Wednesday,03,June,2020,14:28:29:04136
VIN: TRUZZZ8P1B1004211 License Plate:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 61 62 72 77
VIN: TRUZZZ8P1B1004211 Mileage: 161280km-100214miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 9973
Revision: --H23--- Serial number: AUX7Z0J8FN70SN
Coding: 00114034030501080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023M 003014
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 303911D20AA2510BE3B-8064
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13422012092200FEC80D04E5901A0091380800
Shop #: WSC 01236 758 00200
VCID: 76B5E7CAA8C63F3B797-8022
Part No SW: 8P0 820 047 E HW: 8P0 820 047 E
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
VCID: 323D1BDA082E631B95F-8066
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 F HW: 8P0 907 063 F
Component: BCM PQ35 B 107 0615
Revision: 00107 AF
Coding: 46000A3FAA13F140207060E00500004C53325CAA0000C522E4008F000055
VCID: 372B2ACEEF4C8633A21-8062
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0050
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93631028726473
Coding: 000001
VCID: 42DD4B1AB48ED39B05F-8016
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS0015N0S
Coding: 0021330
VCID: 0655970AD4262FBB697-8052
Subsystem 1 - Serial number: 6332DRB40CEB8CB3B
Subsystem 2 - Serial number: 6342DRB40CED95262
Subsystem 3 - Serial number: 63747RB405E00EE6-
Subsystem 4 - Serial number: 63847RB405E012FAV
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003011
VCID: 46D5570A94A6EFBB297-8012
Component: E0221 H04 0100
Part No SW: 8P0 920 982 H HW: 8P0 920 982 H
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2248J003006189
Coding: 0260418
VCID: 3E253FEACC76B77B617-806A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 5304
Revision: H33 Serial number: 071010F1001261
Coding: E9A07F2600060204009101
VCID: 313F14D60D285803EC5-8064
Revision: D0H01003 Serial number: AUX7Z0J8FN70SN
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 B
Component: VSG AUDI A3 H14 0130
VCID: 44D14D02A29ADDAB373-8010
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 G HW: 8P7 959 801 G
Component: Tuer-SG H04 0103
Coding: 0131764
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 233 3001
Revision: 00H17000
Part No SW: 8P7 959 802 F HW: 8P7 959 802 F
Coding: 0019092
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 F HW: 8P0 035 152 F
Component: R Chorus2+ H02 0293
Revision: 00H02000 Serial number: AUZ1Z2K1413171
Coding: 0620221
VCID: 2E050FAA1C1647FBF17-807A
00532 - Supply Voltage B+
Fault Status: 00100001
Reset counter: 175
Mileage: 160923 km
Date: 2020.05.30
Time: 13:08:21
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 5304
Coding: 030B085A
VCID: 74B1DDC2BEBA2D2B473-8020
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650408099
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0054
Coding: 0131216
VCID: 42DD4B1AB88ED39B05F-8016
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0131216
Shop #: WSC 01236 785 1012552
VCID: 43D34E1EA794DA930E9-8016
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005237980
Coding: 0001202
VCID: 74B1DDC2B2BA2D2B473-8020
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)-----------
Hi i have the Audi A3 cabriolet and noticed at weekend that when i use the remote unlock function to open all the windows it works and all 4 windows go down fully,however when i do the same to lock all the windows only 3 go up and the passenger window stays down..Window works from drivers side and passenger side if i do it manualy with ignition on..It's no big deal but just thought if i have the cable and software it may be just a coding issue ..also if i remember correct the car had a issue with a window as i had to wait for that job to be done before they delivered the car ,not sure which one but it could be connectede to issue if they did not code,any help would be appreciated but as sasaid it's no big deal but would be nice to get it working ..Thanks..
