2015 VW GOLF GTD. Upgraded to virtual dash however now have range error. Is someone able to advise which can gateway part no is needed for this car?
Friday,05,June,2020,14:09:59:18214
Dealer/Shop Name: hhhhhhhhhhhhh
Workshop Code: 000 00000 032212
VIN: WVWZZZAUZEW302219 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EP HW: 04L 907 309 A
Component: R4 2,0L EDC X22 7539
Revision: 81X22---
Coding: 01190012034505082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
ROD: EV_ECM20TDI01104L906021AE.rod
VCID: 77ABE8368F4936D3621-8022
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 603440000001D9
Coding: 01FA8AA13420096E0379060141CC2980512C90C0608294F5F4605078C009
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7BA3F406B36112B3069-802E
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0112010420211001100500000010102A
VCID: 6D87CA5EFD158C0388D-8038
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011403701502
Coding: 03000A46C24122FB0BA44080B10C07281000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140203 042 0551
Serial number: 140205074010
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M02D06H22M21S12S6
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140161556
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058683229
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331403704340
Coding: 0071151001
VCID: 3E253D12E0F3C79B617-806A
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 13041476510953
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
VCID: 36352532C8C30FDBB97-8062
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR03HZBA
VCID: 7F5B0016A7790E932A1-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B10021441158
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B11021440489
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 003 101 14
Serial number: 3576700000044C10DE0X
Subsystem 4 - Part No SW: ----------- HW: 480 002 908 14
Serial number: 3586700000096251E01O
Subsystem 5 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3516502C912AB1B2E23E
Subsystem 6 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3526502B313013F2C1A%
Subsystem 7 - Part No SW: ----------- HW: 480 400 804 14
Serial number: 3556502C31524DC4837E
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 07021404220123
Coding: 0C00
ROD: EV_SMLSKLOMQB_009_VW37.rod
Address 17: Instruments
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001606216
Coding: 030100040B087300EF00027E080F00010001000000000000000000000000
ROD: EV_GatewLear_010.rod
VCID: 3FDB4016E7F9CE936A1-806A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 29140002486260044466
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6632152503
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 27011401100173
Coding: 003F0220D001048000001000
VCID: 40D943EA9A07B16B13B-8014
Serial number: 00000000000001692337
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 3537223ED5C504C3B0D-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 04091401101824
Coding: 003F0020DE01048000801000
Serial number: 00000000000003770916
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029A01000B000000
VCID: 3D273A1EEDF5DC8378D-8068
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0757
Coding: 02731001FF00000051110101008808001F0102F601200000CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 313F162E21AD28E3EC5-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT3415614
Subsystem 2 - Part No SW: 5NA 919 866 AH HW: -----------
Component: ECE1 2020/21 --- 1410
B201A 00 [009] - -
Reset counter: 149
Mileage: 88900 km
Date: 2020.05.22
Time: 01:41:34
Voltage terminal 30: 12.0 V
Status_Software_Version_Management-module_name: C
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140129201271
VCID: 6B83C446C3018233969-803E
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.2V)-----------
