Just got this sick A4 in and looking for help
Thursday,04,June,2020,15:11:44:62413
VCDS Version: 20.4.0.1 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: CC Cars & Light Commercials
VIN: WAUZZZ8E45A441291 License Plate: YK05NFZ
Mileage: 271480km-168689mi Repair Order: T CAROL
67 69 75 76 77
VIN: WAUZZZ8E45A441291 Mileage: 271480km-168689miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 8E0 910 401 F HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011171
Shop #: WSC 06335 000 00000
VCID: 221DECF1D8C0CDCB656-8076
6 Faults Found:
005686 - Powertrain Data Bus
P1636 - 001 - Missing Message from Airbag Controller
Fault Status: 01100001
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: -191.1 Nm
012696 - Control Circuit for Intake Manifold Runner (Bank1)
P3198 - 002 - Implausible Signal
Fault Status: 01100010
Torque: 167.7 Nm
Voltage: 11.55 V
Duty Cycle: 0.4 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 008 - Electrical Malfunction
Torque: 167.7 Nm
Temperature: 30.6°C
Duty Cycle: 80.9 %
Voltage: 11.55 V
Duty Cycle: 13.4 %
005489 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
Torque: 167.7 Nm
Voltage: 11.55 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Fault Status: 00100001
Torque: 167.7 Nm
Voltage: 10.87 V
Duty Cycle: 0.4 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
001378 - System Voltage
P0562 - 001 - Too Low - Intermittent
Fault Status: 00110001
Torque: 187.2 Nm
Duty Cycle: 1.0 %
Voltage: 8.82 V
Bin. Bits: 00101100
Temperature: 25.2°C
Readiness: 1 2 0 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 0081671
VCID: 6491AAE9825483FBD7A-8030
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Coding: 0004426
VCID: 270BFDE5B3E228E3328-8072
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x0720
Hex Value: 0x00FF
Hex Value: 0xFF82
Hex Value: 0x00FF
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x0220
Hex Value: 0x00FF
Hex Value: 0xFF83
Hex Value: 0x00FF
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 06335
VCID: 6B83C1D56A9ACC83960-5184
01273 - Fresh Air Blower (V2)
53-10 - Supply Voltage Too Low - Intermittent
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0303
Coding: 01001
Shop #: WSC 06335
VCID: 392F2B9D5046AE1354C-4B00
30-00 - Open or Short to Plus
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02141
Shop #: WSC 06335
VCID: 41DF437D3896F6D31CC-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 K HW: 8E0 920 981 K
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0005441
Shop #: WSC 00468 067 57207
VCID: 353727AD795E4A73B04-5160
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0005441
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
VCID: 353727AD7C6E4A73B04-4B00
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6B83C1D56A9ACC83960-50F4
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 07931
Shop #: WSC 06335
VCID: 7DA7FF8D04EE5233384-4B00
Subsystem 1 - Part No: 8E2959802
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
6 Faults Found:
01366 - Opened Due to Crash Signal
36-00 - Open Circuit
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0460
Coding: 01001
Shop #: WSC 66304
VCID: 313F13BD88066653ECC-5066
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
Component: Parkhilfe 4-Kan H06 0020
Revision: 00H06000 Serial number: 00067802030434
Coding: 0001004
VCID: 2F3B15C59B3270A3FA8-5184
6 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 80
Date: 2000.01.01
Time: 00:00:00
01543 - Parking Aid Warning Chime (H15)
Reset counter: 79
Date: 2000.01.01
Time: 00:00:00
Reset counter: 124
Date: 2000.01.01
Time: 00:00:00
Reset counter: 124
Date: 2000.01.01
Time: 00:00:00
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Reset counter: 81
Date: 2000.01.01
Time: 00:00:00
01549 - Supply Voltage for Parking-Aid Sensor
Reset counter: 124
Date: 2000.01.01
Time: 00:00:00
End----------(Elapsed Time: 05:27, VBatt start/end: 12.0V/12.3V)-----------
