I swapped my halogens to some LEDs and fitted the load resistors but still get a bulb warning.
I din think my BCM allows me to cancel the bulb warning, but hoping somebody can prove me wrong.
Does anybody know of what resistor is needed for this and I can build my own for it.
Here is an auto dump in case its needed
Sunday,31,May,2020,18:51:33:43836
VIN: WAUZZZ8H88K013250 License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUZZZ8H88K013250 Mileage: 140950km-87582miles
Address 01: Engine Labels: 03G-906-016-BPW.clb
Part No SW: 03G 906 016 LQ HW: 03G 906 016 KP
Component: R4 2,0L EDC 000CG 1717
Revision: --H06--- Serial number:
Coding: 0000076
Shop #: WSC 66565 257 00032
VCID: 7DA7FCDBC1FBDD2338D-8028
Readiness: 0 0 1 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E5 910 155 J HW: 01J 927 156 HT
Component: V30 01J 2.0l PD RdW 0040
Revision: 00000012 Serial number: 00000002103869
Shop #: WSC 04940 001 00001
VCID: 313F10EB4D23E943EC5-8064
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Coding: 0004402
Shop #: WSC 63252 001 1048576
VCID: 2C01019F6A0184ABDF3-8078
Fault Status: 00101101
Reset counter: 38
Hex Value: 0x0200
Hex Value: 0x4A02
Hex Value: 0x0027
Hex Value: 0x01AB
Hex Value: 0x0000
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00100
Shop #: WSC 00672
VCID: 6C81C19FAF9144AB9F3-50F4
00710 - Defroster Flap Positioning Motor (V107)
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
30-00 - Open or Short to Plus
09-00 - Adaptation Limit Surpassed
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 20001
Shop #: WSC 00672
VCID: 3D273CDB846B1D2378D-4AA4
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 G HW: 8H0 959 655 G
Component: Airbag 9.42 H01 1840
Revision: 92H01184 Serial number: 003CZ0008MD7
Coding: 0071114
VCID: 3E253BD78C7D063B617-806A
Subsystem 1 - Serial number: 6332BRB403876EFB2
Subsystem 2 - Serial number: 6342BRB4038D8403L
Subsystem 3 - Serial number: 63729RB4037B0B95T
Subsystem 4 - Serial number: 63829RB4037B015EP
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 03111
Shop #: WSC 00672
VCID: 41DF402BF89379C31C5-4AA4
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 951 D HW: 8H0 920 951 D
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0006411
Shop #: WSC 56029 002 1048576
VCID: 2E050B975C0DF6BBF17-50F4
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006411
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 7094
Shop #: WSC 00672 785 00200
VCID: 343119FFB221DC6B873-50F4
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
VCID: 6FBBD6939E87BFB3BA1-50AE
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 M
Component: Komfortgerát T3B 5442
Coding: 06911
Shop #: WSC 00672
VCID: 3E253BD7896D063B617-4AA4
Subsystem 1 - Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H2959801D
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0003
01616 - Signal Wire to Interior Monitor
79-10 - Please Check Fault Codes - Intermittent
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 186 AL HW: 8E0 035 186 AL
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8971904
Coding: 0610331
VCID: 71BFD0EB8D83A943AC5-5160
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005556949
Coding: 0001602
VCID: 44D1493FE2816CEB373-50D0
