
                        Voltage: 14.10 V
                        Text:  16,5∞C; -0,53bar;3456742530;00h; 15∞C
       Part No SW: 8T0 907 441     HW: 4L0 907 441 A
       Revision: --H12---    Serial number: 525PA8-J77507G
       Coding: 1000008
       VCID: 75B7E4BA59C5B53370D-8020
       Part No SW: 4F0 910 336 E    HW: 4E0 862 335
       Component: Handyvorb2      H18 0950
       Revision: 00000000    Serial number: 00000005003956
       Coding: 0010900
       VCID: 2517F4FAA9E585B300D-8070
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.0V/11.9V)-----------
    I don't suppose you have a scan from before you swapped the ABS module?
    Jun 2020
    Vancouver
    Sadly I did not. I now know this was a dumb decision
    First Security Access, then Coding:
    110500
  6. Likes Uwe liked this post
    Jun 2020
    Vancouver
    110500
    Thank you. I'll get @ this shortly...
    Jun 2020
    Vancouver
    That worked perfectly thank you
  9. Likes Uwe liked this post
  10. #8
    Jun 2020
    Vancouver
    I'd like to say that after the dealership said they couldn't program my used abs pump and still charged me 160.00 I was rightfully ticked. This software is fantastic I only wish I'd bought it years ago.
  11. Likes Uwe, PetrolDave, Bruce liked this post
