Results 1 to 8 of 8
Thread: First TIME user with Diagnostic Post
    Verified VCDS User missionanatis's Avatar
    Jun 2020
    Hello. First time Ross-tech user here looking for community support with help diagnosing Fault Codes and related remedies with my 2014 Audi Q7 TDI.
    I have really grown attached to the Audi and like almost everything about it with the exception of the necessary maintenance options associated with its performance. My local Audi shop is actually horrible and I have wasted too much time dealing with them. Sometime I think they border on incompetence. I recently discovered that I can get basic service from the VW dealership which I have a good relationship with from previous Toureg TDI ownership. But I digress.
    Currently, about 3 weeks or less ago the Check Engine light has come on. I did have a few roadside issues while hauling a trailer where the car would go into cripple mode and putter alone until I stopped and restarted. When that happened the glow-lug light would flash. That isnt happening currently and the check engine light was not on during those events.
    Anyway, attached is the first scan. I see lots of engine Faults but all are intermittent. My wonderment is why all the codes are "intermittent"... and if they will change state to something worse or decide to disappear, and which if any, are related. I have looked at the wiki wrt the low pressure one fault and pulling the fuel sensor thingy looks easy enough... and cleaning it I think is a good idea per the recommendations.
    Last time the car was at the Dealer I didnt hear anything about the codes from them so I wonder if they wait for a tow-in or just break the bad news at a certain mileage and then lay it on thick. How and why do all the faults happen at once and which ones wrt the engine fault are actually make the check-engine lite illuminate.
    Thanks very much in advance for your commentary, analysis and advice. I look forward to an education.
    Best regards.
    And there is the dump:
    Wednesday,03,June,2020,18:56:05:32711
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WA1LMAFE9FD0abcdef   License Plate:
    Mileage: 97970km-60875mi   Repair Order:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
              55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1LMAFE9FD0abcdef   Mileage: 97970km-60875miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
       Component: 3.0TDI FSA    H23 0012
       Revision: 54H23---    Serial number:
       Coding: 2A2A4012253600050000
       Shop #: WSC 30836 003 1048576
       ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
       ROD: EV_ECM30TDI0114L2910401A.rod
       VCID: 221DE85754480D6B65F-8076
    10 Faults Found:
    5211 - Fuel Rail/System Pressure
              P0087 00 [032] - Too Low
    4484 - Coolant Thermostat Valve (N214)
              P0128 00 [096] - Temperature below Control Range
    5104 - Oxygen (Lambda) Sensor B1 S1
              P2237 00 [232] - Pump Current Open Circuit
                        Fault Frequency: 84
                        Mileage: 90878 km
                        Date: 2020.02.15
                        Time: 20:46:00
                        Engine speed: 700.50 /min
                        Normed load value: 61.2 %
                        Coolant temperature: 89 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 14.220 V
                        Air mass: actual value (mg/stroke): 368.5 mg/stroke
                        Mean injection quantity: 13.47 mg/stroke
                        Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 1
                        O2 sensor 1: bank 1: voltage raw value O2 signal: 3.8 mV
                        O2 sensor 1 bank 1: voltage reading Ri-signal: filtered.: 1020.4 mV
                        O2 sensor 1 bank 1: duty cycle O2 heater: 39.99 %
                        LSU r O2 Adap 0: 0.00224
    38161 - Reductant Metering Module
              P20FE 00 [096] - Malfunction
                        Fault Frequency: 7
                        Mileage: 88735 km
                        Date: 2020.01.29
                        Time: 08:36:47
                        Engine speed: 1575.00 /min
                        Normed load value: 55.3 %
                        Vehicle speed: 95 km/h
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 14.080 V
                        Unlearning counter according OBD: 26
                        Outside air temperature: 31.0 °C
                        Pressure sensor for reducing agent: measured pressure: 5142 hPa
                        SCR catalytic converter average temperature: 302.6 °C
                        Sensor for reducing agent tank temperature: temperature: 28.0 °C
                        Reducing agent pump: activation: 50.00 %
                        SCRPOD p Cns De Mon Avrg: 772 hPa
    9952 - Catalyst System; Bank 1
              P0420 00 [096] - Efficiency Below Threshold
    31982 - EGR Valve (N18)
              P0403 00 [032] - Malfunction
                        Mileage: 97635 km
                        Date: 2020.05.31
                        Time: 17:56:31
                        Engine speed: 1275.00 /min
                        Vehicle speed: 43 km/h
                        Coolant temperature: 92 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 13.940 V
                        Unlearning counter according OBD: 38
                        EGR Vlv i Eff Flt: 29.64 A
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        EGR Solen.val.: actual value: 85.66 %
                        EGR valve: offset closed: -0.18 %
                        High press EGR actuator: actual unconditioned volt val: 1290.2 mV
                        EGR valve: offset open: 0.18 %
    31983 - EGR Valve (N18)
                        Mileage: 97635 km
                        Date: 2020.05.31
                        Time: 17:56:30
                        Engine speed: 1289.00 /min
                        Vehicle speed: 44 km/h
                        Voltage terminal 30: 13.880 V
                        EGR Vlv i Eff Flt: 29.66 A
                        EGR Vacuum Regulator Solen.val.: activation: 0.00 %
                        EGR Solen.val.: actual value: 25.40 %
                        High press EGR actuator: actual unconditioned volt val: 3347.8 mV
    26254 - Oxygen (Lambda) Sensor B1 S1
              P2196 00 [096] - Signal too High (Rich)
                        Mileage: 94198 km
                        Date: 2020.04.21
                        Time: 11:42:33
                        Engine speed: 1658.00 /min
                        Normed load value: 16.5 %
                        Vehicle speed: 100 km/h
                        Coolant temperature: 66 °C
                        Intake air temperature: 34 °C
                        Voltage terminal 30: 14.100 V
                        Engine status: COENG_RUNNING
    21227 - Fuel Trim; Bank 1
              P0172 00 [232] - System Too Rich
                        Mileage: 93668 km
                        Date: 2020.04.16
                        Time: 15:03:00
                        Engine speed: 1576.50 /min
                        Normed load value: 36.9 %
                        Vehicle speed: 96 km/h
                        Voltage terminal 30: 14.160 V
                        Air mass: actual value (mg/stroke): 276.6 mg/stroke
                        Standardised airflow ratio: 2.1451
                        Ambient temperature: 27.0 °C
                        Mean injection quantity: 5.88 mg/stroke
                        O2 sensor 1 bank 1: O2 sensor actual value: 1.001
                        Pressure control valve adaptation factor: 1.0784
    21232 - Fuel Trim; Bank 1
              P0171 00 [100] - System Too Lean
                        Mileage: 97000 km
                        Date: 2020.05.28
                        Time: 12:44:41
                        Engine speed: 1416.50 /min
                        Normed load value: 13.7 %
                        Vehicle speed: 58 km/h
                        Intake air temperature: 47 °C
                        Voltage terminal 30: 14.000 V
                        Unlearning counter according OBD: 57
                        Air mass: actual value (mg/stroke): 586.3 mg/stroke
                        Standardised airflow ratio: 1.0294
                        Ambient temperature: 32.3 °C
                        Mean injection quantity: 5.30 mg/stroke
                        O2 sensor 1 bank 1: O2 sensor actual value: 32.767
                        Pressure control valve adaptation factor: 1.0846
    Readiness: 1 2 0 0 0
       Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
       Component: AL1000 AISIN  002 3399
       Coding: 001378
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 7BA3F53393629CA3069-802E
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H02001
       Coding: 0099441
       Shop #: WSC 31414 790 00001
       VCID: 34311E0FF23C93DB873-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0210
       Revision: 00H08000    Serial number: 10603902203510
       Coding: 0000135
       VCID: 2517F34B49E6FA5300D-8070
       Subsystem 1 - Part No: 4F0 910 132 L
       Component: FBSAUDIC6 EZS   H05 0020
       Subsystem 2 - Part No: 4F0 910 335 B
       Component: FBSAUDIC6 KSG   H03 0020
    00193 - Rear Right Door Handle Touch Sensor (G418)
                007 - Short to Ground
                        Fault Status: 01110111
                        Fault Frequency: 17
                        Reset counter: 106
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Fault Status: 00111000
                        Fault Frequency: 19
                        Reset counter: 25
                        Mileage: 93618 km
                        Date: 2020.04.12
                        Time: 09:13:17
                        Fault Frequency: 11
                        Reset counter: 99
                        Mileage: 79345 km
                        Date: 2019.11.08
                        Time: 19:19:47
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 6
                        Reset counter: 241
                        Mileage: 96572 km
                        Date: 2020.05.25
                        Time: 20:33:41
                        Fault Status: 00111011
                        Reset counter: 254
                        Mileage: 95204 km
                        Date: 2020.05.04
                        Time: 12:12:01
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
       Component: KLIMA 4 ZONEN H15 0070
       Revision: 00---031    Serial number: 00000030383481
       Coding: 0302A036
       VCID: 2517F34B45E6FA5300D-8070
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0139123
       VCID: 6E85CC67DC90F90BB17-803A
       Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55931509701625
       Coding: 25011E
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 34311E0FFEBC93DB873-8060
       Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
       Component: 73 AIRBAG AUDI8RH45 0230
       Revision: 09H45000    Serial number: 0038QD90SWTJ
       Coding: 0014131
       VCID: 2B0305732F02CC23D69-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME5F53195AS
       Subsystem 3 - Serial number: 6342QSME62531C52C
       Subsystem 4 - Serial number: 6352QSME33584A4AO
       Subsystem 5 - Serial number: 6362QSME595302428
       Subsystem 6 - Serial number: 63734SME24534264V
       Subsystem 7 - Serial number: 63834SME27534558+
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026150720469
       Coding: 0012042
       VCID: 2809FA7F3EF4E73B3BB-807C
       Component: E0221           H03 0040
    Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
       Component: KOMBIINSTR.   H35 0332
       Revision: 00000000    Serial number: X2S51ML4G
       Coding: 8BD664040100CF05020205
       VCID: 42DD48D7B4882D6B05F-8016
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB800038    Serial number: 3800M154130690
       Coding: 00C303
       VCID: 3FDB4123C77A40836A1-806A
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0125
       Serial number: 32098D24034121722263
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
       Component: KLIMABETAETIGUNGH06 0060
       Revision: 00---012    Serial number: 00000000474070
       Coding: 0000006
       VCID: 6889BA7FFE74273BFBB-803C
    00003 - Control Module
                        Fault Status: 00100011
                        Mileage: 66846 km
                        Date: 2019.07.01
                        Time: 19:23:48
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0065
       Revision: AA000000    Serial number: 00000142886738
       Coding: 00581B00000011110000
       VCID: 323D181704289DEB95F-8066
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH03 0050
       Revision: 00H03000    Serial number: 6PZ 009 014-10
       Coding: 0010001
       VCID: 2E050C671C10B90BF17-807A
       Subsystem 1 - Part No: 4L0 910 568 C
       Component: J0770_SWA_Slave_H03 0050
       Subsystem 2 - Serial number: 6PZ 009 014-30
       Subsystem 3 - Serial number: 5F11.04.1500H03000AMS12763˙
       Subsystem 4 - Serial number: S12763˙
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000145801376
       Coding: 011F57205E40440004
       VCID: 48C95AFF92B4073BDBB-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 82010010610000
       Coding: 3569949
       VCID: 38292A3FEE5477BBABB-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000078620
       Coding: 030000
       VCID: 290FFF7B29FEDE33245-807C
    Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191097818
       Coding: 0758477
       VCID: 2313ED5347D204636E9-8076
       Part No SW: 4F0 910 280     HW: 4F0 907 280 D
       Component: ILM Beifahrer   H17 0100
       Revision:             Serial number: 00000000230187
       Coding: 0012001
       VCID: 5EE59CA72C30698B017-800A
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000145805680
       VCID: 47CB59C39FAA0843D21-8012
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 150420-0002-123
       Coding: 1147A71010020400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42DD48D7B4082D6B05F-8016
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156D-0F8253092
       Coding: 020007010000000000
       VCID: 2411EE4F4EDC035B173-8070
       Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
       Component: H-BNT-NA      H42 0901
       Revision: --------    Serial number: 513D$0F7517519
       Coding: 180200060004E3EF510023456F632003140000000100000000
       Subsystem 1 - Part No: 8R0 060 884 CJ
       Component: NAR 2015  1102
       Component: DU7 High  H42 0104
       Serial number: A130DU0F3327178
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002244663
       Component: CD-Database  5950
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000146204658
       Coding: 010E57204040230004
       VCID: 46D554C798A0114B297-8012
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Component: Anhaenger     H12 0100
       Revision: 2A001001    Serial number: 00000366444581
       Coding: 0200000000000000
       VCID: 313F171B012EA6F3EC5-8064
    02539 - Terminal 30 from Control Module
                        Fault Status: 00101110
                        Reset counter: 247
                        Mileage: 94652 km
                        Date: 2020.04.25
                        Time: 14:31:56
       Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
       Component: J772__Rearview      0030
       Revision: --H09---    Serial number: 525PA8-JA3423W
       Coding: 1021101
       Part No SW: 4L0 910 945     HW: 4L0 827 851 F
       Component: ValeoHeckdeckel H58 0500
       Revision: --H58001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81C66FEA8C0B1B9F3-8038
    ó[1]
       Subsystem 3 - Serial number: RD13.04.15--H58001002E0226˙
       Subsystem 4 - Serial number: 2E0226˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0145635128----
       Coding: 0003595
       VCID: 2615F44734E0F14B097-8072
       Component: J_245_EE16_SKB10H15 0220
       Subsystem 2 - Part No: 4L0 910 591 A
       Component: J_394_EE16_SKB10H15 0220
       Subsystem 3 - Part No: 4L0 910 591 A
       Component: J_392_EE16_SKB10H15 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000146204657
    End----------(Elapsed Time: 02:12, VBatt start/end: 13.1V/14.0V)-----------
                    Address 01: Engine       Labels: 059-907-401-V2.clb
    Control Module Part Number: 4L2 910 401 A    HW: 4L0 907 401 E
      Component and/or Version: 3.0TDI FSA    H23 0012
               Software Coding: 2A2A4012253600050000
                Work Shop Code: WSC 30836 003 1048576
                  ASAM Dataset: EV_ECM30TDI0114L2910401A 001013 (AU56)
    10 Faults Found:
              P2237 00 [175] - Pump Current Open Circuit
                        Fault Frequency: 85
                        Mileage: 90878 km
                        Date: 2020.02.15
                        Time: 20:46:00
                        Fault Frequency: 7
                        Mileage: 88735 km
                        Date: 2020.01.29
                        Time: 08:36:47
                        Mileage: 97635 km
                        Date: 2020.05.31
                        Time: 17:56:31
                        Mileage: 97635 km
                        Date: 2020.05.31f
                        Time: 17:56:30
                        Mileage: 94198 km
                        Date: 2020.04.21
                        Time: 11:42:33
                        Mileage: 93668 km
                        Date: 2020.04.16
                        Time: 15:03:00
                        Mileage: 97000 km
                        Date: 2020.05.28
                        Time: 12:44:41
    Readiness Status: 10000010 00001111 11101011 00000000
    MIL Status: MIL ON
    Comprehensive Components: Passed
    Fuel System: Passed
    Exhaust Gas Recirculation: Passed
    Number of EOBD-related DTC(s): 2
                    Address 01: Engine
    Advanced Identification/FAZIT
         Identification: RB8-658
         Revision: 54H23---
         Date: 01.04.15
         Manufacturer number: 1409
         Test stand number: 0341
    Flash Status
         Programming Attempts(application): 0/1/1/1/1
         Successful Attempts(application): 0/1/1/1/1
         Flash Date: 00.00.00
    Misc.
         Hardware number: 4L0 907 401 E
         Workshop System Name: J623
         ASAM Dataset Revision: 001013
    Car Info
         Chassis Number: WA1LMAFE9FD0abcdef
         Engine code: CNRB
    VCDS Info:
           Readiness: No script available
                    Address 01: Engine
         Revision: 54H23---
         Date: 01.04.15
    Flash Status
    Misc.
    Car Info
         Engine code: CNRB
    VCDS Info:
    2015 Audi Q7 quattro 4dr 3.0L TDI Premium Plus 2nd Owner off Lease
    Sep 2016
    Riga, Latvia
    A lot of engine dtc's... I'd suggest to clear them all and start with ones that come back first
  3. Likes Uwe, PetrolDave liked this post
    Jun 2020
    New scan after reset and few miles driven.
    Todays scan after a DTC clear and 15 minute drive down the highway.
    The dreaded P2237 00 [237] - Pump Current Open Circuit
    Saturday,06,June,2020,09:02:00:32711
    VIN: WA1LMAFE9FD0xyzxyz   License Plate:
    Mileage: 98020km-60906mi   Repair Order:
    VIN: WA1LMAFE9FD0xyzxyz   Mileage: 98020km-60906miles
                        Mileage: 98009 km
                        Date: 2020.06.05
                        Time: 15:38:31
                        Engine speed: 700.00 /min
                        Normed load value: 52.5 %
                        Intake air temperature: 46 °C
                        Air mass: actual value (mg/stroke): 323.0 mg/stroke
                        Mean injection quantity: 11.43 mg/stroke
                        Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 0
                        O2 sensor 1: bank 1: voltage raw value O2 signal: -6.8 mV
                        O2 sensor 1 bank 1: voltage reading Ri-signal: filtered.: 1022.4 mV
                        O2 sensor 1 bank 1: duty cycle O2 heater: 39.21 %
                        LSU r O2 Adap 0: 0.00031
    Readiness: 1 1 0 1 1
       Coding: 001378
       Revision: 00H02001
       Coding: 0099441
       Coding: 0000135
                        Fault Frequency: 17
                        Reset counter: 106
                        Fault Frequency: 19
                        Reset counter: 25
                        Mileage: 93618 km
                        Date: 2020.04.12
                        Time: 09:13:17
                        Fault Frequency: 11
                        Reset counter: 99
                        Mileage: 79345 km
                        Date: 2019.11.08
                        Time: 19:19:47
    00955 - Key 1
                        Fault Frequency: 8
                        Reset counter: 242
                        Mileage: 96572 km
                        Date: 2020.05.25
                        Time: 20:33:41
                        Reset counter: 254
                        Mileage: 95204 km
                        Date: 2020.05.04
                        Time: 12:12:01
       Coding: 0302A036
       Coding: 0139123
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Coding: 25011E
       Coding: 0014131
       Coding: 0012042
       Coding: 00C303
       Coding: 0000006
                        Mileage: 66846 km
                        Date: 2019.07.01
                        Time: 19:23:48
       Coding: 0010001
       Coding: 3569949
       Coding: 030000
       Coding: 0758477
       Coding: 0012001
                        Reset counter: 247
                        Mileage: 94652 km
                        Date: 2020.04.25
                        Time: 14:31:56
       Coding: 1021101
       Subsystem 2 - Serial number: ( ó
       Coding: 0003595
    Near Philadelphia, PA, USA
    Thorough check of the wires before you commit to a bad sensor. The wires near the sensor get brittle and break. May not be a bad sensor.
    Channeling Jack here:
    Isn't pretty much anything emissions-related still under warranty due to Dieselgate on this vehicle?
    Fault codes flagged "Intermittent / Not Confirmed" are generally the least of your worries.
    Fault code flagged "MIL ON" are the ones that you need to deal with first.
    If you want to attack this yourself, I'm with Bruce: Inspect/verify the wiring to that sensor carefully.
  7. Likes PetrolDave, MartinsX liked this post
    Jun 2020
    I do want to do it my self for sure.
    I did receive something in the mail this year wrt the EGR or the regenerative part of the EGR, extending the warranty I believe. Last time at the dealership it was slow slow slow and had to take the car back even though we scheduled a visit but 48 hours later the work wasnt done. Ended up taking it to my favorite VW dealer in Georgetown, TX and they did a routine maintenance in minutes...but wont do other AUDI work because they said they dont have the parts. Im not happy with my local Audi service center.
    Will check the wires first on the passenger B1S1 then..
    THANKS
    Jun 2020
    Any pointers for where that wiring harness is and how to inspect it. Ive got the hood open, engine cover off. I see the O2 sensors on the EGR mechanism (looks like 2 there).
    Is there a picture of exactly where the item is? To " Inspect/verify the wiring to that sensor carefully?"
  10. #8
    Jun 2020
    Here is a link to picture of the Exhaust sensors on the 3.0 L Q7. Although MINE is slightly different, maybe it is because of the updates applied to the engine because of diesel-gate... My car has been retrofitted, whatever that means is unknown.
    https://audi.7zap.com/en/rdw/audi+q7.../253-253050/#1
    In the diagram, the #6 part is the lambda sensor. My car has two sensors on the input to the catalyst, both similar but different, but definitely O2 type sensors.
    The connector to the first sensor sits on the firewall and is very accessible and the wires look fine. Im not sure how they could be any better thatn what they are. There is no sign of damage or stretching... and the length of the harness is at most 24". The lower one, inches away, goes to the driverside area to another plug... and looks unscathed.
