Results 1 to 10 of 17
Thread: Audi a3 cruise control retrofit
    Aug 2019
    Reading, UK
    Hi, I'm still new here but really hope someone can help.
    Car is A3 8P 1.6 tdi, '62 plate.
    I've done the physical fit but can't get cruise to work. I followed the instructions from Ross Tech site, had to use the long coding 07 function, used long coding helper and selected 'CCS installed', 'exit', 'do it'. Went for a drive and didn't work so did a scan, I had 2 errors:
    01 Engine- steering column control module (CM), no comms;
    16 steering wheel- CM incorrectly coded.
    I then changed the coding back to 'CCS not installed' and did another scan, this gets rid of the no comms fault but the steering wheel incorrectly coded fault remains.
    I'd really appreciate any help or advice, thanks.
    "62 Plate" means nothing to anyone who doesn't live in the UK, and most of us here do not.
  3. Likes PetrolDave liked this post
    For the majority - who don't live in the UK - 62 plate means first registered between September 1 2012 and February 28 2013. So OPs A3 is most likely a 2013 MY - unless it had been in dealer stock for a few months when it could be a 2012 MY.
    Aug 2019
    Reading, UK
    Apologies, I should have realised. The car was registered Dec 2012.
    Here is a scan from yesterday, with 'CCS installed' selected. Below that are the affected sections after changing back to 'CCS not installed'.
    Chassis Type: 8P-AU35 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WAUZZZ8P6DA043158   Mileage: 224210km-139317miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 PP    HW: 03L 906 023 KS
       Component: 1,6l R4 CR td H43 2520
       Revision: --H43---    Serial number: AUX7Z0L8FNA03W
       Coding: 00114014032501080000
       Shop #: WSC 06314 123 12345
       ASAM Dataset: EV_ECM16TDI02103L906023PP 003003
       ROD: GV_ECM16TDI021PQ36.rod
       VCID: 03469A288AD0CC9E1F-8056
    6082 - Steering Column Control Module
              U0212 00 [037] - No Communications
                        Mileage: 224210 km
                        Date: 2020.06.05
                        Time: 01:39:57
                        Coolant temperature: 45 C
                        Intake air temperature: 21 C
                        Voltage terminal 30: 12.424 V
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 25 C
    Readiness: 0110 0000
       Revision: 00H31001
       Coding: 13422012492600FDC80C04E992210091380800
       Shop #: WSC 06314 000 00000
       VCID: 7DB2ECD0E434BA6E69-8028
       Part No SW: 8P0 820 047 D    HW: 8P0 820 047 D
       Component: J255  Klima Man H08 0060
       Revision: 00H08004    Serial number: 00000000000000
       VCID: 312A00E0A8EC8E0EBD-8064
    Address 09: Cent. Elect.
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H10 0250
       Revision: --------    Serial number: 003JU008HDJN
       Coding: 30314238303830303037554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52E86F6C052A9516E4-8006
       Serial number: 3572DRB40000ED5078C2
       Serial number: 3582DRB40000ED0C9B25
       Serial number: 35128RB400006D50A5AO
       Serial number: 35228RB400006D5F594X
       Serial number: 35547RB400006D3A417O
       Serial number: 35647RB400006D3A3F9/
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H38 0070
       Coding: 0002012
       VCID: 46C0433C316239B678-8012
       Component: E0221           H02 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 G    HW: 8P0 920 983 G
       Component: KOMBIINSTR. VDO H03 0380
       Revision: D0H03005    Serial number: 2248L005008245
       Coding: 0260428
       Shop #: WSC 00011 888 96745
       VCID: 3E302BDC69B2617630-806A
       Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
       Component: J533  Gateway H43 1632
       Revision:   H43       Serial number: 010912F2001290
       Coding: 352103
       VCID: 40CC5524D346178642-8014
       Revision: D0H03005    Serial number: AUX7Z0L8FNA03W
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0131764
       VCID: 49DA4800207CD6CE95-801C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 232    3305
       Revision: 00H22000
       VCID: 373E3EF84688503EF3-8062
    Address 46: Central Conv.
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0131764
       VCID: 4AD8770C257ADDD69C-801E
       Part No SW: 8P0 035 152 F    HW: 8P0 035 152 F
       Component: R Chorus2+      H06 0293
       Revision: 00H06000    Serial number: AUZ1Z2M3157451
       Coding: 0200021
       VCID: 2E101B9CB9D291F6A0-807A
       Part No SW: 7N0 907 534     HW: 7N0 907 530 J
       Component: Batt.regelung H43 1632
       Coding: F30F185A
       VCID: 71AAC0E0A86CCE0EFD-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900062454
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0131216
       Shop #: WSC 06314 000 1012544
       VCID: 42C85F2C1D4A059654-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0131216
       VCID: 43C65A2802500C9E5F-8016
    End----------(Elapsed Time: 01:06, VBatt start/end: 12.4V/12.4V)-----------
    CCS not installed:
       Coding: 00114014030501080000
    Readiness: 1110 1000
       Coding: 0002012
    When looking into doing the job it seemed all that was needed was to replace the indicator stalk module with the cruise control one and then change the coding. I'm now wondering if I need to also replace the steering wheel control module as well, but expect that would need more coding to.
    Quote Originally Posted by CosD View Post
    Registration date doesn't matter, what matters is the Model Year.
    BTW any reason why you have edited off the VCDS header that shows the version number?
    I'm puzzled that neither the 09 Cent Elect or 46 Central Convenience can be reached, but show as OK on the installation list?
    Aug 2019
    Reading, UK
    Ah sorry again, I've checked the VIN and it's 2013 model.
    I only left some info off to reduce the size of the post a bit:
    Friday,05,June,2020,21:01:24:50644
    VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
    www.Ross-Tech.com.
    That is strange, I hadn't noticed as they said OK but I had done a few scans, here is another comms are good with 09 and 46:
                        Mileage: 224213 km
                        Date: 2020.06.05
                        Time: 02:19:06
                        Coolant temperature: 60 C
                        Intake air temperature: 22 C
                        Control Module temperature-TECU: 24 C
       Revision: 00H31001
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
       Component: BCM PQ35  M   111 0715
       Revision: AN111715
       Coding: 4E000A2FA005F0C0207041E00000015C421A29AA004DC122E4008F800041
       VCID: 3FCE56D8AEB8687E3B-806A
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
       Coding: 0002012
       Coding: 0260428
       Coding: 352103
       Coding: 0131764
       Revision: 00H22000
       Coding: 0131764
       Coding: 0200021
       Coding: F30F185A
       Coding: 0131216
       Coding: 0131216
    End----------(Elapsed Time: 01:13, VBatt start/end: 12.4V/12.4V)-----------
    Thanks for having patience with me..
  8. Likes Uwe liked this post
    It looks to me like you've not changed the Steering Wheel Control Module's coding to tell it the car now has Cruise Control.
    00xxx?x: Board Computer / Cruise Control System (CCS)
    0 = w/o Board Computer and w/o Cruise Control System
    1 = with Board Computer and w/o Cruise Control System
    2 = w/o Board Computer and with Cruise Control System
    4 = with Board Computer and with Cruise Control System
    So try changing it from 0002012 to 0002042.
    PS: Got you verified (which would have been automatic if you had joined the forum using the same e-mail address we had on file for you from your order). Moving to Retrofits.
  10. Likes myounus, iichel liked this post
  11. #8
    Aug 2019
    Reading, UK
    Thanks Uwe you were right, I'd only changed the coding on 01 Engine, I've now also changed 16 Steering wheel as suggested and its working.
    Unfortunately I still have a similar fault on the steering wheel but it now says intermittent:
    Saturday,06,June,2020,21:02:01:50644
    VIN: WAUZZZ8P6DA043158   License Plate: FXZ 5211
    Mileage: 224230km-139330mi   Repair Order: CCS working
    VIN: WAUZZZ8P6DA043158   Mileage: 224230km-139330miles
       Revision: 00H31001
       Revision: AN111715
       Coding: 00DD13
       Coding: 0002042
       Coding: 0260428
       Coding: 352103
       Coding: 0131764
       Revision: 00H22000
       Coding: 0131764
       Coding: 0200021
       Coding: F30F185A
       Coding: 0131216
       Coding: 0131216
    End----------(Elapsed Time: 01:13, VBatt start/end: 12.9V/12.7V)-----------
  12. #9
    Aug 2016
    Eindhoven, NB, NL
    Can you clear the error and see if it returns?
  13. Likes PetrolDave, Uwe liked this post
  14. #10
    Aug 2019
    Reading, UK
    Tried clearing it, no luck. It doesn't seem to be having any affect on the car but there were definitely no faults before the install
