Results 1 to 7 of 7
Thread: DPF Problem Golf7 1.6TDI
    Apr 2020
    Belgium
    Basically the Check engine light came on, together with the glow plug light flashing and the DPF warning came up too.
    I checked out the autoscan with the following results:
    Wednesday,03,June,2020,18:04:01:36701
    VIN: WVWZZZAUZEP040490   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEP040490   Mileage: 207030km-128642miles
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 5517
       Revision: 84H22---
       Coding: 01110012034405092000
       Shop #: WSC 00028 028 00080
       ASAM Dataset: EV_ECM16TDI01104L906021M 002009
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F3B16AD4795B9A3FA1-807A
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 206974 km
                        Date: 2020.05.28
                        Time: 21:50:25
                        Engine speed: 1928.00 /min
                        Normed load value: 36.1 %
                        Vehicle speed: 76 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 72 °C
                        Voltage terminal 30: 13.760 V
                        Zähler der Regenerationszeit des Partikelfilters: 0.00 s
                        Particle filter: kilometers since last regeneration: 927714 m
                        Particle filter: soot mass measured: 2.61 g
                        Particle filter: soot mass calculated: 40.01 g
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 7 hPa
    4913 - Exhaust Gas Temperature Sensor 4 Bank 1
              P246E 00 [175] - Electrical Malfunction
                        Mileage: 206376 km
                        Date: 2020.05.25
                        Time: 04:30:18
                        Coolant temperature: 88 °C
                        Intake air temperature: 69 °C
                        Voltage terminal 30: 12.460 V
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 20.0 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: -0.0 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 146.8 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 1000.0 °C
                        Shut-off timer: last engine shut-off time: 386 s
    5258 - Exhaust Gas Temperature Sensor 4 Bank 1
                        Mileage: 206376 km
                        Date: 2020.05.25
                        Time: 04:30:18
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 144.6 °C
    Readiness: 1 2 0 0 1
       Revision: 00000000    Serial number: 6264300000027C
       Coding: 01FA62A12424096C037B060941C32580462490C06082A4F3F440F074C002
       Shop #: WSC 00028 028 00023
       ROD: EV_Brake1UDSContiMK100IPB_033.rod
       VCID: 7BA3F2FDC36D9503069-802E
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 23
                        Mileage: 206781 km
                        Date: 2020.05.27
                        Time: 21:46:11
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00020114202100011005000000101000
       VCID: 38292DF1B2DB7E1BABB-806C
       Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
       Component: BCM MQBAB M   H14 0112
       Serial number: 00011325701415
       Coding: 00100842C20100D34BE44000000403081000000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 48C95D31C23B0E9BDBB-801C
       Component: WWS    130901  042 0551
       Serial number:         130913095906
       Sun Roof:
       Subsystem 2 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.013  H02 0007
       Serial number:     WOO2412619%
       Coding: 181801
       Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20494266
    12554 - Bulb for Left Back-up Light
              B12CB 15 [009] - Open or Short to Plus
                        Reset counter: 241
                        Mileage: 206376 km
                        Date: 2020.05.25
                        Time: 19:47:06
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [008] - Electrical Failure
                        Reset counter: 25
                        Time: 00:00:00
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231326604167
       Coding: 0071051001
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: 3B2332FD83ED5503469-806E
       Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H04 0150
       Serial number: 10091376510383
       Coding: 00000100FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001013
       VCID: 353724C5A5C98373B0D-8060
       Component: AirbagVW20    014 0385
       Serial number: 003F6R00XJGX
       Shop #: WSC 00028 028 00054
       VCID: 41DF4015E1013FD31C5-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 709 13
       Serial number: 35767000000DF5F49D0G
       Subsystem 2 - Part No SW: -----------    HW: 480 000 709 13
       Serial number: 35867000000D96F49D0C
       Subsystem 3 - Part No SW: -----------    HW: 480 401 909 13
       Serial number: 3516502BB11D152470D5
       Subsystem 4 - Part No SW: -----------    HW: 480 401 909 13
       Serial number: 3526502BB11FBEB5A15X
       Subsystem 5 - Part No SW: -----------    HW: 480 401 109 13
       Serial number: 3556502B11118A50712V
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 24091304220794
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
       Component: KOMBI         252 2210
       Coding: 07A51A002780000800886801040000
       VCID: 270BFE8D6F65E1E3321-8072
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2147
       Revision: --------    Serial number: 19091310801257
       Coding: 030100040B087300EF000658080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewConti 009011
       ROD: EV_GatewConti_009.rod
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000567390050291
       Coding: 2CFFFF
       Serial number: 1819011403
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000075230110
       Coding: 003003208000020100001000
       VCID: 55F784450589A37350D-8000
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 0103
       ROD: EV_SteerAssisMQB_010.rod
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000076220460
       Coding: 003001208E00020100801000
       VCID: 015F8015A181FFD35C5-8054
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
       Component: MU-S-N-ER     040 0421
       Serial number: V1F02409130828
       Coding: 02730001FF00000011110001000800001F0100840100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ900ZHC
       Subsystem 2 - Part No SW: 5G0 919 866 E    HW: -----------
       Component:  ECE 2013/14  --- 0034
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.1V)-----------
    I tried to do a standing regeneration but that failed.
    When driving at 2500rpm the soot (calculated and measured) both went up and up.
    I notice a problem with the temp sensor after the DPF. It's reading 1000°C??? And it's throwing a code. Could this mean the sensor failed and eventually clogged up the DPF? Or could it be that the DPF got clogged up and made the sensor fail?
    Maybe because of the sensor it doesn't want to regenerate anymore?
    Thanks in advance
    It likely won't regen with the EGT sensor faults present. Fix the electrical malfunction with the EGT sensor.
  3. Likes Dana liked this post
    Apr 2020
    Belgium
    if the sensor is replaced and there are no more faults except for the DPF, what is the maximum untill you are not able to regenerate again? i read on the ross-tech wiki for the 1.6tdi can version it's this:
    With the newer CR-TDI engines there are 2 different types of regenerations available depending on the actual soot mass/load. If either the calculated or measured soot mass is above 30g but below 40g you can initiate a regeneration while standing (Idle will be raised etc.), a forced regeneration while driving is also possible. Once the values are above 40g (but below the max 45g) the regeneration while standing is no longer available and the regeneration while driving is the only way.
    but for the UDS version there is no such information
    Mar 2019
    Poland
    IDE01408,Granica zapełnienia dla regeneracji podczas użytkowania,23.97, g
    IDE01409,Granica zapełnienia dla regeneracji serwisowej,40.00, g
    IDE01410,Granica zapełnienia - nadmierne zapełnienie,50.00, g
    IDE06060,Granica zapełnienia: masa popiołu: filtr cząstek stałych,80.00, g
    IDE01408, Fill limit for regeneration during use, 23.97, g
    IDE01409, Filling limit for service regeneration, 40.00, g
    IDE01410, Fill limit - overfill, 50.00, g
    IDE06060, Filling limit: ash mass: particulate filter, 80.00, g
  6. Likes Uwe, Dana liked this post
    Apr 2020
    Belgium
    Quote Originally Posted by Jacek View Post
    So in theory i should be able to do an idle regeneration?
    United States
    Quote Originally Posted by GolfswagenVolk View Post
    That depends on the stored values in your Advanced Measuring Values but the IDE list Jacek should be extremely helpful. Posting a Measuring Value function control module map from this 01-Engine controller would be helpful.
    You can open the resulting CSV file in Notepad and wrap in it [CODE] ... [/CODE] tags just like the Auto-Scan.
  9. Likes Uwe liked this post
  10. #7
    Apr 2020
    Belgium
    Don't have the car with me right now.
    As i'm new to the DPF world, what do the last 2 IDE's mean?
