2017 Jetta GLI VCDS windows remote operation
rotorhead23
AB, Canada
C?ID=203428
Has anyone got the procedure for remote windows open and closing using VCDS for 2017 Jetta GLI?
Dana
Western PA, USA
I think you have a typo somewhere. The 2019 GLI (per your subject) is Golf 7 based but the 2017 GLI was Golf 6 based using an entirely different BCM. The Auto-Scan would shed light and we can fix the subject for you if 2019 was an error.
rotorhead23
AB, Canada
C?ID=203428
I didn't notice the mistake. I have a 2017 VW Jetta GLI, not a 2019. Sorry about that.
rotorhead23
AB, Canada
C?ID=203428
VCDS Release 20.4.1:  SRI Reset-SRI1.CLB
Control Module Part Number: 5C6 920 886 A       Labels:  .*5K0-920-xxx-17.clb-SRI1
Component:KOMBI         H02 1104, Coding:331E000000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Warning active                                              	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	13800 km                                                    	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	185 d                                                       	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	14600 km                                                    	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	15000 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	365 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	13900 km                                                    	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	185 d                                                       	---
Friday,24,July,2020,09:49:19:54235
VCDS Version: 20.4.1.0 (x64)
VIN: 3VW5T7AJ9HM215346   License Plate: CCH3412
Mileage: 120840km-75086mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 55
          5F 62 72
VIN: 3VW5T7AJ9HM215346   Mileage: 120840km-75086miles
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BL    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 4892
   Revision: --H13---
   Coding: 00190012242400171000
   Shop #: WSC 00066 790 00012
   ASAM Dataset: EV_ECM20TFS02006K906071BL 001009
   ROD: EV_ECM20TFS02006K906071BL.rod
   VCID: 76CD0D3BC914E63621-8022
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B600C492300FF850E06E8921F00412118F028
   VCID: 75CF0A37DC12ED2E28-8020
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0403167759
   Coding: 032C0C
   Shop #: WSC 00066 000 00295
   VCID: 3957C607B88A494E0C-806C
   Part No SW: 1K8 907 044 CN    HW: 1K8 907 044 CN
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 005000C002
   Shop #: WSC 00066 790 00318
   VCID: 7DDF1217EC22B56E60-8028
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0184
   Revision: BL122001
   Coding: EF200A1A802F3ED40088008124000D4C0074000645A08DB2E4842000A040
   VCID: 7DDF1217E422B56E60-8028
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 270616 04  42  0106
   Coding: 0228DD
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331615311520
   Coding: 0071155001
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   VCID: 364DCD3B8994A636E1-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM06Y4FF
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63EB446F6A86639E76-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000005CRAES
   Coding: 30314D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 305 16
   Serial number: 3570000000003609DA1E
   Subsystem 3 - Part No SW: -----------    HW: 480 001 305 16
   Serial number: 35800000000EC0952B1R
   Subsystem 4 - Part No SW: -----------    HW: 480 022 405 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B3210BB03426L
   Subsystem 5 - Part No SW: -----------    HW: 480 022 405 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B3210BB03471M
   Subsystem 6 - Part No SW: -----------    HW: 480 022 405 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001B520E18B59543
   Subsystem 7 - Part No SW: -----------    HW: 480 022 405 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B520E18B2E614
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160531100650
   Coding: 0002440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F23E81FE62EA77E72-802A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160000847760096166
   Coding: B0FFFF
   Part No SW: 5C6 920 886 A    HW: 5C6 920 886 A
   Component: KOMBI         H02 1104
   Coding: 331E000000
   Shop #: WSC 57566 003 1048576
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3041FB236BF08806BB-8064
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 21061603010150
   Coding: 351032
   VCID: 7BDB1C0FFA36BB5E5E-802E
   Component: IMMO          H02 1104
   Coding: 000007
   VCID: 6AF5294B8DAC32D6B5-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000092027009
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: 3147FE2760FA810EB4-8064
   Component: HRE_Master    H12 0071
   Serial number: 0405233403
   Coding: 02011102
   Shop #: WSC 01383 790 50316
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C59DF13B7B87C6617-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0404560205
   Coding: 020111
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010505456
   Coding: 0404BD
   Shop #: WSC 00066 790 00164
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 1D1F32970C62156E00-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14202745160627060702
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   VCID: 3957C607708A494E0C-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0094590
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 287113435320C0C663-807C
   Component: EZE_2         H56 1682
   Coding: 01030100
   VCID: 6FC3385FBE4ED7FEE2-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST000Z8GOB00000
   Coding: 180000
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010515126
   Coding: 0404BC
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 1E1D359B01640E7619-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14202744160629001012
   Component: AFS-ECU       H05 0111
   Coding: 081200010B000200
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 3753C03F8E9E5F3EFA-8062
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H30 0357
   Serial number: VWZAZ2S0222904
   Coding: 02630102AA00000011220003001828001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 246907732F0824A64F-8070
   Subsystem 1 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [008] - Missing message
                    Reset counter: 38
                    Mileage: 116015 km
                    Date: 2020.05.29
                    Time: 14:54:37
                    Voltage terminal 30: 12.9 V
                    System_Software_Error-SW_Status_Consistency: 02 01 00
                    System_Software_Error-SW_Status_Device: P
End-------------------------(Elapsed Time: 03:19)--------------------------
Friday,24,July,2020,09:59:03:54235
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Warning active                                              	0
Address 17,5C6 920 886 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,
csalvarr
Uruguay
C?ID=243709
Hi. Just go into Module 09 (CECM), Coding, Byte 03, set the right bits:
Then push ESC and change the coding.
You can choose to open / close the sunroof also with the remote using bits 0-1. Acording to my experience bit 2 does not work in the Jetta GLI, and you have to go to module 4F to choose tilting vs opening. Hope this helps.
rotorhead23
AB, Canada
C?ID=203428
Thanks a lot. I'll do that.
