DPF Problem Golf7 1.6TDI
GolfswagenVolk
Belgium
C?ID=401717
Basically the Check engine light came on, together with the glow plug light flashing and the DPF warning came up too.
I checked out the autoscan with the following results:
Wednesday,03,June,2020,18:04:01:36701
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZEP040490   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP040490   Mileage: 207030km-128642miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012034405092000
   Shop #: WSC 00028 028 00080
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F3B16AD4795B9A3FA1-807A
5188 - Diesel Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 206974 km
                    Date: 2020.05.28
                    Time: 21:50:25
                    Engine speed: 1928.00 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 76 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 72 °C
                    Voltage terminal 30: 13.760 V
                    Zähler der Regenerationszeit des Partikelfilters: 0.00 s
                    Particle filter: kilometers since last regeneration: 927714 m
                    Particle filter: soot mass measured: 2.61 g
                    Particle filter: soot mass calculated: 40.01 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 7 hPa
4913 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [175] - Electrical Malfunction
                    Mileage: 206376 km
                    Date: 2020.05.25
                    Time: 04:30:18
                    Coolant temperature: 88 °C
                    Intake air temperature: 69 °C
                    Voltage terminal 30: 12.460 V
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 20.0 °C
                    Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: -0.0 °C
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 146.8 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 1000.0 °C
                    Shut-off timer: last engine shut-off time: 386 s
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
                    Mileage: 206376 km
                    Date: 2020.05.25
                    Time: 04:30:18
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 144.6 °C
Readiness: 1 2 0 0 1
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 6264300000027C
   Coding: 01FA62A12424096C037B060941C32580462490C06082A4F3F440F074C002
   Shop #: WSC 00028 028 00023
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 7BA3F2FDC36D9503069-802E
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 23
                    Mileage: 206781 km
                    Date: 2020.05.27
                    Time: 21:46:11
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00020114202100011005000000101000
   VCID: 38292DF1B2DB7E1BABB-806C
   Air quality sensor:
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011325701415
   Coding: 00100842C20100D34BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C95D31C23B0E9BDBB-801C
   Component: WWS    130901  042 0551
   Serial number:         130913095906
   Sun Roof:
   Subsystem 2 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO2412619%
   Coding: 181801
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20494266
12554 - Bulb for Left Back-up Light
          B12CB 15 [009] - Open or Short to Plus
                    Reset counter: 241
                    Mileage: 206376 km
                    Date: 2020.05.25
                    Time: 19:47:06
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [008] - Electrical Failure
                    Reset counter: 25
                    Time: 00:00:00
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231326604167
   Coding: 0071051001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B2332FD83ED5503469-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 10091376510383
   Coding: 00000100FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 353724C5A5C98373B0D-8060
   Component: AirbagVW20    014 0385
   Serial number: 003F6R00XJGX
   Shop #: WSC 00028 028 00054
   VCID: 41DF4015E1013FD31C5-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 709 13
   Serial number: 35767000000DF5F49D0G
   Subsystem 2 - Part No SW: -----------    HW: 480 000 709 13
   Serial number: 35867000000D96F49D0C
   Subsystem 3 - Part No SW: -----------    HW: 480 401 909 13
   Serial number: 3516502BB11D152470D5
   Subsystem 4 - Part No SW: -----------    HW: 480 401 909 13
   Serial number: 3526502BB11FBEB5A15X
   Subsystem 5 - Part No SW: -----------    HW: 480 401 109 13
   Serial number: 3556502B11118A50712V
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 24091304220794
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
   Component: KOMBI         252 2210
   Coding: 07A51A002780000800886801040000
   VCID: 270BFE8D6F65E1E3321-8072
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 19091310801257
   Coding: 030100040B087300EF000658080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   Component: E221__MFL-DC1  H14 0035
   Serial number: 23130000567390050291
   Coding: 2CFFFF
   Serial number: 1819011403
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Serial number: 0000075230110
   Coding: 003003208000020100001000
   VCID: 55F784450589A37350D-8000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Serial number: 0000076220460
   Coding: 003001208E00020100801000
   VCID: 015F8015A181FFD35C5-8054
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     040 0421
   Serial number: V1F02409130828
   Coding: 02730001FF00000011110001000800001F0100840100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ900ZHC
   Subsystem 2 - Part No SW: 5G0 919 866 E    HW: -----------
   Component:  ECE 2013/14  --- 0034
End----------(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.1V)-----------
I tried to do a standing regeneration but that failed.
When driving at 2500rpm the soot (calculated and measured) both went up and up.
I notice a problem with the temp sensor after the DPF. It's reading 1000°C??? And it's throwing a code. Could this mean the sensor failed and eventually clogged up the DPF? Or could it be that the DPF got clogged up and made the sensor fail?
Maybe because of the sensor it doesn't want to regenerate anymore?
Thanks in advance
It likely won't regen with the EGT sensor faults present. Fix the electrical malfunction with the EGT sensor.
GolfswagenVolk
Belgium
C?ID=401717
if the sensor is replaced and there are no more faults except for the DPF, what is the maximum untill you are not able to regenerate again? i read on the ross-tech wiki for the 1.6tdi can version it's this:
With the newer CR-TDI engines there are 2 different types of regenerations available depending on the actual soot mass/load. If either the calculated or measured soot mass is above 30g but below 40g you can initiate a regeneration while standing (Idle will be raised etc.), a forced regeneration while driving is also possible. Once the values are above 40g (but below the max 45g) the regeneration while standing is no longer available and the regeneration while driving is the only way.
but for the UDS version there is no such information
Jacek
C?ID=360566
IDE01408,Granica zapełnienia dla regeneracji podczas użytkowania,23.97, g
IDE01409,Granica zapełnienia dla regeneracji serwisowej,40.00, g
IDE01410,Granica zapełnienia - nadmierne zapełnienie,50.00, g
IDE06060,Granica zapełnienia: masa popiołu: filtr cząstek stałych,80.00, g
IDE01408, Fill limit for regeneration during use, 23.97, g
IDE01409, Filling limit for service regeneration, 40.00, g
IDE01410, Fill limit - overfill, 50.00, g
IDE06060, Filling limit: ash mass: particulate filter, 80.00, g
GolfswagenVolk
Belgium
C?ID=401717
So in theory i should be able to do an idle regeneration?
Dana
Western PA, USA
That depends on the stored values in your Advanced Measuring Values but the IDE list Jacek should be extremely helpful. Posting a Measuring Value function control module map from this 01-Engine controller would be helpful.
You can open the resulting CSV file in Notepad and wrap in it [CODE] ... [/CODE] tags just like the Auto-Scan.
GolfswagenVolk
Belgium
C?ID=401717
Don't have the car with me right now.
As i'm new to the DPF world, what do the last 2 IDE's mean?
